This reverts commit c6baf131a27bad3515cec907e307c7d0af297409.
Now that the cinematicexperience application doesn't crash anymore we
can enable the restart on failure again. This will handle the unlikely
case when the application would still crash in an unlikely event.
Related-to: ELB-4884
Signed-off-by: Stefan Eichenberger <stefan.eichenberger@toradex.com>
(cherry picked from commit 34121f5c91729f7b9185f879318bfd85746e7112)
If the wayland application fails to start we no longer restart it. This
can happen when there is no display connected. For example the
Qt5_CinematicExperience will fail to start with the following message:
xdg_surface geometry (1920 x 1080) is larger than the configured
fullscreen state (0 x 0)
If we keep restarting the application we spam the kernel log with
the following messages:
imx-drm display-subsystem: [drm] Cannot find any crtc or sizes
Related-to: ELB-4726
(cherry picked from commit c6baf131a27bad3515cec907e307c7d0af297409)
weston uses now systemd-notify to notify systemd when it is up and
running. This is the reason why we do no longer need
wayland-app-launch.sh with the synchronization point in it.
Remove wayland-app-launch.sh script. Remove also the init directory
feature as it is no longer needed. qtsmarthome works now from any
directory.
Related-to: ELB-4784
Weston is no longer being started as root. To allow applications and
other users to start applications that render to weston there is the
socket-file in /run/wayland-0 created.
Do also specify the user we want the app to be started from. Do also
instruct systemd with PAMName to treat as a login so XDG_RUNTIME_DIR is
also set.
Fix weston service name, it was changed in oe-core
commit dd83fb40f767 ("weston-init: Stop running weston as root")
from weston@root.service to weston.service.
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
And limit the restart to once per second.
Related-to: ELB-2838
