path: root/tools/perf/util/trace-event-parse.c
2009-11-25perf tools: Add 'signed' flag setting back into trace-event-parse.cTom Zanussi
Commit 13999e59343b042b0807be2df6ae5895d29782a0 (perf tools: Handle the case with and without the "signed" trace field) removed code to set the FIELD_IS_SIGNED flag that was originally added by commit 26a50744b21fff65bd754874072857bee8967f4d (tracing/events: Add 'signed' field to format files). This adds it back. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1259133299-23594-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-21perf tools: Use strsep() over strtok_r() for parsing single lineSteven Rostedt
The second argument in the strtok_r() function is not to be used generically and can have different implementations. Currently the function parsing of the perf trace code uses the second argument to copy data from. This can crash the tool or just have unpredictable results. The correct solution is to use strsep() which has a defined result. I also added a check to see if the result was correct, and will break out of the loop in case it fails to parse as expected. Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20091020232034.237814877@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Remove all char * typecasts and use const in prototypeSteven Rostedt
The (char *) for all the static strings was a fix for the symptom and not the disease. The real issue was that the function prototypes needed to be declared "const char *". Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194400.635935008@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle - and + in parsing trace print formatSteven Rostedt
The opterators '-' and '+' are not handled in the trace print format. To do: '++' and '--'. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194400.330843045@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Add latency format to trace outputSteven Rostedt
Add the irqs disabled, preemption count, need resched, and other info that is shown in the latency format of ftrace. # perf trace -l perf-16457 2..s2. 53636.260344: kmem_cache_free: call_site=ffffffff811198f perf-16457 2..s2. 53636.264330: kmem_cache_free: call_site=ffffffff811198f perf-16457 2d.s4. 53636.300006: kmem_cache_free: call_site=ffffffff810d889 Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194400.076588953@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle both versions of ftrace outputSteven Rostedt
The ftrace output events can have either arguments or no arguments. The parser needs to be able to handle both. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194359.790221427@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Fix bprintk reading in trace outputSteven Rostedt
The bprintk parsing was broken in more ways than one. The file parsing was incorrect, and the words used by the arguments are always 4 bytes aligned, even on 64-bit machines. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194359.520931637@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Still continue on failed parsing of an eventSteven Rostedt
Even though an event may fail to parse, we should not kill the entire report. The trace should still be able to show what it can. If an event fails to parse, a warning is printed, and the output continues. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194359.190809589@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle the case with and without the "signed" trace fieldSteven Rostedt
The trace format files now have a "signed" field. But we should still be able to handle the kernels that do not have this field. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194358.888239553@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle newlines in trace parsing betterSteven Rostedt
New lines between args in the trace format can break the parsing. This should not be the case. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194358.637991808@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle * as typecast in trace parsingSteven Rostedt
The '*' is currently only treated as a multiplication, and it needs to be handled as a typecast pointer. This is the version used by trace-cmd. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194358.409327875@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle arrays in print fields for trace parsingSteven Rostedt
The array used by the ftrace stack events (caller[x]) causes issues with the parser. This adds code to handle the case, but it also assumes that the array is of type long. Note, this is a special case used (currently) only by the ftrace user and kernel stack records. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194358.124833639@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle trace parsing of < and >Steven Rostedt
The code to handle the '<' and '>' ops was all in place, but they were not in the switch statement to consider them as valid ops. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194357.807434040@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Fix backslash processing on trace print formatsSteven Rostedt
The handling of backslashes was broken. It would stop parsing when encountering one. Also, '\n', '\t', '\r' and '\\' were not converted. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194357.521974680@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Handle print concatenations in event format fileSteven Rostedt
kmem_alloc ftrace event format had a string that was broken up by two tokens. "string 1" "string 2". This patch lets the parser be able to handle the concatenation. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194357.253818714@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15Merge branch 'linus' into perf/coreIngo Molnar
Merge reason: pick up tools/perf/ changes from upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-12perf tools: Fix const char type propagationRandy Dunlap
The following perf build warnings/errors in function argument types: builtin-sched.c:1894: warning: passing argument 1 of 'sort_dimension__add' discards qualifiers from pointer target type util/trace-event-parse.c:685: warning: passing argument 2 of 'read_expected' discards qualifiers from pointer target type util/trace-event-parse.c:741: warning: passing argument 4 of 'test_type_token' discards qualifiers from pointer target type util/trace-event-parse.c:706: warning: passing argument 2 of 'read_expected_item' discards qualifiers from pointer target type ... trigger because older GCC is not able to prove that sort_dimension__add() does not change the string. Some goes for test_type_token(). Fix this by improving type consistency. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091005131729.78444bfb.randy.dunlap@oracle.com> [ Also remove ugly type cast now unnecessary. ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Add string/dynamic cases to format_flagsTom Zanussi
Needed for distinguishing string fields in event stream processing. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: hch@infradead.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254809398-8078-4-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Add subsystem string to struct eventTom Zanussi
Needed to fully qualify event names for event stream processing. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: hch@infradead.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254809398-8078-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06tracing/events: Add 'signed' field to format filesTom Zanussi
The sign info used for filters in the kernel is also useful to applications that process the trace stream. Add it to the format files and make it available to userspace. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: hch@infradead.org Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254809398-8078-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Update eval_flag() flags array to match interrupt.hTom Zanussi
Add missing BLOCK_IOPOLL_SOFTIRQ entry. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254808849-7829-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-14perf tools: Implement counter output multiplexingIngo Molnar
Finish the -M/--multiplex option implementation: - separate it out from group_fd - correctly set it via the ioctl and dont mmap counters that are multiplexed - modify the perf record event loop to deal with buffer-less counters. - remove the -g option from perf sched record - account for unordered events in perf sched latency - (add -f to perf sched record to ease measurements) - skip idle threads (pid==0) in latency output The result is better latency output by 'perf sched latency': ----------------------------------------------------------------------------------- Task | Runtime ms | Switches | Average delay ms | Maximum delay ms | ----------------------------------------------------------------------------------- ksoftirqd/8 | 0.071 ms | 2 | avg: 0.458 ms | max: 0.913 ms | at-spi-registry | 0.609 ms | 19 | avg: 0.013 ms | max: 0.023 ms | perf | 3.316 ms | 16 | avg: 0.013 ms | max: 0.054 ms | Xorg | 0.392 ms | 19 | avg: 0.011 ms | max: 0.018 ms | sleep | 0.537 ms | 2 | avg: 0.009 ms | max: 0.009 ms | ----------------------------------------------------------------------------------- TOTAL: | 4.925 ms | 58 | --------------------------------------------- Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-13perf sched: Fix bad event alignmentFrederic Weisbecker
perf sched raises the following error when it meets a sched switch event: perf: builtin-sched.c:286: register_pid: Assertion `!(pid >= 65536)' failed. Abandon Currently in x86-64, the sched switch events have a hole in the middle of the structure: u16 common_type; u8 common_flags; u8 common_preempt_count; u32 common_pid; u32 common_tgid; char prev_comm[16]; u32 prev_pid; u32 prev_prio; <--- there u64 prev_state; char next_comm[16]; u32 next_pid; u32 next_prio; Gcc inserts a 4 bytes hole there for prev_state to be u64 aligned. And the events are exported to userspace with this hole. But in userspace, from perf sched, we fetch it using a structure that has a new field in the beginning: u32 size. This is because our trace is exported with its size as a field. But now that we have this new field, the hole in the middle disappears because it makes prev_state becoming well aligned. And since we are using a pointer to the raw trace using this struct, instead of reading prev_state, we are reading the hole. We could fix it by keeping the size seperate from the struct but actually there a lot of other potential problems: some fields may be saved as long in a 64 bits system and later read as long in a 32 bits system. Also this direct cast doesn't care about the endianness differences between the host traced machine and the machine in which we do the post processing. So instead of using such dangerous direct casts, fetch the values using the trace parsing API that already takes care of all these problems. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-13perf sched: Import schedbench.cIngo Molnar
Import the schedbench.c tool that i wrote some time ago to simulate scheduler behavior but never finished. It's a good basis for perf sched nevertheless. Most of its guts are not hooked up to the perf event loop yet - that will be done in the patches to come. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-03perf trace: Print out in nanosecondsIngo Molnar
Print out more accurate timestamps - usecs does not cut it anymore on fast enough boxes ;-) Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-02perf tools: Work around strict aliasing related warningsIngo Molnar
Older versions of GCC are rather stupid about strict aliasing: util/trace-event-parse.c: In function 'parse_cmdlines': util/trace-event-parse.c:93: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c: In function 'parse_proc_kallsyms': util/trace-event-parse.c:155: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c:157: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c:158: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c: In function 'parse_ftrace_printk': util/trace-event-parse.c:294: warning: dereferencing type-punned pointer will break strict-aliasing rules util/trace-event-parse.c:295: warning: dereferencing type-punned pointer will break strict-aliasing rules make: *** [util/trace-event-parse.o] Error 1 Make it clear to GCC that we intend with those pointers, by passing them through via an explicit (void *) cast. We might want to add -fno-strict-aliasing as well, like the kernel itself does. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-31perf tools: Complete support for dynamic stringsFrederic Weisbecker
Complete support for __str_loc type strings of ftrace events which have dynamic offsets values set for each of them inside their sammples. Before: geany-5759 [000] 0.000000: lock_release: name geany-5759 [000] 0.000000: lock_release: name geany-5759 [000] 0.000000: lock_release: name kondemand/0-362 [000] 0.000000: lock_release: name pdflush-421 [000] 0.000000: lock_release: name After: geany-5759 [000] 0.000000: lock_release: &u->lock geany-5759 [000] 0.000000: lock_release: key geany-5759 [000] 0.000000: lock_release: &group->notification_mutex kondemand/0-362 [000] 0.000000: lock_release: &rq->lock pdflush-421 [000] 0.000000: lock_release: &rq->lock Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1251693921-6579-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org>
2009-08-28perf tools: Fix missing string field printing in perf traceFrederic Weisbecker
Some string fields are not printed because of a missing printf in the post-processing. Before: perf-10070 [000] 0.000000: sched_switch: task :10070 [120] (R) ==> :5720 [120] geany-5720 [000] 0.000000: sched_switch: task :5720 [120] (S) ==> :10070 [120] perf-10070 [000] 0.000000: sched_switch: task :10070 [120] (R) ==> :5720 [120] geany-5720 [000] 0.000000: sched_switch: task :5720 [120] (S) ==> :10070 [120] <idle>-0 [000] 0.000000: sched_switch: task :0 [140] (R) ==> :361 [115] After: perf-10070 [000] 0.000000: sched_switch: task perf:10070 [120] (R) ==> geany:5720 [120] geany-5720 [000] 0.000000: sched_switch: task geany:5720 [120] (S) ==> perf:10070 [120] perf-10070 [000] 0.000000: sched_switch: task perf:10070 [120] (R) ==> geany:5720 [120] geany-5720 [000] 0.000000: sched_switch: task geany:5720 [120] (S) ==> perf:10070 [120] <idle>-0 [000] 0.000000: sched_switch: task swapper:0 [140] (R) ==> kondemand/1:361 [115] Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1251427567-10551-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-28perf tools: Only save the event formats we needFrederic Weisbecker
While opening a trace event counter, every events are saved in the trace.info file. But we only want to save the specifications of the events we are using. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1251421798-9101-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-18perf tools: Make trace event format parser aware of cast to pointersFrederic Weisbecker
The ftrace event format parser handles the usual casts but not the cast to pointers. Such casts have been introduced recently with the module trace events and raise the following parsing error: Fatal: bad op token ) This is because it considers the "*" character as a binary operator. Make it then aware of casts to pointers. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1250543271-8383-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17perf tools: Add trace event information parserSteven Rostedt
Add util/trace-event-parse.c which provides the handlers to parse the ftrace events info from the stream and handles the ftrace perf samples event printing. This file is a rename of the parse-events.c file from the trace-cmd tools, written by Steven Rostedt and Josh Triplett, originated from the git tree: git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/trace-cmd.git This is a perf tools integration. [ fweisbec@gmail.com: various changes for perf tools integration. ] Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Clark Williams <williams@redhat.com> Cc: Jon Masters <jonathan@jonmasters.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Christoph Hellwig <hch@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Anton Blanchard <anton@samba.org> LKML-Reference: <1250518688-7207-3-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
