path: root/tools/perf/util/symbol.c
2011-10-21perf symbols: Increase symbol KSYM_NAME_LEN sizeRicardo Ribalda Delgado
Fglrx propietary driver has symbol names over 128 chars (:S). This breaks the function kallsyms__parse. This fix increases the size of KSYM_NAME_LEN, so kallsyms__parse can work on such kernels. The only counterparty, is that such function requires 128 more bytes to work. Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Anton Blanchard <anton@samba.org> Cc: David Ahern <daahern@cisco.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1319096606-11568-1-git-send-email-ricardo.ribalda@gmail.com Signed-off-by: Ricardo Ribalda Delgado <ricardo.ribalda@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf tools: Make --no-asm-raw the defaultArnaldo Carvalho de Melo
And add the annotation output knobs to all the tools that have integrated annotation (top, report). Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-gnlob67mke6sji2kf4nstp7m@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-06Merge commit 'v3.1-rc9' into perf/coreIngo Molnar
Merge reason: pick up latest fixes. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-09-23perf symbols: Fix issue with binaries using 16-bytes buildids (v2)Stephane Eranian
Buildid can vary in size. According to the man page of ld, buildid can be 160 bits (sha1) or 128 bits (md5, uuid). Perf assumes buildid size of 20 bytes (160 bits) regardless. When dealing with md5 buildids, it would thus read more than needed and that would cause mismatches and samples without symbols. This patch fixes this by taking into account the actual buildid size as encoded int he section header. The leftover bytes are also cleared. This second version fixes a minor issue with the memset() base position. Cc: David S. Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@gmail.com> Link: http://lkml.kernel.org/r/4cc1af3c.8ee7d80a.5a28.ffff868e@mx.google.com Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Add some heuristics for choosing the best duplicate symbolAnton Blanchard
Try and pick the best symbol based on a few heuristics: - Prefer a non weak symbol over a weak one - Prefer a global symbol over a non global one - Prefer a symbol with less underscores (idea taken from kallsyms.c) - If all else fails, choose the symbol with the longest name Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110824065243.161953371@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Preserve symbol scope when parsing /proc/kallsymsAnton Blanchard
kallsyms__parse capitalises the symbol type, so every symbol is marked global. Remove this and fix symbol_type__is_a to handle both local and global symbols. Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110824065243.077125989@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: /proc/kallsyms does not sort module symbolsAnton Blanchard
kallsyms__parse assumes that /proc/kallsyms is sorted and sets the end of the previous symbol to the start of the current one. Unfortunately module symbols are not sorted, eg: ffffffffa0081f30 t e1000_clean_rx_irq [e1000e] ffffffffa00817a0 t e1000_alloc_rx_buffers [e1000e] Some symbols end up with a negative length and others have a length larger than they should. This results in confusing perf output. We already have a function to fixup the end of zero length symbols so use that instead. Cc: Eric B Munson <emunson@mgebm.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20110824065242.969681349@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-09-23perf symbols: Fix ppc64 SEGV in dso__load_sym with debuginfo filesAnton Blanchard
64bit PowerPC debuginfo files have an empty function descriptor section. I hit a SEGV when perf tried to use this section for symbol resolution. To fix this we need to check the section is valid and we can do this by checking for type SHT_PROGBITS. Cc: <stable@kernel.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Eric B Munson <emunson@mgebm.net> Link: http://lkml.kernel.org/r/20110824065242.895239970@samba.org Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-18perf annotate: Make output more readableStephane Eranian
This patch adds two new options to perf annotate: - --no-asm-raw : Do not display raw instruction encodings - --no-source : Do not interleave source code with assembly code We believe those options make the output of annotate more readable. Systematically displaying source can make it hard to follow code and especially optimized code. Raw encodings are not useful in most cases. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20110517153207.GA9834@quad Signed-off-by: Stephane Eranian <eranian@google.com> [committer note: Use the 'no-' option inverting logic] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-12perf: fix temporary file ownership checkVasiliy Kulikov
A file in /tmp/ might be a symlink, so lstat() should be used instead of stat(). Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20110811205537.GA22864@albatros Signed-off-by: Vasiliy Kulikov <segoon@openwall.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-11perf report: Use properly build_id kernel binariesJiri Olsa
If we bring the recorded perf data together with kernel binary from another machine using: on server A: perf archive on server B: tar xjvf perf.data.tar.bz2 -C ~/.debug the build_id kernel dso is not properly recognized during the "perf report" command on server B. The reason is, that build_id dsos are added during the session initialization, while the kernel maps are created during the sample event processing. The machine__create_kernel_maps functions ends up creating new dso object for kernel, but it does not check if we already have one added by build_id processing. Also the build_id reading ABI quirk added in commit: - commit b25114817a73bbd2b84ce9dba02ee1ef8989a947 perf build-id: Add quirk to deal with perf.data file format breakage populates the "struct build_id_event::pid" with 0, which is later interpreted as DEFAULT_GUEST_KERNEL_ID. This is not always correct, so it's better to guess the pid value based on the "struct build_id_event::header::misc" value. - Tested with data generated on x86 kernel version v2.6.34 and reported back on x86_64 current kernel. - Not tested for guest kernel case. Note the problem stays for PERF_RECORD_MMAP events recorded by perf that does not use proper pid (HOST_KERNEL_ID/DEFAULT_GUEST_KERNEL_ID). They are misinterpreted within the current perf code. Probably there's not much we can do about that. Cc: Avi Kivity <avi@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Link: http://lkml.kernel.org/r/20110601194346.GB1934@jolsa.brq.redhat.com Signed-off-by: Jiri Olsa <jolsa@redhat.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-08-09perf symbols: Check '/tmp/perf-' symbol file ownershipPekka Enberg
The external symbol files are generated by JIT compilers, for example, but we need to make sure they're ours before injecting them to 'perf report'. Requested-by: Ingo Molnar <mingo@elte.hu> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1312919658-17158-1-git-send-email-penberg@kernel.org Signed-off-by: Pekka Enberg <penberg@kernel.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-05-26perf symbols: Handle /proc/sys/kernel/kptr_restrictArnaldo Carvalho de Melo
Perf uses /proc/modules to figure out where kernel modules are loaded. With the advent of kptr_restrict, non root users get zeroes for all module start addresses. So check if kptr_restrict is non zero and don't generate the syntethic PERF_RECORD_MMAP events for them. Warn the user about it in perf record and in perf report. In perf report the reference relocation symbol being zero means that kptr_restrict was set, thus /proc/kallsyms has only zeroed addresses, so don't use it to fixup symbol addresses when using a valid kallsyms (in the buildid cache) or vmlinux (in the vmlinux path) build-id located automatically or specified by the user. Provide an explanation about it in 'perf report' if kernel samples were taken, checking if a suitable vmlinux or kallsyms was found/specified. Restricted /proc/kallsyms don't go to the buildid cache anymore. Example: [acme@emilia ~]$ perf record -F 100000 sleep 1 WARNING: Kernel address maps (/proc/{kallsyms,modules}) are restricted, check /proc/sys/kernel/kptr_restrict. Samples in kernel functions may not be resolved if a suitable vmlinux file is not found in the buildid cache or in the vmlinux path. Samples in kernel modules won't be resolved at all. If some relocation was applied (e.g. kexec) symbols may be misresolved even with a suitable vmlinux or kallsyms file. [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.005 MB perf.data (~231 samples) ] [acme@emilia ~]$ [acme@emilia ~]$ perf report --stdio Kernel address maps (/proc/{kallsyms,modules}) were restricted, check /proc/sys/kernel/kptr_restrict before running 'perf record'. If some relocation was applied (e.g. kexec) symbols may be misresolved. Samples in kernel modules can't be resolved as well. # Events: 13 cycles # # Overhead Command Shared Object Symbol # ........ ....... ................. ..................... # 20.24% sleep [kernel.kallsyms] [k] page_fault 20.04% sleep [kernel.kallsyms] [k] filemap_fault 19.78% sleep [kernel.kallsyms] [k] __lru_cache_add 19.69% sleep ld-2.12.so [.] memcpy 14.71% sleep [kernel.kallsyms] [k] dput 4.70% sleep [kernel.kallsyms] [k] flush_signal_handlers 0.73% sleep [kernel.kallsyms] [k] perf_event_comm 0.11% sleep [kernel.kallsyms] [k] native_write_msr_safe # # (For a higher level overview, try: perf report --sort comm,dso) # [acme@emilia ~]$ This is because it found a suitable vmlinux (build-id checked) in /lib/modules/2.6.39-rc7+/build/vmlinux (use -v in perf report to see the long file name). If we remove that file from the vmlinux path: [root@emilia ~]# mv /lib/modules/2.6.39-rc7+/build/vmlinux \ /lib/modules/2.6.39-rc7+/build/vmlinux.OFF [acme@emilia ~]$ perf report --stdio [kernel.kallsyms] with build id 57298cdbe0131f6871667ec0eaab4804dcf6f562 not found, continuing without symbols Kernel address maps (/proc/{kallsyms,modules}) were restricted, check /proc/sys/kernel/kptr_restrict before running 'perf record'. As no suitable kallsyms nor vmlinux was found, kernel samples can't be resolved. Samples in kernel modules can't be resolved as well. # Events: 13 cycles # # Overhead Command Shared Object Symbol # ........ ....... ................. ...... # 80.31% sleep [kernel.kallsyms] [k] 0xffffffff8103425a 19.69% sleep ld-2.12.so [.] memcpy # # (For a higher level overview, try: perf report --sort comm,dso) # [acme@emilia ~]$ Reported-by: Stephane Eranian <eranian@google.com> Suggested-by: David Miller <davem@davemloft.net> Cc: Dave Jones <davej@redhat.com> Cc: David Miller <davem@davemloft.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Kees Cook <kees.cook@canonical.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/n/tip-mt512joaxxbhhp1odop04yit@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-19perf symbols: Give more useful names to 'self' parametersArnaldo Carvalho de Melo
One more installment on an area that is mostly dormant. Suggested-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf symbols: Properly align symbol_conf.priv_sizeDavid S. Miller
If symbol_conf.priv_size is not a multiple of "sizeof(u64)" we'll bus error on sparc64 in symbol__new because the "struct symbol *" pointer is computed by adding symbol_conf.priv_size to the memory allocated. We cannot isolate the fix to symbol__new and symbol__delete since the private area is computed by subtracting the priv_size value from a "struct symbol" pointer, so then the private area can still be potentially unaligned. So, simply align the symbol_conf.priv_size value in symbol__init() Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110328.175849.112593455.davem@davemloft.net> Signed-off-by: David S. Miller <davem@davemloft.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-28perf symbols: Fix vsyscall symbol lookupAndrew Lutomirski
Perf can't currently trace into the vsyscall page. It looks like it was meant to work. Tested on 2.6.38 and today's -git. The bug is easy to reproduce. Compile this: int main() { int i; struct timespec t; for(i = 0; i < 10000000; i++) clock_gettime(CLOCK_MONOTONIC, &t); return 0; } and run it through perf record; perf report. The top entry shows "[unknown]" and you can't zoom in. It looks like there are two issues. The first is a that a test for user mode executing in kernel space is backwards. (That's the first hunk below). The second (I think) is that something's wrong with the code that generates lots of little struct dso objects for different sections -- when it runs on vmlinux it results in bogus long_name values which cause objdump to fail. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LPU-Reference: <AANLkTikxSw5+wJZUWNz++nL7mgivCh_Zf=2Kq6=f9Ce_@mail.gmail.com> Signed-off-by: Andy Lutomirski <luto@mit.edu> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf symbols: Look at .dynsym again if .symtab not foundArnaldo Carvalho de Melo
The original intent of the code was to repeat the search with want_symtab = 0. But as the code stands now, we never hit the "default" case of the switch statement. Which means we never repeat the search. Tested-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Reported-by: Arun Sharma <asharma@fb.com> Reported-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Dave Martin <dave.martin@linaro.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf symbols: Rename dso->origin to dso->symtab_typeArnaldo Carvalho de Melo
And the DSO__ORIG_ enum to SYMTAB__, to clarify that this is about from where the symtab was obtained. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-05perf hists: Remove needless global col lenght calcsArnaldo Carvalho de Melo
To support multiple events we need to do these calcs per 'struct hists' instance, and it turns out we already do that at: __hists__add_entry hists__inc_nr_entries hists__calc_col_len for all the unfiltered hist_entry instances we stash in the rb tree, so trow away the dead code. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-04Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: Pick up updates before queueing up dependent patches. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-02-28perf symbols: Fix vmlinux path when not using --symfsArnaldo Carvalho de Melo
The ec5761e cset introduced the symfs feature with a bug for loading vmlinux files that ended up causing this failure: [root@emilia v2.6.38-rc5+]# strace -e trace=open perf top --vmlinux ./vmlinux 2>&1 | tail -3 open("/./vmlinux", O_RDONLY) = -1 ENOENT (No such file or directory) ./vmlinux with build id b9266bf40e98dadb5d43a2f3e95d3c5d4aff46dc not found, continuing without symbols The ./vmlinux file can't be used [root@emilia v2.6.38-rc5+]# Remove the extra slash, just like is done in the DSO__ORIG_DSO handling in dso__load() and other parts of the ec5761e cset. Reported-by: Ingo Molnar <mingo@elte.hu> Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-07perf tool: Fix gcc 4.6.0 issuesKyle McMartin
GCC 4.6.0 in Fedora rawhide turned up some compile errors in tools/perf due to the -Werror=unused-but-set-variable flag. I've gone through and annotated some of the assignments that had side effects (ie: return value from a function) with the __used annotation, and in some cases, just removed unused code. In a few cases, we were assigning something useful, but not using it in later parts of the function. kyle@dreadnought:~/src% gcc --version gcc (GCC) 4.6.0 20110122 (Red Hat 4.6.0-0.3) Cc: Ingo Molnar <mingo@redhat.com> LKML-Reference: <20110124161304.GK27353@bombadil.infradead.org> Signed-off-by: Kyle McMartin <kyle@redhat.com> [ committer note: Fixed up the annotation fixes, as that code moved recently ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf tools: Fix 64 bit integer format stringsArnaldo Carvalho de Melo
Using %L[uxd] has issues in some architectures, like on ppc64. Fix it by making our 64 bit integers typedefs of stdint.h types and using PRI[ux]64 like, for instance, git does. Reported by Denis Kirjanov that provided a patch for one case, I went and changed all cases. Reported-by: Denis Kirjanov <dkirjanov@kernel.org> Tested-by: Denis Kirjanov <dkirjanov@kernel.org> LKML-Reference: <20110120093246.GA8031@hera.kernel.org> Cc: Denis Kirjanov <dkirjanov@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Pingtian Han <phan@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-21perf symbols: Fix annotation of thumb codeDr. David Alan Gilbert
In ARM's Thumb mode the bottom bit of the symbol address is set to mark the function as Thumb; the instructions are in reality 2 or 4 byte on 2 byte alignments, and when the +1 address is used in annotate it causes objdump to disassemble invalid instructions. The patch removes that bottom bit during symbol loading. Many thinks to Dave Martin for comments on an initial version of the patch. (For reference this corresponds to this bug https://bugs.launchpad.net/linux-linaro/+bug/677547 ) Cc: Ingo Molnar <mingo@elte.hu> Cc: Dave Martin <dave.martin@linaro.org> LKML-Reference: <20110121163922.GA31398@davesworkthinkpad> Signed-off-by: Dr. David Alan Gilbert <david.gilbert@linaro.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04Merge commit 'v2.6.37-rc8' into perf/coreIngo Molnar
Merge reason: pick up latest -rc. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-22perf symbols: Improve kallsyms symbol end addr calculationArnaldo Carvalho de Melo
For kallsyms we don't have the symbol address end, so we do an extra pass and set the symbol end addr as being the start of the next minus one. But this was being done just after we filtered the symbols of a particular type (functions, variables), so the symbol end was sometimes after what it really is. Fixing up symbol end also was falling apart when we have symbol aliases, then the end address of all but the last alias was being set to be before its start. Fix it up by checking for symbol aliases and making the kallsyms__parse routine use the next symbol, whatever its type, as the limit for the previous symbol, passing that end address to the callback. This was detected by the 'perf test' synthetic paranoid regression tests, fix it up so that even that case doesn't mislead us. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf symbols: Add symfs option for off-box analysis using specified treeDavid Ahern
The symfs argument allows analysis of perf.data file using a locally accessible filesystem tree with debug symbols - e.g., tree created during image builds, sshfs mount, loop mounted KVM disk images, USB keys, initrds, etc. Anything with an OS tree can be analyzed from anywhere without the need to populate a local data store with build-ids. Commiter notes: o Fixed up symfs="/" variants handling. o prefixed DSO__ORIG_GUEST_KMODULE case with symfs too, avoiding use of files outside the symfs directory. LKML-Reference: <1291926427-28846-1-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-16perf probe: Fix use of kernel image path given by 'k' optionFranck Bui-Huu
Users were not being able to have the explicitely specified vmlinux pathname used, instead a search on the vmlinux path was always being made. Reported-by: Francis Moreau <francis.moro@gmail.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Francis Moreau <francis.moro@gmail.com> Cc: Franck Bui-Huu <vagabon.xyz@gmail.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> LPU-Reference: <m3hbelydz8.fsf_-_@gmail.com> Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-16Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: We want to apply a dependent patch. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-12-09perf report: Allow user to specify path to kallsyms fileDavid Ahern
This is useful for analyzing a perf data file on a different system than the one data was collected on and still include symbols from loaded kernel modules in the output. Commiter note: Updated the man page accordingly. LKML-Reference: <1291775986-16475-1-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-30perf symbols: Figure out start address of kernel map from kallsymsMing Lei
On ARM, module symbol start address is ahead of kernel symbol start address, so we can't suppose that the start address of kernel map always is zero, otherwise may cause incorrect .start and .end of kernel map (caused by fixup) when there are modules loaded, then map_groups__find may return incorrect map for symbol query. This patch always figures out the start address of kernel map from /proc/kallsyms if the file is available, so fix the issues on ARM for module loaded case. This patch fixes the following issues on ARM when modules are loaded: - vmlinux symbol can't be found by kallsyms maps doing 'perf test' - module symbols are parsed mistakenlly when doing 'perf top'/'perf report' Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20101125192725.62d31b42@tom-lei> Signed-off-by: Ming Lei <tom.leiming@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-30perf symbols: Fix kallsyms kernel/module map splittingArnaldo Carvalho de Melo
On ARM, module addresss space is ahead of kernel space, so the module symbols are handled before kernel symbol in dso__split_kallsyms, then was causing one map to be created for each kernel symbol. Reported-by: Ming Lei <tom.leiming@gmail.com> Tested-by: Ming Lei <tom.leiming@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20101124144540.GB15875@ghostprotocols.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-27perf symbols: Correct final kernel map guessesIan Munsie
If a 32bit userspace perf is running on a 64bit kernel, the end of the final map in the kernel would incorrectly be set to 2^32-1 rather than 2^64-1. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1290658375-10342-1-git-send-email-imunsie@au1.ibm.com> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-23perf symbols: Remove incorrect open-coded container_of()Rabin Vincent
At least on ARM, padding is inserted between rb_node and sym in struct symbol_name_rb_node, causing "((void *)sym) - sizeof(struct rb_node)" to point inside rb_node rather than to the symbol_name_rb_node. Fix this by converting the code to use container_of(). Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Ming Lei <tom.leiming@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20101123163106.GA25677@debian> Signed-off-by: Rabin Vincent <rabin@rab.in> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-09-15Merge branch 'tip/perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/linux-2.6-trace into perf/core
2010-09-09perf symbols: Fix multiple initialization of symbol systemJovi Zhang
By returning immediately if it was already initialized, do it as well at symbol__exit, refusing multiple deinitializations. This fixes problems in the kmem, sched and timechart commands. Reported-by: Davidlohr Bueso <dave@gnu.org> Cc: Davidlohr Bueso <dave@gnu.org> Signed-off-by: Jovi Zhang <bookjovi@gmail.com> LKML-Reference: AANLkTi=9Cn=R8SPMCRp5z+gEjXbaBHeb-AaOtRbuwwcn@mail.gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-25perf symbols: List symbols in a dso in ascending name orderSrikar Dronamraju
Given a dso, list the symbols in ascending name order. Needed for listing available symbols from perf probe. Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Christoph Hellwig <hch@infradead.org> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com> Cc: Mark Wielaard <mjw@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Cc: Naren A Devaiah <naren.devaiah@in.ibm.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20100825134329.5447.92261.sendpatchset@localhost6.localdomain6> Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf symbols: Ignore mapping symbols on ARMDave Martin
ARM ELF files use symbols with special names $a, $t, $d to identify regions of ARM code, Thumb code and data within code sections. This can cause confusing output from the perf tools, especially for partially stripped binaries, or binaries containing user-added zero-sized symbols (which may occur in hand-written assembler which hasn't been fully annotated with .size directives). This patch filters out these symbols at load time. LKML-Reference: <1281352878-8735-2-git-send-email-dave.martin@linaro.org> Signed-off-by: Dave Martin <dave.martin@linaro.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-05perf symbols: Store the symbol bindingArnaldo Carvalho de Melo
So that tools that wan't to act only on a subset of (weak, global, local) symbols can do so, such as the upcoming uprobes support in 'perf probe'. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-02perf session: Free the ref_reloc_sym memory at the right placeArnaldo Carvalho de Melo
Which is at perf_session__destroy_kernel_maps, counterpart to the perf_session__create_kernel_maps where the kmap structure is located, just after the vmlinux_maps. Make it also check if the kernel maps were actually created, which may not be the case if, for instance, perf_session__new can't complete due to permission problems in, for instance, a 'perf report' case, when a segfault will take place, that is how this was noticed. The problem was introduced in d65a458, thus post .35. This also adds code to release guest machines as them are also created in perf_session__create_kernel_maps, so should be deleted on this newly introduced counterpart, perf_session__destroy_kernel_maps. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-02Merge commit 'v2.6.35' into perf/coreIngo Molnar
Conflicts: tools/perf/Makefile tools/perf/util/hist.c Merge reason: Resolve the conflicts and update to latest upstream. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-07-30perf tools: Release session and symbol resources on exitArnaldo Carvalho de Melo
So that we reduce the noise when looking for leaks using tools such as valgrind. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-30perf symbols: Improve debug image search when loading symbolsDave Martin
Changes: * Simplification of the main search loop on dso__load() * Replace the search with a 2-pass search: * First, try to find an image with a proper symtab. * Second, repeat the search, accepting dynsym. A second scan should only ever happen when needed debug images are missing from the buildid cache or stale, i.e., when the cache is out of sync. Currently, the second scan also happens when using separated debug images, since the caching logic doesn't currently know how to cache those. Improvements to the cache behaviour ought to solve that. Signed-off-by: Dave Martin <dave.martin@linaro.org> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-30perf tools: remove extra build-id check factored into dso__loadDave Martin
2010-07-30perf tools: Factor out buildid reading and make it implicit in dso__loadDave Martin
If we have a buildid, then we never want to load an image which has no buildid, or which has a different buildid, so it makes sense for the check to be built into dso__load and not done separately. This is fine for old distros which don't use buildid at all since we do no check in that case. This refactoring also alleviates some subtle race condition issues by not opening ELF images twice to check the buildid and then load the symbols, which could lead to weirdness if an image is replaced under our feet. Signed-off-by: Dave Martin <dave.martin@linaro.org> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-29perf symbols: Precisely specify if dso->{long,short}_name should be freedArnaldo Carvalho de Melo
2010-07-23perf sort: Make column width code per hists instanceArnaldo Carvalho de Melo
They were globals, and since we support multiple hists and sessions at the same time, it doesn't make sense to calculate those values considereing all symbols in all sessions. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-16perf symbols: Fix directory descriptor leakingGui Jianfeng
When I ran "perf kvm ... top", I encountered the following error output. Error: perfcounter syscall returned with -1 (Too many open files) Fatal: No CONFIG_PERF_EVENTS=y kernel support configured? Looking into perf, I found perf opens too many directories at initialization time, but forgets to close them. Here is the fix. LKML-Reference: <4C230362.5080704@cn.fujitsu.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Gui Jianfeng <guijianfeng@cn.fujitsu.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-17perf symbols: Function descriptor symbol lookupEric B Munson
Currently symbol resolution does not work for 64-bit programs on architectures that use function descriptors such as ppc64. The problem is that a symbol doesn't point to a text address, it points to a data area that contains (amongst other things) a pointer to the text address. We look for a section called ".opd" which is the function descriptor area. To create the full symbol table, when we see a symbol in the function descriptor section we load the first pointer and use that as the text address. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <1276523793-15422-1-git-send-email-ebmunson@us.ibm.com> Signed-off-by: Anton Blanchard <anton@samba.org> Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-06-04perf symbols: Set the DSO long name when using symbol_conf.vmlinux_nameArnaldo Carvalho de Melo
We need to set the long name to the name specified via, for instance, 'perf annotate --vmlinux /path/to/vmlinux', if not it will remain as '[kernel.kallsyms]' and that will make annotate fail when passing this as the vmlinux name in the call to objdump. The way this is setup grew unwieldly and dso__load_vmlinux is the function that should allocate space for the long name, with callers not assuming that filenames should be allocated somehow by then (strdup, dso__build_id_filename, etc). For now this is the minimalistic patch, a proper fix for .36 will be made. Reported-by: Stephane Eranian <eranian@google.com> Tested-by: Stephane Eranian <eranian@google.com> Cc: David S. Miller <davem@davemloft.net> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20100604003900.GD10469@ghostprotocols.net> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
