path: root/tools/perf/util/symbol.c
2009-09-23perf tools: Fix module symbol loading bugMike Galbraith
Avi Kivity reported 'perf annotate' failures with modules, the requested function was not annotated. If there are no modules currently loaded, or the last module scanned is not loaded, dso__load_modules() steps on the value from dso__load_vmlinux(), so we happily load the kallsyms symbols on top of what we've already loaded. Fix that such that the total count of symbols loaded is returned. Should module symbol load fail after parsing of vmlinux, is's a hard failure, so do not silently fall-back to kallsyms. Reported-by: Avi Kivity <avi@redhat.com> Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: rostedt@goodmis.org Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> LKML-Reference: <1253697658.11461.36.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-16perf tools: Librarize trace_event() helperFrederic Weisbecker
Librarize trace_event() helper so that perf trace can use it too. Also clean up the debug.h includes a bit. It's not good to have it included in perf.h because it doesn't make it flexible against other headers it may need (headers that can also depend on perf.h and then create a recursive header dependency). Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <1250453149-664-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-16perf: Enable more compiler warningsIngo Molnar
Related to a shadowed variable bug fix Valdis Kletnieks noticed that perf does not get built with -Wshadow, which could have helped us avoid the bug. So enable -Wshadow and also enable the following warnings on perf builds, in addition to the already enabled -Wall -Wextra -std=gnu99 warnings: -Wcast-align -Wformat=2 -Wshadow -Winit-self -Wpacked -Wredundant-decls -Wstack-protector -Wstrict-aliasing=3 -Wswitch-default -Wswitch-enum -Wno-system-headers -Wundef -Wvolatile-register-var -Wwrite-strings -Wbad-function-cast -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wold-style-definition -Wstrict-prototypes -Wdeclaration-after-statement And change/fix the perf code to build cleanly under GCC 4.3.2. The list of warnings enablement is rather arbitrary: it's based on my (quick) reading of the GCC manpages and trying them on perf. I categorized the warnings based on individually enabling them and looking whether they trigger something in the perf build. If i liked those warnings (i.e. if they trigger for something that arguably could be improved) i enabled the warning. If the warnings seemed to come from language laywers spamming the build with tons of nuisance warnings i generally kept them off. Most of the sign conversion related warnings were in this category. (A second patch enabling some of the sign warnings might be welcome - sign bugs can be nasty.) I also kept warnings that seem to make sense from their manpage description and which produced no actual warnings on our code base. These warnings might still be turned off if they end up being a nuisance. I also left out a few warnings that are not supported in older compilers. [ Note that these changes might break the build on older compilers i did not test, or on non-x86 architectures that produce different warnings, so more testing would be welcome. ] Reported-by: Valdis.Kletnieks@vt.edu Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-15Merge branch 'perfcounters/urgent' into perfcounters/coreIngo Molnar
Conflicts: kernel/perf_counter.c Merge reason: update to latest upstream (-rc6) and resolve the conflict with urgent fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-12perf tools: Fix dso__new handle() to handle deleted DSOsArnaldo Carvalho de Melo
It is better than showing the map addr, this way at least we know that we can't get the symtabs because the DSO was deleted (system update) while an app still used such DSO. Yeah, don't do that, but if you do, you'll figure it out quicker this way. [acme@doppio linux-2.6-tip]$ perf report | head -15 # Samples: 3796 # # Overhead Command Shared Object Symbol # ........ ....... ................................................................... ...... # 23.55% pidgin /lib64/libglib-2.0.so.0.2000.4.#prelink#.Pd98lu (deleted) [.] 0x00000000038844 21.55% pidgin /lib64/libpthread-2.10.1.so.#prelink#.AFwK8Q (deleted) [.] 0x0000000000a42d 10.85% pidgin [kernel] [.] vread_hpet 7.85% pidgin /lib64/libgobject-2.0.so.0.2000.4.#prelink#.o1vpU7 (deleted) [.] 0x00000000014de8 3.35% pidgin /lib64/libc-2.10.1.so (deleted) [.] 0x0000000007a875 3.19% pidgin /lib64/libdbus-1.so.3.4.0.#prelink#.6mwgZP (deleted) [.] 0x0000000001d254 3.06% pidgin /usr/lib64/libgtk-x11-2.0.so.0.1600.5.#prelink#.511hAl (deleted) [.] 0x000000002334e7 2.90% pidgin /usr/lib64/libgdk-x11-2.0.so.0.1600.5.#prelink#.5qlMo1 (deleted) [.] 0x00000000037b2d 1.84% pidgin [kernel] [k] do_sys_poll 1.45% pidgin /usr/lib64/libX11.so.6.2.0.#prelink#.iR59Rx (deleted) [.] 0x0000000004c751 [acme@doppio linux-2.6-tip]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Luis Claudio R. Gonçalves <lclaudio@redhat.com> Cc: Clark Williams <williams@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090811200436.GA3478@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-12perf tools: Fix fallback to cplus_demangle() when bfd_demangle() is not ↵Arnaldo Carvalho de Melo
available In old binutils we can't access bfd_demangle(), use cplus_demangle() just like oprofile. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Luis Claudio R. Gonçalves <lclaudio@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090811192211.GG18061@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-12perf tools: Factorize high level dso helpersFrederic Weisbecker
Factorize multiple definitions of high level dso helpers into the symbol source file. The side effect is a general export of the verbose and eprintf debugging helpers into a new file dedicated to debugging purposes. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Brice Goglin <Brice.Goglin@inria.fr>
2009-08-09perf report: Add debug help for the finding of symbol bugs - show the symtab ↵Arnaldo Carvalho de Melo
origin (DSO, build-id, kernel, etc) Used with perf report --verbose: [acme@doppio linux-2.6-tip]$ perf report -v | head -16 5.17% firefox /usr/lib64/xulrunner-1.9.1/libxul.so 0x00000000005d8eee f [.] imgContainer::DrawFrameTo(gfxIImageFrame*, gfxIImageFrame*, nsRect&) 2.56% firefox /lib64/libpthread-2.10.1.so 0x0000000000008e02 d [.] __pthread_mutex_lock_internal 1.94% firefox /usr/lib64/xulrunner-1.9.1/libxul.so 0x0000000000d0af8f f [.] SearchTable 1.75% firefox [kernel] 0xffffffffff60013b k [.] vread_hpet 1.63% firefox /lib64/libpthread-2.10.1.so 0x000000000000a404 d [.] __pthread_mutex_unlock 1.47% firefox /usr/lib64/xulrunner-1.9.1/libmozjs.so 0x00000000000482ea f [.] js_Interpret 1.42% firefox /usr/lib64/xulrunner-1.9.1/libmozjs.so 0x000000000003eda3 f [.] JS_CallTracer 1.24% firefox [kernel] 0xffffffff8102ca4a k [k] read_hpet 1.16% firefox [kernel] 0xffffffff810f3dd4 k [k] fget_light 1.11% firefox /usr/lib64/xulrunner-1.9.1/libmozjs.so 0x00000000000567ff f [.] js_TraceObject 0.98% firefox /usr/lib64/firefox-3.5.2/firefox 0x000000000000dd23 b [.] arena_ralloc [acme@doppio linux-2.6-tip]$ The new field is just after the symbol address. To help in figuring out symbol resolution bugs. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-06perf symbol: Fix symbol parsing in certain cases: use the build-id as a symlinkArnaldo Carvalho de Melo
In some cases distros have binaries and debuginfo in weird places: [root@doppio tuna]# ls -la /usr/lib64/{xulrunner-1.9.1/xulrunner-stub,firefox-3.5.2/firefox} -rwxr-xr-x 1 root root 90024 2009-08-03 19:45 /usr/lib64/firefox-3.5.2/firefox -rwxr-xr-x 1 root root 90024 2009-08-03 18:23 /usr/lib64/xulrunner-1.9.1/xulrunner-stub [root@doppio tuna]# sha1sum /usr/lib64/{xulrunner-1.9.1/xulrunner-stub,firefox-3.5.2/firefox} 19a858077d263d5de22c9c5da250d3e4396ae739 /usr/lib64/xulrunner-1.9.1/xulrunner-stub 19a858077d263d5de22c9c5da250d3e4396ae739 /usr/lib64/firefox-3.5.2/firefox [root@doppio tuna]# rpm -qf /usr/lib64/{xulrunner-1.9.1/xulrunner-stub,firefox-3.5.2/firefox} xulrunner-1.9.1.2-1.fc11.x86_64 firefox-3.5.2-2.fc11.x86_64 [root@doppio tuna]# ls -la /usr/lib/debug/{usr/lib64/xulrunner-1.9.1/xulrunner-stub,usr/lib64/firefox-3.5.2/firefox}.debug ls: cannot access /usr/lib/debug/usr/lib64/firefox-3.5.2/firefox.debug: No such file or directory -rwxr-xr-x 1 root root 403608 2009-08-03 18:22 /usr/lib/debug/usr/lib64/xulrunner-1.9.1/xulrunner-stub.debug Seemingly we don't have a .symtab when we actually can find it if we use the .note.gnu.build-id ELF section put in place by some distros. Use it and find the symbols we need. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-05perf: Auto-detect libbfdPeter Zijlstra
Since the C++ demangling isn't needed for everybody and bfd/iberty aren't widely/easily available on all machines, make it optional. It also allows you to forcefully disable demangling by using NO_DEMANGLE=1 and otherwise tries to detect libbfd/libiberty combinations that result in a compiling demangler. Reported-by: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> LKML-Reference: <20090801082048.GX12579@kernel.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-02perf tools: Fix faulty checkStoyan Gaydarov
This patch fixes a spelling error that has resulted from copy and pasting. The location of the error was found using a semantic patch but the semantic patch was not trying to find these errors. After looking things over it seemed logical that this change was needed. Please review it and then include the patch if it is in fact the correct change. Signed-off-by: Stoyan Gaydarov <sgayda2@uiuc.edu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1248949529-20891-1-git-send-email-sgayda2@uiuc.edu> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-22perf_counter tools: Fix vmlinux symbol generation breakageMike Galbraith
vmlinux meets the criteria for symbol adjustment, which breaks vmlinux generated symbols. Fix this by exempting vmlinux. This is a bit fragile in that someone could change the kernel dso's name, but currently that name is also hardwired. Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Ingo Molnar <mingo@elte.hu> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1248091298.18702.18.camel@marge.simson.net>
2009-07-22perf symbol: C++ demanglingArnaldo Carvalho de Melo
[acme@doppio ~]$ perf report -s comm,dso,symbol -C firefox -d /usr/lib64/xulrunner-1.9.1/libxul.so | grep :: | head 2.21% [.] nsDeque::Push(void*) 1.78% [.] GraphWalker::DoWalk(nsDeque&) 1.30% [.] GCGraphBuilder::AddNode(void*, nsCycleCollectionParticipant*) 1.27% [.] XPCWrappedNative::CallMethod(XPCCallContext&, XPCWrappedNative::CallMode) 1.18% [.] imgContainer::DrawFrameTo(gfxIImageFrame*, gfxIImageFrame*, nsRect&) 1.13% [.] nsDeque::PopFront() 1.11% [.] nsGlobalWindow::RunTimeout(nsTimeout*) 0.97% [.] nsXPConnect::Traverse(void*, nsCycleCollectionTraversalCallback&) 0.95% [.] nsJSEventListener::cycleCollection::Traverse(void*, nsCycleCollectionTraversalCallback&) 0.95% [.] nsCOMPtr_base::~nsCOMPtr_base() [acme@doppio ~]$ Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Vegard Nossum <vegard.nossum@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Suggested-by: Clark Williams <williams@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20090720171412.GB10410@ghostprotocols.net>
2009-07-11perf_counter tools: PLT info is stripped in -debuginfo packagesArnaldo Carvalho de Melo
So we need to get the richer .symtab from the debuginfo packages but the PLT info from the original DSO where we have just the leaner .dynsym symtab. Example: | [acme@doppio pahole]$ perf report --sort comm,dso,symbol > before | [acme@doppio pahole]$ perf report --sort comm,dso,symbol > after | [acme@doppio pahole]$ diff -U1 before after | --- before 2009-07-11 11:04:22.688595741 -0300 | +++ after 2009-07-11 11:04:33.380595676 -0300 | @@ -80,3 +80,2 @@ | 0.07% pahole ./build/pahole [.] pahole_stealer | - 0.06% pahole /usr/lib64/libdw-0.141.so [.] 0x00000000007140 | 0.06% pahole /usr/lib64/libdw-0.141.so [.] __libdw_getabbrev | @@ -91,2 +90,3 @@ | 0.06% pahole [kernel] [k] free_hot_cold_page | + 0.06% pahole /usr/lib64/libdw-0.141.so [.] tfind@plt | 0.05% pahole ./build/libdwarves.so.1.0.0 [.] ftype__add_parameter | @@ -242,2 +242,3 @@ | 0.01% pahole [kernel] [k] account_group_user_time | + 0.01% pahole /usr/lib64/libdw-0.141.so [.] strlen@plt | 0.01% pahole ./build/pahole [.] strcmp@plt | [acme@doppio pahole]$ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1247325517-12272-4-git-send-email-acme@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-11perf report: Adjust column width to the values sampledArnaldo Carvalho de Melo
Auto-adjust column width of perf report output to the longest occuring string length. Example: [acme@doppio pahole]$ perf report --sort comm,dso,symbol | head -13 12.79% pahole /usr/lib64/libdw-0.141.so [.] __libdw_find_attr 8.90% pahole /lib64/libc-2.10.1.so [.] _int_malloc 8.68% pahole /usr/lib64/libdw-0.141.so [.] __libdw_form_val_len 8.15% pahole /lib64/libc-2.10.1.so [.] __GI_strcmp 6.80% pahole /lib64/libc-2.10.1.so [.] __tsearch 5.54% pahole ./build/libdwarves.so.1.0.0 [.] tag__recode_dwarf_type [acme@doppio pahole]$ [acme@doppio pahole]$ perf report --sort comm,dso,symbol -d /lib64/libc-2.10.1.so | head -10 21.92% pahole /lib64/libc-2.10.1.so [.] _int_malloc 20.08% pahole /lib64/libc-2.10.1.so [.] __GI_strcmp 16.75% pahole /lib64/libc-2.10.1.so [.] __tsearch [acme@doppio pahole]$ Also add these extra options to control the new behaviour: -w, --field-width Force each column width to the provided list, for large terminal readability. -t, --field-separator: Use a special separator character and don't pad with spaces, replacing all occurances of this separator in symbol names (and other output) with a '.' character, that thus it's the only non valid separator. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20090711014728.GH3452@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-03perf_counter tools: Adjust symbols in ET_EXEC files tooArnaldo Carvalho de Melo
Ingo Molnar wrote: > i just bisected a 'perf report' bug that would cause us to not > resolve all user-space symbols in a 'git gc' run to: > > f5812a7a336fb952d819e4427b9a2dce02368e82 is first bad commit > commit f5812a7a336fb952d819e4427b9a2dce02368e82 > Author: Arnaldo Carvalho de Melo <acme@redhat.com> > Date: Tue Jun 30 11:43:17 2009 -0300 > > perf_counter tools: Adjust only prelinked symbol's addresses Rename ->prelinked to ->adjust_symbols and making what was done only for prelinked libraries also to ET_EXEC binaries, such as /usr/bin/git: [acme@doppio pahole]$ readelf -h /usr/bin/git | grep Type Type: EXEC (Executable file) [acme@doppio pahole]$ And after installing the 'git-debuginfo' package, I get correct results: [acme@doppio linux-2.6-tip]$ perf report --sort comm,dso,symbol -d /usr/bin/git | head -20 # # (1139614 samples) # # Overhead Command Shared Object Symbol # ........ ................ ......................... ...... # 34.98% git /usr/bin/git [.] send_sideband 33.39% git /usr/bin/git [.] enter_repo 6.81% git /usr/bin/git [.] diff_opt_parse 4.95% git /usr/bin/git [.] is_repository_shallow 3.24% git /usr/bin/git [.] odb_mkstemp 1.39% git /usr/bin/git [.] output 1.34% git /usr/bin/git [.] xmmap 1.25% git /usr/bin/git [.] receive_pack_config 1.16% git /usr/bin/git [.] git_pathdup 0.90% git /usr/bin/git [.] read_object_with_reference 0.86% git /usr/bin/git [.] show_patch_diff 0.85% git /usr/bin/git 0x00000000095e2e 0.69% git /usr/bin/git [.] display [acme@doppio linux-2.6-tip]$ I'll check what are the last cases where we can't resolve symbols, like this 0x00000000095e2e later. And I guess this will fix the problems Mike were seeing too: [acme@doppio linux-2.6-tip]$ readelf -h ../build/perf/vmlinux | grep Type Type: EXEC (Executable file) [acme@doppio linux-2.6-tip]$ Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-02perf_counter tools: Connect module support infrastructure to symbol loading ↵Mike Galbraith
infrastructure Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1246514916.13293.46.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-02perf_counter tools: Make symbol loading consistently return number of loaded ↵Mike Galbraith
symbols perf_counter tools: Make symbol loading consistently return number of loaded symbols. Signed-off-by: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1246514758.13293.42.camel@marge.simson.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-30perf_counter tools: Adjust only prelinked symbol's addressesArnaldo Carvalho de Melo
I.e. we can't handle these two kinds of files in the same way: 1) prelinked system library: [acme@doppio pahole]$ readelf -s /usr/lib64/libdw-0.141.so | egrep 'FUNC.+GLOBAL.+dwfl_report_elf' 278: 00000030450105a0 261 FUNC GLOBAL DEFAULT 12 dwfl_report_elf@@ELFUTILS_0.122 2) not prelinked library with debug information from a -debuginfo package: [acme@doppio pahole]$ readelf -s /usr/lib/debug/usr/lib64/libdw-0.141.so.debug | egrep 'FUNC.+GLOBAL.+dwfl_report_elf' 629: 00000000000105a0 261 FUNC GLOBAL DEFAULT 12 dwfl_report_elf [acme@doppio pahole]$ Now the numbers I got for a pahole perf run are in line with the numbers I get from oprofile. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <20090630144317.GB12663@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-22perf report: Output more symbol related debug dataPeter Zijlstra
Print more symbol relocation related info under -vv. Signed-off-by: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-21perf_counter tools: Fix vmlinux fallback when running on a different kernelIngo Molnar
Lucas De Marchi reported that perf report and perf annotate displays mismatching profile if a perf.data is analyzed on an older kernel - even if the correct vmlinux is specified via the -k option. The reason is the fallback path in util/symbol.c:dso__load_kernel(): int dso__load_kernel(struct dso *self, const char *vmlinux, symbol_filter_t filter, int verbose) { int err = -1; if (vmlinux) err = dso__load_vmlinux(self, vmlinux, filter, verbose); if (err) err = dso__load_kallsyms(self, filter, verbose); return err; } dso__load_vmlinux() returns negative on error, but on success it returns the number of symbols loaded - which confuses the function to load the kallsyms. This is normally harmless, as reporting is usually performed on the same kernel that is analyzed - but if there's a mismatch then we load the wrong kallsyms and create a non-sensical symbol tree. The fix is to only fall back to kallsyms on errors. Reported-by: Lucas De Marchi <lucas.de.marchi@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-19perf_counter tools: Define and use our own u64, s64 etc. definitionsPaul Mackerras
On 64-bit powerpc, __u64 is defined to be unsigned long rather than unsigned long long. This causes compiler warnings every time we print a __u64 value with %Lx. Rather than changing __u64, we define our own u64 to be unsigned long long on all architectures, and similarly s64 as signed long long. For consistency we also define u32, s32, u16, s16, u8 and s8. These definitions are put in a new header, types.h, because these definitions are needed in util/string.h and util/symbol.h. The main change here is the mechanical change of __[us]{64,32,16,8} to remove the "__". The other changes are: * Create types.h * Include types.h in perf.h, util/string.h and util/symbol.h * Add types.h to the LIB_H definition in Makefile * Added (u64) casts in process_overflow_event() and print_sym_table() to kill two remaining warnings. Signed-off-by: Paul Mackerras <paulus@samba.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: benh@kernel.crashing.org LKML-Reference: <19003.33494.495844.956580@cargo.ozlabs.ibm.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-11perf_counter tools: Clean up u64 usageIngo Molnar
A build error slipped in: builtin-report.c: In function ‘hist_entry__fprintf’: builtin-report.c:711: error: format ‘%12d’ expects type ‘int’, but argument 3 has type ‘uint64_t’ Because we got a bit sloppy with those types. uint64_t really sucks, because there's no printf format for it. So standardize on __u64 instead - for all types that go to or come from the ABI (which is __u64), or for values that need to be large enough even on 32-bit. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-08perf report: Add support for profiling JIT generated codePekka Enberg
This patch adds support for profiling JIT generated code to 'perf report'. A JIT compiler is required to generate a "/tmp/perf-$PID.map" symbols map that is parsed when looking and displaying symbols. Thanks to Peter Zijlstra for his help with this patch! Example "perf report" output with the Jato JIT: # # (40311 samples) # # Overhead Command Shared Object Symbol # ........ ................ ......................... ...... # 97.80% jato /tmp/perf-11915.map [.] Fibonacci.fib(I)I 0.56% jato 00000000b7fa023b 0x000000b7fa023b 0.45% jato /tmp/perf-11915.map [.] Fibonacci.main([Ljava/lang/String;)V 0.38% jato [kernel] [k] get_page_from_freelist 0.06% jato [kernel] [k] kunmap_atomic 0.05% jato ./jato [.] utf8Hash 0.04% jato ./jato [.] executeJava 0.04% jato ./jato [.] defineClass Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: a.p.zijlstra@chello.nl Cc: acme@redhat.com LKML-Reference: <Pine.LNX.4.64.0906082111590.12407@melkki.cs.Helsinki.FI> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-06perf_counter tools: Initialize a stack variable before useArjan van de Ven
the "perf report" utility crashed in some circumstances because the "sym" stack variable was not initialized before used (as also proven by valgrind). With this fix both the crash goes away and valgrind no longer complains. Signed-off-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-06perf_counter tools: Warning fixes on 32-bitArjan van de Ven
2009-06-06perf_counter tools: Move from Documentation/perf_counter/ to tools/perf/Ingo Molnar
Several people have suggested that 'perf' has become a full-fledged tool that should be moved out of Documentation/. Move it to the (new) tools/ directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
