Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
Setting perf_guest to true by default makes no sense because the perf
subcommands can not setup guest symbol information and thus not process
and guest samples. The only exception is perf-kvm which changes the
perf_guest value on its own. So change the default for perf_guest back
to false.
Cc: David Ahern <dsahern@gmail.com>
Cc: Jason Wang <jasowang@redhat.com>
Link: http://lkml.kernel.org/r/1328893505-4115-3-git-send-email-joerg.roedel@amd.com
Signed-off-by: Joerg Roedel <joerg.roedel@amd.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Make use of exclude_guest and exlude_host in perf-kvm to do only
guest-only counting by default.
Cc: Gleb Natapov <gleb@redhat.com>
Cc: Joerg Roedel <joro@8bytes.org>
Signed-off-by: Gleb Natapov <gleb@redhat.com>
[ committer note: Moved perf_{guest,host} & event_attr_init to util.c ]
[ so as not to drag more stuff to the python binding]
Not really something to be exported from session.c. Rename it to
'readn' as others did in the past.
Cc: Stephane Eranian <eranian@google.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <new-submission>
Number of samples is meaningless after we switched to auto-freq, so
report the number of events, i.e. not the sum of the different periods,
but the number PERF_RECORD_SAMPLE emitted by the kernel.
While doing this I noticed that naming "count" to the sum of all the
event periods can be confusing, so rename it to .period, just like in
struct sample.data, so that we become more consistent.
This helps with the next step, that was to record in struct hist_entry
the number of sample events for each instance, we need that because we
use it to generate the number of events when applying filters to the
tree of hist entries like it is being done in the TUI report browser.
Suggested-by: Ingo Molnar <mingo@elte.hu>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
getline() is considered as undeclared in util/util.c because
it includes string.h, that in turn includes stdio.h, without
having defined _GNU_SOURCE.
But util.c also includes util.h that handles the _GNU_SOURCE and
all the needed inclusions already. Let's include only util.h
and sys/mman.h which is the only one header not handled by
util.h
This fixes the following build error:
util/util.c: In function 'slow_copyfile':
util/util.c:49: erreur: implicit declaration of function
'getline' util/util.c:49: erreur: nested extern declaration of 'getline'
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <1263648075-3858-1-git-send-regression-fweisbec@gmail.com>
So that when we don't have a vmlinux handy we can store the
kallsyms for later use by 'perf report'.
LKML-Reference: <1263501006-14185-3-git-send-email-acme@infradead.org>
Now a cache will be created in a ~/.debug debuginfo like
hierarchy, so that at the end of a 'perf record' session all the
binaries (with build-ids) involved get collected and indexed by
their build-ids, so that perf report can find them.
This is interesting when developing software where you want to
do a 'perf diff' with the previous build and opens avenues for
lots more interesting tools, like a 'perf diff --graph' that
takes more than two binaries into account.
Tunables for collecting just the symtabs can be added if one
doesn't want to have the full binary, but having the full binary
allows things like 'perf rerecord' or other tools that can
re-run the tests by having access to the exact binary in some
perf.data file, so it may well be interesting to keep the full
binary there.
Space consumption is minimised by trying to use hard links, a
'perf cache' tool to manage the space used, a la ccache is
required to purge older entries.
With this in place it will be possible also to introduce new
commands, 'perf archive' and 'perf restore' (or some more
suitable and future proof names) to create a cpio/tar file with
the perf data and the files in the cache that _had_ perf hits of
interest.
There are more aspects to polish, like finding the right vmlinux
file to cache, etc, but this is enough for a first step.
LKML-Reference: <1261957026-15580-10-git-send-email-acme@infradead.org>
