path: root/backport/scripts
2018-10-12backports: support xz compression in uninstallJohannes Berg
Support xz compression in uninstall. Also use compat.ko instead of mac80211.ko to detect this, as compat is always compiled and mac80211 may not be. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2014-11-14backports: replace BACKPORT_PWD with BACKPORT_DIRLuis R. Rodriguez
This will also be used for built-in kernel integration, by using this we can share more code with the built-in kernel approach. Reviewed-by: Johannes Berg <johannes@sipsolutions.net> Signed-off-by: Luis R. Rodriguez <mcgrof@suse.com>
2014-04-17backports: nuke support for kernels < 3.0Luis R. Rodriguez
mcgrof@drvbp1 ~/backports (git::master)$ time ./gentree.py --clean /home/mcgrof/linux-next /home/mcgrof/build/next-20140409 Copy original source files ... Apply patches ... Modify Kconfig tree ... Rewrite Makefiles and Kconfig files ... Done! real 1m30.186s user 9m25.180s sys 0m24.428s mcgrof@drvbp1 ~/build/next-20140409 $ time ckmake --allyesconfig 1 3.0.101 [ OK ] 2 3.1.10 [ OK ] 3 3.2.54 [ OK ] 4 3.3.8 [ OK ] 5 3.4.79 [ OK ] 6 3.5.7 [ OK ] 7 3.6.11 [ OK ] 8 3.7.10 [ OK ] 9 3.8.13 [ OK ] 10 3.9.11 [ OK ] 11 3.10.29 [ OK ] 12 3.11.10 [ OK ] 13 3.12.10 [ OK ] 14 3.13.2 [ OK ] 15 3.14-rc1 [ OK ] real 26m54.859s user 744m15.764s sys 83m47.440s Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2014-01-24backports: fix uninstall filenamebackports-20140124Hauke Mehrtens
The uninstall script calculated the filename in the wrong way. It added the current working dir into the file name, this resulted in names like this: /lib/modules/2.6.32-431.3.1.el6.x86_64/updates//home/hauke/backports-20140124/drivers/net/wireless/ipw2x00/ipw2100.ko The correct one would be this /lib/modules/2.6.32-431.3.1.el6.x86_64/updates/drivers/net/wireless/ipw2x00/ipw2100.ko Signed-off-by: Hauke Mehrtens <hauke@hauke-m.de>
2013-06-26backports: re-introduce make uninstallASIC Felix
This approach only uninstalls modules you have built previously on your current build directory for backports. If this requires adjustments then we'll have to just have to use our own new backports KMODDIR. Signed-off-by: Felix Bitterli <ic.felix@gmail.com> [mcgrof: extended the commit log a bit] Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-06-05backports: fix firmware install for old udev on UbuntuAnoop Karollil
Rules for older versions of udev (e.g. version 113-0ubuntu16 on Ubuntu 7.10) are looked for in /etc/udev/rules.d. For later versions, they are looked for in either the default /lib/udev/rules.d location or the custom /etc/udev/rules.d location. For backwards compatibility with older udev, the rules should be installed in /etc/udev/rules.d. Signed-off-by: Anoop Karollil <anoop.karollil@gmail.com> Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com>
2013-04-17backports: update-initramfs: change/reformat messageJohannes Berg
Change the "severity" of the message, it doesn't have to be prefixed with "Warning:" since for many modules it'll work without updating initramfs. Also reformat it so it's aligned more nicely. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-17backports: fix install script return codeJohannes Berg
My "test ... && ..." trick won't work with set -e since then the script will fail, use a proper if. Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-10backports: add update-initramfs supportLuis R. Rodriguez
You'll need to update your initramfs for for a few modules. This is very distribution specific. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> [fix script argument] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-10backports: add udev rules if required for backported firmware_classLuis R. Rodriguez
Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-10backports: add check_depmod to look for module search pathLuis R. Rodriguez
This backports project relies on you being able to update your Linux distribution modules by looking at an updates search path, if one is not found we update depmod to look for the new path for you. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-10backports: add support for module compressionLuis R. Rodriguez
Some Linux distributions like to compress their modules. Add support to detect this in a modutils / modprobe agnostic way. Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> [refactor to just a single script] Signed-off-by: Johannes Berg <johannes.berg@intel.com>
2013-04-10backports: add blacklist module supportLuis R. Rodriguez
This lets us provide a simple map of new drivers and old drivers that it replaces at install time. This generates a blacklist via the file: /etc/modprobe.d/backports.conf Signed-off-by: Luis R. Rodriguez <mcgrof@do-not-panic.com> Signed-off-by: Johannes Berg <johannes.berg@intel.com>
