path: root/tools/perf/util/parse-options.c
2009-12-10perf tools: Align long options which have no short formsLi Zefan
Before: $ ./perf kmem ... -l, --line <num> show n lines --raw-ip show raw ip instead of symbol After: $ ./perf kmem ... -l, --line <num> show n lines --raw-ip show raw ip instead of symbol Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Cc: Pekka Enberg <penberg@cs.helsinki.fi> LKML-Reference: <4B20A1A9.3040104@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-16perf: Enable more compiler warningsIngo Molnar
Related to a shadowed variable bug fix Valdis Kletnieks noticed that perf does not get built with -Wshadow, which could have helped us avoid the bug. So enable -Wshadow and also enable the following warnings on perf builds, in addition to the already enabled -Wall -Wextra -std=gnu99 warnings: -Wcast-align -Wformat=2 -Wshadow -Winit-self -Wpacked -Wredundant-decls -Wstack-protector -Wstrict-aliasing=3 -Wswitch-default -Wswitch-enum -Wno-system-headers -Wundef -Wvolatile-register-var -Wwrite-strings -Wbad-function-cast -Wmissing-declarations -Wmissing-prototypes -Wnested-externs -Wold-style-definition -Wstrict-prototypes -Wdeclaration-after-statement And change/fix the perf code to build cleanly under GCC 4.3.2. The list of warnings enablement is rather arbitrary: it's based on my (quick) reading of the GCC manpages and trying them on perf. I categorized the warnings based on individually enabling them and looking whether they trigger something in the perf build. If i liked those warnings (i.e. if they trigger for something that arguably could be improved) i enabled the warning. If the warnings seemed to come from language laywers spamming the build with tons of nuisance warnings i generally kept them off. Most of the sign conversion related warnings were in this category. (A second patch enabling some of the sign warnings might be welcome - sign bugs can be nasty.) I also kept warnings that seem to make sense from their manpage description and which produced no actual warnings on our code base. These warnings might still be turned off if they end up being a nuisance. I also left out a few warnings that are not supported in older compilers. [ Note that these changes might break the build on older compilers i did not test, or on non-x86 architectures that produce different warnings, so more testing would be welcome. ] Reported-by: Valdis.Kletnieks@vt.edu Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-02perf_counter tools: Add new OPT_CALLBACK_DEFAULT optionFrederic Weisbecker
There is no predefined macro to create an option that can have a custom value or a default one if none is given. This patch provides a new helper OPT_CALLBACK_DEFAULT() which defines such kind of option. For example, considering an option -c, we want to get the default value in the following cases: perf command -c -d perf command -d -c And the foo value when it's given: perf command -c foo -d perf command -d -c foo That's also why PARSE_OPT_LASTARG_DEFAULT is extended here to support default values whatever the position of the option, not only in the end. Should it now be renamed to PARSE_OPT_ARG_DEFAULT ? Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: git@vger.kernel.org LKML-Reference: <1246550301-8954-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-07-01perf_counter tools: Add more warnings and fix/annotate themIngo Molnar
Enable -Wextra. This found a few real bugs plus a number of signed/unsigned type mismatches/uncleanlinesses. It also required a few annotations All things considered it was still worth it so lets try with this enabled for now. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-06-06perf_counter tools: Move from Documentation/perf_counter/ to tools/perf/Ingo Molnar
Several people have suggested that 'perf' has become a full-fledged tool that should be moved out of Documentation/. Move it to the (new) tools/ directory. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
