Make sure the git hash is always 12 characters long. This avoids issues
where we can get different length git hashes between to independent
builds. This can be problematic when sstate is shared.
Related-to: TOR-810
It contains a helper function kernel_configure_variable that could be
called in do_configure_append task to assign a value to a config
variable in ${B}/.config.
Change toradex-kernel-localversion.bbclass to use this function.
Signed-off-by: Ming Liu <ming.liu@toradex.com>
Handle the case where SRCREV_machine is set to AUTOREV.
As SRCREV_machine isn't set to INVALID as its default drop checking for INVALID.
fixes: f22318f toradex-kernel-localversion.bbclass: use SRCREV to set scmversion
Related-to: TOR-694
Handle the case where SRCREV is set to AUTOREV.
Related-to: TOR-694
In commit 32df2d41:
[ toradex-kernel-localversion.bbclass: use origin branch set scmversion ]
we changed to use origin branch to set scmversion, but that's not good
enough, we should stick to SRCREV which is the latest original commit
in the source.
Related-to: TOR-694
For kernel-yocto, the commit hash of HEAD is different for every run of
do_patch if there is any patch in SRC_URI, this is breaking the recipes
that relying on KERNEL_VERSION which contains scmversion, so we should
let scmversion stick to the original head instead of the HEAD after
do_patch, this will make scmversion stable and hence will make
KERNEL_VERSION stable for the recipes that relying on it.
Actually, LOCALVERSION_AUTO needs to be enabled to make the kernel
build system picking up .scmversion. So make sure LOCALVERSION_AUTO
is enabled when we generate a .scmversion file and disabled otherwise.
Fixes: 1bb212d9311a ("toradex-kernel-localversion: disable automatic localversion")
Make sure LOCALVERSION_AUTO is disabled to avoid interference with
our LOCALVERSION. This fixes building of the i.MX 8 kernel recipe.
Make sure TDX_VERSION is defined in case Toradex distro is not used.
This avoids confusing localverisons with just a dash.
The mainline recipe has the .config file ready later then our kernel
recipes. Use kernel_do_configure_append() which seems to work for both
cases.
Add Toradex specific local version implementation for the Linux
kernel. This implementation is a simplified version from what is in
meta-freescale. It can be used with linux-yocto based Linux recipes
as well as regular OE kernel recipes and linux-fslc based recipes.
This allows us to reuse the class in all Linux recipes used by Toradex.
