path: root/tools/perf/util/hist.h
2011-11-16perf python: Fix undefined symbol problemArnaldo Carvalho de Melo
Recently we made perf_evsel__init call hists__init, which broke the perf python binding: [root@emilia linux]# ./tools/perf/python/twatch.py Traceback (most recent call last): File "./tools/perf/python/twatch.py", line 16, in <module> import perf ImportError: /home/acme/git/build/perf/python/perf.so: undefined symbol: hists__init Fix it by moving the hists__init function to its only caller, evsel.c. This way we avoid dragging in other parts of tools/perf/util/ to the perf python binding. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-5nffmdt5mu6ozxgj54oi4qon@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-11-02perf hists browser: Warn about lost eventsArnaldo Carvalho de Melo
Just like the old perf top --tui and the --stdio version. But because we have the initial menu to choose which event to show in a session with multiple events we can see how many chunks were lost in each of the event types, clarifying which events are being affected the most. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-47yyqbubmjzch2chezmb21m6@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-20perf ui browser: Use libslang to read keysArnaldo Carvalho de Melo
Just another step in stopping the use of libnewt in perf. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-uy6s534uqxq8tenh6s3k8ocj@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-19perf hists: Move the dso and thread filters from hist_browserArnaldo Carvalho de Melo
Since with dynamic addition of new hist entries we need to apply those filters as we merge new batches of hist_entry instances, for instance in perf top. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-zjhhf8kh9w1buty9p10od6rz@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-18perf hists: Don't format the percentage on hist_entry__snprintfArnaldo Carvalho de Melo
We can't have color correctly set there because in libslang (and in a future GUI) the colors must be set on a separate function call, so move that part to a separate function and make the stdio fprintf function call it. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-jpgy42438ce9tgbqppm397lq@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-17perf top: Honour --hide_{user,kernel}_symbols and the 'U' hotkeyArnaldo Carvalho de Melo
The new decay routine (__hists__decay_entries) wasn't being passed the toggles, fix it. Reported-by: Mike Galbraith <efault@gmx.de> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-hg6m0mi1colket982oq9hhly@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-13perf top: Remove entries from entries_collapsed on decayArnaldo Carvalho de Melo
We were removing only when using a --sort order that needs collapsing, while we also use it in the threaded case, causing memory corruption because we were scribbling freed hist entries, oops. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-k16fb4jsulr7x0ixv43amb6d@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-13perf hists: Fix compilation when NO_NEWT_SUPPORT is setStephane Eranian
This patch, relative to tip/master, makes perf compile when NO_NEWT_SUPPORT is set. It also fixes the line formatting to fit 80 columns. Please test with NO_NEWT. Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/20111012120328.GA1619@quad Signed-off-by: Stephane Eranian <eranian@google.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf annotate browser: Allow navigation to called functionsArnaldo Carvalho de Melo
I.e. when in the annotate TUI window, if Enter is pressed over an assembly line with a 'callq' it will try to open another TUI window with that symbol. This is just a proof of concept and works only on x86_64, more work is needed to support kernel modules, userland, other arches, etc, but should already be useful as-is. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-opyvskw5na3qdmkv8vxi3zbr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf top: Reuse the 'report' hist_entry/hists classesArnaldo Carvalho de Melo
This actually fixes several problems we had in the old 'perf top': 1. Unresolved symbols not show, limitation that came from the old "KernelTop" codebase, to solve it we would need to do changes that would make sym_entry have most of the hist_entry fields. 2. It was using the number of samples, not the sum of sample->period. And brings the --sort code that allows us to have all the views in 'perf report', for instance: [root@emilia ~]# perf top --sort dso PerfTop: 5903 irqs/sec kernel:77.5% exact: 0.0% [1000Hz cycles], (all, 8 CPUs) ------------------------------------------------------------------------------ 31.59% libcrypto.so.1.0.0 21.55% [kernel] 18.57% libpython2.6.so.1.0 7.04% libc-2.12.so 6.99% _backend_agg.so 4.72% sshd 1.48% multiarray.so 1.39% libfreetype.so.6.3.22 1.37% perf 0.71% libgobject-2.0.so.0.2200.5 0.53% [tg3] 0.48% libglib-2.0.so.0.2200.5 0.44% libstdc++.so.6.0.13 0.40% libcairo.so.2.10800.8 0.38% libm-2.12.so 0.34% umath.so 0.30% libgdk-x11-2.0.so.0.1800.9 0.22% libpthread-2.12.so 0.20% libgtk-x11-2.0.so.0.1800.9 0.20% librt-2.12.so 0.15% _path.so 0.13% libpango-1.0.so.0.2800.1 0.11% libatlas.so.3.0 0.09% ft2font.so 0.09% libpangoft2-1.0.so.0.2800.1 0.08% libX11.so.6.3.0 0.07% [vdso] 0.06% cyclictest ^C All the filter lists can be used as well: --dsos, --comms, --symbols, etc. The 'perf report' TUI is also reused, being possible to apply all the zoom operations, do annotation, etc. This change will allow multiple simplifications in the symbol system as well, that will be detailed in upcoming changesets. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-xzaaldxq7zhqrrxdxjifk1mh@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf browsers: Add live mode to the hists, annotate browsersArnaldo Carvalho de Melo
This allows passing a timer to be run periodically, which will update the hists tree that then gers refreshed on the screen, just like the Live mode (symbol entries, annotation) we already have in 'perf top --tui'. Will be used by the new hist_entry/hists based 'top' tool. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-2r44qd8oe4sagzcgoikl8qzc@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf hists: Threaded addition and sorting of entriesArnaldo Carvalho de Melo
By using a mutex just for inserting and rotating two hist_entry rb trees, so that when sorting we can get the last batch of entries created from the ring buffer, merge it with whatever we have processed so far and show the output while new entries are being added. The 'report' tool continues, for now, to do it without threading, but will use this in the future to allow visualization of results in long perf.data sessions while the entries are being processed. The new 'top' tool will be the first user. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-9b05atsn0q6m7fqgrug8fk2i@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf hists: Allow limiting the number of rows and columns in fprintfArnaldo Carvalho de Melo
So that we can reuse hists__fprintf for in the new perf top tool. Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-huazw48x05h8r9niz5cf63za@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf session: Pass evsel in event_ops->sample()Arnaldo Carvalho de Melo
Resolving the sample->id to an evsel since the most advanced tools, report and annotate, and the others will too when they evolve to properly support multi-event perf.data files. Good also because it does an extra validation, checking that the ID is valid when present. When that is not the case, the overhead is just a branch + function call (perf_evlist__id2evsel). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-06perf report tui: Improve multi event session supportArnaldo Carvalho de Melo
When multiple events were used in 'perf record', allow the user to choose which one is wanted before showing the per event histograms. Annotations will be performed on the chosen event. Allow going back and forth from event to event quickly using just the arrow keys and enter. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: William Cohen <wcohen@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-06perf tools: Improve support for sessions with multiple eventsArnaldo Carvalho de Melo
By creating an perf_evlist out of the attributes in the perf.data file header, so that we can use evlists and evsels when reading recorded sessions in addition to when we record sessions. More work is needed to allow tools to allow the user to select which events are wanted when browsing sessions, be it just one or a subset of them, aggregated or showed at the same time but with different indications on the UI to allow seeing workloads thru different views at the same time. But the overall goal/trend is to more uniformly use evsels and evlists. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-08perf annotate: Move locking to struct annotationArnaldo Carvalho de Melo
Since we'll need it when implementing the live annotate TUI browser. This also simplifies things a bit by having the list head for the source code to be in the dynamicly allocated part of struct annotation, that way we don't have to pass it around, it can be found from the struct symbol that is passed everywhere. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-05perf annotate: Support multiple histograms in annotationArnaldo Carvalho de Melo
The perf annotate tool continues aggregating everything on just one histograms, but to support the top model add support for one histogram perf evsel in the evlist. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-05perf annotate: Move annotate functions to util/Arnaldo Carvalho de Melo
They will be used by perf top, so that we have just one set of routines to do annotation. Rename "struct sym_priv" to "struct annotation", etc, to clarify this code a bit. Rename "struct sym_ext" to "struct source_line", to give it a meaningful name, that clarifies that it is a the result of an addr2line call, that is sorted by percentage one particular source code line appeared in the annotation. And since we're moving things around also rename 'sym_hist->ip' to 'sym_hist->addr' as we want to do data structure annotation at some point. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf callchain: Feed callchains into a cursorFrederic Weisbecker
The callchains are fed with an array of a fixed size. As a result we iterate over each callchains three times: - 1st to resolve symbols - 2nd to filter out context boundaries - 3rd for the insertion into the tree This also involves some pairs of memory allocation/deallocation everytime we insert a callchain, for the filtered out array of addresses and for the array of symbols that comes along. Instead, feed the callchains through a linked list with persistent allocations. It brings several pros like: - Merge the 1st and 2nd iterations in one. That was possible before but in a way that would involve allocating an array slightly taller than necessary because we don't know in advance the number of context boundaries to filter out. - Much lesser allocations/deallocations. The linked list keeps persistent empty entries for the next usages and is extendable at will. - Makes it easier for multiple sources of callchains to feed a stacktrace together. This is deemed to pave the way for cfi based callchains wherein traditional frame pointer based kernel stacktraces will precede cfi based user ones, producing an overall callchain which size is hardly predictable. This requirement makes the static array obsolete and makes a linked list based iterator a much more flexible fit. Basic testing on a big perf file containing callchains (~ 176 MB) has shown a throughput gain of about 11% with perf report. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <1294977121-5700-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-04perf session: Parse sample earlierArnaldo Carvalho de Melo
At perf_session__process_event, so that we reduce the number of lines in eache tool sample processing routine that now receives a sample_data pointer already parsed. This will also be useful in the next patch, where we'll allow sample the identity fields in MMAP, FORK, EXIT, etc, when it will be possible to see (cpu, timestamp) just after before every event. Also validate callchains in perf_session__process_event, i.e. as early as possible, and keep a counter of the number of events discarded due to invalid callchains, warning the user about it if it happens. There is an assumption that was kept that all events have the same sample_type, that will be dealt with in the future, when this preexisting limitation will be removed. Tested-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1291318772-30880-4-git-send-email-acme@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-08-10perf annotate: Sort by hottest lines in the TUIArnaldo Carvalho de Melo
Right now it will just sort and position at the hottest line, i.e. the one where more samples were taken. It will be at the center of the screen and later TAB/shift-TAB will cycle thru the hottest lines. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-27perf hist: Introduce routine to measure lenght of formatted entryArnaldo Carvalho de Melo
Will be used to figure out the window width needed in the new tree widget. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-07-23perf sort: Make column width code per hists instanceArnaldo Carvalho de Melo
They were globals, and since we support multiple hists and sessions at the same time, it doesn't make sense to calculate those values considereing all symbols in all sessions. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-23perf report: Support multiple events on the TUIArnaldo Carvalho de Melo
The hists__tty_browse_tree function was created with the loop to print all events, and its equivalent, hists__tui_browse_tree, was created in a similar fashion, where it is possible to switch among the multiple events, if present, using TAB to go the next event, and shift+TAB (UNTAB) to go to the previous. The report TUI now shows as the window title the name of the event and a leak was fixed wrt pstacks. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-22perf annotate: Add TUI interfaceArnaldo Carvalho de Melo
When annotating multiple entries, for instance, when running simply as: $ perf annotate the right and left keys, as well as TAB can be used to cycle thru the multiple symbols being annotated. If one doesn't like TUI annotate, disable it by editing ~/.perfconfig and adding: [tui] annotate = off Just like it is possible for report. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf report: Report number of events, not samplesArnaldo Carvalho de Melo
Number of samples is meaningless after we switched to auto-freq, so report the number of events, i.e. not the sum of the different periods, but the number PERF_RECORD_SAMPLE emitted by the kernel. While doing this I noticed that naming "count" to the sum of all the event periods can be confusing, so rename it to .period, just like in struct sample.data, so that we become more consistent. This helps with the next step, that was to record in struct hist_entry the number of sample events for each instance, we need that because we use it to generate the number of events when applying filters to the tree of hist entries like it is being done in the TUI report browser. Suggested-by: Ingo Molnar <mingo@elte.hu> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf hist: Clarify events_stats fields usageArnaldo Carvalho de Melo
The events_stats.total field is too generic, rename it to .total_period, and also add a comment explaining that it is the sum of all the .period fields in samples, that is needed because we use auto-freq to avoid sampling artifacts. Ditto for events_stats.lost, that is the sum of all lost_event.lost fields, i.e. the number of events the kernel dropped. Looking at the users, builtin-sched.c can make use of these fields and stop doing it again. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-14perf hist: Make event__totals per histsArnaldo Carvalho de Melo
This is one more thing that started global but are more useful per hist or per session. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-13perf hist: Fix hists__browse no-newt caseFrederic Weisbecker
Fix mistake in a parameter type of the no-newt hists__browse() version. Fixes: builtin-report.c: In function ‘__cmd_report’: builtin-report.c:314: erreur: incompatible type for argument 1 of ‘hists__browse’ Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1273771378-8577-1-git-send-regression-fweisbec@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf report: Librarize the annotation code and use it in the newt browserArnaldo Carvalho de Melo
Now we don't anymore use popen to run 'perf annotate' for the selected symbol, instead we collect per address samplings when processing samples in 'perf report' if we're using the newt browser, then we use this data directly to do annotation. Done this way we can actually traverse the objdump_line objects directly, matching the addresses to the collected samples and colouring them appropriately using lower level slang routines. The new ui_browser class will be reused for the main, callchain aware, histogram browser, when it will be made generic and don't assume that the objects are always instances of the objdump_line class maintained using list_heads. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-11perf hist: Adopt filter by dso and by thread methods from the newt browserArnaldo Carvalho de Melo
Those are really not specific to the newt code, can be used by other UI frontends. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf hist: Calculate max_sym name len and nr_entriesArnaldo Carvalho de Melo
Better done when we are adding entries, be it initially of when we're re-sorting the histograms. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-10perf hist: Introduce hists class and move lots of methods to itArnaldo Carvalho de Melo
In cbbc79a we introduced support for multiple events by introducing a new "event_stat_id" struct and then made several perf_session methods receive a point to it instead of a pointer to perf_session, and kept the event_stats and hists rb_tree in perf_session. While working on the new newt based browser, I realised that it would be better to introduce a new class, "hists" (short for "histograms"), renaming the "event_stat_id" struct and the perf_session methods that were really "hists" methods, as they manipulate only struct hists members, not touching anything in the other perf_session members. Other optimizations, such as calculating the maximum lenght of a symbol name present in an hists instance will be possible as we add them, avoiding a re-traversal just for finding that information. The rationale for the name "hists" to replace "event_stat_id" is that we may have multiple sets of hists for the same event_stat id, as, for instance, the 'perf diff' tool has, so event stat id is not what characterizes what this struct and the functions that manipulate it do. Cc: Eric B Munson <ebmunson@us.ibm.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-09perf hist: Simplify the insertion of new hist_entry instancesArnaldo Carvalho de Melo
And with that fix at least one bug: The first hit for an entry, the one that calls malloc to create a new instance in __perf_session__add_hist_entry, wasn't adding the count to the per cpumode (PERF_RECORD_MISC_USER, etc) total variable. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-19perf: 'perf kvm' tool for monitoring guest performance from hostZhang, Yanmin
Here is the patch of userspace perf tool. Signed-off-by: Zhang Yanmin <yanmin_zhang@linux.intel.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2010-04-02perf hist: Replace ->print() routines by ->snprintf() equivalentsArnaldo Carvalho de Melo
Then hist_entry__fprintf will just us the newly introduced hist_entry__snprintf, add the newline and fprintf it to the supplied FILE descriptor. This allows us to remove the use_browser checking in the color_printf routines, that now got color_snprintf variants too. The newt TUI browser (and other GUIs that may come in the future) don't have to worry about stdio specific stuff in the strings they get from the se->snprintf routines and instead use whatever means to do the equivalent. Also the newt TUI browser don't have to use the fmemopen() hack, instead it can use the se->snprintf routines directly. For now tho use the hist_entry__snprintf routine to reduce the patch size. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-02perf report: Add progress barsArnaldo Carvalho de Melo
For when we are processing the events and inserting the entries in the browser. Experimentation here: naming "ui_something" we may be treading into creating a TUI/GUI set of routines that can then be implemented in terms of multiple backends. Also the time it takes for adding things to the "browser" takes, visually (I guess I should do some profiling here ;-) ), more time than for processing the events... That means we probably need to create a custom hist_entry browser, so that we reuse the structures we have in place instead of duplicating them in newt. But progress was made and at least we can see something while long files are being loaded, that must be one of UI 101 bullet points :-) Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-03-12perf report: Implement initial UI using newtArnaldo Carvalho de Melo
Newt has widespread availability and provides a rather simple API as can be seen by the size of this patch. The work needed to support it will benefit other frontends too. In this initial patch it just checks if the output is a tty, if not it falls back to the previous behaviour, also if newt-devel/libnewt-dev is not installed the previous behaviour is maintaned. Pressing enter on a symbol will annotate it, ESC in the annotation window will return to the report symbol list. More work will be done to remove the special casing in color_fprintf, stop using fmemopen/FILE in the printing of hist_entries, etc. Also the annotation doesn't need to be done via spawning "perf annotate" and then browsing its output, we can do better by calling directly the builtin-annotate.c functions, that would then be moved to tools/perf/util/annotate.c and shared with perf top, etc But lets go by baby steps, this patch already improves perf usability by allowing to quickly do annotations on symbols from the report screen and provides a first experimentation with libnewt/TUI integration of tools. Tested on RHEL5 and Fedora12 X86_64 and on Debian PARISC64 to browse a perf.data file collected on a Fedora12 x86_64 box. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Avi Kivity <avi@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1268349164-5822-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf session: Change perf_session post processing functions to take ↵Eric B Munson
histogram tree Now that report can store historgrams for multiple events we need to be able to do the post processing work for each histogram. This patch changes the post processing functions so that they can be called individually for each event's histogram. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> [ Guarantee bisectabilty by fixing up builtin-report.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-5-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-03-10perf session: Change add_hist_entry to take the tree root instead of sessionEric B Munson
In order to minimize the impact of storing multiple events in a report this function will now take the root of the histogram tree so that the logic for selecting the proper tree can be inserted before the call. Signed-off-by: Eric B Munson <ebmunson@us.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1267804269-22660-3-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf diff: Use perf_session__fprintf_hists just like 'perf record'Arnaldo Carvalho de Melo
That means that almost everything you can do with 'perf report' can be done with 'perf diff', for instance: $ perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2699 samples) ] $ perf record -f find / > /dev/null [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.062 MB perf.data (~2687 samples) ] perf diff | head -8 9.02% +1.00% find libc-2.10.1.so [.] _IO_vfprintf_internal 2.91% -1.00% find [kernel] [k] __kmalloc 2.85% -1.00% find [kernel] [k] ext4_htree_store_dirent 1.99% -1.00% find [kernel] [k] _atomic_dec_and_lock 2.44% find [kernel] [k] half_md4_transform $ So if you want to zoom into libc: $ perf diff --dsos libc-2.10.1.so | head -8 37.34% find [.] _IO_vfprintf_internal 10.34% find [.] __GI_memmove 8.25% +2.00% find [.] _int_malloc 5.07% -1.00% find [.] __GI_mempcpy 7.62% +2.00% find [.] _int_free $ And if there were multiple commands using libc, it is also possible to aggregate them all by using --sort symbol: $ perf diff --dsos libc-2.10.1.so --sort symbol | head -8 37.34% [.] _IO_vfprintf_internal 10.34% [.] __GI_memmove 8.25% +2.00% [.] _int_malloc 5.07% -1.00% [.] __GI_mempcpy 7.62% +2.00% [.] _int_free $ The displacement column now is off by default, to use it: perf diff -m --dsos libc-2.10.1.so --sort symbol | head -8 37.34% [.] _IO_vfprintf_internal 10.34% [.] __GI_memmove 8.25% +2.00% [.] _int_malloc 5.07% -1.00% +2 [.] __GI_mempcpy 7.62% +2.00% -1 [.] _int_free $ Using -t/--field-separator can be used for scripting: $ perf diff -t, -m --dsos libc-2.10.1.so --sort symbol | head -8 37.34, , ,[.] _IO_vfprintf_internal 10.34, , ,[.] __GI_memmove 8.25,+2.00%, ,[.] _int_malloc 5.07,-1.00%, +2,[.] __GI_mempcpy 7.62,+2.00%, -1,[.] _int_free 6.99,+1.00%, -1,[.] _IO_new_file_xsputn 1.89,-2.00%, +4,[.] __readdir64 $ Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260978567-550-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-16perf tools: Move hist entries printing routines from perf reportArnaldo Carvalho de Melo
Will be used in other tools such as 'perf diff'. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260973631-28035-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf session: Move the hist_entries rb tree to perf_sessionArnaldo Carvalho de Melo
As we'll need to sort multiple times for multiple perf sessions, so that we can then do a diff. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260803439-16783-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-12-14perf tools: No need for three rb_trees for sorting hist entriesArnaldo Carvalho de Melo
All hist entries are in only one of them, so use just one and a temporary rb_root while sorting/collapsing. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1260797831-11220-1-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-27perf tools: Consolidate symbol resolving across all toolsArnaldo Carvalho de Melo
Now we have a very high level routine for simple tools to process IP sample events: int event__preprocess_sample(const event_t *self, struct addr_location *al, symbol_filter_t filter) It receives the event itself and will insert new threads in the global threads list and resolve the map and symbol, filling all this info into the new addr_location struct, so that tools like annotate and report can further process the event by creating hist_entries in their specific way (with or without callgraphs, etc). It in turn uses the new next layer function: void thread__find_addr_location(struct thread *self, u8 cpumode, enum map_type type, u64 addr, struct addr_location *al, symbol_filter_t filter) This one will, given a thread (userspace or the kernel kthread one), will find the given type (MAP__FUNCTION now, MAP__VARIABLE too in the near future) at the given cpumode, taking vdsos into account (userspace hit, but kernel symbol) and will fill all these details in the addr_location given. Tools that need a more compact API for plain function resolution, like 'kmem', can use this other one: struct symbol *thread__find_function(struct thread *self, u64 addr, symbol_filter_t filter) So, to resolve a kernel symbol, that is all the 'kmem' tool needs, its just a matter of calling: sym = thread__find_function(kthread, addr, NULL); The 'filter' parameter is needed because we do lazy parsing/loading of ELF symtabs or /proc/kallsyms. With this we remove more code duplication all around, which is always good, huh? :-) Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: John Kacur <jkacur@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1259346563-12568-12-git-send-email-acme@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-03perf tools: Move hist_entry__add common code to hist.cArnaldo Carvalho de Melo
Now perf report and annotate do the callgraph/hit processing in their specialized hist_entry__add functions. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Acked-by: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-30perf tools: Put common histogram functions in their own fileJohn Kacur
Move histogram related functions into their own files (hist.c and hist.h) and make use of them in builtin-annotate.c and builtin-report.c. Signed-off-by: John Kacur <jkacur@redhat.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <alpine.LFD.2.00.0909281531180.8316@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
