git://git.kernel.org/pub/scm/linux/kernel/git/acme/linux into perf/urgent
Pull perf/core improvements and fixes from Arnaldo Carvalho de Melo:
User visible changes:
- Mark events as (x86 only) in help output for 'perf kvm stat live" (Alexander Yarygin)
- Provide a better explanation when mmap fails in 'trace' (Arnaldo Carvalho de Melo)
- Add --buildid-dir option to set cache directory, i.e. use:
$ perf --buildid-dir /path/to/dir tool --tool-options
(Jiri Olsa)
- Fix memcpy/memset 'perf bench' output (Rabin Vicent)
- Fix 'perf test' attr tests size values to cope with machine state on
interrupt ABI changes (Jiri Olsa)
- Fixup callchain type parameter handling error message (Kan Liang)
Infrastructure changes and cleanups:
- calloc/xcalloc: Fix argument order (Arjun Sreedharan)
- Move filename__read_int from tools/perf/ to tools/lib, add sysctl__read_int
there and use it in place of ad-hoc copies (Arnaldo Carvalho de Melo)
- Use single strcmp call instead of two (Jiri Olsa)
- Remove extra debugdir variables in 'perf buildid-cache' (Jiri Olsa)
- Fix -a segfault related to kcore handling in 'perf buildid-cache' (Jiri Olsa)
- Move cpumode resolve code to add_callchain_ip (Kan Liang)
- Merge memset into memcpy 'perf bench' (Rabin Vincent)
- Change print format from %lu to %PRIu64 in the hists browser (Tom Huynh)
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
To pretty print hints about perf_evlist__mmap errors. Will be used in
'trace' in the next patch.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Borislav Petkov <bp@suse.de>
Cc: David Ahern <dsahern@gmail.com>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-2g3gczfwyz0xt3we0s15mqqt@git.kernel.org
Link: http://lkml.kernel.org/n/tip-pt2u7a3b50oddggecx7rwq2n@git.kernel.org
Will be useful for new helpers to read sysctl values.
Pull leftover perf fixes from Ingo Molnar:
"Two perf fixes left over from the previous cycle"
* 'perf-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip:
perf session: Do not fail on processing out of order event
x86/asm/traps: Disable tracing and kprobes in fixup_bad_iret and sync_regs
Using flag to distinguish between branch_history and normal callchain.
Move the cpumode to add_callchain_ip function.
No change in behavior.
Signed-off-by: Kan Liang <kan.liang@intel.com>
Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1417532814-26208-3-git-send-email-kan.liang@intel.com
Fix up parse_callchain_record_opt error message for 'fp', in the past using '-g
fp' was a valid alternative to '--call-graph fp', which is not the case since:
commit 09b0fd45ff63413df94cbd832a765076b201edbb
Author: Jiri Olsa <jolsa@redhat.com>
Date: Sat Oct 26 16:25:33 2013 +0200
perf record: Split -g and --call-graph
I.e. -g means "use the configured unwind data collection method" which has as
default 'fp', while --call-graph requires passing the method to use.
Link: http://lkml.kernel.org/r/1417532814-26208-2-git-send-email-kan.liang@intel.com
[ split this from a larger patch related to LBR based unwinding ]
Adding --buildid-dir to be able to set specific cache directory. It's
going to be handy for buildid tests coming in shortly.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/1417460789-13874-4-git-send-email-jolsa@kernel.org
There's no need to copy over the buildid_dir into separate variable with
no change.
This is leftover from commit:
45de34bbe3e1 perf buildid: add perfconfig option to specify buildid cache dir
that added global buildid_dir variable that holds cache directory, but
did not cleanup the debugdir copies.
Link: http://lkml.kernel.org/r/1417460789-13874-3-git-send-email-jolsa@kernel.org
There's no need to use 2 strcmp calls, one is enough.
Link: http://lkml.kernel.org/r/1417460789-13874-2-git-send-email-jolsa@kernel.org
Currently branch stacks can be only shown as edge histograms for
individual branches. I never found this display particularly useful.
This implements an alternative mode that creates histograms over
complete branch traces, instead of individual branches, similar to how
normal callgraphs are handled. This is done by putting it in front of
the normal callgraph and then using the normal callgraph histogram
infrastructure to unify them.
This way in complex functions we can understand the control flow that
lead to a particular sample, and may even see some control flow in the
caller for short functions.
Example (simplified, of course for such simple code this is usually not
needed), please run this after the whole patchkit is in, as at this
point in the patch order there is no --branch-history, that will be
added in a patch after this one:
tcall.c:
volatile a = 10000, b = 100000, c;
__attribute__((noinline)) f2()
c = a / b;
__attribute__((noinline)) f1()
f2();
f2();
main()
int i;
for (i = 0; i < 1000000; i++)
f1();
% perf record -b -g ./tsrc/tcall
[ perf record: Woken up 1 times to write data ]
[ perf record: Captured and wrote 0.044 MB perf.data (~1923 samples) ]
% perf report --no-children --branch-history
54.91% tcall.c:6 [.] f2 tcall
|--65.53%-- f2 tcall.c:5
| |--70.83%-- f1 tcall.c:11
| | f1 tcall.c:10
| | main tcall.c:18
| | main tcall.c:18
| | main tcall.c:17
| | main tcall.c:17
| | f1 tcall.c:13
| | f1 tcall.c:13
| | f2 tcall.c:7
| | f2 tcall.c:5
| | f1 tcall.c:12
| | f1 tcall.c:12
| | f2 tcall.c:7
| | f2 tcall.c:5
| | f1 tcall.c:11
| --29.17%-- f1 tcall.c:12
| f1 tcall.c:12
| f2 tcall.c:7
| f2 tcall.c:5
| f1 tcall.c:11
| f1 tcall.c:10
| main tcall.c:18
| main tcall.c:18
| main tcall.c:17
| main tcall.c:17
| f1 tcall.c:13
| f1 tcall.c:13
| f2 tcall.c:7
| f2 tcall.c:5
| f1 tcall.c:12
The default output is unchanged.
This is only implemented in perf report, no change to record or anywhere
else.
This adds the basic code to report:
- add a new "branch" option to the -g option parser to enable this mode
- when the flag is set include the LBR into the callstack in machine.c.
The rest of the history code is unchanged and doesn't know the
difference between LBR entry and normal call entry.
- detect overlaps with the callchain
- remove small loop duplicates in the LBR
Current limitations:
- The LBR flags (mispredict etc.) are not shown in the history
and LBR entries have no special marker.
- It would be nice if annotate marked the LBR entries somehow
(e.g. with arrows)
v2: Various fixes.
v3: Merge further patches into this one. Fix white space.
v4: Improve manpage. Address review feedback.
v5: Rename functions. Better error message without -g. Fix crash without
-b.
v6: Rebase
v7: Rebase. Use NO_ENTRY in memset.
v8: Port to latest tip. Move add_callchain_ip to separate
patch. Skip initial entries in callchain. Minor cleanups.
Link: http://lkml.kernel.org/r/1415844328-4884-3-git-send-email-andi@firstfloor.org
The .per-pkg file indicates that all but one value per socket should be
discarded. Adding the logic of skipping the rest of the socket once
first value was read.
Cc: Matt Fleming <matt.fleming@intel.com>
Link: http://lkml.kernel.org/r/1416562275-12404-11-git-send-email-jolsa@kernel.org
Removing the perf_evsel__read interfaces because we replaced the only
user in the stat command code.
Link: http://lkml.kernel.org/r/1416562275-12404-8-git-send-email-jolsa@kernel.org
Linus reported perf report command being interrupted due to processing
of 'out of order' event, with following error:
Timestamp below last timeslice flush
0x5733a8 [0x28]: failed to process type: 3
I could reproduce the issue and in my case it was caused by one CPU
(mmap) being behind during record and userspace mmap reader seeing the
data after other CPUs data were already stored.
This is expected under some circumstances because we need to limit the
number of events that we queue for reordering when we receive a
PERF_RECORD_FINISHED_ROUND or when we force flush due to memory
pressure.
Reported-by: Linus Torvalds <torvalds@linux-foundation.org>
Acked-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/r/1417016371-30249-1-git-send-email-jolsa@kernel.org
The .snapshot file indicates that the provided event value is a snapshot
value and we have to bypass the delta computation logic.
Adding support to check up this file and set event flag accordingly.
Link: http://lkml.kernel.org/r/1416562275-12404-10-git-send-email-jolsa@kernel.org
discarded. Adding support to check up this file and set event flag
accordingly.
This patch is part of Matt's original patch:
http://marc.info/?l=linux-kernel&m=141527675002139&w=2 only the file
parsing part, the rest is solved differently.
Signed-off-by: Matt Fleming <matt.fleming@intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1416562275-12404-9-git-send-email-jolsa@kernel.org
Adding perf_evsel__read_cb read function that retuns count values via
callback. It will be used later in stat command as single way to
retrieve counter values.
Link: http://lkml.kernel.org/r/1416562275-12404-4-git-send-email-jolsa@kernel.org
Factoring out scale login into perf_counts_values__scale function.
Link: http://lkml.kernel.org/r/1416562275-12404-3-git-send-email-jolsa@kernel.org
Making compute_deltas functions global and renaming it to
perf_evsel__compute_deltas.
It will be used in stat command in later patch.
Link: http://lkml.kernel.org/r/1416562275-12404-2-git-send-email-jolsa@kernel.org
When debugging the tui browser I find it useful to redirect the debug
log into a file. Currently it's always forced to the message line.
Add an option to force it to stderr. Then it can be easily redirected.
Example:
[root@zoo ~]# perf --debug stderr report -vv 2> /tmp/debug
[root@zoo ~]# tail /tmp/debug
dso open failed, mmap: No such file or directory
Using /root/.debug/.build-id/4e/841948927029fb650132253642d5dbb2c1fb93 for symbols
Failed to open /tmp/perf-8831.map, continuing without symbols
Failed to open /tmp/perf-12721.map, continuing without symbols
Failed to open /tmp/perf-6966.map, continuing without symbols
Failed to open /tmp/perf-8802.map, continuing without symbols
[root@zoo ~]#
Link: http://lkml.kernel.org/r/1416605880-25055-2-git-send-email-andi@firstfloor.org
Jiri reported that the commit 96d78059d6d9 ("perf tools: Make vmlinux
short name more like kallsyms short name") segfaults on perf script.
When processing kernel mmap event, it should access the 'kernel'
variable as sometimes it cannot find a matching dso from build-id table
so 'dso' might be invalid.
Reported-by: Jiri Olsa <jolsa@redhat.com>
Tested-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/1416285028-30572-1-git-send-email-namhyung@kernel.org
When the source line is not found fall back to sym + offset. This is
generally much more useful than a raw address.
For this we need to pass in the symbol from the caller.
For some callers it's awkward to compute, so we stay at the old
behaviour.
Link: http://lkml.kernel.org/r/1415844328-4884-10-git-send-email-andi@firstfloor.org
We need to define bfd_demangle() to either a wrapper for
cplus_demangle() or to a stub when NO_DEMANGLE is defined.
That is at odds with using bfd.h for some other reason, as it defines
bfd_demangle() and then if code that wants to use symbol.h, where the
above stubbing/wrapping is done, and bfd.h for other reasons, we end up
with a build error where bfd_demangle() is found to be redefined.
Avoid that by moving the stubbing/wrapping to symbol-elf.c, that is the
only user of such function. If we ever get to a point where there are
more valid users, we can then introduce a header for that.
Link: http://lkml.kernel.org/n/tip-6wzjpe2fy9xtgchshulixlzw@git.kernel.org
For lbr-as-callgraph we need to see the line number in the history,
because many LBR entries can be in a single function, and just
showing the same function name many times is not useful.
When the history code is configured to sort by address, also try to
resolve the address to a file:srcline and display this in the browser.
If that doesn't work still display the address.
This can be also useful without LBRs for understanding which call in a large
function (or in which inlined function) called something else.
Contains fixes from Namhyung Kim
v2: Refactor code into common function
v3: Fix GTK build
v4: Rebase
Link: http://lkml.kernel.org/r/1415844328-4884-7-git-send-email-andi@firstfloor.org
Events may still be ordered even if there are no timestamps e.g. if the
data is recorded per-thread.
Also synthesized COMM events have a timestamp of zero.
Consequently it is better to keep comm entries even if they have a
timestamp of zero.
However, when a struct thread is created the command string is not known
and a comm entry with a string of the form ":<tid>" is used.
In that case thread->comm_set is false and the comm entry should be
overridden.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1415715423-15563-4-git-send-email-adrian.hunter@intel.com
The system_wide flag causes a selected event to be opened always without
a pid.
Consequently it will never get a POLLHUP, but it is used for tracking in
combination with other events, so it should not need to be polled
anyway.
Therefore don't add it for polling.
Link: http://lkml.kernel.org/r/1415715423-15563-2-git-send-email-adrian.hunter@intel.com
Following patch fails (-EINVAL) ftrace:function with enabled user
space callchains:
cfa77bc4af2c perf: Disallow user-space callchains for function trace events
We need to follow in perf tool itself and explicitly set the
perf_event_attr::exclude_callchain_user flag for ftrace:function
event.
Reported-by: Steven Rostedt <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/1415899263-24820-1-git-send-email-jolsa@kernel.org
Problem introduced in:
commit 5b5916696051 "perf report: Honor column width setting"
Where the left justification signal was after the width, which ended up,
when the width was, say, 11, always printing:
%11.11-s
Instead of src:line left justified and limited to 11 chars.
Resulting in a like:
70.93% %11.11-s [.] f2 tcall
When it should instead be:
70.93% tcall.c:5 [.] f2 tcall
Link: http://lkml.kernel.org/n/tip-2xnt0vqkoox52etq2qhyetr0@git.kernel.org
With srcline key/sort'ing it's useful to have line numbers in the
annotate window. This patch implements this.
Use objdump -l to request the line numbers and save them in the line
structure. Then the browser displays them for source lines.
The line numbers are not displayed by default, but can be toggled on
with 'k'
There is one unfortunate problem with this setup. For lines not
containing source and which are outside functions objdump -l reports
line numbers off by a few: it always reports the first line number in
the next function even for lines that are outside the function.
I haven't found a nice way to detect/correct this. Probably objdump has
to be fixed.
See https://sourceware.org/bugzilla/show_bug.cgi?id=16433
The line numbers are still useful even with these problems, as most are
correct and the ones which are not are nearby.
v2: Fix help text. Handle (discriminator...) output in objdump.
Left align the line numbers.
Link: http://lkml.kernel.org/r/1415844328-4884-9-git-send-email-andi@firstfloor.org
For perf report with --sort srcline only print the base source file
name. This makes the results generally fit much better to the screen.
The path is usually not that useful anyways because it is often from
different systems.
Link: http://lkml.kernel.org/r/1415844328-4884-8-git-send-email-andi@firstfloor.org
Refactor the duplicated code to resolve the symbol name or
the address of a symbol into a single function.
Used in next patch to add common functionality.
Link: http://lkml.kernel.org/r/1415844328-4884-6-git-send-email-andi@firstfloor.org
Use the relative address, this makes get_srcline work correctly in the
end.
Link: http://lkml.kernel.org/r/1415844328-4884-4-git-send-email-andi@firstfloor.org
Move the code to resolve and add a new callchain entry into a new
add_callchain_ip function. This will be used in the next patches to add
LBRs too.
Link: http://lkml.kernel.org/r/1415844328-4884-2-git-send-email-andi@firstfloor.org
Patch "perf tools: Fix build-id matching on vmlinux" breaks annotation
with kcore. The problem is that symbol__annotate() first gets the
filename based on the build-id which was previously not set.
This patch provides a quick fix, however there should probably be only
one way to determine the filename. e.g. symbol__annotate() should use
the same way as dso__data_fd().
Link: http://lkml.kernel.org/r/1415700294-30816-1-git-send-email-adrian.hunter@intel.com
The minimal ELF loader should not return 1 when it manages to read the
vmlinux build-id, it should instead return 0, meaning that it hasn't
loaded any symbols, since it doesn't parses ELF at all.
That way, the main symbol.c routines will understand that it is
necessary to continue looking for a file with symbols, and when no
libelf is linked, that means it will eventually try kallsyms.
Reported-by: Peter Zijlstra <peterz@infradead.org>
Tested-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/20141111130326.GT18464@kernel.org
Also move static variable no_buildid_cache and check it in the
perf_session_cache_build_ids().
Cc: Aravinda Prasad <aravinda@linux.vnet.ibm.com>
Cc: Brendan Gregg <brendan.d.gregg@gmail.com>
Cc: Hemant Kumar <hemant@linux.vnet.ibm.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Pekka Enberg <penberg@iki.fi>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: Vasant Hegde <hegdevasant@linux.vnet.ibm.com>
Cc: systemtap@sourceware.org
Link: http://lkml.kernel.org/r/1415368677-3794-1-git-send-email-namhyung@kernel.org
Add the infrastructure to setup, collect and report the interrupt
machine state regs which can be captured by the kernel.
Signed-off-by: Stephane Eranian <eranian@google.com>
Cc: cebbert.lkml@gmail.com
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Jean Pihet <jean.pihet@linaro.org>
Cc: Waiman Long <Waiman.Long@hp.com>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/r/1411559322-16548-4-git-send-email-eranian@google.com
The libtraceevent library's main handle 'struct pevent' holds pointers
of every event that was added to it via functions:
pevent_parse_format
pevent_parse_event
We can't release struct event_format (call pevent_free_format)
separately, because that breaks that pointers array mentioned above and
another add_event call could end up with segfault.
All added events are released within the handle cleanup in pevent_free.
Link: http://lkml.kernel.org/r/1415098538-1512-1-git-send-email-jolsa@kernel.org
We don't need to maintain cache of 'struct event_format' objects.
Currently the 'struct perf_evsel' holds this reference already.
Adding events_defined bitmap to keep track of defined events, which is
much cheaper than array of pointers.
Acked-by: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1414363445-22370-3-git-send-email-jolsa@kernel.org
Link: http://lkml.kernel.org/r/1414363445-22370-2-git-send-email-jolsa@kernel.org
Set a bit and return its old value. Stolen from kernel sources, will be
used in next patches.
Link: http://lkml.kernel.org/r/1414363445-22370-1-git-send-email-jolsa@kernel.org
The previous patch changed kernel dso name from '[kernel.kallsyms]' to
vmlinux. However it might add confusion to old users accustomed to the
old name. So change the short name to '[kernel.vmlinux]' to reduce such
confusion.
Before:
# Overhead Command Shared Object Symbol
9.83% swapper vmlinux [k] intel_idle
4.10% awk libc-2.20.so [.] __strcmp_sse2
1.86% sed libc-2.20.so [.] __strcmp_sse2
1.78% netctl-auto libc-2.20.so [.] __strcmp_sse2
1.23% netctl-auto libc-2.20.so [.] __mbrtowc
1.21% firefox libxul.so [.] 0x00000000024b62bd
1.20% swapper vmlinux [k] cpuidle_enter_state
1.03% sleep vmlinux [k] copy_user_generic_unrolled
After:
9.83% swapper [kernel.vmlinux] [k] intel_idle
1.20% swapper [kernel.vmlinux] [k] cpuidle_enter_state
1.03% sleep [kernel.vmlinux] [k] copy_user_generic_unrolled
Link: http://lkml.kernel.org/r/1415063674-17206-9-git-send-email-namhyung@kernel.org
There's a problem on finding correct kernel symbols when perf report
runs on a different kernel. Although a part of the problem was solved
by the prior commit 0a7e6d1b6844 ("perf tools: Check recorded kernel
version when finding vmlinux"), there's a remaining problem still.
When perf records samples, it synthesizes the kernel map using
machine__mmap_name() and ref_reloc_sym like "[kernel.kallsyms]_text".
You can easily see it using 'perf report -D' command.
After finishing record, it goes through the recorded events to find
maps/dsos actually used. And then record build-id info of them.
During this process, it needs to load symbols in a dso and it'd call
dso__load_vmlinux_path() since the default value of the symbol_conf.
try_vmlinux_path is true. However it changes dso->long_name to a real
path of the vmlinux file (e.g. /lib/modules/3.16.4/build/vmlinux) if one
is running on a custom kernel.
It resulted in that perf report reads the build-id of the vmlinux, but
cannot use it since it only knows about the [kernel.kallsyms] map. It
then falls back to possible vmlinux paths by using the recorded kernel
version (in case of a recent version) or a running kernel silently.
Even with the recent tools, this still has a possibility of breaking
the result. As the build directory is a symbolic link, if one built a
new kernel in the same directory with different source/config, the old
link to vmlinux will point the new file. So it's absolutely needed to
use build-id when finding a kernel image.
In this patch, it's now changed to try to search a kernel dso in the
existing dso list which was constructed during build-id table parsing
so it'll always have a build-id. If not found, search "[kernel.kallsyms]".
Before:
$ perf report
# Children Self Command Shared Object Symbol
72.15% 0.00% swapper [kernel.kallsyms] [k] set_curr_task_rt
72.15% 0.00% swapper [kernel.kallsyms] [k] native_calibrate_tsc
72.15% 0.00% swapper [kernel.kallsyms] [k] tsc_refine_calibration_work
71.87% 71.87% swapper [kernel.kallsyms] [k] module_finalize
After (for the same perf.data):
72.15% 0.00% swapper vmlinux [k] cpu_startup_entry
72.15% 0.00% swapper vmlinux [k] arch_cpu_idle
72.15% 0.00% swapper vmlinux [k] default_idle
71.87% 71.87% swapper vmlinux [k] native_safe_halt
Link: http://lkml.kernel.org/r/20140924073356.GB1962@gmail.com
Link: http://lkml.kernel.org/r/1415063674-17206-8-git-send-email-namhyung@kernel.org
When perf record finishes a session, it pre-processes samples in order
to write build-id info from DSOs that had samples.
During this process it'll call map__load() for the kernel map, and it
ends up calling dso__load_vmlinux_path() which replaces dso->long_name.
But this function checks kernel's build-id before searching vmlinux path
so it'll end up with a cryptic name, the pathname for the entry in the
~/.debug cache, which can be confusing to users.
This patch adds a flag to skip the build-id check during record, so
that it'll have the original vmlinux path for the kernel dso->long_name,
not the entry in the ~/.debug cache.
Before:
# perf record -va sleep 3
mmap size 528384B
[ perf record: Captured and wrote 0.196 MB perf.data (~8545 samples) ]
Looking at the vmlinux_path (7 entries long)
Using /home/namhyung/.debug/.build-id/f0/6e17aa50adf4d00b88925e03775de107611551 for symbols
After:
mmap size 528384B
[ perf record: Captured and wrote 0.193 MB perf.data (~8432 samples) ]
Using /lib/modules/3.16.4-1-ARCH/build/vmlinux for symbols
Link: http://lkml.kernel.org/r/1415063674-17206-7-git-send-email-namhyung@kernel.org
It'd be better managing those functions in a separate place as
util/header.c file is already big.
It now exports following 3 functions to others:
bool perf_session__read_build_ids(struct perf_session *session, bool with_hits);
int perf_session__write_buildid_table(struct perf_session *session, int fd);
int perf_session__cache_build_ids(struct perf_session *session);
Acked-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/545733E7.6010105@intel.com
Link: http://lkml.kernel.org/r/1415063674-17206-5-git-send-email-namhyung@kernel.org
The dsos__write_buildid_table() is not use struct dso and it mostly
uses perf_session struct.
So rename it to perf_session__write_buildid_ table() so that it
corresponds to other related functions such as
perf_session__read_build_ids() and perf_session__cache_build_ids().
Link: http://lkml.kernel.org/r/1415063674-17206-4-git-send-email-namhyung@kernel.org
Now my Archlinux box shows module symbols correctly.
Before:
$ perf report --stdio
Failed to open /tmp/perf-3477.map, continuing without symbols
no symbols found in /usr/bin/date, maybe install a debug package?
No kallsyms or vmlinux with build-id 7b4ea0a49ae2111925857099aaf05c3246ff33e0 was found
[drm] with build id 7b4ea0a49ae2111925857099aaf05c3246ff33e0 not found, continuing without symbols
No kallsyms or vmlinux with build-id edd931629094b660ca9dec09a1b635c8d87aa2ee was found
[jbd2] with build id edd931629094b660ca9dec09a1b635c8d87aa2ee not found, continuing without symbols
No kallsyms or vmlinux with build-id a7b1eada671c34933e5610bb920b2ca4945a82c3 was found
[ext4] with build id a7b1eada671c34933e5610bb920b2ca4945a82c3 not found, continuing without symbols
No kallsyms or vmlinux with build-id d69511fa3e5840e770336ef45b06c83fef8d74e3 was found
[scsi_mod] with build id d69511fa3e5840e770336ef45b06c83fef8d74e3 not found, continuing without symbols
No kallsyms or vmlinux with build-id af0430af13461af058770ee9b87afc07922c2e77 was found
[libata] with build id af0430af13461af058770ee9b87afc07922c2e77 not found, continuing without symbols
No kallsyms or vmlinux with build-id aaeedff8160ce631a5f0333591c6ff291201d29f was found
[libahci] with build id aaeedff8160ce631a5f0333591c6ff291201d29f not found, continuing without symbols
No kallsyms or vmlinux with build-id c57907712becaf662dc4981824bb372c0441d605 was found
[mac80211] with build id c57907712becaf662dc4981824bb372c0441d605 not found, continuing without symbols
No kallsyms or vmlinux with build-id e0589077cc0ec8c3e4c40eb9f2d9e69d236bee8f was found
[iwldvm] with build id e0589077cc0ec8c3e4c40eb9f2d9e69d236bee8f not found, continuing without symbols
No kallsyms or vmlinux with build-id 2d86086bf136bf374a2f029cf85a48194f9b950b was found
[cfg80211] with build id 2d86086bf136bf374a2f029cf85a48194f9b950b not found, continuing without symbols
No kallsyms or vmlinux with build-id 4493c48599bdb3d91d0f8db5150e0be33fdd9221 was found
[iwlwifi] with build id 4493c48599bdb3d91d0f8db5150e0be33fdd9221 not found, continuing without symbols
0.03% swapper [ext4] [k] 0x000000000000fe2e
0.03% swapper [kernel.kallsyms] [k] account_entity_enqueue
0.03% swapper [ext4] [k] 0x000000000000fc2b
0.03% irq/50-iwlwifi [iwlwifi] [k] 0x000000000000200b
0.03% swapper [kernel.kallsyms] [k] ktime_add_safe
0.03% swapper [kernel.kallsyms] [k] elv_completed_request
0.03% swapper [libata] [k] 0x0000000000003997
0.03% swapper [libahci] [k] 0x0000000000001f25
0.03% swapper [kernel.kallsyms] [k] rb_next
0.03% swapper [kernel.kallsyms] [k] blk_finish_request
0.03% swapper [ext4] [k] 0x0000000000010248
0.00% perf [kernel.kallsyms] [k] native_write_msr_safe
After:
no symbols found in /usr/bin/tr, maybe install a debug package?
0.04% kworker/u16:3 [ext4] [k] ext4_read_block_bitmap
0.03% kworker/u16:0 [mac80211] [k] ieee80211_sta_reset_beacon_monitor
0.02% irq/50-iwlwifi [mac80211] [k] ieee80211_get_bssid
0.02% firefox [e1000e] [k] __ew32_prepare
0.02% swapper [libahci] [k] ahci_handle_port_interrupt
0.02% emacs libglib-2.0.so.0.4000.0 [.] g_mutex_unlock
0.02% swapper [e1000e] [k] e1000_clean_tx_irq
0.02% dwm [kernel.kallsyms] [k] __schedule
0.02% gnome-terminal- [vdso] [.] __vdso_clock_gettime
0.02% swapper [e1000e] [k] e1000_alloc_rx_buffers
0.02% irq/50-iwlwifi [mac80211] [k] ieee80211_rx
0.01% firefox [vdso] [.] __vdso_gettimeofday
0.01% irq/50-iwlwifi [iwlwifi] [k] iwl_pcie_rxq_restock.part.13
Link: http://lkml.kernel.org/r/87h9yexshi.fsf@sejong.aot.lge.com
This patch adds basic support to handle compressed kernel module as some
distro (such as Archlinux) carries on it now. The actual work using
compression library will be added later.
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1415063674-17206-2-git-send-email-namhyung@kernel.org
Tracing for a workload begins before the comm event is seen, which
results in the initial comm having a string of the form ":<pid>" (e.g.
":12345").
In order to export the correct string, defer the export until the new
script 'flush' callback.
Link: http://lkml.kernel.org/r/1414678188-14946-8-git-send-email-adrian.hunter@intel.com
Add the ability to export detailed information about paired calls and
returns to Python db export and the export-to-postgresql.py script.
Link: http://lkml.kernel.org/r/1414678188-14946-7-git-send-email-adrian.hunter@intel.com
