path: root/tools/perf/util/probe-event.c
2014-02-18perf probe: Support distro-style debuginfo for uprobeMasami Hiramatsu
Support distro-style debuginfo supported by dso for setting uprobes. Note that this tries to find a debuginfo file based on the real path of the target binary. If the debuginfo is not correctly installed on the system, this can not find it. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053227.29635.54434.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Allow to add events on the local functionsMasami Hiramatsu
Allow to add events on the local functions without debuginfo. (With the debuginfo, we can add events even on inlined functions) Currently, probing on local functions requires debuginfo to locate actual address. It is also possible without debuginfo since we have symbol maps. Without this change; ---- # ./perf probe -a t_show Added new event: probe:t_show (on t_show) You can now use it in all perf tools, such as: perf record -e probe:t_show -aR sleep 1 # ./perf probe -x perf -a identity__map_ip no symbols found in /kbuild/ksrc/linux-3/tools/perf/perf, maybe install a debug package? Failed to load map. Error: Failed to add events. (-22) ---- As the above results, perf probe just put one event on the first found symbol for kprobe event. Moreover, for uprobe event, perf probe failed to find local functions. With this change; ---- # ./perf probe -a t_show Added new events: probe:t_show (on t_show) probe:t_show_1 (on t_show) probe:t_show_2 (on t_show) probe:t_show_3 (on t_show) You can now use it in all perf tools, such as: perf record -e probe:t_show_3 -aR sleep 1 # ./perf probe -x perf -a identity__map_ip Added new events: probe_perf:identity__map_ip (on identity__map_ip in /kbuild/ksrc/linux-3/tools/perf/perf) probe_perf:identity__map_ip_1 (on identity__map_ip in /kbuild/ksrc/linux-3/tools/perf/perf) probe_perf:identity__map_ip_2 (on identity__map_ip in /kbuild/ksrc/linux-3/tools/perf/perf) probe_perf:identity__map_ip_3 (on identity__map_ip in /kbuild/ksrc/linux-3/tools/perf/perf) You can now use it in all perf tools, such as: perf record -e probe_perf:identity__map_ip_3 -aR sleep 1 ---- Now we succeed to put events on every given local functions for both kprobes and uprobes. :) Note that this also introduces some symbol rbtree iteration macros; symbols__for_each, dso__for_each_symbol, and map__for_each_symbol. These are for walking through the symbol list in a map. Changes from v2: - Fix add_exec_to_probe_trace_events() not to convert address to tp->symbol any more. - Fix to set kernel probes based on ref_reloc_sym. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053225.29635.15026.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Show source-level or symbol-level info for uprobesMasami Hiramatsu
Show source-level or symbol-level information for uprobe events. Without this change; # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d110 in /kbuild/ksrc/linux-3/tools/perf/perf) With this change; # ./perf probe -l probe_perf:dso__load_vmlinux (on dso__load_vmlinux@util/symbol.c in /kbuild/ksrc/linux-3/tools/perf/perf) Changes from v2: - Update according to previous patches. Changes from v1: - Rewrite the code based on new series. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053223.29635.51280.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Show appropriate symbol for ref_reloc_sym based kprobesMasami Hiramatsu
Show appropriate symbol for ref_reloc_sym based kprobes instead of refpoint+offset when perf-probe -l runs without debuginfo. Without this change: # ./perf probe -l probe:t_show (on _stext+889880 with m v) probe:t_show_1 (on _stext+928568 with m v t) probe:t_show_2 (on _stext+969512 with m v fmt) probe:t_show_3 (on _stext+1001416 with m v file) With this change: # ./perf probe -l probe:t_show (on t_show with m v) probe:t_show_1 (on t_show with m v t) probe:t_show_2 (on t_show with m v fmt) probe:t_show_3 (on t_show with m v file) Changes from v2: - Check ref_reloc_sym to find correct unrelocated address. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053220.29635.81819.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Find given address from offline dwarfMasami Hiramatsu
Find the given address from offline dwarfs instead of online kernel dwarfs. On the KASLR enabled kernel, the kernel text section is loaded with random offset, and the debuginfo__new_online_kernel can't handle it. So let's move to the offline dwarf loader instead of using the online dwarf loader. As a result, since we don't need debuginfo__new_online_kernel any more, this also removes the functions related to that. Without this change; # ./perf probe -l probe:t_show (on _stext+901288 with m v) probe:t_show_1 (on _stext+939624 with m v t) probe:t_show_2 (on _stext+980296 with m v fmt) probe:t_show_3 (on _stext+1014392 with m v file) With this change; # ./perf probe -l probe:t_show (on t_show@linux-3/kernel/trace/ftrace.c with m v) probe:t_show_1 (on t_show@linux-3/kernel/trace/trace.c with m v t) probe:t_show_2 (on t_show@kernel/trace/trace_printk.c with m v fmt) probe:t_show_3 (on t_show@kernel/trace/trace_events.c with m v file) Changes from v2: - Instead of retrying, directly opens offline dwarf. - Remove debuginfo__new_online_kernel and related functions. - Refer map->reloc to get the correct address of a symbol. - Add a special case for handling ref_reloc_sym based address. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053218.29635.74821.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Use ref_reloc_sym based address instead of the symbol nameMasami Hiramatsu
Since several local symbols can have same name (e.g. t_show), we need to use the relative address from the symbol referred by kmap->ref_reloc_sym instead of the target symbol name itself. Because the kernel address space layout randomize (kASLR) changes the absolute address of kernel symbols, we can't rely on the absolute address. Note that this works only with debuginfo. E.g. without this change; ---- # ./perf probe -a "t_show \$vars" Added new events: probe:t_show (on t_show with $vars) probe:t_show_1 (on t_show with $vars) probe:t_show_2 (on t_show with $vars) probe:t_show_3 (on t_show with $vars) You can now use it in all perf tools, such as: perf record -e probe:t_show_3 -aR sleep 1 ---- OK, we have 4 different t_show()s. All functions have different arguments as below; ---- # cat /sys/kernel/debug/tracing/kprobe_events p:probe/t_show t_show m=%di:u64 v=%si:u64 p:probe/t_show_1 t_show m=%di:u64 v=%si:u64 t=%si:u64 p:probe/t_show_2 t_show m=%di:u64 v=%si:u64 fmt=%si:u64 p:probe/t_show_3 t_show m=%di:u64 v=%si:u64 file=%si:u64 ---- However, all of them have been put on the *same* address. ---- # cat /sys/kernel/debug/kprobes/list ffffffff810d9720 k t_show+0x0 [DISABLED] ffffffff810d9720 k t_show+0x0 [DISABLED] ffffffff810d9720 k t_show+0x0 [DISABLED] ffffffff810d9720 k t_show+0x0 [DISABLED] ---- With this change; ---- # ./perf probe -a "t_show \$vars" Added new events: probe:t_show (on t_show with $vars) probe:t_show_1 (on t_show with $vars) probe:t_show_2 (on t_show with $vars) probe:t_show_3 (on t_show with $vars) You can now use it in all perf tools, such as: perf record -e probe:t_show_3 -aR sleep 1 # cat /sys/kernel/debug/tracing/kprobe_events p:probe/t_show _stext+889880 m=%di:u64 v=%si:u64 p:probe/t_show_1 _stext+928568 m=%di:u64 v=%si:u64 t=%si:u64 p:probe/t_show_2 _stext+969512 m=%di:u64 v=%si:u64 fmt=%si:u64 p:probe/t_show_3 _stext+1001416 m=%di:u64 v=%si:u64 file=%si:u64 # cat /sys/kernel/debug/kprobes/list ffffffffb50d95e0 k t_show+0x0 [DISABLED] ffffffffb50e2d00 k t_show+0x0 [DISABLED] ffffffffb50f4990 k t_show+0x0 [DISABLED] ffffffffb50eccf0 k t_show+0x0 [DISABLED] ---- This time, each event is put in different address correctly. Note that currently this doesn't support address-based probe on modules (thus the probes on modules are symbol based), since it requires relative address probe syntax for kprobe-tracer, and it isn't implemented yet. One more note, this allows us to put events on correct address, but --list option should be updated to show correct corresponding source code. Changes from v2: - Refer kmap->ref_reloc_sym instead of "_stext". - Refer map->reloc to catch up the kASLR perf fix. Changes from v1: - Use _stext relative address instead of actual absolute address recorded in debuginfo. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053216.29635.22584.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Show in what binaries/modules probes are setMasami Hiramatsu
Show the name of binary file or modules in which the probes are set with --list option. Without this change; # ./perf probe -m drm drm_av_sync_delay # ./perf probe -x perf dso__load_vmlinux # ./perf probe -l probe:drm_av_sync_delay (on drm_av_sync_delay) probe_perf:dso__load_vmlinux (on 0x000000000006d110) With this change; # ./perf probe -l probe:drm_av_sync_delay (on drm_av_sync_delay in drm) probe_perf:dso__load_vmlinux (on 0x000000000006d110 in /kbuild/ksrc/linux-3/tools/perf/perf) Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053213.29635.69948.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Unify show_available_functions for uprobes/kprobesMasami Hiramatsu
Unify show_available_functions for uprobes/kprobes to cleanup and reduce the code. This also improves error messages. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053211.29635.20563.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Replace line_list with intlistMasami Hiramatsu
Replace line_list (struct line_node) with intlist for reducing similar codes. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053209.29635.81043.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Remove incorrect symbol check for --listMasami Hiramatsu
Remove unneeded symbol check for --list option. This code actually checks whether the given symbol exists in the kernel. But this is incorrect for online kernel/module and offline module too: - For online kernel/module, the kprobes itself already ensured the symbol exist in the kernel. - For offline module, this code can't access the offlined modules. Ignore it. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053206.29635.7453.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-18perf probe: Fix to do exit call for symbol mapsMasami Hiramatsu
Some perf-probe commands do symbol_init() but doesn't do exit call. This fixes that to call symbol_exit() and releases machine if needed. This also merges init_vmlinux() and init_user_exec() because both of them are doing similar things. (init_user_exec() just skips init vmlinux related symbol maps) Changes from v2: - Not to set symbol_conf.try_vmlinux_path in init_symbol_maps() (Thanks to Namhyung Kim!) Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140206053204.29635.28334.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-02-10perf probe: Do not add offset twice to uprobe addressMasami Hiramatsu
Fix perf-probe not to add offset value twice to uprobe probe address when post processing. The tevs[i].point.address struct member is the address of symbol+offset, but current perf-probe adjusts the point.address by adding the offset. As a result, the probe address becomes symbol+offset+offset. This may cause unexpected code corruption. Urgent fix is needed. Without this fix: --- # ./perf probe -x ./perf dso__load_vmlinux+4 # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d2b8) # nm ./perf.orig | grep dso__load_vmlinux\$ 000000000046d0a0 T dso__load_vmlinux --- You can see the given offset is 3 but the actual probed address is dso__load_vmlinux+8. With this fix: --- # ./perf probe -x ./perf dso__load_vmlinux+4 # ./perf probe -l probe_perf:dso__load_vmlinux (on 0x000000000006d2b4) --- Now the problem is fixed. Note: This bug is introduced by commit fb7345bbf7fad9bf72ef63a19c707970b9685812 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140205051858.6519.27314.stgit@kbuild-fedora.yrl.intra.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-16perf symbols: Export elf_section_by_name and reuseMasami Hiramatsu
Remove duplicated elf_section_by_name() functions from unwind.c and probe-event.c and use one exported elf_section_by_name() instance defined in symbol-elf.c. Note that this also moves get_text_start_address() to merge HAVE_DWARF_SUPPORT defined area. Reported-by: David Ahern <dsahern@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: "Steven Rostedt (Red Hat)" <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140116093949.24403.38093.stgit@kbuild-fedora.novalocal Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-16perf probe: Release all dynamically allocated parametersMasami Hiramatsu
To fix a memory leak, release all dynamically allocated options/parameters in params data structure. This also introduces/exports some init/clear routines. Reported-by: David Ahern <dsahern@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: "Steven Rostedt (Red Hat)" <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140116093947.24403.80118.stgit@kbuild-fedora.novalocal Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-16perf probe: Release allocated probe_trace_event if failedMasami Hiramatsu
To fix a memory leak, release all allocated probe_trace_event on the error path of try_to_find_probe_trace_events. Reported-by: David Ahern <dsahern@gmail.com> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: "Steven Rostedt (Red Hat)" <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20140116093944.24403.30228.stgit@kbuild-fedora.novalocal Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-13perf probe: Fix build when DWARF support libraries not presentArnaldo Carvalho de Melo
On a freshly installed system, after libelf-dev is installed we get: CC /tmp/build/perf/util/probe-event.o util/probe-event.c: In function ‘try_to_find_probe_trace_events’: util/probe-event.c:753:46: error: unused parameter ‘target’ [-Werror=unused-parameter] int max_tevs __maybe_unused, const char *target) ^ CC /tmp/build/perf/util/cgroup.o util/probe-event.c: At top level: util/probe-event.c:193:12: error: ‘get_text_start_address’ defined but not used [-Werror=unused-function] static int get_text_start_address(const char *exec, unsigned long *address) ^ cc1: all warnings being treated as errors make[1]: *** [/tmp/build/perf/util/probe-event.o] Error 1 make[1]: *** Waiting for unfinished jobs.... make: *** [install] Error 2 Fix it by enclosing functions only used when those libraries are installed under the suitable preprocessor define and using __maybe_unused to a function that is only built when DWARF support is disabled. Problem introduced in this changeset: commit fb7345bbf7fad9bf72ef63a19c707970b9685812 Author: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Date: Thu Dec 26 05:41:53 2013 +0000 perf probe: Support basic dwarf-based operations on uprobe events Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-73kc2fopt81517hrdgdra18o@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-27perf tools: Use zfree to help detect use after free bugsArnaldo Carvalho de Melo
Several areas already used this technique, so do some audit to consistently use it elsewhere. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-9sbere0kkplwe45ak6rk4a1f@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-27perf tools: Introduce zfreeArnaldo Carvalho de Melo
For the frequent idiom of: free(ptr); ptr = NULL; Make it expect a pointer to the pointer being freed, so that it becomes clear at first sight that the variable being freed is being modified. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-pfw02ezuab37kha18wlut7ir@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-26perf tools: No need to test against NULL before calling free()Arnaldo Carvalho de Melo
Its perfectly fine to call free(NULL), so no need to clutter the source code with all those superfluous testing. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-uux5wpvevlerd42gqer13e7n@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-26perf probe: Support basic dwarf-based operations on uprobe eventsMasami Hiramatsu
Support basic dwarf(debuginfo) based operations for uprobe events. With this change, perf probe can analyze debuginfo of user application binary to set up new uprobe event. This allows perf-probe --add(with local variables, line numbers) and --line works with -x option. (Actually, --vars has already accepted -x option) For example, the following command shows the probe-able lines of a given user space function. Something that so far was only available in the 'perf probe' tool for kernel space functions: # ./perf probe -x perf --line map__load <map__load@/home/fedora/ksrc/linux-2.6/tools/perf/util/map.c:0> 0 int map__load(struct map *map, symbol_filter_t filter) 1 { 2 const char *name = map->dso->long_name; int nr; 5 if (dso__loaded(map->dso, map->type)) 6 return 0; 8 nr = dso__load(map->dso, map, filter); 9 if (nr < 0) { 10 if (map->dso->has_build_id) { And this shows the available variables at the given line of the function. # ./perf probe -x perf --vars map__load:8 Available variables at map__load:8 @<map__load+96> char* name struct map* map symbol_filter_t filter @<map__find_symbol+112> char* name symbol_filter_t filter @<map__find_symbol_by_name+136> char* name symbol_filter_t filter @<map_groups__find_symbol_by_name+176> char* name struct map* map symbol_filter_t filter And lastly, we can now define probe(s) with all available variables on the given line: # ./perf probe -x perf --add 'map__load:8 $vars' Added new events: probe_perf:map__load (on map__load:8 with $vars) probe_perf:map__load_1 (on map__load:8 with $vars) probe_perf:map__load_2 (on map__load:8 with $vars) probe_perf:map__load_3 (on map__load:8 with $vars) You can now use it in all perf tools, such as: perf record -e probe_perf:map__load_3 -aR sleep 1 Changes from previous version: - Add examples in the patch description. - Use .text section start address and dwarf symbol address for calculating the offset of given symbol, instead of searching the symbol in symtab again. With this change, we can safely handle multiple local function instances (e.g. scnprintf in perf). Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: David A. Long <dave.long@linaro.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: systemtap@sourceware.org Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20131226054152.22364.47021.stgit@kbuild-fedora.novalocal Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-26perf probe: Expand given path to absolute pathMasami Hiramatsu
Expand given path to absolute path in the option parser, except for a module name. Since realpath at later stage in processing several probe point, can be called several times (even if currently doesn't, it can happen when we expands the feature), it is waste of the performance. Processing it once at the early stage can avoid that. Changes from previous one: - Fix not to print null string. - Allocate memory for given path/module name everytime. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: "David A. Long" <dave.long@linaro.org> Cc: "Steven Rostedt (Red Hat)" <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: systemtap@sourceware.org Cc: yrl.pp-manager.tt@hitachi.com Link: http://lkml.kernel.org/r/20131226054150.22364.12187.stgit@kbuild-fedora.novalocal [ Clarified the pr_warning message as per David Ahern's suggestion ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-16tools/: Convert to new topic librariesBorislav Petkov
Move debugfs.* to api/fs/. We have a common tools/lib/api/ place where the Makefile lives and then we place the headers in subdirs. For example, all the fs-related stuff goes to tools/lib/api/fs/ from which we get libapikfs.a (acme got almost the naming he wanted :-)) and we link it into the tools which need it - in this case perf and tools/vm/page-types. acme: "Looking at the implementation, I think some tools can even link directly to the .o files, avoiding the .a file altogether. But that is just an optimization/finer granularity tools/lib/ cherrypicking that toolers can make use of." Fixup documentation cleaning target while at it. Signed-off-by: Borislav Petkov <bp@suse.de> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Andi Kleen <ak@linux.intel.com> Cc: Arjan van de Ven <arjan@linux.intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Pekka Enberg <penberg@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <rric@kernel.org> Cc: Stanislav Fomichev <stfomichev@yandex-team.ru> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386605664-24041-2-git-send-email-bp@alien8.de Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-10perf symbols: Set alloc flag close to setting the long_nameArnaldo Carvalho de Melo
This is a preparatory patch to do with dso__set_long_name what was done with the short name variant. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-mb7eqhkyejq1qcf3p22wz2x7@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-23perf probe: Support "$vars" meta argument syntax for local variablesMasami Hiramatsu
Support "$vars" meta argument syntax for tracing all local variables at probe point. Now you can trace all available local variables (including function parameters) at the probe point by passing $vars. # perf probe --add foo $vars This automatically finds all local variables at foo() and adds it as probe arguments. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20131011071023.15557.51770.stgit@udc4-manage.rcp.hitachi.co.jp Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-09tools/perf: Standardize feature support define names to: HAVE_{FEATURE}_SUPPORTIngo Molnar
Standardize all the feature flags based on the HAVE_{FEATURE}_SUPPORT naming convention: HAVE_ARCH_X86_64_SUPPORT HAVE_BACKTRACE_SUPPORT HAVE_CPLUS_DEMANGLE_SUPPORT HAVE_DWARF_SUPPORT HAVE_ELF_GETPHDRNUM_SUPPORT HAVE_GTK2_SUPPORT HAVE_GTK_INFO_BAR_SUPPORT HAVE_LIBAUDIT_SUPPORT HAVE_LIBELF_MMAP_SUPPORT HAVE_LIBELF_SUPPORT HAVE_LIBNUMA_SUPPORT HAVE_LIBUNWIND_SUPPORT HAVE_ON_EXIT_SUPPORT HAVE_PERF_REGS_SUPPORT HAVE_SLANG_SUPPORT HAVE_STRLCPY_SUPPORT Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/n/tip-u3zvqejddfZhtrbYbfhi3spa@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-03-15perf tools: Introduce tools/lib/lk libraryBorislav Petkov
This introduces the tools/lib/lk library, that will gradually have the routines that now are used in tools/perf/ and other tools and that can be shared. Start by carving out debugfs routines for general use. Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Ingo Molnar <mingo@kernel.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1361374353-30385-5-git-send-email-bp@alien8.de [ committer note: Add tools/lib/lk/ to perf's MANIFEST so that its tarballs continue to build ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-24perf tools: remove sscanf extension %asIrina Tirdea
perf uses sscanf extension %as to read and allocate a string in the same step. This is a non-standard extension only present in new versions of glibc. Replacing the use of sscanf and %as with strtok_r calls in order to parse a given string into its components. This is needed in Android since bionic does not support %as extension for sscanf. Reviewed-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Tested-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1348173470-4936-1-git-send-email-irina.tirdea@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-08perf probe: Make a copy of exec path for passing to basenameDavid Ahern
The basename function may modify the string passed to it, so the string should not be marked const. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: Irina Tirdea <irina.tirdea@gmail.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Link: http://lkml.kernel.org/r/1347116812-93646-3-git-send-email-dsahern@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-31perf uprobes: Remove unnecessary check before strlist__deleteSrikar Dronamraju
Since strlist__delete() itself checks, the additional check before calling strlist__delete() is redundant. No Functional change. Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Suggested-by: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Anton Arapov <anton@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20120531114643.23691.38666.sendpatchset@srdronam.in.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-05-11perf probe: Provide perf interface for uprobesSrikar Dronamraju
- Enhances perf to probe user space executables and libraries. - Enhances -F/--funcs option of "perf probe" to list possible probe points in an executable file or library. - Documents userspace probing support in perf. [ Probing a function in the executable using function name ] perf probe -x /bin/zsh zfree [ Probing a library function using function name ] perf probe -x /lib64/libc.so.6 malloc [ list probe-able functions in an executable ] perf probe -F -x /bin/zsh [ list probe-able functions in an library] perf probe -F -x /lib/libc.so.6 Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Arapov <anton@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux-mm <linux-mm@kvack.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120416120909.30661.99781.sendpatchset@srdronam.in.ibm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-05Merge branch 'perf/urgent' into perf/coreIngo Molnar
Conflicts: tools/perf/builtin-record.c tools/perf/builtin-top.c tools/perf/perf.h tools/perf/util/top.h Merge reason: resolve these cherry-picking conflicts. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2012-02-29perf probe: Ensure offset provided is not greater than function length ↵Prashanth Nageshappa
without DWARF info too The 'perf probe' command allows kprobe to be inserted at any offset from a function start, which results in adding kprobes to unintended location. (example: perf probe do_fork+10000 is allowed even though size of do_fork is ~904). My previous patch https://lkml.org/lkml/2012/2/24/42 addressed the case where DWARF info was available for the kernel. This patch fixes the case where perf probe is used on a kernel without debuginfo available. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Link: http://lkml.kernel.org/r/4F4C544D.1010909@linux.vnet.ibm.com Signed-off-by: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-17perf tools: Remove duplicated string.h includesDanny Kukawka
tools/perf/util/probe-event.c included 'string.h' twice, remove the duplicate. Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Danny Kukawka <dkukawka@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jovi Zhang <bookjovi@gmail.com> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1329400459-31570-1-git-send-email-danny.kukawka@bisect.de Signed-off-by: Danny Kukawka <danny.kukawka@bisect.de> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-02-02perf probe: Rename target_module to targetSrikar Dronamraju
This is a precursor patch that modifies names that refer to kernel/module to also refer to user space names. Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com> Cc: Andi Kleen <andi@firstfloor.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Anton Arapov <anton@redhat.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux-mm <linux-mm@kvack.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Oleg Nesterov <oleg@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Roland McGrath <roland@hack.frob.com> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/20120202142040.5967.64156.sendpatchset@srdronam.in.ibm.com Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-30perf tools: Fix broken build by defining _GNU_SOURCE in MakefileDavid Daney
When building on my Debian/mips system, util/util.c fails to build because commit 1aed2671738785e8f5aea663a6fda91aa7ef59b5 (perf kvm: Do guest-only counting by default) indirectly includes stdio.h before the feature selection in util.h is done. This prevents _GNU_SOURCE in util.h from enabling the declaration of getline(), from now second inclusion of stdio.h, and the build is broken. There is another breakage in util/evsel.c caused by include ordering, but I didn't fully track down the commit that caused it. The root cause of all this is an inconsistent definition of _GNU_SOURCE, so I move the definition into the Makefile so that it is passed to all invocations of the compiler and used uniformly for all system header files. All other #define and #undef of _GNU_SOURCE are removed as they cause conflicts with the definition passed to the compiler. All the features.h definitions (_LARGEFILE64_SOURCE _FILE_OFFSET_BITS=64 and _GNU_SOURCE) are needed by the python glue code too, so they are moved to BASIC_CFLAGS, and the misleading comments about BASIC_CFLAGS are removed. This gives me a clean build on x86_64 (fc12) and mips (Debian). Cc: David Daney <david.daney@cavium.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Joerg Roedel <joerg.roedel@amd.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1326836461-11952-1-git-send-email-ddaney.cavm@gmail.com Signed-off-by: David Daney <david.daney@cavium.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-24perf probe: Usability fixesSrikar Dronamraju
Ingo pointed out few perf probe usability related errors during his review of uprobes. Since these issues are independent of uprobes, fixing them in a separate patch. Suggested-by: Ingo Molnar <mingo@elte.hu> Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Link: http://lkml.kernel.org/r/20120120121354.GL15447@linux.vnet.ibm.com Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-24perf tools: Fix broken build by defining _GNU_SOURCE in MakefileDavid Daney
2011-10-10perf probe: Fix to show correct error stringMasami Hiramatsu
Fix perf probe to show correct error string when it fails to delete an event. The write(2) returns -1 if failed, and errno stores real error number. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: stable@kernel.org Link: http://lkml.kernel.org/r/20111004104504.14591.41266.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-08-08perf probe: Fix coredump introduced by probe module optionJovi Zhang
perf will coredump if the user doesn't give the "-m" option in probe command, this patch fixes it. [root@localhost perf]# ./perf probe --add='PROBE' Segmentation fault (core dumped) Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1311602888-2389-1-git-send-email-bookjovi@gmail.com Signed-off-by: Jovi Zhang <bookjovi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-07-15perf probe: Support adding probes on offline kernel modulesMasami Hiramatsu
Support adding probes on offline kernel modules. This enables perf-probe to trace kernel-module init functions via perf-probe. If user gives the path of module with -m option, perf-probe expects the module is offline. This feature works with --add, --funcs, and --vars. E.g) # perf probe -m /lib/modules/`uname -r`/kernel/fs/btrfs/btrfs.ko \ -a "extent_io_init:5 extent_state_cache" Add new events: probe:extent_io_init (on extent_io_init:5 with extent_state_cache) probe:extent_io_init_1 (on extent_io_init:5 with extent_state_cache) You can now use it on all perf tools, such as: perf record -e probe:extent_io_init_1 -aR sleep 1 Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072751.6528.10230.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Add probed module in front of functionMasami Hiramatsu
Add probed module name and ":" in front of function name if -m module option is given. In the result, the symbol name passed to kprobe-tracer becomes MODULE:FUNCTION, so that kallsyms can solve it as a symbol in the module correctly. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072745.6528.26416.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-07-15perf probe: Introduce debuginfo to encapsulate dwarf informationMasami Hiramatsu
Introduce debuginfo to encapsulate dwarf information. This new object allows us to reuse and expand debuginfo easily. Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net> Link: http://lkml.kernel.org/r/20110627072739.6528.12438.stgit@fedora15 Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2011-04-05perf probe: Fix multiple --vars options behaviorMasami Hiramatsu
Fix a bug that perf-probe fails to initialize libdwfl and shows incorrect error when user gives multiple --vars options. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092553.2132.42691.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-05perf probe: Fix to remove redundant closeMasami Hiramatsu
Since dwfl_end() closes given fd with dwfl, caller doesn't need to close its fd when finishing process. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Lin Ming <ming.m.lin@intel.com> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110330092547.2132.93728.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-22perf probe: Remove redundant checksArnaldo Carvalho de Melo
While fixing an error propagating problem in f809b25 I added two redundant checks. I did that because I didn't expect the checks to be on the while and for loop condition expression, where they are tested before we run the loop, where the 'ret' variable is set. So remove it from there and leave it just after it is actually set, eliminating unneded tests. Reported-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-21perf probe: Fix error propagation leading to segfaultArnaldo Carvalho de Melo
There are two hunks in this patch that stops probe processing as soon as one error is found, breaking out of loops, the other fix an error propagation that should return a negative error number but instead was returning the result of "ret < 0", which is 1 and thus made several error checks fail because they test agains < 0. The problem could be triggered by asking for a variable that was optimized out, fact that should stop the whole probe processing but instead was segfaulting while installing broken probes: [root@emilia ~]# probe perf_mmap:55 user_lock_limit Failed to find the location of user_lock_limit at this address. Perhaps, it has been optimized out. Failed to find 'user_lock_limit' in this function. Add new events: probe:perf_mmap (on perf_mmap:55 with user_lock_limit) probe:perf_mmap_1 (on perf_mmap:55 with user_lock_limit) Segmentation fault (core dumped) [root@emilia ~]# perf probe -l probe:perf_mmap (on perf_mmap:55@git/linux/kernel/perf_event.c with user_lock_limit) probe:perf_mmap_1 (on perf_mmap:55@git/linux/kernel/perf_event.c with user_lock_limit) [root@emilia ~]# After the fix: [root@emilia ~]# probe perf_mmap:55 user_lock_limit Failed to find the location of user_lock_limit at this address. Perhaps, it has been optimized out. Failed to find 'user_lock_limit' in this function. Error: Failed to add events. (-2) [root@emilia ~]# Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-16perf probe: Show filename which contains target functionMasami Hiramatsu
Show filename which contains a target function with the function name on "--lines" mode, because perf-probe just shows the first function even if there are many same-name functions. Originally adopted by Franck Bui-Huu's patch which shows file name instead of function name. I've just modified it to show both of function name and file name, because of completeness of output. E.g.) $ perf probe -L t_show <t_show@/home/mhiramat/ksrc/linux-2.6-tip/kernel/trace/ftrace.c:0> 0 static int t_show(struct seq_file *m, void *v) 1 { 2 struct ftrace_iterator *iter = m->private; ... $ perf probe -L t_show@trace/trace.c <t_show@/home/mhiramat/ksrc/linux-2.6-tip/kernel/trace/trace.c:0> 0 static int t_show(struct seq_file *m, void *v) 1 { struct tracer *t = v; ... Original-patch-by: Franck Bui-Huu <fbuihuu@gmail.com> Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Franck Bui-Huu <fbuihuu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <20110210090816.1809.43426.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-16perf probe: Support function@filename syntax for --lineMasami Hiramatsu
Since "perf probe --add" supports function@filename syntax, --line option should also support it. Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Franck Bui-Huu <fbuihuu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: linux-kernel@vger.kernel.org LKML-Reference: <20110210090810.1809.26913.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-28perf probe: Add filters support for available functionsMasami Hiramatsu
Add filters support for available function list. Default filter is "!_*" for filtering out local-purpose symbols. e.g.: # perf probe --filter="add*" -F add_disk add_disk_randomness add_input_randomness add_interrupt_randomness add_memory add_page_to_unevictable_list add_page_wait_queue ... Cc: 2nddept-manager@sdl.hitachi.co.jp Cc: Chase Douglas <chase.douglas@canonical.com> Cc: Franck Bui-Huu <fbuihuu@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <20110120141545.25915.85930.stgit@ltc236.sdl.hitachi.co.jp> Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
