We need this to know where a symbol in a callchain came from,
for various reasons, among them precise annotation from a
TUI/GUI tool.
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1269459619-982-5-git-send-email-acme@infradead.org>
That will be in both struct hist_entry and struct
callchain_list, so that the TUI can store a pointer to the pair
(map, symbol) in the trees where hist_entries and
callchain_lists are present, to allow precise annotation instead
of looking for the first symbol with the selected name.
LKML-Reference: <1269459619-982-4-git-send-email-acme@infradead.org>
We were performing the full thread__find_addr_location
operation, i.e. resolving to a map/dso _and_ loading its symbols
when we can optimize it by first calling thread__find_addr_map
to find just the map/dso, check if it is one that we are
interested in (passed via --dsos/-d in 'perf annotate', 'perf
report', etc) and if not avoid loading the symtab.
Nice speedup when we know which DSO we're interested in.
LKML-Reference: <1269459619-982-2-git-send-email-acme@infradead.org>
Right now it presents a menu with these options:
| Annotate CURRENT_SYMBOL_NAME |
| Exit |
If the highlighted (current) symbol is not annotatable only the
"Exit" option will appear.
Also add a confirmation dialog when ESC is pressed on the top
level to avoid exiting the application by pressing one too many
ESC key.
To get to the menu just press the -> (Right navigation key), to
exit just press ESC.
LKML-Reference: <1269459619-982-1-git-send-email-acme@infradead.org>
Starts collapsed, allows annotating by pressing 'A' or 'a' on
the symbol, be it the top level one or any of the symbols in the
chains.
It (ab)uses the only tree widget in newt, that is actually a
checkbox tree that we use with just one option ('.'), end result
is usable but we really need to create a custom widget tree so
that we can use the data structures we have (hist_entry rb_tree
+ callchain rb_tree + lists), so that we reduce the memory
footprint by not creating a mirror set of data structures in the
newtCheckboxTree widget.
Thanks to Frédéric Weisbacker for fixing the orphanage problem
in 301fde2, without that we were tripping a newt bug (fix
already sent to newt's maintainer).
Cc: Avi Kivity <avi@redhat.com>
LKML-Reference: <1269291169-29820-1-git-send-email-acme@infradead.org>
If not the screen will get garbled when using newt.
LKML-Reference: <1269274229-20442-5-git-send-email-acme@infradead.org>
Cleanup debuginfo related code to eliminate fragile code which
pointed by Ingo (Thanks!).
1) Invert logic of NO_DWARF_SUPPORT to DWARF_SUPPORT.
2) For removing assymetric/local variable ifdefs, introduce
more helper functions.
3) Change options order to reduce the number of ifdefs.
Reported-by: Ingo Molnar <mingo@elte.hu>
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <1269274229-20442-2-git-send-email-acme@infradead.org>
Show an OK message box with the last message sent via pr_err,
etc.
LKML-Reference: <1269274229-20442-1-git-send-email-acme@infradead.org>
Callchains have markers inside their capture to tell we
enter a context (kernel, user, ...).
Those are not displayed in the callchains but they are
incidentally an active part of the radix tree where
callchains are stored, just like any other address.
If we have the two following callchains:
addr1 -> addr2 -> user context -> addr3
addr1 -> addr2 -> user context -> addr4
addr1 -> addr2 -> addr 5
This is pretty common if addr1 and addr2 are part of an
interrupt path, addr3 and addr4 are user addresses and
addr5 is a kernel non interrupt path.
This will be stored as follows in the tree:
addr1
addr2
/ addr5
user context
addr3 addr4
But we ignore the context markers in the report, hence
the addr3 and addr4 will appear as orphan branches:
|--28.30%-- hrtimer_interrupt
| smp_apic_timer_interrupt
| | <------------- here, no parent!
| | |--11.11%-- 0x7fae7bccb875
| | |--11.11%-- 0xffffffffff60013b
| | |--11.11%-- __pthread_mutex_lock_internal
| | |--11.11%-- __errno_location
Fix this by removing the context markers when we process the
callchains to the tree.
Reported-by: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
LKML-Reference: <1269274173-20328-1-git-send-email-acme@infradead.org>
Merge reason: Pick up latest perf fixes from upstream.
* 'perf-fixes-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (35 commits)
perf: Fix unexported generic perf_arch_fetch_caller_regs
perf record: Don't try to find buildids in a zero sized file
perf: export perf_trace_regs and perf_arch_fetch_caller_regs
perf, x86: Fix hw_perf_enable() event assignment
perf, ppc: Fix compile error due to new cpu notifiers
perf: Make the install relative to DESTDIR if specified
kprobes: Calculate the index correctly when freeing the out-of-line execution slot
perf tools: Fix sparse CPU numbering related bugs
perf_event: Fix oops triggered by cpu offline/online
perf: Drop the obsolete profile naming for trace events
perf: Take a hot regs snapshot for trace events
perf: Introduce new perf_fetch_caller_regs() for hot regs snapshot
perf/x86-64: Use frame pointer to walk on irq and process stacks
lockdep: Move lock events under lockdep recursion protection
perf report: Print the map table just after samples for which no map was found
perf report: Add multiple event support
perf session: Change perf_session post processing functions to take histogram tree
perf session: Add storage for seperating event types in report
perf session: Change add_hist_entry to take the tree root instead of session
perf record: Add ID and to recorded event data when recording multiple events
gcc 4.2.1 produces:
util/probe-event.c: In function 'add_perf_probe_events':
util/probe-event.c:883: warning: 'tev' may be used uninitialized in this function
make: *** [util/probe-event.o] Error 1
Newer GCCs get this right.
To work it around, initialize the variable to NULL so that older GCCs see
it as initialized too.
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20100316220612.32050.33806.stgit@localhost6.localdomain6>
of thread-wide
Parameter --pid (or -p) of perf currently means a thread-wide
collection. For exmaple, if a process whose id is 8888 has 10
threads, 'perf top -p 8888' just collects the main thread
statistics. That's misleading. Users are used to attach a whole
process when debugging a process by gdb. To follow normal usage
style, the patch change --pid to process-wide collection and add
--tid (-t) to mean a thread-wide collection.
Usage example is:
# perf top -p 8888
# perf record -p 8888 -f sleep 10
# perf stat -p 8888 -f sleep 10
Above commands collect the statistics of all threads of process
8888.
Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com>
Cc: Sheng Yang <sheng@linux.intel.com>
Cc: Joerg Roedel <joro@8bytes.org>
Cc: Jes Sorensen <Jes.Sorensen@redhat.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: Gleb Natapov <gleb@redhat.com>
Cc: zhiteng.huang@intel.com
Cc: Zachary Amsden <zamsden@redhat.com>
LKML-Reference: <1268922965-14774-3-git-send-email-acme@infradead.org>
Fix the !drawf build.
This uses the existing NO_DWARF_SUPPORT mechanism we use for that,
but it's really fragile and needs a cleanup. (in a separate patch)
1) Such uses:
#ifndef NO_DWARF_SUPPORT
are double inverted logic a'la 'not not'. Instead the flag should
be called DWARF_SUPPORT.
2) Furthermore, assymetric #ifdef polluted code flow like:
if (need_dwarf)
#ifdef NO_DWARF_SUPPORT
die("Debuginfo-analysis is not supported");
#else /* !NO_DWARF_SUPPORT */
pr_debug("Some probes require debuginfo.\n");
fd = open_vmlinux();
is very fragile and not acceptable. Instead of that helper functions
should be created and the dwarf/no-dwarf logic should be separated more
cleanly.
3) Local variable #ifdefs like this:
int fd;
#endif
Are fragile as well and should be eliminated. Helper functions achieve
that too.
Support accessing members in the data structures. With this,
perf-probe accepts data-structure members(IOW, it now accepts
dot '.' and arrow '->' operators) as probe arguemnts.
e.g.
./perf probe --add 'schedule:44 rq->curr'
./perf probe --add 'vfs_read file->f_op->read file->f_path.dentry'
Note that '>' can be interpreted as redirection in command-line.
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
LKML-Reference: <20100316220626.32050.57552.stgit@localhost6.localdomain6>
Improve --list to show current exist probes with line number and
file name. This enables user easily to check which line is
already probed.
for example:
./perf probe --list
probe:vfs_read (on vfs_read:8@linux-2.6-tip/fs/read_write.c)
LKML-Reference: <20100316220619.32050.48702.stgit@localhost6.localdomain6>
Introduce kprobe_trace_event and perf_probe_event and replace
old probe_point structure with it. probe_point structure is
not enough flexible nor extensible. New data structures
will help implementing further features.
Add --dry-run option for debugging and testing.
LKML-Reference: <20100316220605.32050.6571.stgit@localhost6.localdomain6>
Introduce die_find_child() function to integrate DIE-tree
searching functions.
LKML-Reference: <20100316220558.32050.7905.stgit@localhost6.localdomain6>
Rename die_get_real_subprogram and die_get_inlinefunc to
die_find_real_subprogram and die_find_inlinefunc respectively,
because these functions search its children. After that,
'die_get_' means getting a property of that die, and
'die_find_' means searching DIE-tree to get an appropriate
child die.
LKML-Reference: <20100316220551.32050.36181.stgit@localhost6.localdomain6>
Move add-probe routine to util/probe_event.c. This simplifies
main routine for reducing maintenance cost.
LKML-Reference: <20100316220537.32050.72214.stgit@localhost6.localdomain6>
Use wrapped functions as much as possible, to check out of
memory conditions in perf probe.
LKML-Reference: <20100316220530.32050.53951.stgit@localhost6.localdomain6>
Introducing xzalloc() which wrapping zalloc() for detecting out
of memory conditions.
LKML-Reference: <20100316220521.32050.85155.stgit@localhost6.localdomain6>
[ -v2: small cleanups in surrounding code ]
Merge reason: We'll be queueing dependent changes.
Use original address for looking up the location of variables
for dwarf_getlocation_addr() instead of CU-based address.
LKML-Reference: <20100315170235.31852.91195.stgit@localhost6.localdomain6>
Fix dereference offset to intmax_t from uintmax_t, because
it can have negative values (for example local variable's offset
from frame pointer).
LKML-Reference: <20100315170228.31852.71946.stgit@localhost6.localdomain6>
When profiling C++ workloads the symbol name length can be
really big, so cap it before it garbles the result.
This builds upon the autosizing already present where we choose
to use the short, basename of DSOs instead of its long, full
pathname.
Reported-by: Pavel Krauz <krauz@cngroup.cz>
LKML-Reference: <1268676230-9261-1-git-send-email-acme@infradead.org>
Before this patch we would not find a vmlinux, then try to pass
objdump "[kernel.kallsyms]" as the filename, it would get
confused and produce no output:
[root@doppio ~]# perf annotate n_tty_write
Percent | Source code & Disassembly of [kernel.kallsyms]
Now we check that and emit meaningful warning:
Can't annotate n_tty_write: No vmlinux file was found in the
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.34-rc1-tip+
[3] /lib/modules/2.6.34-rc1-tip+/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.34-rc1-tip+/vmlinux
[root@doppio ~]#
This bug was introduced when we added automatic search for
vmlinux, before that time the user had to specify a vmlinux
file.
v2: Print the warning just for the first symbol found when no
symbol name is specified, otherwise it will spam the screen
repeating the warning for each symbol.
Cc: <stable@kernel.org>
LKML-Reference: <1268669073-6856-1-git-send-email-acme@infradead.org>
Before this patch this message would very briefly appear on the
screen and then the screen would get updates only on the top,
for number of interrupts received, etc, but no annotation would
be performed:
[root@doppio linux-2.6-tip]# perf top -s n_tty_write > /tmp/bla
objdump: '[kernel.kallsyms]': No such file
Now this is what the user gets:
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.33-rc5
[3] /lib/modules/2.6.33-rc5/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.33-rc5/vmlinux
file.
Reported-by: David S. Miller <davem@davemloft.net>
LKML-Reference: <1268664418-28328-2-git-send-email-acme@infradead.org>
perf: Provide generic perf_sample_data initialization
MAINTAINERS: Add Arnaldo as tools/perf/ co-maintainer
perf trace: Don't use pager if scripting
perf trace/scripting: Remove extraneous header read
perf, ARM: Modify kuser rmb() call to compile for Thumb-2
x86/stacktrace: Don't dereference bad frame pointers
perf archive: Don't try to collect files without a build-id
perf_events, x86: Fixup fixed counter constraints
perf, x86: Restrict the ANY flag
perf, x86: rename macro in ARCH_PERFMON_EVENTSEL_ENABLE
perf, x86: add some IBS macros to perf_event.h
perf, x86: make IBS macros available in perf_event.h
hw-breakpoints: Remove stub unthrottle callback
x86/hw-breakpoints: Remove the name field
perf: Remove pointless breakpoint union
perf lock: Drop the buffers multiplexing dependency
perf lock: Fix and add misc documentally things
percpu: Add __percpu sparse annotations to hw_breakpoint
Set need_dwarf if lazy matching pattern is specified, because
lazy matching requires real source path for which we must use
debuginfo.
LKML-Reference: <20100312232224.2017.54550.stgit@localhost6.localdomain6>
Fix probe_point array-size overrun problem. In some cases (e.g.
inline function), one user-specified probe-point can be
translated to many probe address, and it overruns pre-defined
array-size. This also removes redundant MAX_PROBES macro
definition.
LKML-Reference: <20100312232217.2017.45017.stgit@localhost6.localdomain6>
[ Note that only root can create new probes. Eventually we should remove
the MAX_PROBES limit, but that is a larger patch not eligible to
perf/urgent treatment. ]
The use_browser needs to be in a file that is always built and
also we need a browser__show_help stub in that case.
Reported-by: Anton Blanchard <anton@samba.org>
LKML-Reference: <1268438710-32697-1-git-send-email-acme@infradead.org>
[root@doppio ~]# perf report -i newt.data | head -10
# Samples: 11999679868
# Overhead Command Shared Object Symbol
63.61% perf libslang.so.2.1.4 [.] SLsmg_write_chars
6.30% perf perf [.] symbols__find
2.19% perf libnewt.so.0.52.10 [.] newtListboxAppendEntry
2.08% perf libslang.so.2.1.4 [.] SLsmg_write_chars@plt
1.99% perf libc-2.10.2.so [.] _IO_vfprintf_internal
[root@doppio ~]#
Not good, the newt form for report works, but slang has to eat
the cost of the additional callgraph lines everytime it prints a
line, and the callgraph doesn't appear on the screen, so move
the callgraph printing to a separate function and don't use it
in newt.c.
Newt tree widgets are being investigated to properly support
callgraphs, but till that gets merged, lets remove this huge
overhead and show at least the symbol overheads for a callgraph
rich perf.data with good performance.
LKML-Reference: <1268408808-13595-2-git-send-email-acme@infradead.org>
For consistency, use the newt API more fully.
LKML-Reference: <1268408808-13595-1-git-send-email-acme@infradead.org>
These are keys people expect when pressed to exit the current
widget, so have associate all of them to this semantic.
Suggested-by: Ingo Molnar <mingo@elte.hu>
LKML-Reference: <1268401692-9361-1-git-send-email-acme@infradead.org>
Newt has widespread availability and provides a rather simple
API as can be seen by the size of this patch.
The work needed to support it will benefit other frontends too.
In this initial patch it just checks if the output is a tty, if
not it falls back to the previous behaviour, also if
newt-devel/libnewt-dev is not installed the previous behaviour
is maintaned.
Pressing enter on a symbol will annotate it, ESC in the
annotation window will return to the report symbol list.
More work will be done to remove the special casing in
color_fprintf, stop using fmemopen/FILE in the printing of
hist_entries, etc.
Also the annotation doesn't need to be done via spawning "perf
annotate" and then browsing its output, we can do better by
calling directly the builtin-annotate.c functions, that would
then be moved to tools/perf/util/annotate.c and shared with perf
top, etc
But lets go by baby steps, this patch already improves perf
usability by allowing to quickly do annotations on symbols from
the report screen and provides a first experimentation with
libnewt/TUI integration of tools.
Tested on RHEL5 and Fedora12 X86_64 and on Debian PARISC64 to
browse a perf.data file collected on a Fedora12 x86_64 box.
LKML-Reference: <1268349164-5822-5-git-send-email-acme@infradead.org>
We need those to properly size the browser widht in the newt
TUI.
LKML-Reference: <1268349164-5822-4-git-send-email-acme@infradead.org>
Just like we do for pr_debug, so that we can have a single point
where to redirect to the currently used output system, be it
stdio or newt.
LKML-Reference: <1268349164-5822-3-git-send-email-acme@infradead.org>
LKML-Reference: <1268349164-5822-1-git-send-email-acme@infradead.org>
Merge reason: We want to queue up a dependent patch.
At present, the perf subcommands that do system-wide monitoring
(perf stat, perf record and perf top) don't work properly unless
the online cpus are numbered 0, 1, ..., N-1. These tools ask
for the number of online cpus with sysconf(_SC_NPROCESSORS_ONLN)
and then try to create events for cpus 0, 1, ..., N-1.
This creates problems for systems where the online cpus are
numbered sparsely. For example, a POWER6 system in
single-threaded mode (i.e. only running 1 hardware thread per
core) will have only even-numbered cpus online.
This fixes the problem by reading the /sys/devices/system/cpu/online
file to find out which cpus are online. The code that does that is in
tools/perf/util/cpumap.[ch], and consists of a read_cpu_map()
function that sets up a cpumap[] array and returns the number of
online cpus. If /sys/devices/system/cpu/online can't be read or
can't be parsed successfully, it falls back to using sysconf to
ask how many cpus are online and sets up an identity map in cpumap[].
The perf record, perf stat and perf top code then calls
read_cpu_map() in the system-wide monitoring case (instead of
sysconf) and uses cpumap[] to get the cpu numbers to pass to
perf_event_open.
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
LKML-Reference: <20100310093609.GA3959@brick.ozlabs.ibm.com>
If -vv is used just the map table will be printed, -vvv will
print the symbol table too, with it we can see that we have a
bug where some samples are not being resolved to a map when we
get them in the perf.data stream, but after we have it all
processed, we can find the right map, some reordering probably
is happening.
Upcoming patches will provide ways to ask for most PERF_SAMPLE_
conditional samples to be taken for !PERF_RECORD_SAMPLE events
too, then we'll be able to ask for PERF_SAMPLE_TIME and
PERF_SAMPLE_CPU to help diagnose this.
LKML-Reference: <1268161097-17761-1-git-send-email-acme@infradead.org>
histogram tree
Now that report can store historgrams for multiple events we
need to be able to do the post processing work for each
histogram. This patch changes the post processing functions so
that they can be called individually for each event's histogram.
Signed-off-by: Eric B Munson <ebmunson@us.ibm.com>
[ Guarantee bisectabilty by fixing up builtin-report.c ]
LKML-Reference: <1267804269-22660-5-git-send-email-acme@infradead.org>
This patch adds the structures necessary to count each event
type independently in perf report.
LKML-Reference: <1267804269-22660-4-git-send-email-acme@infradead.org>
In order to minimize the impact of storing multiple events in a
report this function will now take the root of the histogram
tree so that the logic for selecting the proper tree can be
inserted before the call.
LKML-Reference: <1267804269-22660-3-git-send-email-acme@infradead.org>
cc1: warnings being treated as errors
util/probe-finder.c: In function 'find_line_range':
util/probe-finder.c:172: warning: 'src' may be used
uninitialized in this function make: *** [util/probe-finder.o]
Error 1
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <1267804269-22660-1-git-send-email-acme@infradead.org>
LKML-Reference: <1267800842-22324-1-git-send-email-acme@infradead.org>
Minimal userspace interface to the new 'precise' events flag.
Can be used like "perf top -e r00c0p" which will use PEBS to sample
retired instructions.
Cc: paulus@samba.org
Cc: eranian@google.com
Cc: robert.richter@amd.com
Cc: fweisbec@gmail.com
LKML-Reference: <20100304140100.468665803@chello.nl>
tools/perf/util/probe-event.c
Merge reason: Pick up -rc1 and resolve the conflict as well.
