Its perfectly fine to call free(NULL), so no need to clutter the source
code with all those superfluous testing.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-uux5wpvevlerd42gqer13e7n@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Implement a simple, full-screen header window which shows session header
(metadata) information. Press 'i' key to display the header window.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1388036284-32342-4-git-send-email-namhyung@kernel.org
Some hotkeys don't work for perf top so split help messages for them.
It'll be helpful to a future modification. Also sort the message by
alphabetical order of the hotkey.
Link: http://lkml.kernel.org/r/1388036284-32342-3-git-send-email-namhyung@kernel.org
Sometimes perf top TUI breaks display with concurrent help/input window
and pr_* messages since they're not protected by ui__lock.
You can check it by pressing (and not releasing) 'h' key on a "perf top
-vvv" TUI session.
Link: http://lkml.kernel.org/r/1388036284-32342-2-git-send-email-namhyung@kernel.org
Support basic dwarf(debuginfo) based operations for uprobe events. With
this change, perf probe can analyze debuginfo of user application binary
to set up new uprobe event.
This allows perf-probe --add(with local variables, line numbers) and
--line works with -x option. (Actually, --vars has already accepted -x
option)
For example, the following command shows the probe-able lines of a given
user space function. Something that so far was only available in the
'perf probe' tool for kernel space functions:
# ./perf probe -x perf --line map__load
<map__load@/home/fedora/ksrc/linux-2.6/tools/perf/util/map.c:0>
0 int map__load(struct map *map, symbol_filter_t filter)
1 {
2 const char *name = map->dso->long_name;
int nr;
5 if (dso__loaded(map->dso, map->type))
6 return 0;
8 nr = dso__load(map->dso, map, filter);
9 if (nr < 0) {
10 if (map->dso->has_build_id) {
And this shows the available variables at the given line of the
function.
# ./perf probe -x perf --vars map__load:8
Available variables at map__load:8
@<map__load+96>
char* name
struct map* map
@<map__find_symbol+112>
char* name
@<map__find_symbol_by_name+136>
char* name
@<map_groups__find_symbol_by_name+176>
char* name
struct map* map
And lastly, we can now define probe(s) with all available
variables on the given line:
# ./perf probe -x perf --add 'map__load:8 $vars'
Added new events:
probe_perf:map__load (on map__load:8 with $vars)
probe_perf:map__load_1 (on map__load:8 with $vars)
probe_perf:map__load_2 (on map__load:8 with $vars)
probe_perf:map__load_3 (on map__load:8 with $vars)
You can now use it in all perf tools, such as:
perf record -e probe_perf:map__load_3 -aR sleep 1
Changes from previous version:
- Add examples in the patch description.
- Use .text section start address and dwarf symbol address
for calculating the offset of given symbol, instead of
searching the symbol in symtab again.
With this change, we can safely handle multiple local
function instances (e.g. scnprintf in perf).
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: David A. Long <dave.long@linaro.org>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: systemtap@sourceware.org
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20131226054152.22364.47021.stgit@kbuild-fedora.novalocal
Expand given path to absolute path in the option parser, except for a
module name.
Since realpath at later stage in processing several probe point, can be
called several times (even if currently doesn't, it can happen when we
expands the feature), it is waste of the performance.
Processing it once at the early stage can avoid that.
Changes from previous one:
- Fix not to print null string.
- Allocate memory for given path/module name everytime.
Cc: "David A. Long" <dave.long@linaro.org>
Cc: "Steven Rostedt (Red Hat)" <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20131226054150.22364.12187.stgit@kbuild-fedora.novalocal
[ Clarified the pr_warning message as per David Ahern's suggestion ]
1. Rename the test-* binary files to test-*.bin for easier pattern matching as
suggested by Ingo.
2. Ignore *.bin and *.d files.
Signed-off-by: Chunwei Chen <tuxoko@gmail.com>
Reviewed-by: Ingo Molnar <mingo@kernel.org>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/52B52B9B.50708@gmail.com
As the default guest is designed to handle orphan kernel symboles with
--guestkallsysms and --guestmodules, it has no user space.
So we should skip synthesizing threads if machine is default guest.
Signed-off-by: Dongsheng Yang <yangds.fnst@cn.fujitsu.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/e9ddb5dac6f963169657218b12ceb3c2030f54e8.1387572416.git.yangds.fnst@cn.fujitsu.com
When we synthesize an comm event, if machine is guest, we should
use the pid of machine as the event->comm.pid, rather than tgid
of thread.
Link: http://lkml.kernel.org/r/22455abe107c618a361e7b667ad0f098f7c9b4a3.1387572416.git.yangds.fnst@cn.fujitsu.com
is guest.
When we synthesize the mmap events of user space, if machine is guest,
we should set the event->header.misc to PERF_RECORD_MISC_GUEST_USER,
rather than PERF_RECORD_MISC_USER.
Link: http://lkml.kernel.org/r/e6f8ff6505d2db8a4b21bff8e448bb9be0bcff35.1387572416.git.yangds.fnst@cn.fujitsu.com
When we synthesize the threads, we are looking for the infomation under
/proc. But it is only for host.
This patch look for the path of proc under machine->root_dir, then
XXX__synthesize_threads() functions can support guest machines.
Link: http://lkml.kernel.org/r/927b937da9177a079abafe4532fa9c9b60b5c4b7.1387572416.git.yangds.fnst@cn.fujitsu.com
thread__find_addr_map().
This patch remove a TODO in thread__find_addr_map() and add support of
PERF_RECORD_MISC_GUEST_USER.
Link: http://lkml.kernel.org/r/3dd652201171a19c910b500984c7c3590e77603b.1387572416.git.yangds.fnst@cn.fujitsu.com
Currently, if we use perf kvm --guestkallsyms --guestmodules report, we
can not get the perf information from perf data file. All sample are
shown as unknown.
Reproducing steps:
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules record -a sleep 1
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.624 MB perf.data.guest (~27260 samples) ]
# perf kvm --guestkallsyms /tmp/kallsyms --guestmodules /tmp/modules report |grep %
100.00% [guest/6471] [unknown] [g] 0xffffffff8164f330
This bug was introduced by 207b57926 (perf kvm: Fix regression with guest machine creation).
In original code, it uses perf_session__find_machine(), it means we deliver symbol to machine
which has the same pid, if no machine found, deliver it to *default* guest. But if we use
perf_session__findnew_machine() here, if no machine was found, new machine with pid will be built
and added. Then the default guest which with pid == 0 will never get a symbol.
And because the new machine initialized here has no kernel map created, the symbol delivered to
it will be marked as "unknown".
This patch here is to revert commit 207b57926 and fix the SEGFAULT bug in another way.
Verification steps:
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules record -a sleep 1
[ perf record: Captured and wrote 0.651 MB perf.data.guest (~28437 samples) ]
# ./perf kvm --guestkallsyms /home/kallsyms --guestmodules /home/modules report |grep %
22.64% :6471 [guest.kernel.kallsyms] [g] update_rq_clock.part.70
19.99% :6471 [guest.kernel.kallsyms] [g] d_free
18.46% :6471 [guest.kernel.kallsyms] [g] bio_phys_segments
16.25% :6471 [guest.kernel.kallsyms] [g] dequeue_task
12.78% :6471 [guest.kernel.kallsyms] [g] __switch_to
7.91% :6471 [guest.kernel.kallsyms] [g] scheduler_tick
1.75% :6471 [guest.kernel.kallsyms] [g] native_apic_mem_write
0.21% :6471 [guest.kernel.kallsyms] [g] apic_timer_interrupt
Acked-by: David Ahern <dsahern@gmail.com>
Cc: stable@vger.kernel.org # 3.3+
Link: http://lkml.kernel.org/r/1387564907-3045-1-git-send-email-yangds.fnst@cn.fujitsu.com
Move those print functions under "if (use_browser == 0)" so that they
don't interfere with TUI output.
Maybe they can handle other UIs later.
Link: http://lkml.kernel.org/r/1387516278-17024-3-git-send-email-namhyung@kernel.org
There're some places printing messages to stdout/err directly.
It should be converted to use proper error printing functions instead.
Link: http://lkml.kernel.org/r/1387516278-17024-2-git-send-email-namhyung@kernel.org
The addr_location struct should fully qualify an address, and to do that
it should have in it the machine where the thread was found.
Thus all functions that receive an addr_location now don't need to also
receive a 'machine', those functions just need to access al->machine
instead, just like it does with the other parts of an address location:
al->thread, al->map, etc.
Link: http://lkml.kernel.org/n/tip-o51iiee7vyq4r3k362uvuylg@git.kernel.org
The 'evsel' parameter is not used, ditch it, reducing the function
signature.
Link: http://lkml.kernel.org/n/tip-kx9temzdcy7mk2edya9c1tdu@git.kernel.org
Removing unused parameters.
Link: http://lkml.kernel.org/n/tip-b7r7o80o2xwwtlzgqxv50foe@git.kernel.org
Link: http://lkml.kernel.org/n/tip-fspmnjadohrik8uvhytyu8lp@git.kernel.org
The 'browser' arg _is_ used, so ditch the misplaced attribute.
Link: http://lkml.kernel.org/n/tip-bo4dabkip5iikhk3x384ac46@git.kernel.org
Reduce typing, functions use class__method convention, so unlikely to
clash with other libraries.
This actually was discussed in the "Link:" referenced message below.
Link: http://lkml.kernel.org/r/20131112113427.GA4053@ghostprotocols.net
Moving QUIET_(CLEAN|INSTAL) variables into:
tools/scripts/Makefile.include
to be usable by other tools. The change to use them in libtraceevent is
in following patches.
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1387460527-15030-3-git-send-email-jolsa@redhat.com
Factoring make install tests to check for multiple files. Adding default
set of installed files for install and install_bin tests.
Putting the 'test' line into the log file instead to the screen as it
gets more complex now.
If the tests fails to find a file, following message is displayed:
$ make -f tests/make make_install_bin
- make_install_bin: cd . && make -f Makefile DESTDIR=/tmp/tmp.nCVuQoSHaJ install-bin
failed to find: bin/perf
Link: http://lkml.kernel.org/r/1387460527-15030-2-git-send-email-jolsa@redhat.com
Its a local struct and the functions use the __ separator from the class
name to the method name, so its unlikely that this will clash with other
namespaces.
Save some typing then.
Link: http://lkml.kernel.org/n/tip-r011tdv7ianars9jr9ur2n4q@git.kernel.org
1. Since all callers either test if it is less than zero or assign its
result to an int variable, convert it from ssize_t to int;
2. There is just one use for the 'session' variable, so use rec->session
directly instead;
3. No need to store the result of perf_data_file__write, since that
result is either 'size' or -1, the later making the error result to
be stored in 'errno' and accessed thru printf's %m in the pr_err
call.
Link: http://lkml.kernel.org/n/tip-xwsk964dp681fica3xlqhjin@git.kernel.org
Changing the file output code to use the newly
added perf_data_file__write interface.
No functional change intended.
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Using the perf_data_file object to handle output file processing.
Link: http://lkml.kernel.org/n/tip-01j9ophd7tntmgrxa40uqjjm@git.kernel.org
The va_end() in _eprintf() should be removed since the caller also
invokes va_end().
Link: http://lkml.kernel.org/r/1387436411-20160-4-git-send-email-namhyung@kernel.org
Continuing to try to remove the code duplication introduced with mem and
branch hist entry code, this time providing prologue and epilogues to
deal with callchains when processing samples.
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/n/tip-js3pour59yk2aibqzb1tpumh@git.kernel.org
Since it is now accessed just thru addr_map_symbol and hist_entry
wrappers.
Link: http://lkml.kernel.org/n/tip-gjoam7wcfrb03sp753gk1nfk@git.kernel.org
Those are just wrappers to annotation methods, so move them to
annotate.c
Link: http://lkml.kernel.org/n/tip-336h7z0bi2k51cbfi6mkpo5k@git.kernel.org
Since it has a hist_entry, no need to skip the hist layer and use the
underlying symbol one.
Link: http://lkml.kernel.org/n/tip-txsgu9umb0i86ijk888r1a0o@git.kernel.org
Since there are three calls that could receive just the struct
addr_map_symbol pointer and call the symbol method.
Link: http://lkml.kernel.org/n/tip-d728gz1orgkaknac9ppnzd9e@git.kernel.org
Since now symbol__addr_inc_samples() does the auto alloc, no need to do
it prior to calling hist_entry__inc_addr_samples.
Link: http://lkml.kernel.org/n/tip-6ife7xq2kef1nn017m04b3id@git.kernel.org
Instead of open coding it in multiple places in 'report' and 'top'.
Link: http://lkml.kernel.org/n/tip-ay1ushp57qsva9aw59rha5ve@git.kernel.org
The @entry argument already has the info so no need to pass them.
Cc: Arun Sharma <asharma@fb.com>
Cc: Rodrigo Campos <rodrigo@sdfg.com.ar>
Link: http://lkml.kernel.org/r/1387344086-12744-4-git-send-email-namhyung@kernel.org
The commit 09600e0f9ebb ("perf tools: Compare dso's also when comparing
symbols") added a comparison of dso when comparing symbol.
But if the sort key already has dso, it doesn't need to do it again
since entries have a different dso already filtered out.
Link: http://lkml.kernel.org/r/1387344086-12744-3-git-send-email-namhyung@kernel.org
If a hist entry doesn't have symbol information, compare it with its
address. Currently it only compares its level or whether it's NULL.
This can lead to an undesired result like an overhead exceeds 100%
especially when callchain accumulation is enabled by later patch.
Link: http://lkml.kernel.org/r/1387344086-12744-2-git-send-email-namhyung@kernel.org
It was called "data_type", but in this context "data" is way too vague,
it could mean the "data" ELF segment, or something else.
Since we have dso__read_binary_type_filename() and the values this field
receives are all DSO__BINARY_TYPE_<FOO> we may as well call it
"binary_type" for consistency sake.
It also seems more appropriate since it determines if we can do
operations like annotation and DWARF unwinding, that needs more than
just the symtab, requiring access to ELF text segments, CFI ELF
sections, etc.
Link: http://lkml.kernel.org/n/tip-2lkbqrn23uc2uvnn9w9in379@git.kernel.org
This option highlights tasks (using different color) that run more than
given duration or tasks with given name.
Signed-off-by: Stanislav Fomichev <stfomichev@yandex-team.ru>
Acked-by: Ingo Molnar <mingo@kernel.org>
Cc: Ramkumar Ramachandra <artagnon@gmail.com>
Link: http://lkml.kernel.org/r/20131217155349.GA13021@stfomichev-desktop
Using dso__binary_type_file() make it look like this function will
return a file, not just its filename, so rename it to:
to make its purpose clear, just like we have:
dso__read_running_kernel_build_id()
Link: http://lkml.kernel.org/n/tip-vkf3upzrfrxtr01wueej4xw4@git.kernel.org
There are no references to that array anywhere, it is only used to try
a series of "binary" types in turn, always setting dso->data_type till
one can be used.
Link: http://lkml.kernel.org/n/tip-4mw7xrbs12tln6v2uthg7sqc@git.kernel.org
Add -t switch to sort CPUs topologically.
Link: http://lkml.kernel.org/r/1385995056-20158-5-git-send-email-stfomichev@yandex-team.ru
Print all CPUs, even if there were no events (use perf header to get
number of CPUs).
This is required to support topology in the next patch.
Link: http://lkml.kernel.org/r/1385995056-20158-4-git-send-email-stfomichev@yandex-team.ru
Add PID to the figures of CPU usage timechart.
Link: http://lkml.kernel.org/r/1385995056-20158-3-git-send-email-stfomichev@yandex-team.ru
Add backtrace info to the CPU usage timechart.
Link: http://lkml.kernel.org/r/1385995056-20158-2-git-send-email-stfomichev@yandex-team.ru
Move debugfs.* to api/fs/. We have a common tools/lib/api/ place where
the Makefile lives and then we place the headers in subdirs.
For example, all the fs-related stuff goes to tools/lib/api/fs/ from
which we get libapikfs.a (acme got almost the naming he wanted :-)) and
we link it into the tools which need it - in this case perf and
tools/vm/page-types.
acme:
"Looking at the implementation, I think some tools can even link
directly to the .o files, avoiding the .a file altogether.
But that is just an optimization/finer granularity tools/lib/
cherrypicking that toolers can make use of."
Fixup documentation cleaning target while at it.
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Cc: Pekka Enberg <penberg@kernel.org>
Cc: Robert Richter <rric@kernel.org>
Cc: Stanislav Fomichev <stfomichev@yandex-team.ru>
Link: http://lkml.kernel.org/r/1386605664-24041-2-git-send-email-bp@alien8.de
Currently, there is no way to enumerate the subcommands under 'perf
kvm', so hardcode them.
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
Link: http://lkml.kernel.org/r/1386758056-24618-2-git-send-email-artagnon@gmail.com
Add a function to move a selected event to the
front of the list.
This is needed because it is not possible
to use the PERF_EVENT_IOC_SET_OUTPUT IOCTL
from an Instruction Tracing event to a
non-Instruction Tracing event. Thus the
Instruction Tracing event must come first.
Link: http://lkml.kernel.org/r/1386765443-26966-24-git-send-email-alexander.shishkin@linux.intel.com
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
