commit 8381cdd0e32dd748bd34ca3ace476949948bd793 upstream.
The -o/--order option is to select column number to sort a diff result.
It does the job by adding a hpp field at the beginning of the sort list.
But it should not be added to the output field list as it has no
callbacks required by a output field.
During the setup_sorting(), the perf_hpp__setup_output_field() appends
the given sort keys to the output field if it's not there already.
Originally it was checked by fmt->list being non-empty. But commit
3f931f2c4274 ("perf hists: Make hpp setup function generic") changed it
to check the ->equal callback.
Anyways, we don't need to add the pseudo hpp field to the output field
list since it won't be used for output. So just skip fields if they
have no ->color or ->entry callbacks.
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Fixes: 3f931f2c4274 ("perf hists: Make hpp setup function generic")
Link: http://lkml.kernel.org/r/20170118051457.30946-1-namhyung@kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
commit a1c9f97f0b64e6337d9cfcc08c134450934fdd90 upstream.
Commit 21e6d8428664 ("perf diff: Use perf_hpp__register_sort_field
interface") changed list_add() to perf_hpp__register_sort_field().
This resulted in a behavior change since the field was added to the tail
instead of the head. So the -o option is mostly ignored due to its
order in the list.
This patch fixes it by adding perf_hpp__prepend_sort_field().
Fixes: 21e6d8428664 ("perf diff: Use perf_hpp__register_sort_field interface")
Link: http://lkml.kernel.org/r/20170118051457.30946-2-namhyung@kernel.org
Will be used from external places in the upcoming c2c patch series.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: David Ahern <dsahern@gmail.com>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Joe Mario <jmario@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1474558645-19956-8-git-send-email-jolsa@kernel.org
The stdio and tui has same code to reset hpp format column width.
Factor it out as a new function.
Suggested-and-Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/20160920053025.13989-2-namhyung@kernel.org
Add span argument for header callback function.
The handling of this argument is completely in the hands of the
callback. The only thing the caller ensures is it's zeroed on the
beginning.
Omitting span skipping in hierarchy headers and gtk code.
The c2c code use this to span header lines based on the entries span
configuration.
Link: http://lkml.kernel.org/r/1470583710-1649-6-git-send-email-jolsa@kernel.org
Adding line argument into perf_hpp_fmt's header callback to be able to
request specific header line.
Link: http://lkml.kernel.org/r/1470583710-1649-3-git-send-email-jolsa@kernel.org
Currently we support just single line headers, this is first step to
allow more.
Store the number of header lines in perf_hpp_list, which encompasses all
the display/sort entries and is thus suitable to hold this value.
Link: http://lkml.kernel.org/r/1470583710-1649-2-git-send-email-jolsa@kernel.org
To match the semantics for list.h in the kernel, that are used to
implement those macros.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Milian Wolff <milian.wolff@kdab.com>
Cc: Taeung Song <treeze.taeung@gmail.com>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-qbcjlgj0ffxquxscahbpddi3@git.kernel.org
Replacing perf_evsel arg perf_hpp_fmt's width callback with hists
object.
This will be helpful in future for non evsel related hist browsers.
Link: http://lkml.kernel.org/r/1465928361-2442-11-git-send-email-jolsa@kernel.org
Replacing perf_evsel arg perf_hpp_fmt's header callback with hists
object.
None of the actual callbacks actually use evsel object, also this will
Link: http://lkml.kernel.org/r/1465928361-2442-10-git-send-email-jolsa@kernel.org
Now we have sort dimensions private for struct hists, we need to make
dimension booleans hists specific as well.
Moving sort__has_sym into struct perf_hpp_list.
Link: http://lkml.kernel.org/r/1462276488-26683-4-git-send-email-jolsa@kernel.org
The nr_sort_keys field is to carry the number of sort entries in a
hpp_list or hists to determine the depth of indentation of a hist entry.
As it's only used in hierarchy mode and now we have used nr_hpp_node for
this reason, there's no need to keep it anymore. Let's get rid of it.
Tested-by: Jiri Olsa <jolsa@kernel.org>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1457531222-18130-7-git-send-email-namhyung@kernel.org
When multiple sort keys are used in a single hierarchy, it should indent
using number of hierarchy levels instead of number of sort keys.
Cc: Alexander Shishkin <alexander.shishkin@linux.intel.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1457361308-514-5-git-send-email-namhyung@kernel.org
Now each hists has its own hpp lists in hierarchy. So instead of having
a pointer to a single perf_hpp_fmt in a hist entry, make it point the
hpp_list for its level. This will be used to support multiple sort keys
in a single hierarchy level.
Link: http://lkml.kernel.org/r/1457361308-514-3-git-send-email-namhyung@kernel.org
The perf_hpp__setup_hists_formats() is to build hists-specific output
formats (and sort keys). Currently it's only used in order to build the
output format in a hierarchy with same sort keys, but it could be used
with different sort keys in non-hierarchy mode later.
Link: http://lkml.kernel.org/r/1457361308-514-2-git-send-email-namhyung@kernel.org
The hists__overhead_width() is to calculate width occupied by the
overhead (and others) columns before the sort columns.
The hist_entry__has_hiearchy_children() is to check whether an entry has
lower entries (children) in the hierarchy to be shown in the output.
This means the children should not be filtered out and above the percent
limit.
These two functions will be used to show information when all children
of an entry is omitted by the percent limit (or filter).
Link: http://lkml.kernel.org/r/1456488800-28124-1-git-send-email-namhyung@kernel.org
It'll be used for hierarchy output mode to indent entries properly.
Link: http://lkml.kernel.org/r/1456326830-30456-9-git-send-email-namhyung@kernel.org
The dynamic entry is created for each field in a tracepoint event.
Since they have no fixed hpp format index, it should skip when
perf_hpp__reset_width() is called.
This caused following assertion failure..
$ perf record -e sched:sched_switch -a sleep 1
$ perf report -s comm,next_pid --stdio
perf: ui/hist.c:651: perf_hpp__reset_width:
Assertion `!(fmt->idx >= PERF_HPP__MAX_INDEX)' failed.
Link: http://lkml.kernel.org/r/1456064558-13086-1-git-send-email-namhyung@kernel.org
With the hist object having the perf_hpp_list we can now iterate output
format entries based in the hists object. Adding hists__for_each_format
macro to do that.
Link: http://lkml.kernel.org/r/1453109064-1026-26-git-send-email-jolsa@kernel.org
Adding struct perf_hpp_list argument to following helper functions:
void perf_hpp__setup_output_field(struct perf_hpp_list *list);
void perf_hpp__reset_output_field(struct perf_hpp_list *list);
void perf_hpp__append_sort_keys(struct perf_hpp_list *list);
so they could be used on hists's hpp_list.
Link: http://lkml.kernel.org/r/1453109064-1026-24-git-send-email-jolsa@kernel.org
Introducing perf_hpp_list__for_each_sort_list_safe macro
to iterate perf_hpp_list object's sort entries safely.
Link: http://lkml.kernel.org/r/1453109064-1026-23-git-send-email-jolsa@kernel.org
Introducing perf_hpp_list__for_each_sort_list macro to iterate
perf_hpp_list object's sort entries.
Link: http://lkml.kernel.org/r/1453109064-1026-22-git-send-email-jolsa@kernel.org
Introducing perf_hpp_list__for_each_format_safe macro to iterate
perf_hpp_list object's output entries safely.
Link: http://lkml.kernel.org/r/1453109064-1026-21-git-send-email-jolsa@kernel.org
Introducing perf_hpp_list__for_each_format macro to iterate
perf_hpp_list object's output entries.
Link: http://lkml.kernel.org/r/1453109064-1026-20-git-send-email-jolsa@kernel.org
Adding 2 perf_hpp_list register helpers:
perf_hpp_list__column_register()
perf_hpp_list__register_sort_field()
to be called within existing helpers:
perf_hpp__column_register()
to register format entries within global perf_hpp_list object.
Link: http://lkml.kernel.org/r/1453109064-1026-17-git-send-email-jolsa@kernel.org
Gather output and sort lists under struct perf_hpp_list, so we could
have multiple instancies of sort/output format entries.
Replacing current perf_hpp__list and perf_hpp__sort_list lists with
single perf_hpp_list instance.
Link: http://lkml.kernel.org/r/1453109064-1026-15-git-send-email-jolsa@kernel.org
[ Renamed fields to .{fields,sorts} as suggested by Namhyung and acked by Jiri ]
With multiple list holding format entries, we need the support properly
releasing format output/sort fields.
Link: http://lkml.kernel.org/r/1453109064-1026-12-git-send-email-jolsa@kernel.org
Those functions are no longer needed. They operate over perf_hpp__format
array which is now used only as template for dynamic entries.
Link: http://lkml.kernel.org/r/1453109064-1026-11-git-send-email-jolsa@kernel.org
Currently we use static output fields, because we have single global
list of all sort/output fields.
We will add hists specific sort and output lists in following patches,
so we need all format entries to be dynamically allocated. Adding
support to allocate output sort field.
Link: http://lkml.kernel.org/r/1453109064-1026-10-git-send-email-jolsa@kernel.org
Now that we have the 'equal' method implemented for hpp format entries
we can ease up the logic in the following functions and make them
generic wrt comparing format entries:
Link: http://lkml.kernel.org/r/1453109064-1026-8-git-send-email-jolsa@kernel.org
Adding 'hpp__equal' callback function to compare hpp output format
entries.
Link: http://lkml.kernel.org/r/1453109064-1026-7-git-send-email-jolsa@kernel.org
To easily compare format entries and make it available for all kinds of
format entries.
Link: http://lkml.kernel.org/r/1453109064-1026-6-git-send-email-jolsa@kernel.org
We are going to add dynamic hpp format fields, so we need to make the
'len' change for the format itself, not in the perf_hpp__format
template.
Link: http://lkml.kernel.org/r/1453109064-1026-5-git-send-email-jolsa@kernel.org
Currently there's no way of comparing hpp format entries, which is
needed in following patches.
Adding _idx fields into struct perf_hpp_fmt to recognize and be able to
compare hpp format entries.
Link: http://lkml.kernel.org/r/1453109064-1026-4-git-send-email-jolsa@kernel.org
We currently set 'overhead' and 'overhead_children' as default sort keys
within perf_hpp__init function by directly adding into the sort list.
This patch adds 'overhead' and 'overhead_children' in text form into
sort_keys and let them be added by standard sort dimension interface.
We need to eliminate dirrect sort_list additions to be able to add
support for hists specific sort keys.
Acked-by: Namhyung Kim <namhyung@kernel.org>
Cc: Noel Grandin <noelgrandin@gmail.com>
Link: http://lkml.kernel.org/r/1452158050-28061-12-git-send-email-jolsa@kernel.org
When there are multiple events, each dynamic sort key is defined just
for one event. In this case other events will always show "N/A" for
those fields. But they are meaningless and consume precious screen
width.
Let's skip those undefined dynamic fields.
$ perf record -e kmem:kmalloc,kmem:kfree -a sleep 1
$ perf report -s 'comm,kmalloc.*' --stdio
# To display the perf.data header info, please use --header/--header-only options.
# Total Lost Samples: 0
# Samples: 20K of event 'kmem:kmalloc'
# Event count (approx.): 20533
# Overhead Command call_site ptr bytes_req bytes_alloc gfp_flags
99.89% perf ffffffffa01d4396 0xffff8803ffb79720 96 96 GFP_NOFS|GFP_ZERO
0.06% sleep ffffffff8114e1cd 0xffff8803d228a000 4096 4096 GFP_KERNEL
0.03% perf ffffffff811d6ae6 0xffff8803f7678f00 240 256 GFP_KERNEL|GFP_ZERO
0.00% perf ffffffff812263c1 0xffff880406172380 128 128 GFP_KERNEL
0.00% perf ffffffff812264b9 0xffff8803ffac1600 504 512 GFP_KERNEL
0.00% perf ffffffff81226634 0xffff880401dc5280 28 32 GFP_KERNEL
0.00% sleep ffffffff81226da9 0xffff8803ffac3a00 392 512 GFP_KERNEL
# Samples: 20K of event 'kmem:kfree'
# Event count (approx.): 20597
# Overhead Command
99.63% perf
0.14% sleep
0.11% irq/36-iwlwifi
0.11% kworker/u16:0
0.01% Xorg
0.00% firefox
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/1450804030-29193-12-git-send-email-namhyung@kernel.org
The perf_hpp__init currently does not respect sorting dimensions and the
setup_sorting function could endup queueing same format twice. That
screwed up the perf_hpp__list and got stuck in loop within
perf_hpp__setup_output_field function.
$ perf report -F +overhead
0x00000000004c1355 in perf_hpp__is_sort_entry (format=format@entry=0x880440 <perf_hpp.format>) at util/sort.c:1506
1506 {
#0 0x00000000004c1355 in perf_hpp__is_sort_entry (format=format@entry=0x880440 <perf_hpp.format>) at util/sort.c:1506
#1 0x00000000004c139d in perf_hpp__same_sort_entry (a=a@entry=0x880440 <perf_hpp.format>, b=b@entry=0x2bb2fe0) at util/sort.c:1380
#2 0x00000000004f8d3c in perf_hpp__setup_output_field () at ui/hist.c:554
#3 0x00000000004c1d1e in setup_sorting () at util/sort.c:1984
#4 0x000000000042efbf in cmd_report (argc=0, argv=0x7ffea5a0e790, prefix=<optimized out>) at builtin-report.c:874
#5 0x0000000000476f13 in run_builtin (p=p@entry=0x875628 <commands+168>, argc=argc@entry=3, argv=argv@entry=0x7ffea5a0e790) at perf.c:385
#6 0x000000000047710b in handle_internal_command (argc=3, argv=0x7ffea5a0e790) at perf.c:445
#7 0x0000000000477176 in run_argv (argcp=argcp@entry=0x7ffea5a0e5fc, argv=argv@entry=0x7ffea5a0e5f0) at perf.c:489
#8 0x00000000004773e7 in main (argc=3, argv=0x7ffea5a0e790) at perf.c:606
Using hpp_dimension__add_output function to register the output column.
It will also mark the dimension as taken and omit above stuck.
Reported-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/1444134312-29136-4-git-send-email-jolsa@kernel.org
Currently ->cmp, ->collapse and ->sort callbacks doesn't pass
corresponding fmt. But it'll be needed by upcoming changes in
perf diff command.
Suggested-by: Jiri Olsa <jolsa@kernel.org>
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1420677949-6719-6-git-send-email-namhyung@kernel.org
[ fix build by passing perf_hpp_fmt pointer to hist_entry__cmp_ methods ]
When perf report --children resorts output fields, it tries to put
caller above the callee. But this was only meaningful for a same thread
and doing this requires callchain enabled. So fix its check before
comparing the callchain depth.
This also changes the hist accumulation tests: In test 3, xmalloc in
bash thread should be above than other perf threads due to alphabetical
order of comm string. Also it's under page_fault in bash thread since
alphabetical order of dso name. The sys_perf_event_open in perf thread
is put on the last line since it's self overhead is 0.
In test 4, the sys_perf_event_open is put above other perf entries that
have same children overhead since its callchain depth is smaller.
Link: http://lkml.kernel.org/r/1419309381-2593-1-git-send-email-namhyung@kernel.org
The calloc() and xcalloc() functions takes @nmemb first and then @size. Fix all w/
pattern "calloc\s*(\s*sizeof".
Signed-off-by: Arjun Sreedharan <arjun024@gmail.com>
Cc: "Yann E. MORIN" <yann.morin.1998@free.fr>
Link: http://lkml.kernel.org/r/1417866043-1877-1-git-send-email-arjun024@gmail.com
Adding support to add field(s) to default field order via using the '+'
prefix, like for report:
$ perf report
Samples: 10 of event 'cycles', Event count (approx.): 4463799
Overhead Command Shared Object Symbol
32.40% ls [kernel.kallsyms] [k] filemap_fault
28.19% ls [kernel.kallsyms] [k] get_page_from_freelist
23.38% ls [kernel.kallsyms] [k] enqueue_entity
15.04% ls [kernel.kallsyms] [k] mmap_region
$ perf report -F +period,sample
Overhead Period Samples Command Shared Object Symbol
32.40% 1446493 1 ls [kernel.kallsyms] [k] filemap_fault
28.19% 1258486 1 ls [kernel.kallsyms] [k] get_page_from_freelist
23.38% 1043754 1 ls [kernel.kallsyms] [k] enqueue_entity
15.04% 671160 1 ls [kernel.kallsyms] [k] mmap_region
Works in general for commands using --field option.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Jean Pihet <jean.pihet@linaro.org>
Link: http://lkml.kernel.org/r/1408715919-25990-2-git-send-email-jolsa@kernel.org
When perf report runs on TUI, 'P' key dumps current screen to a file but
it incorrectly displayed children overhead (as same of self overhead).
This was because it fetched the value from self stats.
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/1408522080-26556-2-git-send-email-namhyung@kernel.org
It makes the code a bit simpler and easier to debug IMHO.
I guess it can also remove similar code in perf diff, but let's keep
it for a future work. :)
Link: http://lkml.kernel.org/r/1406785662-5534-7-git-send-email-namhyung@kernel.org
Set column width and do not change it if user gives -w/--column-widths
option. It'll truncate longer symbols than the width if exists.
Link: http://lkml.kernel.org/r/1406785662-5534-5-git-send-email-namhyung@kernel.org
Save column length in the hpp format and pass it to print functions.
This is a preparation for users to control column width in the output.
Link: http://lkml.kernel.org/r/1406785662-5534-4-git-send-email-namhyung@kernel.org
So that it can properly handle alignment requirements later. To do
that, add percent_color_len_snprintf() fucntion to help coloring of
overhead columns.
Link: http://lkml.kernel.org/r/1406785662-5534-3-git-send-email-namhyung@kernel.org
Depending on the configuration perf inserts/removes the Children
column in the output automatically. But it might not be what user
wants if [s]he give --fields option explicitly.
Tested-by: Rodrigo Campos <rodrigo@sdfg.com.ar>
Cc: Arun Sharma <asharma@fb.com>
Link: http://lkml.kernel.org/r/1401335910-16832-18-git-send-email-namhyung@kernel.org
Sometimes it needs to disable some columns at runtime. Add help
functions to support that.
Tested-by: Arun Sharma <asharma@fb.com>
Link: http://lkml.kernel.org/r/1401335910-16832-15-git-send-email-namhyung@kernel.org
Print accumulated stat of a hist entry if requested.
To do that, add new HPP_PERCENT_ACC_FNS macro and generate a
perf_hpp_fmt using it. The __hpp__sort_acc() function sorts entries
by accumulated period value. When accumulated periods of two entries
are same (i.e. single path callchain) put the caller above since
accumulation tends to put callers on higher position for obvious
reason.
Also add "overhead_children" output field to be selected by user.
Link: http://lkml.kernel.org/r/1401335910-16832-11-git-send-email-namhyung@kernel.org
The reset_output_field() function is for clearing output field
settings and will be used for test code in later patch.
Link: http://lkml.kernel.org/r/1400480762-22852-19-git-send-email-namhyung@kernel.org
