path: root/tools/perf/builtin-trace.c
2009-10-17perf tools: Move dereference after NULL testJulia Lawall
In each case, if the NULL test on thread is needed, then the dereference should be after the NULL test. A simplified version of the semantic match that detects this problem is as follows (http://coccinelle.lip6.fr/): // <smpl> @match exists@ expression x, E; identifier fld; @@ * x->fld ... when != \(x = E\|&x\) * x == NULL // </smpl> Signed-off-by: Julia Lawall <julia@diku.dk> LKML-Reference: <Pine.LNX.4.64.0910170842500.9213@ask.diku.dk> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-15perf tools: Add latency format to trace outputSteven Rostedt
Add the irqs disabled, preemption count, need resched, and other info that is shown in the latency format of ftrace. # perf trace -l perf-16457 2..s2. 53636.260344: kmem_cache_free: call_site=ffffffff811198f perf-16457 2..s2. 53636.264330: kmem_cache_free: call_site=ffffffff811198f perf-16457 2d.s4. 53636.300006: kmem_cache_free: call_site=ffffffff810d889 Signed-off-by: Steven Rostedt <srostedt@redhat.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <20091014194400.076588953@goodmis.org> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-13perf tools: Move threads & last_match to threads.cArnaldo Carvalho de Melo
This was just being copy'n'pasted all over. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> LKML-Reference: <20091013141629.GD21809@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-08perf tools: Unify perf.data mapping and events handlingFrederic Weisbecker
This librarizes the perf.data file mapping and handling in various perf tools, roughly reducing the amount of code and fixing the places that mmap from beginning of the file whereas we want to mmap from the beginning of the data, leading to page fault because the mmap window is too small since the trace info are written in the file too. TODO: - convert perf timechart too Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arjan van de Ven <arjan@infradead.org> LKML-Reference: <20091007104729.GD5043@nowhere> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-07perf tools: Merge trace.info content into perf.dataFrederic Weisbecker
This drops the trace.info file and move its contents into the common perf.data file. This is done by creating a new trace_info section into this file. A user of perf headers needs to call perf_header__set_trace_info() to save the trace meta informations into the perf.data file. A file created by perf after his patch is unsupported by previous version because the size of the headers have increased. That said, it's two new fields that have been added in the end of the headers, and those could be ignored by previous versions if they just handled the dynamic header size and then ignore the unknow part. The offsets guarantee the compatibility. We'll do a -stable fix for that. But current previous versions handle the header size using its static size, not dynamic, then it's not backward compatible with trace records. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <20091006213643.GA5343@nowhere> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-07perf tools: Start the perf.data mapping at data offset in perf traceFrederic Weisbecker
Currently, we are mapping perf.data in the beginning of the file and use the data offset as a buffer offset. This may exceed the mapping area if the data offset is upper than page_size * mmap_window and result in a page fault (thing that happen if we merge trace.info in perf.data). Instead, let's start the mapping in the page that matches our data offset. v2: Drop a junk from another patch (trace_report() removal) Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <1254856886-10348-1-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06Merge branch 'perf/urgent' into perf/coreIngo Molnar
Merge reason: Upcoming patch is dependent on a fix in perf/urgent. Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-10-06perf trace: Remove unused code in builtin-trace.cTom Zanussi
And some minor whitespace cleanup. Signed-off-by: Tom Zanussi <tzanussi@gmail.com> Acked-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: rostedt@goodmis.org Cc: lizf@cn.fujitsu.com Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1254808849-7829-2-git-send-email-tzanussi@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-30perf trace: Remove dead codeArnaldo Carvalho de Melo
Several variables are not used at all, cut'n'paste leftovers. Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Mike Galbraith <efault@gmx.de> Cc: "H. Peter Anvin" <hpa@zytor.com> LKML-Reference: <20090928200818.GF3361@ghostprotocols.net> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-21perf: Do the big rename: Performance Counters -> Performance EventsIngo Molnar
Bye-bye Performance Counters, welcome Performance Events! In the past few months the perfcounters subsystem has grown out its initial role of counting hardware events, and has become (and is becoming) a much broader generic event enumeration, reporting, logging, monitoring, analysis facility. Naming its core object 'perf_counter' and naming the subsystem 'perfcounters' has become more and more of a misnomer. With pending code like hw-breakpoints support the 'counter' name is less and less appropriate. All in one, we've decided to rename the subsystem to 'performance events' and to propagate this rename through all fields, variables and API names. (in an ABI compatible fashion) The word 'event' is also a bit shorter than 'counter' - which makes it slightly more convenient to write/handle as well. Thanks goes to Stephane Eranian who first observed this misnomer and suggested a rename. User-space tooling and ABI compatibility is not affected - this patch should be function-invariant. (Also, defconfigs were not touched to keep the size down.) This patch has been generated via the following script: FILES=$(find * -type f | grep -vE 'oprofile|[^K]config') sed -i \ -e 's/PERF_EVENT_/PERF_RECORD_/g' \ -e 's/PERF_COUNTER/PERF_EVENT/g' \ -e 's/perf_counter/perf_event/g' \ -e 's/nb_counters/nb_events/g' \ -e 's/swcounter/swevent/g' \ -e 's/tpcounter_event/tp_event/g' \ $FILES for N in $(find . -name perf_counter.[ch]); do M=$(echo $N | sed 's/perf_counter/perf_event/g') mv $N $M done FILES=$(find . -name perf_event.*) sed -i \ -e 's/COUNTER_MASK/REG_MASK/g' \ -e 's/COUNTER/EVENT/g' \ -e 's/\<event\>/event_id/g' \ -e 's/counter/event/g' \ -e 's/Counter/Event/g' \ $FILES ... to keep it as correct as possible. This script can also be used by anyone who has pending perfcounters patches - it converts a Linux kernel tree over to the new naming. We tried to time this change to the point in time where the amount of pending patches is the smallest: the end of the merge window. Namespace clashes were fixed up in a preparatory patch - and some stylistic fallout will be fixed up in a subsequent patch. ( NOTE: 'counters' are still the proper terminology when we deal with hardware registers - and these sed scripts are a bit over-eager in renaming them. I've undone some of that, but in case there's something left where 'counter' would be better than 'event' we can undo that on an individual basis instead of touching an otherwise nicely automated patch. ) Suggested-by: Stephane Eranian <eranian@google.com> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Acked-by: Paul Mackerras <paulus@samba.org> Reviewed-by: Arjan van de Ven <arjan@linux.intel.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: David Howells <dhowells@redhat.com> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: "David S. Miller" <davem@davemloft.net> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: <linux-arch@vger.kernel.org> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-03perf trace: Fix parsing of perf.dataIngo Molnar
We started parsing perf.data at head 0. This caused -D to segfault and it could possibly also case incorrect trace entries to be displayed. Parse it at data_offset instead. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-03perf trace: Sample timestamps as wellIngo Molnar
Before: perf-21082 [013] 0.000000: sched_wakeup_new: task perf:21083 [120] success=1 [015] perf-21082 [013] 0.000000: sched_migrate_task: task perf:21082 [120] from: 13 to: 15 perf-21082 [013] 0.000000: sched_process_fork: parent perf:21082 child perf:21083 true-21083 [015] 0.000000: sched_wakeup: task migration/15:33 [0] success=1 [015] perf-21082 [013] 0.000000: sched_switch: task perf:21082 [120] (S) ==> swapper:0 [140] true-21083 [015] 0.000000: sched_switch: task perf:21083 [120] (R) ==> migration/15:33 [0] true-21083 [011] 0.000000: sched_process_exit: task true:21083 [120] After: perf-21082 [013] 14674.797613: sched_wakeup_new: task perf:21083 [120] success=1 [015] perf-21082 [013] 14674.797506: sched_migrate_task: task perf:21082 [120] from: 13 to: 15 perf-21082 [013] 14674.797610: sched_process_fork: parent perf:21082 child perf:21083 true-21083 [015] 14674.797725: sched_wakeup: task migration/15:33 [0] success=1 [015] perf-21082 [013] 14674.797722: sched_switch: task perf:21082 [120] (S) ==> swapper:0 [140] true-21083 [015] 14674.797729: sched_switch: task perf:21083 [120] (R) ==> migration/15:33 [0] true-21083 [011] 14674.798159: sched_process_exit: task true:21083 [120] Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-09-02perf trace: Sample the CPU tooIngo Molnar
Sample, record, parse and print the CPU field - it had all zeroes before. Before (watch the second column, the CPU values): perf-32685 [000] 0.000000: sched_wakeup_new: task perf:32686 [120] success=1 [011] perf-32685 [000] 0.000000: sched_migrate_task: task perf:32685 [120] from: 1 to: 11 perf-32685 [000] 0.000000: sched_process_fork: parent perf:32685 child perf:32686 true-32686 [000] 0.000000: sched_wakeup: task migration/11:25 [0] success=1 [011] true-32686 [000] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] true-32686 [000] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] perf-32685 [000] 0.000000: sched_switch: task perf:32685 [120] (S) ==> swapper:0 [140] true-32686 [000] 0.000000: sched_switch: task perf:32686 [120] (R) ==> migration/11:25 [0] true-32686 [000] 0.000000: sched_switch: task perf:32686 [120] (R) ==> distccd:12793 [125] true-32686 [000] 0.000000: sched_switch: task true:32686 [120] (R) ==> distccd:12793 [125] true-32686 [000] 0.000000: sched_process_exit: task true:32686 [120] true-32686 [000] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767985949080 [ns] true-32686 [000] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767986139446 [ns] true-32686 [000] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 132844 [ns] true-32686 [000] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 131724 [ns] After: perf-32685 [001] 0.000000: sched_wakeup_new: task perf:32686 [120] success=1 [011] perf-32685 [001] 0.000000: sched_migrate_task: task perf:32685 [120] from: 1 to: 11 perf-32685 [001] 0.000000: sched_process_fork: parent perf:32685 child perf:32686 true-32686 [011] 0.000000: sched_wakeup: task migration/11:25 [0] success=1 [011] true-32686 [015] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] true-32686 [015] 0.000000: sched_wakeup: task distccd:12793 [125] success=1 [015] perf-32685 [001] 0.000000: sched_switch: task perf:32685 [120] (S) ==> swapper:0 [140] true-32686 [011] 0.000000: sched_switch: task perf:32686 [120] (R) ==> migration/11:25 [0] true-32686 [015] 0.000000: sched_switch: task perf:32686 [120] (R) ==> distccd:12793 [125] true-32686 [015] 0.000000: sched_switch: task true:32686 [120] (R) ==> distccd:12793 [125] true-32686 [015] 0.000000: sched_process_exit: task true:32686 [120] true-32686 [015] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767985949080 [ns] true-32686 [015] 0.000000: sched_stat_wait: task: distccd:12793 wait: 6767986139446 [ns] true-32686 [015] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 132844 [ns] true-32686 [015] 0.000000: sched_stat_sleep: task: distccd:12793 sleep: 131724 [ns] So we can now see how this workload migrated between CPUs. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-31perf tools: Resolve idle thread cmdline for perf traceFrederic Weisbecker
The cmd-trace tool used the cmdline file and resolved the idle thread using a hardcoded check for the 0 task pid. Now we have a centralized way to do that from perf using register_idle_thread() API. Before: :0-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name :0-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name After: [idle]-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name [idle]-0 [000] 0.000000: irq_handler_entry: irq=0 handler=name Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> LKML-Reference: <1251693921-6579-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-21perf trace: Add OPT_END to option array of perf-traceMasami Hiramatsu
Add OPT_END to option array of perf-trace for fixing a SEGV bug when showing perf-trace help message. Without this patch; ./perf trace -h usage: perf trace [<options>] <command> -D, --dump-raw-trace dump raw trace in ASCII -v, --verbose be more verbose (show symbol address, etc) -f, Segmentation fault With this patch: ./perf trace -h usage: perf trace [<options>] <command> -D, --dump-raw-trace dump raw trace in ASCII -v, --verbose be more verbose (show symbol address, etc) Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com> Cc: systemtap <systemtap@sources.redhat.com> Cc: DLE <dle-develop@lists.sourceforge.net> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <20090821185603.11039.62109.stgit@localhost.localdomain> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-18perf tools: Warn while running perf trace without sampleFrederic Weisbecker
When a user runs perf trace using an input with logged counters without PERF_SAMPLE_RAW attribute, warn by giving a nice tip. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> LKML-Reference: <1250543271-8383-2-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-08-17perf tools: Add perf traceFrederic Weisbecker
This adds perf trace into the set of perf tools. It is written to fetch the tracepoint samples from perf events and display them, according to the events information given by the debugfs files through the util/trace* tools. It is a rough first shot and doesn't yet handle the cpu, timestamps fields and some other things. Example: perf record -f -e workqueue:workqueue_execution:record -F 1 -a perf trace kblockd/0-236 [000] 0.000000: workqueue_execution: thread=:236 func=cfq_kick_queue+0x0 kondemand/0-360 [000] 0.000000: workqueue_execution: thread=:360 func=do_dbs_timer+0x0 kondemand/0-360 [000] 0.000000: workqueue_execution: thread=:360 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 kondemand/1-361 [000] 0.000000: workqueue_execution: thread=:361 func=do_dbs_timer+0x0 Todo: - A lot of things! Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: "Luis Claudio R. Goncalves" <lclaudio@uudg.org> Cc: Clark Williams <williams@redhat.com> Cc: Jon Masters <jonathan@jonmasters.org> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> Cc: Christoph Hellwig <hch@infradead.org> Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com> Cc: Zhaolei <zhaolei@cn.fujitsu.com> Cc: Li Zefan <lizf@cn.fujitsu.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Masami Hiramatsu <mhiramat@redhat.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Roland McGrath <roland@redhat.com> Cc: Jason Baron <jbaron@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Jiaying Zhang <jiayingz@google.com> Cc: Anton Blanchard <anton@samba.org> LKML-Reference: <1250518688-7207-4-git-send-email-fweisbec@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
