path: root/tools/perf/scripts/perl/Perf-Trace-Util
2010-12-25perf script: Finish the rename from trace to scriptArnaldo Carvalho de Melo
The scripts have calls to 'perf trace' that need to be converted to 'perf script', do it. This problem was introduced in 133dc4c. Reported-by: Torok Edwin <edwintorok@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Torok Edwin <edwintorok@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-14perf trace/scripting: Add rwtop and sctop scriptsTom Zanussi
A couple of scripts, one in Python and the other in Perl, that demonstrate 'live mode' tracing. For each, the output of the perf event stream is fed continuously to the script, which continuously aggregates the data and reports the current results every 3 seconds, or at the optionally specified interval. After the current results are displayed, the aggregations are cleared and the cycle begins anew. To run the scripts, simply pipe the output of the 'perf trace record' step as input to the corresponding 'perf trace report' step, using '-' as the filename to -o and -i: $ perf trace record sctop -o - | perf trace report sctop -i - Also adds clear_term() utility functions to the Util.pm and Util.py utility modules, for use by any script to clear the screen. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org Cc: k-keiichi@bx.jp.nec.com Cc: acme@ghostprotocols.net LKML-Reference: <1270184365-8281-10-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2010-02-23perf/scripts: Move common code out of Perl-specific filesTom Zanussi
This stuff is needed by all scripting engines; move it from the Perl engine source to a more common place. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1264580883-15324-4-git-send-email-tzanussi@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2010-02-23perf/scripts: Fix bug in Util.pmTom Zanussi
Fix bogus calculation. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Keiichi KII <k-keiichi@bx.jp.nec.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1264580883-15324-3-git-send-email-tzanussi@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-11-30perf trace/scripting: Add Fedora libperl install note to docTom Zanussi
Fedora needs perl-ExtUtils-Embed for Perl scripting, which also brings along libperl-devel; note this info for the convenience of Fedora users. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org Cc: anton@samba.org Cc: hch@infradead.org LKML-Reference: <1259565529-6407-5-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-30perf trace/scripting: Fix Perl common_* access functionsTom Zanussi
The common_* functions (e.g. common_pc(), etc) are exported as common_* but named get_common_*, resulting in unresolved subroutine errors when executing scripts. Make the internal and external names match. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org Cc: anton@samba.org Cc: hch@infradead.org LKML-Reference: <1259565529-6407-4-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-28perf trace: Add interface to access perf data from Perl handlersTom Zanussi
The Perl scripting support for perf trace allows most of a trace event's data to be accessed directly as handler arguments, but not all of it e.g. the less common fields aren't passed in. To give scripts access to the other fields and/or any other data or metadata in the main perf executable that might be useful, a way to access the C data in perf from Perl is needed; this patch uses the Perl XS facility to do it for the common_xxx event fields not passed to handler functions. Context.pm exports three functions to Perl scripts that access fields for the current event by calling back into perf: common_pc(), common_flags() and common_lock_depth(). Support for common_flags() field values was added to Core.pm and a script used to sanity check these and other basic scripting features, check-perf-trace.pl, was also added. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org Cc: anton@samba.org Cc: hch@infradead.org LKML-Reference: <1259133352-23685-6-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-28perf trace: Add perf trace scripting support modules for PerlTom Zanussi
Add Perf-Trace-Util Perl module and some scripts that use it. Core.pm contains Perl code to define and access flag and symbolic fields. Util.pm contains general-purpose utility functions. Also adds some makefile bits to install them in libexec/perf-core/scripts/perl (or wherever perfexec_instdir points). Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Cc: fweisbec@gmail.com Cc: rostedt@goodmis.org Cc: anton@samba.org Cc: hch@infradead.org LKML-Reference: <1259133352-23685-5-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
