They are unmaintained for a while now. Likely built images will not run
if they even build. Drop them for BSP 7.
Remove them to not create unmet expectation.
Related-to: ELB-5740
This is the result of automated script (0.9.3) conversion:
../openembedded-core/scripts/contrib/convert-overrides.py .
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
converting the metadata to use ":" as the override character instead of "_".
So far the graphical backend (X11 / Wayland) did not show in the created
image names or the Toradex Easy Installer meta data at all.
As we now build by default only Wayland, leave those alone. If one builds
for X11 then add this to the file name and the descriptive meta data.
meta-freescale handles use-mainline-bsp in the common imx-base.inc
file. Follow that change.
While at it, simplify the upstream-rt distros by including the
corresponding upstream distro.
'DISTRO' is in DISTROOVERRIDES by default, we should not use "=" to
override that when adding 'tdx' to DISTROOVERRIDES, use ".=" to append
to it.
With the above change, we do not need to append 'tdx-x11' and
'tdx-xwayland' to DISTROOVERRIDES, drop them.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit 9a93acdeda3fed168b74c33788f385ac42702ed4)
(cherry picked from commit 74a602aa995bf0331e6aa0619874487dd14ba49c)
Most of the desktop like images require polkit.
E.g. liblxqt depends on it.
This is used in generating the image name, so that one sees in the
Toradex Easy Installer which is which.
This defines preempt-rt in distro overrides. The individual machine
configuration then needs to choose the RT kernel flavour.
While at it, unify comment.
Only adds a tdx-x11 distro. Additional flavours to follow.
