gnome-disk-utility in a later version is available from meta-openembedded.
joe version 4.6 has landed in meta-openembedded.
tinycompress version 1.1.6 has landed in meta-freescale.
imlib2: now available from meta-openembedded.
Since OE-Core commit 9379f80f48 ("license/insane: Show warning for
obsolete license usage"), LICENSE field not containing SPDX identifiers
are treated with WARNING.
An automated conversion using scripts/contrib/convert-spdx-licenses.py to
convert to use the standard SPDX license identifiers has been done on
the entire layer.
This is the result of automated script (0.9.3) conversion:
+# meta-toradex-distro
+vars = vars + ["preempt-rt","tdx","upstream"]
+# meta-toradex-* machines
+vars = vars + ["apalis-","colibri-","verdin-","tegra124"]
+# meta-freescale
+vars = vars + ["imx","mx6","mx7","mx8","use-mainline-bsp","use-nxp-bsp"]
../openembedded-core/scripts/contrib/convert-overrides.py .
converting the metadata to use ":" as the override character instead of "_".
Without gphoto libusb is otherwise not available and configure fails.
meta-oe now provides libpwquality. Drop the recipe here.
meta-openembedded no longer builds with samba in PACKAGE_CONFIG. Thus drop
removing it here.
The icon theme package is no longer provided.
This reverts commit 9584b1a639c349b4b8023ddfed8e09efb5e5ae68.
The recipe is again available upstream
Without this many of the buttons are shown with an ugly place holder
image.
root@apalis-t30:~# gnome-disks
(gnome-disks:660): GNOME-Disks-WARNING **: Error lookup up icon media-playback-start-symbolic
libwnck3 was removed from oe-core but did not (yet) make it into
meta-openembedded. Pull in the patch here.
From: Alexander Kanavin <alexander.kanavin@linux.intel.com>
Date: Tue, 1 Nov 2016 17:28:21 +0200
Subject: [PATCH] libwnck3: add a recipe
It is no longer needed in oe-core.
Signed-off-by: Alexander Kanavin <alexander.kanavin@linux.intel.com>
Signed-off-by: Martin Jansa <Martin.Jansa@gmail.com>
| WARNING: gnome-disk-utility-3.21.3-r4 do_package: QA Issue: gnome-disk-utility: Files/directories were installed but not shipped in any package:
| /usr/share/appdata
| /usr/share/dbus-1
| /usr/share/appdata/org.gnome.DiskUtility.appdata.xml
| /usr/share/dbus-1/services
| /usr/share/dbus-1/services/org.gnome.DiskUtility.service
While at it, drop the nautilus extension package, that is no longer provided.
add libpwquality recipe from meta-qt5-extra.
This bbappend is required by packages built with meta-lxde.
Thus move it were it belongs.
compiling gvfs with samba support in dizzy does not only pull in smbclient
but the full samba package, i.e. 50MB+.
save space by not requiring smbclient.
This uses the % wildcard for recipe matching.
remove the deprecated PRINC variable while at it.
libpcre splits into libpcre-*, use packages-dynamic so we can put them into an image
rename bbappend because coresponding bb does not exist
