path: root/recipes-bsp/alsa-state/alsa-state/verdin-imx8mm/asound-dahlia.state
2024-04-24alsa-state: Remove specific configuration files for verdin-imx8m[mp]Hiago De Franco
To enhance compatibility with a read-only rootfs system, remove the dynamically assigned and utilize alsa-ucm-conf configuration from meta-toradex-bsp-common pulled-in via the meta-toradex-demos layer instead. Related-to: ELB-4916 Signed-off-by: Hiago De Franco <hiago.franco@toradex.com> (cherry picked from commit 54721dc86ece6b41d88f5e9de4262b575efc5393)
2022-05-16alsa-state: set up asound configs dynamically for verdin-imx8 boardsMing Liu
We need set up asound.conf and asound.state dynamitically at runtime since the Verdin Development/Dahlia boards are using different ones. To achieve that, we now introduce a on-target package postinst script to set up them at runtime by checking /proc/device-tree/model to determine which config files should be used. Related-to: ELB-4349 Signed-off-by: Ming Liu <ming.liu@toradex.com> (cherry picked from commit 9e5c0e3043a7c49fb71276a0f6604047129eafdc)
