Change to use the defconfig which is part of the kernel tree. In order
to provide a defconfig from your bbappend add a file 'defconfig' through
SRC_URI which will take precedence.
Related-to: ELB-3035
(cherry picked from commit 0006e2a7616674e768a698123a13caff5c1661ba)
Use the common defconfig from the kernel sources toradex-imx_v6_v7_defconfig.
This increases the kernel size for the so far smallest kernel by about 200k.
We need a file for each machine as we do not have a common override to use
in the use-mainline-bsp case.
This additionally adds CAN_J1939 as a kernel module.
Related-to: ELB-3023
Enable GPIO and serial-port (CD-signal) sources for
the PPS (pulse-per-second) module.
Related-to: ELB-2837
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit b736ab934b1067d032c1ac61bb753a8039222096)
NAND support may help (;-p).
(cherry picked from commit c6be4ddf709f00546caa534f96cb553b883d1ea3)
Bump to latest LTS release Linux 5.4.2.
