This fixes link errors with gcc 10.
| ...ld: lxtask-callbacks.o:.../lxtask-0.1.9/src/interface.h:64: multiple definition of `column';
| lxtask-main.o:.../lxtask-0.1.9/src/interface.h:64: first defined here
Remove the only place where gdk-x11 is needed and thus make it
work under gtk under wayland.
(cherry picked from commit c8d84165284d95c0775584537ab2a2e9490723ea)
The desktop file has key 'MimeType' which mandates 'inhert mime-xdg'.
This dropes the no longer available dependency on libglade and moves to gtk3+
Change to master.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
(cherry picked from commit ef686d11201b780d7db650f94b3a850a0eb3a6f5)
Adapted from thud to master:
The openbox recipe now also provides x-session-manager. Adapt recipe,
so that when lxde-common is installed the lxde session takes precedence.
wireless-tools got removed from openembedded-core but the package libiw
from the recipe is required for lxde panel. Re-add it here.
Using the following pattern is very inefficent, stop using it.
SRC_URI = "src1"
SRC_URI += "src2"
meta-openembedded no longer uses that patchfile (or a follow up) which
gets removed here.
See http://git.openembedded.org/meta-openembedded/commit/meta-oe/recipes-graphics/xserver-common?id=2f6e45baba961629bfe023599144be6cfcd45728
This reverts commit 42cf6a87c90c4e1e62c7e417bba6d7ad6343889b.
Updates to version 0.3.2.
Uses the code from git rather than from a (changing) source tarball.
Move back to use the versioned tar ball, as that is now supporting
gtk3.
The gtk3 patch is upstreamed now, but new code does not comply with
gtk3.
Fixes run.do_configure: line 169: glib-gettextize: command not found.
Fixes run.do_configure: line 172: glib-gettextize: command not found.
Fixes do_compile:/bin/sh: valac: command not found.
While at it clean-up and unify with other Toradex layers.
Otherwise you get build errors like this:
| error: Package `glib-2.0' not found in specified Vala API directories
| or GObject-Introspection GIR directories
configure checks for XML catalogs from the host installation. If missing
the resulting man/Makefile will fail in do_compile.
Workaround this by ignoring that the man page can not be built.
On Ubuntu were this was observed the following installs the required
dependencies:
sudo apt-get install docbook-xsl
Better still one would fix lxterminal's configure to pick up OE's catalogs.
While libxslt-native is needed there are still docbook stylesheets and
xmlto-native missing.
xmlot-native pulls in all needed components so replacing libxslt-native
with xmlto-native fixes the build.
| make[2]: Entering directory '/build/krm/oe-core_V2.6.2/build_test/tmp-glibc/work/armv7at2hf-neon-angstrom-linux-gnueabi/lxterminal/git-r0/build/man'
| /build/krm/oe-core_V2.6.2/build_test/tmp-glibc/sysroots/x86_64-linux/usr/bin/xsltproc -nonet http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl ../../git/man/lxterminal.xml
| I/O error : Attempt to load network entity http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl
| warning: failed to load external entity "http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl"
| cannot parse http://docbook.sourceforge.net/release/xsl/current/manpages/docbook.xsl
| Makefile:532: recipe for target 'lxterminal.1' failed
