path: root/patches/collateral-evolutions/network/0053-possible_net_t.patch
2017-02-07backports: get rid of patch directory structureJohannes Berg
This directory structure was never really managed well, simply get rid of it. With the patch system that only applies patches when the modified file exists, and with a lot of spatches applying everywhere anyway, it's no longer really useful either. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2016-07-13patches: refresh on next-20160324Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.81 [ OK ] 4 3.3.8 [ OK ] 5 3.4.112 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.102 [ OK ] 12 3.11.10 [ OK ] 13 3.12.61 [ OK ] 14 3.13.11 [ OK ] 15 3.14.73 [ OK ] 16 3.15.10 [ OK ] 17 3.16.36 [ OK ] 18 3.17.8 [ OK ] 19 3.18.36 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.27 [ OK ] 23 4.2.8 [ OK ] 24 4.3.6 [ OK ] 25 4.4.14 [ OK ] 26 4.5.7 [ OK ] Manual changes done to: patches/collateral-evolutions/network/0033-ndo_vlan_rx_vid/igb_ndo_vlan_rx_vid.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2016-04-30patches: refresh on next-20160216backports-20160216Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.79 [ OK ] 4 3.3.8 [ OK ] 5 3.4.112 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.101 [ OK ] 12 3.11.10 [ OK ] 13 3.12.59 [ OK ] 14 3.13.11 [ OK ] 15 3.14.67 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.32 [ OK ] 20 4.1.23 [ OK ] 21 4.3.6 [ OK ] 22 4.4.8 [ OK ] 23 4.5.2 [ OK ] 24 4.6-rc5 [ FAIL ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-12-06patches: refresh on next-20151203backports-20151203Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.74 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.93 [ OK ] 12 3.11.10 [ OK ] 13 3.12.51 [ OK ] 14 3.13.11 [ OK ] 15 3.14.57 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.24 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.13 [ OK ] 23 4.2.6 [ OK ] 24 4.3.0 [ OK ] 25 4.4-rc3 [ FAIL ] Build on kernel 4.4-rc3 failed because of a bug introduces in kernel 4.4 in this commit: aabc92bbe3cfe4c "net: add __netdev_alloc_pcpu_stats() to indicate gfp flags" Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-15patches: refresh on next-20151115backports-20151115Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] Bigger, manual changes were needed on patches/collateral-evolutions/media/0002-no_dmabuf/v4l2.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-11-07patches: refresh on next-20151013backports-20151013Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.72 [ OK ] 4 3.3.8 [ OK ] 5 3.4.110 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.92 [ OK ] 12 3.11.10 [ OK ] 13 3.12.49 [ OK ] 14 3.13.11 [ OK ] 15 3.14.56 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.23 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.12 [ OK ] 23 4.2.5 [ OK ] 24 4.3-rc7 [ OK ] manual changes done to the following patches: * patches/collateral-evolutions/network/0059-uuid-in-mei/nfc.patch * patches/collateral-evolutions/network/0013-fix-makefile-includes/brcmfmac.patch * patches/collateral-evolutions/network/0062-acpi-gpio-remove/hci_bcm.patch Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-09-14backports: refresh on next-20150818backports-20150818Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.71 [ OK ] 4 3.3.8 [ OK ] 5 3.4.108 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.88 [ OK ] 12 3.11.10 [ OK ] 13 3.12.47 [ OK ] 14 3.13.11 [ OK ] 15 3.14.52 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.21 [ OK ] 20 3.19.8 [ OK ] 21 4.0.9 [ OK ] 22 4.1.7 [ OK ] 23 4.2.0 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-25patches: refresh patches on next-20150402backports-20150402Hauke Mehrtens
1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.68 [ OK ] 4 3.3.8 [ OK ] 5 3.4.106 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.73 [ OK ] 12 3.11.10 [ OK ] 13 3.12.39 [ OK ] 14 3.13.11 [ OK ] 15 3.14.37 [ OK ] 16 3.15.10 [ OK ] 17 3.16.7 [ OK ] 18 3.17.8 [ OK ] 19 3.18.10 [ OK ] 20 3.19.3 [ OK ] 21 4.0-rc6 [ OK ] Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2015-04-22backports: deal better with possible_net_tEmmanuel Grumbach
Instead of just assuming CONFIG_NET_NS is defined, deal with this better. Sadly, it needs a header file patch (as an spatch doesn't deal properly with header files.) Signed-off-by: Emmanuel Grumbach <emmanuel.grumbach@intel.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com> Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
