Change-Id: Ib3b69ffc5ac3e07c9cc44cc49e9142088eec477e
When building on my Debian/mips system, util/util.c fails to build
because commit 1aed2671738785e8f5aea663a6fda91aa7ef59b5 (perf kvm: Do
guest-only counting by default) indirectly includes stdio.h before the
feature selection in util.h is done. This prevents _GNU_SOURCE in
util.h from enabling the declaration of getline(), from now second
inclusion of stdio.h, and the build is broken.
There is another breakage in util/evsel.c caused by include ordering,
but I didn't fully track down the commit that caused it.
The root cause of all this is an inconsistent definition of _GNU_SOURCE,
so I move the definition into the Makefile so that it is passed to all
invocations of the compiler and used uniformly for all system header
files. All other #define and #undef of _GNU_SOURCE are removed as they
cause conflicts with the definition passed to the compiler.
All the features.h definitions (_LARGEFILE64_SOURCE _FILE_OFFSET_BITS=64
and _GNU_SOURCE) are needed by the python glue code too, so they are
moved to BASIC_CFLAGS, and the misleading comments about BASIC_CFLAGS
are removed.
This gives me a clean build on x86_64 (fc12) and mips (Debian).
Cc: David Daney <david.daney@cavium.com>
Cc: Joerg Roedel <joerg.roedel@amd.com>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/1326836461-11952-1-git-send-email-ddaney.cavm@gmail.com
Signed-off-by: David Daney <david.daney@cavium.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
A update is made to the sched:sched_switch event that adds some
logic to the first parameter of the __print_flags() that shows the
state of tasks. This change cause perf to fail parsing the flags.
A simple fix is needed to have the parser be able to process ops
within the argument.
Cc: stable@vger.kernel.org
Reported-by: Andrew Vagin <avagin@openvz.org>
Commit a26ac2455ffcf3(rcu: move TREE_RCU from softirq to kthread)
introduced performance regression. In an AIM7 test, this commit degraded
performance by about 40%.
The commit runs rcu callbacks in a kthread instead of softirq. We observed
high rate of context switch which is caused by this. Out test system has
64 CPUs and HZ is 1000, so we saw more than 64k context switch per second
which is caused by RCU's per-CPU kthread. A trace showed that most of
the time the RCU per-CPU kthread doesn't actually handle any callbacks,
but instead just does a very small amount of work handling grace periods.
This means that RCU's per-CPU kthreads are making the scheduler do quite
a bit of work in order to allow a very small amount of RCU-related
processing to be done.
Alex Shi's analysis determined that this slowdown is due to lock
contention within the scheduler. Unfortunately, as Peter Zijlstra points
out, the scheduler's real-time semantics require global action, which
means that this contention is inherent in real-time scheduling. (Yes,
perhaps someone will come up with a workaround -- otherwise, -rt is not
going to do well on large SMP systems -- but this patch will work around
this issue in the meantime. And "the meantime" might well be forever.)
This patch therefore re-introduces softirq processing to RCU, but only
for core RCU work. RCU callbacks are still executed in kthread context,
so that only a small amount of RCU work runs in softirq context in the
common case. This should minimize ksoftirqd execution, allowing us to
skip boosting of ksoftirqd for CONFIG_RCU_BOOST=y kernels.
Signed-off-by: Shaohua Li <shaohua.li@intel.com>
Tested-by: "Alex,Shi" <alex.shi@intel.com>
If RCU priority boosting is to be meaningful, callback invocation must
be boosted in addition to preempted RCU readers. Otherwise, in presence
of CPU real-time threads, the grace period ends, but the callbacks don't
get invoked. If the callbacks don't get invoked, the associated memory
doesn't get freed, so the system is still subject to OOM.
But it is not reasonable to priority-boost RCU_SOFTIRQ, so this commit
moves the callback invocations to a kthread, which can be boosted easily.
Also add comments and properly synchronized all accesses to
rcu_cpu_kthread_task, as suggested by Lai Jiangshan.
Signed-off-by: Paul E. McKenney <paul.mckenney@linaro.org>
Reviewed-by: Josh Triplett <josh@joshtriplett.org>
This change does impact output: latency data is trace specific and is
now printed after the common data - comm, tid, cpu, time and event name.
Acked-by: Frederic Weisbecker <fweisbec@gmail.com>
LKML-Reference: <1299734608-5223-4-git-send-email-daahern@cisco.com>
Signed-off-by: David Ahern <daahern@cisco.com>
Next patch moves printing of 'common' data into perf-script which
removes the need for these functions.
LKML-Reference: <1299734608-5223-3-git-send-email-daahern@cisco.com>
GCC 4.6.0 in Fedora rawhide turned up some compile errors in tools/perf
due to the -Werror=unused-but-set-variable flag.
I've gone through and annotated some of the assignments that had side
effects (ie: return value from a function) with the __used annotation,
and in some cases, just removed unused code.
In a few cases, we were assigning something useful, but not using it in
later parts of the function.
kyle@dreadnought:~/src% gcc --version
gcc (GCC) 4.6.0 20110122 (Red Hat 4.6.0-0.3)
LKML-Reference: <20110124161304.GK27353@bombadil.infradead.org>
Signed-off-by: Kyle McMartin <kyle@redhat.com>
[ committer note: Fixed up the annotation fixes, as that code moved recently ]
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (311 commits)
perf tools: Add mode to build without newt support
perf symbols: symbol inconsistency message should be done only at verbose=1
perf tui: Add explicit -lslang option
perf options: Type check all the remaining OPT_ variants
perf options: Type check OPT_BOOLEAN and fix the offenders
perf options: Check v type in OPT_U?INTEGER
perf options: Introduce OPT_UINTEGER
perf tui: Add workaround for slang < 2.1.4
perf record: Fix bug mismatch with -c option definition
perf options: Introduce OPT_U64
perf tui: Add help window to show key associations
perf tui: Make <- exit menus too
perf newt: Add single key shortcuts for zoom into DSO and threads
perf newt: Exit browser unconditionally when CTRL+C, q or Q is pressed
perf newt: Fix the 'A'/'a' shortcut for annotate
perf newt: Make <- exit the ui_browser
x86, perf: P4 PMU - fix counters management logic
perf newt: Make <- zoom out filters
perf report: Report number of events, not samples
perf hist: Clarify events_stats fields usage
Fix up trivial conflicts in kernel/fork.c and tools/perf/builtin-record.c
The raw_field_ptr() helper, used to retrieve the address of a field
inside a trace event, treats every strings as if they were dynamic
ie: having a secondary level of indirection to retrieve their
contents.
FIELD_IS_STRING doesn't mean FIELD_IS_DYNAMIC, we only need to
compute the secondary dereference for the latter case.
This fixes perf sched segfaults, bad cmdline report and may be
some other bugs.
Reported-by: Jason Baron <jbaron@redhat.com>
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
commit e9e94e3bd862d31777335722e747e97d9821bc1d
"perf trace: Ignore "overwrite" field if present in
/events/header_page" makes perf trace launching spurious warnings
about unexpected tokens read:
Warning: Error: expected type 6 but read 4
This change tries to handle the overcommit field in the header_page
file whenever this field is present or not.
The problem is that if this field is not present, we try to find it
and give up in the middle of the line when we realize we are actually
dealing with another field, which is the "data" one. And this failure
abandons the file pointer in the middle of the "data" description
line:
field: u64 timestamp; offset:0; size:8; signed:0;
field: local_t commit; offset:8; size:8; signed:1;
field: char data; offset:16; size:4080; signed:1;
Here
What happens next is that we want to read this line to parse the data
field, but we fail because the pointer is not in the beginning of the
line.
We could probably fix that by rewinding the pointer. But in fact we
don't care much about these headers that only concern the ftrace
ring-buffer. We don't use them from perf.
Just skip this part of perf.data, but don't remove it from recording
to stay compatible with olders perf.data
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Checking if a tracing field is an array with a dynamic length
requires to check the field type and seek the "__data_loc"
string that prepends the actual type, as can be found in a trace
event format file:
field:__data_loc char[] name; offset:16; size:4; signed:1;
But we actually use strcmp() to check if the field type fully
matches "__data_loc", which may fail as we trip over the rest of
the type.
To fix this, use strncmp to only check if it starts with
"__data_loc".
LKML-Reference: <1271282283-23721-1-git-send-regression-fweisbec@gmail.com>
OPT_INCR()
Parsing an option from the command line with OPT_BOOLEAN on a
bool data type would not work on a big-endian machine due to the
manner in which the boolean was being cast into an int and
incremented. For example, running 'perf probe --list' on a
PowerPC machine would fail to properly set the list_events bool
and would therefore print out the usage information and
terminate.
This patch makes OPT_BOOLEAN work as expected with a bool
datatype. For cases where the original OPT_BOOLEAN was
intentionally being used to increment an int each time it was
passed in on the command line, this patch introduces OPT_INCR
with the old behaviour of OPT_BOOLEAN (the verbose variable is
currently the only such example of this).
I have reviewed every use of OPT_BOOLEAN to verify that a true
C99 bool was passed. Where integers were used, I verified that
they were only being used for boolean logic and changed them to
bools to ensure that they would not be mistakenly used as ints.
The major exception was the verbose variable which now uses
OPT_INCR instead of OPT_BOOLEAN.
Signed-off-by: Ian Munsie <imunsie@au.ibm.com>
Cc: <stable@kernel.org> # NOTE: wont apply to .3[34].x cleanly, please backport
Cc: Git development list <git@vger.kernel.org>
Cc: Ian Munsie <imunsie@au1.ibm.com>
Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: Valdis.Kletnieks@vt.edu
Cc: WANG Cong <amwang@redhat.com>
Cc: Thiago Farina <tfransosi@gmail.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: John Kacur <jkacur@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com>
That is not used in perf where we have the LOST events.
Without this patch we get:
[root@doppio ~]# perf lock report | head -3
Warning: Error: expected 'data' but read 'overwrite'
So, to make the same perf command work with kernels with and without
this field, introduce variants for the parsing routines to not warn the
user in such case.
Discussed-with: Steven Rostedt <rostedt@goodmis.org>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
LKML-Reference: <new-submission>
This stuff is needed by all scripting engines; move it from the Perl
engine source to a more common place.
Signed-off-by: Tom Zanussi <tzanussi@gmail.com>
Cc: Keiichi KII <k-keiichi@bx.jp.nec.com>
LKML-Reference: <1264580883-15324-4-git-send-email-tzanussi@gmail.com>
This patch is required to test the next patch for perf lock.
At 064739bc4b3d7f424b2f25547e6611bcf0132415 ,
support for the modifier "__data_loc" of format is added.
But, when I wanted to parse format of lock_acquired (or some
event else), raw_field_ptr() did not returned correct pointer.
So I modified raw_field_ptr() like this patch. Then
raw_field_ptr() works well.
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Steven Rostedt <srostedt@redhat.com>
LKML-Reference: <1264851813-8413-2-git-send-email-mitake@dcl.info.waseda.ac.jp>
[ v3: fixed minor stylistic detail ]
Memset should be given the size of the structure, not the size
of the pointer.
The semantic patch that makes this change is as follows:
(http://coccinelle.lip6.fr/)
// <smpl>
type T;
T *x;
expression E;
memset(x, E, sizeof(
x))
// </smpl>
LKML-Reference: <Pine.LNX.4.64.0912092026000.1870@ask.diku.dk>
- util/header.c
"len" is aligned to 64. So, it tries to write the out of
long_name buffer.
So, this use "zero_buf" to write aligned area.
- util/trace-event-read.c
"size" is not including nul byte. So, this allocates it, and set '\0'.
- util/trace-event-parse.c
It needs parens to calc correct size.
Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
LKML-Reference: <87d42s8iiu.fsf_-_@devron.myhome.or.jp>
The Perl scripting support for perf trace allows most of a trace
event's data to be accessed directly as handler arguments, but
not all of it e.g. the less common fields aren't passed in. To
give scripts access to the other fields and/or any other data or
metadata in the main perf executable that might be useful, a way
to access the C data in perf from Perl is needed; this patch
uses the Perl XS facility to do it for the common_xxx event
fields not passed to handler functions.
Context.pm exports three functions to Perl scripts that access
fields for the current event by calling back into perf:
common_pc(), common_flags() and common_lock_depth(). Support
for common_flags() field values was added to Core.pm and a
script used to sanity check these and other basic scripting
features, check-perf-trace.pl, was also added.
Cc: fweisbec@gmail.com
Cc: rostedt@goodmis.org
Cc: anton@samba.org
Cc: hch@infradead.org
LKML-Reference: <1259133352-23685-6-git-send-email-tzanussi@gmail.com>
Implement trace_scripting_ops to make Perl a supported perf
trace scripting language.
Additionally adds code that allows Perl trace scripts to access
the 'flag' and 'symbolic' (__print_flags(), __print_symbolic())
field information parsed from the trace format files.
Also adds the Perl implementation of the generate_script()
trace_scripting_op, which creates a ready-to-run perf trace Perl
script based on existing trace data. Scripts generated by this
implementation print out all the fields for each event mentioned
in perf.data (and will detect and generate the proper scripting
code for 'flag' and 'symbolic' fields), and will additionally
generate handlers for the special 'trace_unhandled',
'trace_begin' and 'trace_end' handlers. Script authors can
simply remove the printing code to implement their own custom
event handling.
Cc: anton@samba.org
LKML-Reference: <1259133352-23685-4-git-send-email-tzanussi@gmail.com>
It's useful to know whether a field is a flag or symbolic field
for e.g. when generating scripts - it allows us to translate
those fields specially rather than literally as plain numeric
values.
Cc: anton@samba.org
LKML-Reference: <1259133352-23685-3-git-send-email-tzanussi@gmail.com>
Commit 13999e59343b042b0807be2df6ae5895d29782a0 (perf tools:
Handle the case with and without the "signed" trace field)
removed code to set the FIELD_IS_SIGNED flag that was originally
added by commit 26a50744b21fff65bd754874072857bee8967f4d
(tracing/events: Add 'signed' field to format files).
This adds it back.
LKML-Reference: <1259133299-23594-2-git-send-email-tzanussi@gmail.com>
The second argument in the strtok_r() function is not to be used
generically and can have different implementations. Currently
the function parsing of the perf trace code uses the second
argument to copy data from. This can crash the tool or just have
unpredictable results.
The correct solution is to use strsep() which has a defined
result.
I also added a check to see if the result was correct, and will
break out of the loop in case it fails to parse as expected.
LKML-Reference: <20091020232034.237814877@goodmis.org>
The (char *) for all the static strings was a fix for the
symptom and not the disease. The real issue was that the
function prototypes needed to be declared "const char *".
Signed-off-by: Steven Rostedt <srostedt@redhat.com>
LKML-Reference: <20091014194400.635935008@goodmis.org>
The opterators '-' and '+' are not handled in the trace print
format.
To do: '++' and '--'.
LKML-Reference: <20091014194400.330843045@goodmis.org>
Add the irqs disabled, preemption count, need resched, and other
info that is shown in the latency format of ftrace.
# perf trace -l
perf-16457 2..s2. 53636.260344: kmem_cache_free: call_site=ffffffff811198f
perf-16457 2..s2. 53636.264330: kmem_cache_free: call_site=ffffffff811198f
perf-16457 2d.s4. 53636.300006: kmem_cache_free: call_site=ffffffff810d889
LKML-Reference: <20091014194400.076588953@goodmis.org>
The ftrace output events can have either arguments or no
arguments. The parser needs to be able to handle both.
LKML-Reference: <20091014194359.790221427@goodmis.org>
The bprintk parsing was broken in more ways than one.
The file parsing was incorrect, and the words used by the
arguments are always 4 bytes aligned, even on 64-bit machines.
LKML-Reference: <20091014194359.520931637@goodmis.org>
Even though an event may fail to parse, we should not kill the
entire report. The trace should still be able to show what it
can.
If an event fails to parse, a warning is printed, and the output
continues.
LKML-Reference: <20091014194359.190809589@goodmis.org>
The trace format files now have a "signed" field. But we should
still be able to handle the kernels that do not have this field.
LKML-Reference: <20091014194358.888239553@goodmis.org>
New lines between args in the trace format can break the
parsing. This should not be the case.
LKML-Reference: <20091014194358.637991808@goodmis.org>
The '*' is currently only treated as a multiplication, and it
needs to be handled as a typecast pointer.
This is the version used by trace-cmd.
LKML-Reference: <20091014194358.409327875@goodmis.org>
The array used by the ftrace stack events (caller[x]) causes
issues with the parser. This adds code to handle the case, but
it also assumes that the array is of type long.
Note, this is a special case used (currently) only by the ftrace
user and kernel stack records.
LKML-Reference: <20091014194358.124833639@goodmis.org>
The code to handle the '<' and '>' ops was all in place, but
they were not in the switch statement to consider them as valid
ops.
LKML-Reference: <20091014194357.807434040@goodmis.org>
The handling of backslashes was broken. It would stop parsing
when encountering one. Also, '\n', '\t', '\r' and '\\' were not
converted.
LKML-Reference: <20091014194357.521974680@goodmis.org>
kmem_alloc ftrace event format had a string that was broken up
by two tokens. "string 1" "string 2". This patch lets the parser
be able to handle the concatenation.
LKML-Reference: <20091014194357.253818714@goodmis.org>
Merge reason: pick up tools/perf/ changes from upstream.
The following perf build warnings/errors in function
argument types:
builtin-sched.c:1894: warning: passing argument 1 of 'sort_dimension__add' discards qualifiers from pointer target type
util/trace-event-parse.c:685: warning: passing argument 2 of 'read_expected' discards qualifiers from pointer target type
util/trace-event-parse.c:741: warning: passing argument 4 of 'test_type_token' discards qualifiers from pointer target type
util/trace-event-parse.c:706: warning: passing argument 2 of 'read_expected_item' discards qualifiers from pointer target type
... trigger because older GCC is not able to prove that
sort_dimension__add() does not change the string.
Some goes for test_type_token().
Fix this by improving type consistency.
Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl>
LKML-Reference: <20091005131729.78444bfb.randy.dunlap@oracle.com>
[ Also remove ugly type cast now unnecessary. ]
Needed for distinguishing string fields in event stream processing.
Cc: lizf@cn.fujitsu.com
LKML-Reference: <1254809398-8078-4-git-send-email-tzanussi@gmail.com>
Needed to fully qualify event names for event stream processing.
LKML-Reference: <1254809398-8078-3-git-send-email-tzanussi@gmail.com>
The sign info used for filters in the kernel is also useful to
applications that process the trace stream. Add it to the format
files and make it available to userspace.
LKML-Reference: <1254809398-8078-2-git-send-email-tzanussi@gmail.com>
Add missing BLOCK_IOPOLL_SOFTIRQ entry.
LKML-Reference: <1254808849-7829-3-git-send-email-tzanussi@gmail.com>
Finish the -M/--multiplex option implementation:
- separate it out from group_fd
- correctly set it via the ioctl and dont mmap counters that
are multiplexed
- modify the perf record event loop to deal with buffer-less
counters.
- remove the -g option from perf sched record
- account for unordered events in perf sched latency
- (add -f to perf sched record to ease measurements)
- skip idle threads (pid==0) in latency output
The result is better latency output by 'perf sched latency':
Task | Runtime ms | Switches | Average delay ms | Maximum delay ms |
ksoftirqd/8 | 0.071 ms | 2 | avg: 0.458 ms | max: 0.913 ms |
at-spi-registry | 0.609 ms | 19 | avg: 0.013 ms | max: 0.023 ms |
perf | 3.316 ms | 16 | avg: 0.013 ms | max: 0.054 ms |
Xorg | 0.392 ms | 19 | avg: 0.011 ms | max: 0.018 ms |
sleep | 0.537 ms | 2 | avg: 0.009 ms | max: 0.009 ms |
TOTAL: | 4.925 ms | 58 |
perf sched raises the following error when it meets a sched
switch event:
perf: builtin-sched.c:286: register_pid: Assertion `!(pid >= 65536)' failed.
Abandon
Currently in x86-64, the sched switch events have a hole in the
middle of the structure:
u16 common_type;
u8 common_flags;
u8 common_preempt_count;
u32 common_pid;
u32 common_tgid;
char prev_comm[16];
u32 prev_pid;
u32 prev_prio;
<--- there
u64 prev_state;
char next_comm[16];
u32 next_pid;
u32 next_prio;
Gcc inserts a 4 bytes hole there for prev_state to be u64
aligned. And the events are exported to userspace with this
hole.
But in userspace, from perf sched, we fetch it using a
structure that has a new field in the beginning: u32 size. This
is because our trace is exported with its size as a field. But
now that we have this new field, the hole in the middle
disappears because it makes prev_state becoming well aligned.
And since we are using a pointer to the raw trace using this
struct, instead of reading prev_state, we are reading the hole.
We could fix it by keeping the size seperate from the struct
but actually there a lot of other potential problems: some
fields may be saved as long in a 64 bits system and later read
as long in a 32 bits system. Also this direct cast doesn't care
about the endianness differences between the host traced
machine and the machine in which we do the post processing.
So instead of using such dangerous direct casts, fetch the
values using the trace parsing API that already takes care of
all these problems.
Import the schedbench.c tool that i wrote some time ago to
simulate scheduler behavior but never finished. It's a good
basis for perf sched nevertheless.
Most of its guts are not hooked up to the perf event loop
yet - that will be done in the patches to come.
Print out more accurate timestamps - usecs does not cut it
anymore on fast enough boxes ;-)
Older versions of GCC are rather stupid about strict aliasing:
util/trace-event-parse.c: In function 'parse_cmdlines':
util/trace-event-parse.c:93: warning: dereferencing type-punned pointer will break strict-aliasing rules
util/trace-event-parse.c: In function 'parse_proc_kallsyms':
util/trace-event-parse.c:155: warning: dereferencing type-punned pointer will break strict-aliasing rules
util/trace-event-parse.c:157: warning: dereferencing type-punned pointer will break strict-aliasing rules
util/trace-event-parse.c:158: warning: dereferencing type-punned pointer will break strict-aliasing rules
util/trace-event-parse.c: In function 'parse_ftrace_printk':
util/trace-event-parse.c:294: warning: dereferencing type-punned pointer will break strict-aliasing rules
util/trace-event-parse.c:295: warning: dereferencing type-punned pointer will break strict-aliasing rules
make: *** [util/trace-event-parse.o] Error 1
Make it clear to GCC that we intend with those pointers, by passing
them through via an explicit (void *) cast.
We might want to add -fno-strict-aliasing as well, like the kernel
itself does.
Complete support for __str_loc type strings of ftrace events
which have dynamic offsets values set for each of them inside
their sammples.
Before:
geany-5759 [000] 0.000000: lock_release: name
kondemand/0-362 [000] 0.000000: lock_release: name
pdflush-421 [000] 0.000000: lock_release: name
After:
geany-5759 [000] 0.000000: lock_release: &u->lock
geany-5759 [000] 0.000000: lock_release: key
geany-5759 [000] 0.000000: lock_release: &group->notification_mutex
kondemand/0-362 [000] 0.000000: lock_release: &rq->lock
pdflush-421 [000] 0.000000: lock_release: &rq->lock
LKML-Reference: <1251693921-6579-4-git-send-email-fweisbec@gmail.com>
Some string fields are not printed because of a missing printf
in the post-processing.
Before:
perf-10070 [000] 0.000000: sched_switch: task :10070 [120] (R) ==> :5720 [120]
geany-5720 [000] 0.000000: sched_switch: task :5720 [120] (S) ==> :10070 [120]
<idle>-0 [000] 0.000000: sched_switch: task :0 [140] (R) ==> :361 [115]
After:
perf-10070 [000] 0.000000: sched_switch: task perf:10070 [120] (R) ==> geany:5720 [120]
geany-5720 [000] 0.000000: sched_switch: task geany:5720 [120] (S) ==> perf:10070 [120]
<idle>-0 [000] 0.000000: sched_switch: task swapper:0 [140] (R) ==> kondemand/1:361 [115]
LKML-Reference: <1251427567-10551-2-git-send-email-fweisbec@gmail.com>
While opening a trace event counter, every events are saved in
the trace.info file. But we only want to save the
specifications of the events we are using.
LKML-Reference: <1251421798-9101-1-git-send-email-fweisbec@gmail.com>
