path: root/tools/perf/util/scripting-engines
2012-09-20perf tools: Fix a compiling error in trace-event-perl.c for 32 bits machineFeng Tang
On my x86_32 mahcine, there is a compile error: CC util/scripting-engines/trace-event-perl.o cc1: warnings being treated as errors util/scripting-engines/trace-event-perl.c: In function perl_process_tracepoint: util/scripting-engines/trace-event-perl.c:285: error: format expects type 'int', but argument 2 has type '__u64' make: *** [util/scripting-engines/trace-event-perl.o] Error 1 Fix it by using the "%PRIu64" for __u64. v2: use PRIu64 as suggested by Arnaldo. Signed-off-by: Feng Tang <feng.tang@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20120828101730.6b2fd97e@feng-i7 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-05perf tools: remove unneeded include of network header filesDavid Ahern
perf does not have networking related functionality, and the inclusion of these headers is one of the causes of compile failures for Android: https://lkml.org/lkml/2012/8/23/316 https://lkml.org/lkml/2012/8/28/293 So, remove them. Signed-off-by: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1346255732-93246-1-git-send-email-dsahern@gmail.com [ committer note: fix trace-event-perl.c compile failure by reordering includes ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-09perf script python: Correct handler check and spelling errorsFeng Tang
Correct the checking for handler returned by PyDict_GetItemString(), also fix some spelling error and remove some data code in event_analyzing_sample.py, as suggested by Namhyung Kim. v2: restore back the wrongly removed trace_unhandled() func Signed-off-by: Feng Tang <feng.tang@intel.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/20120809134613.067104c4@feng-i7 Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-08perf scripts python: Pass event/thread/dso name and symbol info to event ↵Feng Tang
handler in python Also as suggested by Arnaldo, pack all these parameters to a dictionary, which is more expandable for adding new parameters while keeping the compatibility for old scripts. Signed-off-by: Feng Tang <feng.tang@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1344419875-21665-4-git-send-email-feng.tang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-08perf script: Replace "struct thread" with "struct addr_location" as a ↵Feng Tang
parameter for "process_event()" Both perl and python script start processing events other than trace points, and it's useful to pass the resolved symbol and the dso info to the event handler in script for better analysis and statistics. Struct thread is already a member of struct addr_location, using addr_location will keep the thread info, while providing additional symbol and dso info if exist, so that the script itself doesn't need to bother to do the symbol resolving and dso searching work. Tested-by: David Ahern <dsahern@gmail.com> Signed-off-by: Feng Tang <feng.tang@intel.com> Acked-by: David Ahern <dsahern@gmail.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1344419875-21665-3-git-send-email-feng.tang@intel.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-08perf script: Add general python handler to process non-tracepoint eventsFeng Tang
This patch just follows Robert Richter's idea and the commit 37a058ea0 "perf script: Add generic perl handler to process events" to similarly add a python handler for general events other than tracepoints. For non-tracepoint events, this patch will try to find a function named "process_event" in the python script, and pass the event attribute, perf_sample, raw_data in format of raw string. And the python script can use "struct" module's unpack function to disasemble the needed info and process. Signed-off-by: Feng Tang <feng.tang@intel.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1344419875-21665-2-git-send-email-feng.tang@intel.com [ committer note: Fixed up wrt da37896, i.e. pevent parm in script event handlers ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-07perf script: Stop using pevent directlyArnaldo Carvalho de Melo
We can get all that is needed using just event_format, that is available via evsel->tp_format now. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-2hsr1686epa9f0vx4yg7z2zj@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-07perf evsel: Cache associated event_formatArnaldo Carvalho de Melo
We already lookup the associated event_format when reading the perf.data header, so that we can cache the tracepoint name in evsel->name, so do it a little further and save the event_format itself, so that we can avoid relookups in tools that need to access it. Change the tools to take the most obvious advantage, when they were using pevent_find_event directly. More work is needed for further removing the need of a pointer to pevent, such as when asking for event field values ("common_pid" and the other common fields and per event_format fields). This is something that was planned but only got actually done when Andrey Wagin needed to do this lookup at perf_tool->sample() time, when we don't have access to pevent (session->pevent) to use with pevent_find_event(). Cc: Andrey Wagin <avagin@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Link: http://lkml.kernel.org/n/tip-txkvew2ckko0b594ae8fbnyk@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-29tools lib traceevent: Add support for __print_hex()Namhyung Kim
Since the __print_hex() function is used in print fmt now, add corresponding parser routines. This makes the output of perf script on the kvm_emulate_insn event not to fail any more. before: kvm_emulate_insn: [FAILED TO PARSE] rip=3238197797 ... after: kvm_emulate_insn: 0:c102fa25:89 10 (prot32) Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1340757701-10711-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-27perf tools: Stop using a global trace events description listArnaldo Carvalho de Melo
The pevent thing is per perf.data file, so I made it stop being static and become a perf_session member, so tools processing perf.data files use perf_session and _there_ we read the trace events description into session->pevent and then change everywhere to stop using that single global pevent variable and use the per session one. Note that it _doesn't_ fall backs to trace__event_id, as we're not interested at all in what is present in the /sys/kernel/debug/tracing/events in the workstation doing the analysis, just in what is in the perf.data file. This patch also introduces perf_session__set_tracepoints_handlers that is the perf perf.data/session way to associate handlers to tracepoint events by resolving their IDs using the events descriptions stored in a perf.data file. Make 'perf sched' use it. Reported-by: Dmitry Antipov <dmitry.antipov@linaro.org> Tested-by: Dmitry Antipov <dmitry.antipov@linaro.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: linaro-dev@lists.linaro.org Cc: patches@linaro.org Link: http://lkml.kernel.org/r/20120625232016.GA28525@infradead.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-22perf script: Rename struct event to struct event_format in perl engineFrederic Weisbecker
While migrating to the libtraceevent, the perl scripting engine missed this structure rename. This fixes: util/scripting-engines/trace-event-perl.c: In function "find_cache_event": util/scripting-engines/trace-event-perl.c:244: error: assignment from incompatible pointer type util/scripting-engines/trace-event-perl.c:248: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:248: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:250: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c: In function "perl_process_tracepoint": util/scripting-engines/trace-event-perl.c:286: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:286: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:307: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c: In function "perl_generate_script": util/scripting-engines/trace-event-perl.c:498: error: passing argument 1 of "trace_find_next_event" from incompatible pointer type util/scripting-engines/../trace-event.h:56: note: expected "struct event_format *" but argument is of type "struct event *" util/scripting-engines/trace-event-perl.c:498: error: assignment from incompatible pointer type util/scripting-engines/trace-event-perl.c:499: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:499: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:513: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:532: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:556: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:569: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:570: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:579: error: dereferencing pointer to incomplete type util/scripting-engines/trace-event-perl.c:580: error: dereferencing pointer to incomplete type Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@redhat.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/r/1337697049-30251-2-git-send-email-fweisbec@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-22perf script: Explicitly handle known default print arg typeFrederic Weisbecker
Handle the print argument types brought by the new libparsevent in perl scripting engine. PRINT_BSTRING and PRINT_DYNAMIC_ARRAY are treated just like strings and thus don't require specific processing. But PRINT_FUNC need specific plugins which are not yet handled, lets warn if we meet this case. This fixes: util/scripting-engines/trace-event-perl.c: In function define_event_symbol: util/scripting-engines/trace-event-perl.c:188: error: enumeration value PRINT_BSTRING not handled in switch util/scripting-engines/trace-event-perl.c:188: error: enumeration value PRINT_DYNAMIC_ARRAY not handled in switch util/scripting-engines/trace-event-perl.c:188: error: enumeration value PRINT_FUNC not handled in switch Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Frederic Weisbecker <fweisbec@redhat.com> Cc: Frederic Weisbecker <fweisbec@redhat.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/r/1337697049-30251-1-git-send-email-fweisbec@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-25perf: Have perf use the new libtraceevent.a librarySteven Rostedt
The event parsing code in perf was originally copied from trace-cmd but never was kept up-to-date with the changes that was done there. The trace-cmd libtraceevent.a code is much more mature than what is currently in perf. This updates the code to use wrappers to handle the calls to the new event parsing code. The new code requires a handle to be pass around, which removes the global event variables and allows more than one event structure to be read from different files (and different machines). But perf still has the old global events and the code throughout perf does not yet have a nice way to pass around a handle. A global 'pevent' has been made for perf and the old calls have been created as wrappers to the new event parsing code that uses the global pevent. With this change, perf can later incorporate the pevent handle into the perf structures and allow more than one file to be read and compared, that contains different events. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2012-01-30perf tools: Remove unnecessary ctype.h inclusionNamhyung Kim
There are unnecessary #include <ctype.h> out there, and they might cause a nasty build failure in some environment. As we already have most of ctype macros in util.h, just get rid of them. A few of exceptions are util/symbol.c which needs isupper() macro util.h doesn't provide and perl scripting support code which includes ctype.h internally. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1327827356-8786-4-git-send-email-namhyung@gmail.com Signed-off-by: Namhyung Kim <namhyung@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-12-23perf script: Add generic perl handler to process eventsRobert Richter
The current perf scripting facility only supports tracepoints. This patch implements a generic perl handler to support other events than tracepoints too. This patch introduces a function process_event() that is called by perf for each sample. The function is called with byte streams as arguments containing information about the event, its attributes, the sample and raw data. Perl's unpack() function can easily be used for byte decoding. The following is the default implementation for process_event() that can also be generated with perf script: # Packed byte string args of process_event(): # # $event: union perf_event util/event.h # $attr: struct perf_event_attr linux/perf_event.h # $sample: struct perf_sample util/event.h # $raw_data: perf_sample->raw_data util/event.h sub process_event { my ($event, $attr, $sample, $raw_data) = @_; my @event = unpack("LSS", $event); my @attr = unpack("LLQQQQQLLQQ", $attr); my @sample = unpack("QLLQQQQQLL", $sample); my @raw_data = unpack("C*", $raw_data); use Data::Dumper; print Dumper \@event, \@attr, \@sample, \@raw_data; } Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/1323969824-9711-4-git-send-email-robert.richter@amd.com Signed-off-by: Robert Richter <robert.richter@amd.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-28perf tools: Resolve machine earlier and pass it to perf_event_opsArnaldo Carvalho de Melo
Reducing the exposure of perf_session further, so that we can use the classes in cases where no perf.data file is created. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-stua66dcscsezzrcdugvbmvd@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf session: Pass evsel in event_ops->sample()Arnaldo Carvalho de Melo
Resolving the sample->id to an evsel since the most advanced tools, report and annotate, and the others will too when they evolve to properly support multi-event perf.data files. Good also because it does an extra validation, checking that the ID is valid when present. When that is not the case, the overhead is just a branch + function call (perf_evlist__id2evsel). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-14perf script: Change process_event prototypeDavid Ahern
Prepare for handling of samples for any event type. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1299734608-5223-2-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-07perf tool: Fix gcc 4.6.0 issuesKyle McMartin
GCC 4.6.0 in Fedora rawhide turned up some compile errors in tools/perf due to the -Werror=unused-but-set-variable flag. I've gone through and annotated some of the assignments that had side effects (ie: return value from a function) with the __used annotation, and in some cases, just removed unused code. In a few cases, we were assigning something useful, but not using it in later parts of the function. kyle@dreadnought:~/src% gcc --version gcc (GCC) 4.6.0 20110122 (Red Hat 4.6.0-0.3) Cc: Ingo Molnar <mingo@redhat.com> LKML-Reference: <20110124161304.GK27353@bombadil.infradead.org> Signed-off-by: Kyle McMartin <kyle@redhat.com> [ committer note: Fixed up the annotation fixes, as that code moved recently ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-16perf: Rename 'perf trace' to 'perf script'Ingo Molnar
Free the perf trace name space and rename the trace to 'script' which is a better match for the scripting engine. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2010-06-01perf scripts python: Give field dict to unhandled callbackPierre Tardy
trace_unhandled() callback does not allow to access event fields, this patch resolves the problem. It can also been used as a more pythonic and flexible way for script writters to demux event types This will for example greatly simplify pytimechart event demux. Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Tom Zanussi <tzanussi@gmail.com> Cc: Ingo Molnar <mingo@elte.hu>, Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <1275340329-2397-1-git-send-email-tardyp@gmail.com> Signed-off-by: Pierre Tardy <tardyp@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf/trace/scripting: don't show script start/stop messages by defaultTom Zanussi
Only print the script start/stop messages in verbose mode - users normally don't care and it just clutters up the output. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> LKML-Reference: <1273466820-9330-7-git-send-email-tzanussi@gmail.com> Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-02perf/scripts: Tuple was set from long in both branches in python_process_event()Tom Zanussi
This is a fix to the signed/unsigned field handling in the Python scripting engine, based on a patch from Roel Kluin. Basically, Python wants to use a PyInt (which is internally a long) if it can i.e. if the value will fit into that type. If not, it stores it into a PyLong, which isn't actually a long, but an arbitrary-precision integer variable. The code below is similar to to what Python does internally, and it seems to work as expected on the x86 and x86_64 sytems I tested it on. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Roel Kluin <roel.kluin@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org LKML-Reference: <1270184305.6422.10.camel@tropicana> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-25perf/scripts: Remove unnecessary PyTuple resizesTom Zanussi
If we know the size of a tuple in advance, there's no need to resize it - start out with the known size in the first place. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1266822779.6426.4.camel@tropicana> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-02-25perf/scripts: Add Python scripting engineTom Zanussi
Add base support for Python scripting to perf trace. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1264580883-15324-6-git-send-email-tzanussi@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-02-23perf/scripts: Move Perl scripting files to scripting-engines dirTom Zanussi
Create a scripting-engines directory to contain scripting engine implementation code, in anticipation of the addition of new scripting support. Also removes trace-event-perl.h. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1264580883-15324-5-git-send-email-tzanussi@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
