Check the return value of strbuf APIs in perf-probe
related code, so that it can handle errors in strbuf.
Signed-off-by: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/20160510054707.6158.69861.stgit@devbox
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
If not, tell the user that:
config/Makefile:273: Old libdw.h, finding variables at given 'perf probe' point will not work, install elfutils-devel/libdw-dev >= 0.157
And return -ENOTSUPP in die_get_var_range(), failing features that
need it, like the one pointed out above.
This fixes the build on older systems, such as Ubuntu 12.04.5.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Vinson Lee <vlee@freedesktop.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-9l7luqkq4gfnx7vrklkq4obs@git.kernel.org
We have addch() for chars, add() for fixed size data, and addstr() for
variable length strings, use them.
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/n/tip-0ap02fn2xtvpduj2j6b2o1j4@git.kernel.org
The commit 75186a9b09e4 (perf probe: Fix to show lines of sys_ functions
correctly) introduced a bug by a missed brace around if block. This
fixes to add it.
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Fixes: 75186a9b09e4 ("perf probe: Fix to show lines of sys_ functions correctly")
Link: http://lkml.kernel.org/r/20150812215541.9088.62425.stgit@localhost.localdomain
"perf probe --lines sys_poll" shows only the first line of sys_poll,
because the SYSCALL_DEFINE macro:
SYSCALL_DEFINE*(foo,...)
body;
is expanded as below (on debuginfo)
static inline int SYSC_foo(...)
body;
int SyS_foo(...) <- is an alias of sys_foo.
return SYSC_foo(...);
So, "perf probe --lines sys_foo" decodes SyS_foo function and it also skips
inlined functions(SYSC_foo) inside the target function because those functions
are usually defined somewhere else.
To fix this issue, this fix checks whether the inlined function is defined at
the same point of the target function, and if so, it doesn't skip the inline
function.
Reported-by: Arnaldo Carvalho de Melo <acme@kernel.org>
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/20150812012406.11811.94691.stgit@localhost.localdomain
Replacing %lu format strings for Dwarf_Addr type with PRIu64 as it fits
for Dwarf_Addr (defined as uint64_t) type and works also on both 32/64
bits.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: He Kuang <hekuang@huawei.com>
Link: http://lkml.kernel.org/r/1431706991-15646-1-git-send-email-jolsa@kernel.org
perf probe currently errors out if there are any tail calls to probed
functions:
[root@rhel71be]# perf probe do_fork
Failed to find probe point in any functions.
Error: Failed to add events.
Fix this by teaching perf to ignore tail calls.
Without patch:
[root@rhel71be perf]# ./perf probe -v do_fork
probe-definition(0): do_fork symbol:do_fork file:(null) line:0 offset:0
return:0 lazy:(null)
0 arguments
Looking at the vmlinux_path (7 entries long)
symsrc__init: build id mismatch for /boot/vmlinux.
Using /usr/lib/debug/lib/modules/3.10.0-201.el7.ppc64/vmlinux for symbols
Open Debuginfo file:
Try to find probe point from debuginfo.
found inline addr: 0xc0000000000bb9b0
Probe point found: do_fork+0
found inline addr: 0xc0000000000bbe20
Probe point found: kernel_thread+48
found inline addr: 0xc0000000000bbe5c
Probe point found: sys_fork+28
found inline addr: 0xc0000000000bbfac
Probe point found: sys_vfork+44
found inline addr: 0xc0000000000bc27c
An error occurred in debuginfo analysis (-2).
Error: Failed to add events. Reason: No such file or directory (Code: -2)
With patch:
0 arguments
Ignoring tail call from SyS_clone
Found 4 probe_trace_events.
Opening /sys/kernel/debug/tracing/kprobe_events write=1
No kprobe blacklist support, ignored
Added new events:
Writing event: p:probe/do_fork _text+768432
Failed to write event: Invalid argument
Error: Failed to add events. Reason: Invalid argument (Code: -22)
[Ignore the error about failure to write event - this kernel is missing
a patch to resolve _text properly]
The reason to ignore tail calls is that the address does not belong to
any function frame. In the example above, the address in SyS_clone is
0xc0000000000bc27c, but looking at the debug-info:
<1><830081>: Abbrev Number: 133 (DW_TAG_subprogram)
<830083> DW_AT_external : 1
<830083> DW_AT_name : (indirect string, offset: 0x3cea3): SyS_clone
<830087> DW_AT_decl_file : 7
<830088> DW_AT_decl_line : 1689
<83008a> DW_AT_prototyped : 1
<83008a> DW_AT_type : <0x8110eb>
<83008e> DW_AT_low_pc : 0xc0000000000bc270
<830096> DW_AT_high_pc : 0xc
<83009e> DW_AT_frame_base : 1 byte block: 9c (DW_OP_call_frame_cfa)
<8300a0> DW_AT_GNU_all_call_sites: 1
<8300a0> DW_AT_sibling : <0x830178>
<snip>
<3><830147>: Abbrev Number: 125 (DW_TAG_GNU_call_site)
<830148> DW_AT_low_pc : 0xc0000000000bc27c
<830150> DW_AT_GNU_tail_call: 1
<830150> DW_AT_abstract_origin: <0x82e7e1>
The frame ends at 0xc0000000000bc27c. I suppose this is why this
particular call is a "tail" call. FWIW, systemtap seems to ignore these
as well and requires users to explicitly place probes at these call
sites if necessary. I print out the caller so that users know.
Signed-off-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/1430394151-15928-1-git-send-email-naveen.n.rao@linux.vnet.ibm.com
It is not easy for users to get the accurate byte offset or the line
number where a local variable can be probed.
With '--range' option, local variables in the scope of the probe point
are showed with a byte offset range, and can be added according to this
range information.
For example, there are some variables in the function
generic_perform_write():
<generic_perform_write@mm/filemap.c:0>
0 ssize_t generic_perform_write(struct file *file,
1 struct iov_iter *i, loff_t pos)
2 {
3 struct address_space *mapping = file->f_mapping;
4 const struct address_space_operations *a_ops = mapping->a_ops;
42 status = a_ops->write_begin(file, mapping, pos, bytes, flags,
&page, &fsdata);
44 if (unlikely(status < 0))
But we fail when we try to probe the variable 'a_ops' at line 42 or 44.
$ perf probe --add 'generic_perform_write:42 a_ops'
Failed to find the location of a_ops at this address.
Perhaps, it has been optimized out.
This is because the source code do not match the assembly, so a variable
may not be available in the source code line where it appears.
After this patch, we can lookup the accurate byte offset range of a
variable, 'INV' indicates that this variable is not valid at the given
point, but available in the scope:
$ perf probe --vars 'generic_perform_write:42' --range
Available variables at generic_perform_write:42
@<generic_perform_write+141>
[INV] ssize_t written @<generic_perform_write+[324-331]>
[INV] struct address_space_operations* a_ops @<generic_perform_write+[55-61,170-176,223-246]>
[VAL] (unknown_type) fsdata @<generic_perform_write+[70-307,346-411]>
[VAL] loff_t pos @<generic_perform_write+[0-286,286-336,346-411]>
[VAL] long int status @<generic_perform_write+[83-342,346-411]>
[VAL] long unsigned int bytes @<generic_perform_write+[122-311,320-338,346-403,403-411]>
[VAL] struct address_space* mapping @<generic_perform_write+[35-344,346-411]>
[VAL] struct iov_iter* i @<generic_perform_write+[0-340,346-411]>
[VAL] struct page* page @<generic_perform_write+[70-307,346-411]>
Then it is more clear for us to add a probe with this variable:
$ perf probe --add 'generic_perform_write+170 a_ops'
Added new event:
probe:generic_perform_write (on generic_perform_write+170 with a_ops)
Signed-off-by: He Kuang <hekuang@huawei.com>
Link: http://lkml.kernel.org/r/1431336304-16863-2-git-send-email-hekuang@huawei.com
Use struct strbuf instead of bare char[] to remove the length limitation
of variables in variable_list, so they will not disappear due to
overlength, and make preparation for adding more description for
variables.
Link: http://lkml.kernel.org/r/1431336304-16863-1-git-send-email-hekuang@huawei.com
Support glob wildcards for function name when adding new probes. This
will allow us to build caches of function-entry level information with
$params.
e.g.
# perf probe --no-inlines --add 'kmalloc* $params'
Added new events:
probe:kmalloc_slab (on kmalloc* with $params)
probe:kmalloc_large_node (on kmalloc* with $params)
probe:kmalloc_order_trace (on kmalloc* with $params)
You can now use it in all perf tools, such as:
perf record -e probe:kmalloc_order_trace -aR sleep 1
# perf probe --list
probe:kmalloc_large_node (on kmalloc_large_node@mm/slub.c with size flags node)
probe:kmalloc_order_trace (on kmalloc_order_trace@mm/slub.c with size flags order)
probe:kmalloc_slab (on kmalloc_slab@mm/slab_common.c with size flags)
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: Hemant Kumar <hemant@linux.vnet.ibm.com>
Link: http://lkml.kernel.org/r/20150508010335.24812.19972.stgit@localhost.localdomain
Fix 'perf probe' to track down unnamed union/structure members.
perf probe did not track down the tree of unnamed union/structure
members, since it just failed to find given "name" in a parent
structure/union. To solve this issue, I've introduced 2 changes.
- Fix die_find_member() to track down the type-DIE if it is
unnamed, and if it contains the specified member, returns the
unnamed member.
(note that we don't return found member, since unnamed member
has the offset in the parent structure)
- Fix convert_variable_fields() to track down the unnamed union/
structure (one-by-one).
With this patch, perf probe can access unnamed fields:
#./perf probe -nfx ./perf lock__delete ops 'locked_ops=ops->locked.ops'
Added new event:
probe_perf:lock__delete (on lock__delete in /home/mhiramat/ksrc/linux-3/tools/perf/perf with ops locked_ops=ops->locked.ops)
perf record -e probe_perf:lock__delete -aR sleep 1
Report-Link: https://lkml.org/lkml/2015/3/5/431
Link: http://lkml.kernel.org/r/20150402073312.14482.37942.stgit@localhost.localdomain
Fix to handle optimized no-inline functions which have only function
definition but no actual instance at that point.
To fix this problem, we need to find actual instance of the function.
Without this patch:
# perf probe -a __up
Failed to get entry address of __up.
# perf probe -L __up
Specified source line is not found.
Error: Failed to show lines.
With this patch:
Added new event:
probe:__up (on __up)
perf record -e probe:__up -aR sleep 1
<__up@/home/fedora/ksrc/linux-3/kernel/locking/semaphore.c:0>
0 static noinline void __sched __up(struct semaphore *sem)
struct semaphore_waiter *waiter = list_first_entry(&sem->wait_
4 list_del(&waiter->list);
5 waiter->up = true;
6 wake_up_process(waiter->task);
7 }
Link: http://lkml.kernel.org/r/20150130093744.30575.43290.stgit@localhost.localdomain
Fix perf probe to find correct variable DIE which has location or
external instance by tracking down the lexical blocks.
Current die_find_variable() expects that the all variable DIEs
which has DW_TAG_variable have a location. However, since recent
dwarf information may have declaration variable DIEs at the
entry of function (subprogram), die_find_variable() returns it.
To solve this problem, it must track down the DIE tree to find
a DIE which has an actual location or a reference for external
instance.
e.g. finding a DIE which origin is <0xdc73>;
<1><11496>: Abbrev Number: 95 (DW_TAG_subprogram)
<11497> DW_AT_abstract_origin: <0xdc42>
<1149b> DW_AT_low_pc : 0x1850
<2><114cc>: Abbrev Number: 119 (DW_TAG_variable) <- this is a declaration
<114cd> DW_AT_abstract_origin: <0xdc73>
<2><114d1>: Abbrev Number: 119 (DW_TAG_variable)
<3><115a7>: Abbrev Number: 105 (DW_TAG_lexical_block)
<115a8> DW_AT_ranges : 0xaa0
<4><115ac>: Abbrev Number: 96 (DW_TAG_variable) <- this has a location
<115ad> DW_AT_abstract_origin: <0xdc73>
<115b1> DW_AT_location : 0x486c (location list)
Tested-by: Arnaldo Carvalho de Melo <acme@kernel.org>
Acked-by: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Link: http://lkml.kernel.org/r/20140529121930.30879.87092.stgit@ltc230.yrl.intra.hitachi.co.jp
Fix to find the correct (as much as possible) line information for
listing probes. Without this fix, perf probe --list action will show
incorrect line information as below;
probe:getname_flags (on getname_flags@ksrc/linux-3/fs/namei.c)
probe:getname_flags_1 (on getname:-89@x86/include/asm/current.h)
probe:getname_flags_2 (on user_path_at_empty:-2054@x86/include/asm/current.h)
The minus line number is obviously wrong, and current.h is not related
to the probe point. Deeper investigation discovered that there were 2
issues related to this bug, and minor typos too.
The 1st issue is the rack of considering about nested inlined functions,
which causes the wrong (relative) line number.
The 2nd issue is that the dwarf line info is not correct at those
points. It points 14th line of current.h.
Since it seems that the line info includes somewhat unreliable
information, this fixes perf to try to find correct line information
from both of debuginfo and line info as below.
1) Probe address is the entry of a function instance
In this case, the line is set as the function declared line.
2) Probe address is the entry of an expanded inline function block
In this case, the line is set as the function call-site line.
This means that the line number is relative from the entry line
of caller function (which can be an inlined function if nested)
3) Probe address is inside a function instance or an expanded
In this case, perf probe queries the line number from lineinfo
and verify the function declared file is same as the file name
queried from lineinfo.
If the file name is different, it is a failure case. The probe
address is shown as symbol+offset.
4) Probe address is not in the any function instance
This is a failure case, the probe address is shown as
symbol+offset.
With this fix, perf probe -l shows correct probe lines as below;
probe:getname_flags_1 (on getname:2@ksrc/linux-3/fs/namei.c)
probe:getname_flags_2 (on user_path_at_empty:4@ksrc/linux-3/fs/namei.c)
Changes at v2:
- Fix typos in the function comments. (Thanks to Namhyung Kim)
- Use die_find_top_inlinefunc instead of die_find_inlinefunc_next.
Link: http://lkml.kernel.org/r/20130930092144.1693.11058.stgit@udc4-manage.rcp.hitachi.co.jp
The commit ba28c59bc9ed8fb7b9a753cd88ee54a2c4f6265b fixed a declaration
entry bug in probe_point_search_cb(). There are same bugs in line
finder and call_probe_finder(). This introduces a new dwarf utility
function to determine given DIE is a function definition, not
declaration.
Cc: Prashanth Nageshappa <prashanth@linux.vnet.ibm.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
Cc: yrl.pp-manager.tt@hitachi.com
Link: http://lkml.kernel.org/r/20120423032435.8737.80064.stgit@localhost.localdomain
showing accessible variables
When showing accessible variables, an enum type variable was printed in
"variable-name" format. Change this format into "enum variable-name".
Signed-off-by: Hyeoncheol Lee <hyc.lee@gmail.com>
Link: http://lkml.kernel.org/r/1348713399-4541-1-git-send-email-hyc.lee@gmail.com
With gcc4.6, some instances of concrete inlined function looks redundant
and broken, because it appears inside of a concrete instance and its
call_file and call_line are same as the original abstruct's decl_file
and decl_line respectively.
e.g.
[ d1aa] subprogram
external (flag) Yes
name (strp) "add_timer"
decl_file (data1) 2 ;here is original
decl_line (data2) 847 ;line and file
prototyped (flag) Yes
inline (data1) inlined (1)
sibling (ref4) [ d1c6]
[ 11d84] subprogram
abstract_origin (ref4) [ d1aa] ; concrete instance
low_pc (addr) .text+0x000000000000246f <add_timer>
high_pc (addr) .text+0x000000000000248b <mod_timer_pending>
frame_base (block1) [ 0] call_frame_cfa
sibling (ref4) [ 11dd9]
[ 11d9f] formal_parameter
abstract_origin (ref4) [ d1b9]
location (data4) location list [ 701b]
[ 11da8] inlined_subroutine
abstract_origin (ref4) [ d1aa] ; redundant instance
low_pc (addr) .text+0x000000000000247e <add_timer+0xf>
high_pc (addr) .text+0x0000000000002480 <add_timer+0x11>
call_file (data1) 2 ; call line and file
call_line (data2) 847 ; are same as above
Those redundant instances leads unwilling results;
e.g. find probe points inside of functions even if we specify
a function entry as below;
$ perf probe -V add_timer
Available variables at add_timer
@<add_timer+0>
struct timer_list* timer
@<add_timer+15>
(No matched variables)
So, this filters out those redundant instances based on call-site and
decl-site information.
Cc: Pekka Enberg <penberg@kernel.org>
Link: http://lkml.kernel.org/r/20110811110317.19900.59525.stgit@fedora15
gcc 4.6 generates a concrete out-of-line instance when there is a
function which is implicitly inlined somewhere but also has its own
instance. The concrete out-of-line instance means that it has an
abstract origin of the function which is referred by not only
inlined-subroutines but also a concrete subprogram.
Since current dwarf_func_inline_instances() can find only instances of
inlined-subroutines, this introduces new die_walk_instances() to find
both of subprogram and inlined-subroutines.
e.g. without this,
Available variables at sched_group_rt_period
@<cpu_rt_period_read_uint+9>
struct task_group* tg
perf probe failed to find actual subprogram instance of
sched_group_rt_period().
With this,
@<sched_group_rt_period+0>
Now it found the sched_group_rt_period() itself.
Link: http://lkml.kernel.org/r/20110811110311.19900.63997.stgit@fedora15
Fix perf probe to search local variables in appropriate local inlined
function scope. For example, pre_schedule() has only 2 local variables,
as below;
$ perf probe -L pre_schedule
<pre_schedule@/home/mhiramat/ksrc/linux-2.6/kernel/sched.c:0>
0 static inline void pre_schedule(struct rq *rq, struct task_struct *prev)
2 if (prev->sched_class->pre_schedule)
3 prev->sched_class->pre_schedule(rq, prev);
However, current perf probe shows 4 local variables on pre_schedule(),
because it searches variables in the caller(schedule()) scope.
$ perf probe -V pre_schedule
Available variables at pre_schedule
@<schedule+445>
int cpu
long unsigned int* switch_count
struct rq* rq
struct task_struct* prev
This patch fixes this issue by searching variables in the local scope of
the instance of inlined function. Here is the result.
@<schedule+445>
struct rq* rq
Link: http://lkml.kernel.org/r/20110811110259.19900.85664.stgit@fedora15
Fix perf probe to walk through the lines of all nested inlined function
call sites and declared lines when a whole CU is passed to the line
walker.
The die_walk_lines() can have two different type of DIEs, subprogram (or
inlined-subroutine) DIE and CU DIE.
If a caller passes a subprogram DIE, this means that the walker walk on
lines of given subprogram. In this case, it just needs to search on
direct children of DIE tree for finding call-site information of inlined
function which directly called from given subprogram.
On the other hand, if a caller passes a CU DIE to the walker, this means
that the walker have to walk on all lines in the source files included
in given CU DIE. In this case, it has to search whole DIE trees of all
subprograms to find the call-site information of all nested inlined
functions.
Without this patch:
$ perf probe --line kernel/cpu.c:151-157
</home/mhiramat/ksrc/linux-2.6/kernel/cpu.c:151>
static int cpu_notify(unsigned long val, void *v)
154 return __cpu_notify(val, v, -1, NULL);
With this:
152 static int cpu_notify(unsigned long val, void *v)
As you can see, --line option with source line range shows the declared
lines as probe-able.
Link: http://lkml.kernel.org/r/20110811110241.19900.34994.stgit@fedora15
Fix line walker to check whether a given DIE is CU or not.
Actually this function accepts CU, subprogram and inlined_subroutine
DIEs.
Without this fix, perf probe always fails to analyze lines on inlined
functions;
Debuginfo analysis failed. (-2)
Error: Failed to show lines. (-2)
This fixes that bug, as below.
/* rq->lock is NOT held, but preemption is disabled */
Changes from v1:
- Update against current tip tree.(Fix dwarf-aux.c)
Cc: Masami Hiramatsu <masami.hiramatsu@gmail.com>
Link: http://lkml.kernel.org/r/20110811110235.19900.20614.stgit@fedora15
Signed-off-by: Masami Hiramatsu <masami.hiramatsu@gmail.com>
Move dwarf library related routines to dwarf-aux.{c,h}.
This includes several minor changes.
- Add simple documents for each API.
- Rename die_find_real_subprogram() to die_find_realfunc()
- Rename line_walk_handler_t to line_walk_callback_t.
- Minor cleanups.
Cc: Arnaldo Carvalho de Melo <acme@ghostprotocols.net>
Link: http://lkml.kernel.org/r/20110627072727.6528.57647.stgit@fedora15
