path: root/tools/perf/builtin-top.c
2011-05-22Merge branch 'perf/core' of ↵Ingo Molnar
git://git.kernel.org/pub/scm/linux/kernel/git/frederic/random-tracing into perf/urgent Conflicts: tools/perf/builtin-top.c Semantic conflict: util/include/linux/list.h # fix prefetch.h removal fallout Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-05-22perf tools: Propagate event parse error handlingFrederic Weisbecker
Better handle event parsing error by propagating the details in upper layers or by dumping some failure message. So that the user knows he has some crazy events in the batch. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Stephane Eranian <eranian@google.com>
2011-05-15perf evlist: Fix per thread mmap setupArnaldo Carvalho de Melo
The PERF_EVENT_IOC_SET_OUTPUT ioctl was returning -EINVAL when using --pid when monitoring multithreaded apps, as we can only share a ring buffer for events on the same thread if not doing per cpu. Fix it by using per thread ring buffers. Tested with: [root@felicio ~]# tuna -t 26131 -CP | nl 1 thread ctxt_switches 2 pid SCHED_ rtpri affinity voluntary nonvoluntary cmd 3 26131 OTHER 0 0,1 10814276 2397830 chromium-browse 4 642 OTHER 0 0,1 14688 0 chromium-browse 5 26148 OTHER 0 0,1 713602 115479 chromium-browse 6 26149 OTHER 0 0,1 801958 2262 chromium-browse 7 26150 OTHER 0 0,1 1271128 248 chromium-browse 8 26151 OTHER 0 0,1 3 0 chromium-browse 9 27049 OTHER 0 0,1 36796 9 chromium-browse 10 618 OTHER 0 0,1 14711 0 chromium-browse 11 661 OTHER 0 0,1 14593 0 chromium-browse 12 29048 OTHER 0 0,1 28125 0 chromium-browse 13 26143 OTHER 0 0,1 2202789 781 chromium-browse [root@felicio ~]# So 11 threads under pid 26131, then: [root@felicio ~]# perf record -F 50000 --pid 26131 [root@felicio ~]# grep perf_event /proc/`pidof perf`/maps | nl 1 7fa4a2538000-7fa4a25b9000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 2 7fa4a25b9000-7fa4a263a000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 3 7fa4a263a000-7fa4a26bb000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 4 7fa4a26bb000-7fa4a273c000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 5 7fa4a273c000-7fa4a27bd000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 6 7fa4a27bd000-7fa4a283e000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 7 7fa4a283e000-7fa4a28bf000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 8 7fa4a28bf000-7fa4a2940000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 9 7fa4a2940000-7fa4a29c1000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 10 7fa4a29c1000-7fa4a2a42000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 11 7fa4a2a42000-7fa4a2ac3000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] [root@felicio ~]# 11 mmaps, one per thread since we didn't specify any CPU list, so we need one mmap per thread and: [root@felicio ~]# perf record -F 50000 --pid 26131 ^M ^C[ perf record: Woken up 79 times to write data ] [ perf record: Captured and wrote 20.614 MB perf.data (~900639 samples) ] [root@felicio ~]# perf report -D | grep PERF_RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort -n | uniq -c | sort -nr | nl 1 371310 26131 2 96516 26148 3 95694 26149 4 95203 26150 5 7291 26143 6 87 27049 7 76 661 8 60 29048 9 47 618 10 43 642 [root@felicio ~]# Ok, one of the threads, 26151 was quiescent, so no samples there, but all the others are there. Then, if I specify one CPU: [root@felicio ~]# perf record -F 50000 --pid 26131 --cpu 1 ^C[ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.680 MB perf.data (~29730 samples) ] [root@felicio ~]# perf report -D | grep PERF_RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort -n | uniq -c | sort -nr | nl 1 8444 26131 2 2584 26149 3 2518 26148 4 2324 26150 5 123 26143 6 9 661 7 9 29048 [root@felicio ~]# This machine has two cores, so fewer threads appeared on the radar, and: [root@felicio ~]# grep perf_event /proc/`pidof perf`/maps | nl 1 7f484b922000-7f484b9a3000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] [root@felicio ~]# Just one mmap, as now we can use just one per-cpu buffer instead of the per-thread needed in the previous case. For global profiling: [root@felicio ~]# perf record -F 50000 -a ^C[ perf record: Woken up 26 times to write data ] [ perf record: Captured and wrote 7.128 MB perf.data (~311412 samples) ] [root@felicio ~]# grep perf_event /proc/`pidof perf`/maps | nl 1 7fb49b435000-7fb49b4b6000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] 2 7fb49b4b6000-7fb49b537000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] [root@felicio ~]# It uses per-cpu buffers. For just one thread: [root@felicio ~]# perf record -F 50000 --tid 26148 ^C[ perf record: Woken up 2 times to write data ] [ perf record: Captured and wrote 0.330 MB perf.data (~14426 samples) ] [root@felicio ~]# perf report -D | grep PERF_RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort -n | uniq -c | sort -nr | nl 1 9969 26148 [root@felicio ~]# [root@felicio ~]# grep perf_event /proc/`pidof perf`/maps | nl 1 7f286a51b000-7f286a59c000 rwxs 00000000 00:09 4064 anon_inode:[perf_event] [root@felicio ~]# Tested-by: David Ahern <dsahern@gmail.com> Tested-by: Lin Ming <ming.m.lin@intel.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/r/20110426204401.GB1746@ghostprotocols.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-04-15perf evsel: Fix use of inheritArnaldo Carvalho de Melo
perf stat doesn't mmap and its perfectly fine for it to use task-bound counters with inheritance. So set the attr.inherit on the caller and leave the syscall itself to validate it. When the mmap fails perf_evlist__mmap will just emit a warning if this is the failure reason. Reported-by: Peter Zijlstra <peterz@infradead.org> Acked-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Link: http://lkml.kernel.org/r/20110414170121.GC3229@ghostprotocols.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf tools: Emit clearer message for sys_perf_event_open ENOENT returnDavid Ahern
Resend of patch sent back in January 2011 in light of recent confusion around unsupported events for a given platform. Improve sys_perf_event_open ENOENT return handling in top and record, just like 5a3446b does for stat. Retry of Arnaldo's patch using ui_warning instead of die which allows the fallback from hardware cycles to software clock. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org LKML-Reference: <1301080271-20945-1-git-send-email-daahern@cisco.com> Signed-off-by: David Ahern <daahern@cisco.com> [ committer note: Some adjustments to make it apply to newer codebase ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-29perf tools: Fixup exit path when not able to open eventsArnaldo Carvalho de Melo
We have to deal with the TUI mode in perf top, so that we don't end up with a garbled screen when, say, a non root user on a machine with a paranoid setting (the default) tries to use 'perf top'. Introduce a ui__warning_paranoid() routine shared by top and record that tells the user the valid values for /proc/sys/kernel/perf_event_paranoid. Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-23perf top: Fix uninitialized 'counter' variableAkihiro Nagai
builtin-top.c has an uninitialized variable. gcc(version 4.5.1) warns about it and it results in build failure: builtin-top.c: In function 'display_thread': builtin-top.c:518:9: error: 'counter' may be used uninitialized This situation can indeed trigger, if the getline() call in prompt_integer() fails. Signed-off-by: Akihiro Nagai <akihiro.nagai.hw@hitachi.com> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> LKML-Reference: <20110323072939.11638.50173.stgit@localhost6.localdomain6> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2011-03-11perf symbol: Move sym_entry->skip to symbol->ignoreArnaldo Carvalho de Melo
While going thru each of the sym_entry fields looking to reduce it to the set of entries needed when in an active symbols list, 'skip' should really be in symbol, as we set it when loading the symtab. And the space used by the basic symbol allocation remains the same as we had 5 bytes of padding. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf symbols: Rename dso->origin to dso->symtab_typeArnaldo Carvalho de Melo
And the DSO__ORIG_ enum to SYMTAB__, to clarify that this is about from where the symtab was obtained. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf top: Remove redundant syme->origin fieldArnaldo Carvalho de Melo
We can get it from syme->map->dso->kernel (that should be renamed to origin, but leave this for another patch). Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-11perf top: Remove redundant perf_top->sym_counterArnaldo Carvalho de Melo
We can get that counter index from perf_top->sym_evsel->idx instead. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-10perf session: Use evlist/evsel for managing perf.data attributesArnaldo Carvalho de Melo
So that we can reuse things like the id to attr lookup routine (perf_evlist__id2evsel) that uses a hash table instead of the linear lookup done in the older perf_header_attr routines, etc. Also to make evsels/evlist more pervasive an API, simplyfing using the emerging perf lib. cc: Arun Sharma <arun@sharma-home.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-03-01perf top tui: Wait till the first sample to refresh the screen.Arnaldo Carvalho de Melo
2011-03-01perf top: Fix reporting of invalid --vmlinuxArnaldo Carvalho de Melo
Using ui__warning, that will, in --tui, show a window with the message, waiting for the user to press Ok. Also run exit_browser() to let newt do its final cleaning of the screen. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-22perf top: Live TUI AnnotationArnaldo Carvalho de Melo
Now one has just to press the right key, 'a' or Enter on the main 'perf top --tui' screen to live annotate the symbol under the cursor. The annotate window starts centered on the hottest line (the one with most samples so far) then TAB and shift+TAB can be used to go to the prev/next hot line. Pressing 'H' at any point will center again the screen on the hottest line. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-11Merge remote branch 'acme/perf/urgent' into perf/coreArnaldo Carvalho de Melo
Fixups due to rename of event_t routines from event__ to perf_event__ done in perf/core. Conflicts: tools/perf/builtin-record.c tools/perf/builtin-top.c tools/perf/util/event.c tools/perf/util/event.h Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-10perf tools: Fix thread_map event synthesizing in top and recordArnaldo Carvalho de Melo
Jeff Moyer reported these messages: Warning: ... trying to fall back to cpu-clock-ticks couldn't open /proc/-1/status couldn't open /proc/-1/maps [ls output] [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.008 MB perf.data (~363 samples) ] That lead me and David Ahern to see that something was fishy on the thread synthesizing routines, at least for the case where the workload is started from 'perf record', as -1 is the default for target_tid in 'perf record --tid' parameter, so somehow we were trying to synthesize the PERF_RECORD_MMAP and PERF_RECORD_COMM events for the thread -1, a bug. So I investigated this and noticed that when we introduced support for recording a process and its threads using --pid some bugs were introduced and that the way to fix it was to instead of passing the target_tid to the event synthesizing routines we should better pass the thread_map that has the list of threads for a --pid or just the single thread for a --tid. Checked in the following ways: On a 8-way machine run cyclictest: [root@emilia ~]# perf record cyclictest -a -t -n -p99 -i100 -d50 policy: fifo: loadavg: 0.00 0.13 0.31 2/139 28798 T: 0 (28791) P:99 I:100 C: 25072 Min: 4 Act: 5 Avg: 6 Max: 122 T: 1 (28792) P:98 I:150 C: 16715 Min: 4 Act: 6 Avg: 5 Max: 27 T: 2 (28793) P:97 I:200 C: 12534 Min: 4 Act: 5 Avg: 4 Max: 8 T: 3 (28794) P:96 I:250 C: 10028 Min: 4 Act: 5 Avg: 5 Max: 96 T: 4 (28795) P:95 I:300 C: 8357 Min: 5 Act: 6 Avg: 5 Max: 12 T: 5 (28796) P:94 I:350 C: 7163 Min: 5 Act: 6 Avg: 5 Max: 12 T: 6 (28797) P:93 I:400 C: 6267 Min: 4 Act: 5 Avg: 5 Max: 9 T: 7 (28798) P:92 I:450 C: 5571 Min: 4 Act: 5 Avg: 5 Max: 9 ^C[ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.108 MB perf.data (~4719 samples) ] [root@emilia ~]# This will create one extra thread per CPU: [root@emilia ~]# tuna -t cyclictest -CP thread ctxt_switches pid SCHED_ rtpri affinity voluntary nonvoluntary cmd 28825 OTHER 0 0xff 2169 671 cyclictest 28832 FIFO 93 6 52338 1 cyclictest 28833 FIFO 92 7 46524 1 cyclictest 28826 FIFO 99 0 209360 1 cyclictest 28827 FIFO 98 1 139577 1 cyclictest 28828 FIFO 97 2 104686 0 cyclictest 28829 FIFO 96 3 83751 1 cyclictest 28830 FIFO 95 4 69794 1 cyclictest 28831 FIFO 94 5 59825 1 cyclictest [root@emilia ~]# So we should expect only samples for the above 9 threads when using the --dump-raw-trace|-D perf report switch to look at the column with the tid: [root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c 629 28825 110 28826 491 28827 308 28828 198 28829 621 28830 225 28831 203 28832 89 28833 [root@emilia ~]# So for workloads started by 'perf record' seems to work, now for existing workloads, just run cyclictest first, without 'perf record': [root@emilia ~]# tuna -t cyclictest -CP thread ctxt_switches pid SCHED_ rtpri affinity voluntary nonvoluntary cmd 28859 OTHER 0 0xff 594 200 cyclictest 28864 FIFO 95 4 16587 1 cyclictest 28865 FIFO 94 5 14219 1 cyclictest 28866 FIFO 93 6 12443 0 cyclictest 28867 FIFO 92 7 11062 1 cyclictest 28860 FIFO 99 0 49779 1 cyclictest 28861 FIFO 98 1 33190 1 cyclictest 28862 FIFO 97 2 24895 1 cyclictest 28863 FIFO 96 3 19918 1 cyclictest [root@emilia ~]# and then later did: [root@emilia ~]# perf record --pid 28859 sleep 3 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.027 MB perf.data (~1195 samples) ] [root@emilia ~]# To collect 3 seconds worth of samples for pid 28859 and its children: [root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c 15 28859 33 28860 19 28861 13 28862 13 28863 10 28864 11 28865 9 28866 255 28867 [root@emilia ~]# Works, last thing is to check if looking at just one of those threads also works: [root@emilia ~]# perf record --tid 28866 sleep 3 [ perf record: Woken up 1 times to write data ] [ perf record: Captured and wrote 0.006 MB perf.data (~242 samples) ] [root@emilia ~]# perf report -D | grep RECORD_SAMPLE | cut -d/ -f2 | cut -d: -f1 | sort | uniq -c 3 28866 [root@emilia ~]# Works too. Reported-by: Jeff Moyer <jmoyer@redhat.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Jeff Moyer <jmoyer@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-08perf annotate: Fix annotate context lines regressionArnaldo Carvalho de Melo
The live annotation done in 'perf top' needs to limit the context before lines that aren't filtered out by the min percent filter, if we don't do that, the screen in a tty often is not enough for showing what is interesting: lines with hits and a few source code lines before it. Reported-by: Mike Galbraith <efault@gmx.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-08perf annotate: Move locking to struct annotationArnaldo Carvalho de Melo
Since we'll need it when implementing the live annotate TUI browser. This also simplifies things a bit by having the list head for the source code to be in the dynamicly allocated part of struct annotation, that way we don't have to pass it around, it can be found from the struct symbol that is passed everywhere. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-07perf tool: Fix gcc 4.6.0 issuesKyle McMartin
GCC 4.6.0 in Fedora rawhide turned up some compile errors in tools/perf due to the -Werror=unused-but-set-variable flag. I've gone through and annotated some of the assignments that had side effects (ie: return value from a function) with the __used annotation, and in some cases, just removed unused code. In a few cases, we were assigning something useful, but not using it in later parts of the function. kyle@dreadnought:~/src% gcc --version gcc (GCC) 4.6.0 20110122 (Red Hat 4.6.0-0.3) Cc: Ingo Molnar <mingo@redhat.com> LKML-Reference: <20110124161304.GK27353@bombadil.infradead.org> Signed-off-by: Kyle McMartin <kyle@redhat.com> [ committer note: Fixed up the annotation fixes, as that code moved recently ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-06perf top: Ditch private annotation code, share perf annotate'sArnaldo Carvalho de Melo
Next step: Live TUI annotation in perf top, just press enter on a symbol line. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-02-05perf top: Remove superfluous name_len fieldArnaldo Carvalho de Melo
From the sym_entry struct, struct symbol already has this field. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-31perf top: Introduce slang based TUIArnaldo Carvalho de Melo
Disabled by default as there are features found in the stdio based one that aren't implemented, like live annotation, filtering knobs data entry. Annotation hopefully will get somehow merged with the 'perf annotate' code. To use it: perf top --tui Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-31perf top: Move display agnostic routines to util/top.[ch]Arnaldo Carvalho de Melo
Paving the way for a slang browser a la 'perf report --tui'. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-31perf evlist: Store pointer to the cpu and thread mapsArnaldo Carvalho de Melo
So that we don't have to pass it around to the several methods that needs it, simplifying usage. There is one case where we don't have the thread/cpu map in advance, which is in the parsing routines used by top, stat, record, that we have to wait till all options are parsed to know if a cpu or thread list was passed to then create those maps. For that case consolidate the cpu and thread map creation via perf_evlist__create_maps() out of the code in top and record, while also providing a perf_evlist__set_maps() for cases where multiple evlists share maps or for when maps that represent CPU sockets, for instance, get crafted out of topology information or subsets of threads in a particular application are to be monitored, providing more granularity in specifying which cpus and threads to monitor. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-29perf tools: Kill event_t typedef, use 'union perf_event' insteadArnaldo Carvalho de Melo
And move the event_t methods to the perf_event__ too. No code changes, just namespace consistency. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-29perf tools: Rename 'struct sample_data' to 'struct perf_sample'Arnaldo Carvalho de Melo
Making the namespace more uniform. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-29perf top: Switch to non overwrite modeArnaldo Carvalho de Melo
Just like 'perf record'. Warn the user when PERF_RECORD_LOST events happen. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-24perf tools: Move event__parse_sample to evsel.cArnaldo Carvalho de Melo
To avoid linking more stuff in the python binding I'm working on, future csets will make the sample type be taken from the evsel itself, but for that we need to first have one file per cpu and per sample_type, not a single perf.data file. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-24perf threads: Move thread_map to separate fileArnaldo Carvalho de Melo
To untangle it from struct thread handling, that is tied to symbols, etc. Right now in the python bindings I'm working on I need just a subset of the util/ files, untangling it allows me to do that. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf top: Add native_safe_halt to skip symbolsArnaldo Carvalho de Melo
2011-01-22perf evlist: Steal mmap reading routine from 'perf top'Arnaldo Carvalho de Melo
Will be used in the upcoming 'perf test' entry for the evlist mmap routines. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf evlist: Move the mmap array from perf_evselArnaldo Carvalho de Melo
Adopting the new model used in 'perf record', where we don't have a map per thread per cpu, instead we have an mmap per cpu, established on the first fd for that cpu and ask the kernel using the PERF_EVENT_IOC_SET_OUTPUT ioctl to send events for the other fds on that cpu for the one with the mmap. The methods moved from perf_evsel to perf_evlist, but for easing review they were modified in place, in evsel.c, the next patch will move the migrated methods to evlist.c. With this 'perf top' now uses the same mmap model used by 'perf record' and the next patches will make 'perf record' use these new routines, establishing a common codebase for both tools. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf evsel: Introduce mmap supportArnaldo Carvalho de Melo
Out of the code in 'perf top'. Record is next in line. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf top: Use perf_evsel__openArnaldo Carvalho de Melo
Now that it handles group_fd and inherit we can use it, sharing it with stat. Next step: 'perf record' should use, then move the mmap_array out of ->priv and into perf_evsel, with top and record sharing this, and at the same time, write a 'perf test' stress test. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf evlist: Adopt the pollfd arrayArnaldo Carvalho de Melo
Allocating just the space needed for nr_cpus * nr_threads * nr_evsels, not the MAX_NR_CPUS and counters. LKML-Reference: <new-submission> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf evsel: Introduce perf_evlistArnaldo Carvalho de Melo
Killing two more perf wide global variables: nr_counters and evsel_list as a list_head. There are more operations that will need more fields in perf_evlist, like the pollfd for polling all the fds in a list of evsel instances. Use option->value to pass the evsel_list to parse_{events,filters}. LKML-Reference: <new-submission> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-22perf tools: Fix 64 bit integer format stringsArnaldo Carvalho de Melo
Using %L[uxd] has issues in some architectures, like on ppc64. Fix it by making our 64 bit integers typedefs of stdint.h types and using PRI[ux]64 like, for instance, git does. Reported by Denis Kirjanov that provided a patch for one case, I went and changed all cases. Reported-by: Denis Kirjanov <dkirjanov@kernel.org> Tested-by: Denis Kirjanov <dkirjanov@kernel.org> LKML-Reference: <20110120093246.GA8031@hera.kernel.org> Cc: Denis Kirjanov <dkirjanov@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Pingtian Han <phan@redhat.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-11Revert "perf tools: Emit clearer message for sys_perf_event_open ENOENT return"Arnaldo Carvalho de Melo
This reverts commit aa7bc7ef73efc46d7c3a0e185eefaf85744aec98. It removed the fallback from hardware profiling to software profiling. .e.g., in a VM with no PMU. Reported-by: David Ahern <daahern@cisco.com> Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-11perf top: Fix annotate segvArnaldo Carvalho de Melo
Before we had sym_counter, it was initialized to zero and we used that as an index in the global attrs variable, now we have a list of evsel entries, and sym_counter became sym_evsel, that remained initialized to zero (NULL): b00m. Fix it by initializing it to the first entry in the evsel list. Bug-introduced: 69aad6f Reported-by: Kirill Smelkov <kirr@mns.spb.ru> Tested-by: Kirill Smelkov <kirr@mns.spb.ru> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Kirill Smelkov <kirr@mns.spb.ru> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-11perf evsel: Fix order of event list deletionArnaldo Carvalho de Melo
We need to defer calling perf_evsel_list__delete() till after atexit registered routines, because we need to traverse the events being recorded at that time at least on 'perf record'. This fixes the problem reported by Thomas Renninger where cmd_record called by cmd_timechart would not write the tracing data to the perf.data file header because the evsel_list at atexit (control+C on 'perf timechart record') time would be empty, being already deleted by run_builtin(), and thus 'perf timechart' when trying to process such perf.data file would die with: "no trace data in the file" Problem introduced in 70d544d. Reported-by: Thomas Renninger <trenn@suse.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Thomas Renninger <trenn@suse.de> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-10perf tools: Emit clearer message for sys_perf_event_open ENOENT returnArnaldo Carvalho de Melo
Improve sys_perf_event_open ENOENT return handling in top and record, just like 5a3446b does for stat. Cc: David Ahern <daahern@cisco.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf tools: Refactor all_tids to hold nr and the mapArnaldo Carvalho de Melo
So that later, we can pass the thread_map instance instead of (thread_num, thread_map) for things like perf_evsel__open and friends, just like was done with cpu_map. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-04perf tools: Refactor cpumap to hold nr and the mapArnaldo Carvalho de Melo
So that later, we can pass the cpu_map instance instead of (nr_cpus, cpu_map) for things like perf_evsel__open and friends. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf evsel: Delete the event selectors at exitArnaldo Carvalho de Melo
Freeing all the possibly allocated resources, reducing complexity on each tool exit path. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-01-03perf tools: Introduce event selectorsArnaldo Carvalho de Melo
Out of ad-hoc code and global arrays with hard coded sizes. This is the first step on having a library that will be first used on regression tests in the 'perf test' tool. [acme@felicio linux]$ size /tmp/perf.before text data bss dec hex filename 1273776 97384 5104416 6475576 62cf38 /tmp/perf.before [acme@felicio linux]$ size /tmp/perf.new text data bss dec hex filename 1275422 97416 1392416 2765254 2a31c6 /tmp/perf.new Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-21perf session: Fallback to unordered processing if no sample_id_allIan Munsie
If we are running the new perf on an old kernel without support for sample_id_all, we should fall back to the old unordered processing of events. If we didn't than we would *always* process events without timestamps out of order, whether or not we hit a reordering race. In other words, instead of there being a chance of not attributing samples correctly, we would guarantee that samples would not be attributed. While processing all events without timestamps before events with timestamps may seem like an intuitive solution, it falls down as PERF_RECORD_EXIT events would also be processed before any samples. Even with a workaround for that case, samples before/after an exec would not be attributed correctly. This patch allows commands to indicate whether they need to fall back to unordered processing, so that commands that do not care about timestamps on every event will not be affected. If we do fallback, this will print out a warning if report -D was invoked. This patch adds the test in perf_session__new so that we only need to test once per session. Commands that do not use an event_ops (such as record and top) can simply pass NULL in it's place. Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> LKML-Reference: <1291951882-sup-6069@au1.ibm.com> Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-04perf tools: Ask for ID PERF_SAMPLE_ info on all PERF_RECORD_ eventsArnaldo Carvalho de Melo
So that we can use -T == --timestamp, asking for PERF_SAMPLE_TIME: $ perf record -aT $ perf report -D | grep PERF_RECORD_ <SNIP> 3 5951915425 0x47530 [0x58]: PERF_RECORD_SAMPLE(IP, 1): 16811/16811: 0xffffffff8138c1a2 period: 215979 cpu:3 3 5952026879 0x47588 [0x90]: PERF_RECORD_SAMPLE(IP, 1): 16811/16811: 0xffffffff810cb480 period: 215979 cpu:3 3 5952059959 0x47618 [0x38]: PERF_RECORD_FORK(6853:6853):(16811:16811) 3 5952138878 0x47650 [0x78]: PERF_RECORD_SAMPLE(IP, 1): 16811/16811: 0xffffffff811bac35 period: 431478 cpu:3 3 5952375068 0x476c8 [0x30]: PERF_RECORD_COMM: find:6853 3 5952395923 0x476f8 [0x50]: PERF_RECORD_MMAP 6853/6853: [0x400000(0x25000) @ 0]: /usr/bin/find 3 5952413756 0x47748 [0xa0]: PERF_RECORD_SAMPLE(IP, 1): 6853/6853: 0xffffffff810d080f period: 859332 cpu:3 3 5952419837 0x477e8 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f44600000(0x21d000) @ 0]: /lib64/ld-2.5.so 3 5952437929 0x47840 [0x48]: PERF_RECORD_MMAP 6853/6853: [0x7fff7e1c9000(0x1000) @ 0x7fff7e1c9000]: [vdso] 3 5952570127 0x47888 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f46200000(0x218000) @ 0]: /lib64/libselinux.so.1 3 5952623637 0x478e0 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f44a00000(0x356000) @ 0]: /lib64/libc-2.5.so 3 5952675720 0x47938 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f44e00000(0x204000) @ 0]: /lib64/libdl-2.5.so 3 5952710080 0x47990 [0x58]: PERF_RECORD_MMAP 6853/6853: [0x3f45a00000(0x246000) @ 0]: /lib64/libsepol.so.1 3 5952847802 0x479e8 [0x58]: PERF_RECORD_SAMPLE(IP, 1): 6853/6853: 0xffffffff813897f0 period: 1142536 cpu:3 <SNIP> First column is the cpu and the second the timestamp. That way we can investigate problems in the event stream. If the new perf binary is run on an older kernel, it will disable this feature automatically. Tested-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1291318772-30880-5-git-send-email-acme@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-12-04perf session: Parse sample earlierArnaldo Carvalho de Melo
At perf_session__process_event, so that we reduce the number of lines in eache tool sample processing routine that now receives a sample_data pointer already parsed. This will also be useful in the next patch, where we'll allow sample the identity fields in MMAP, FORK, EXIT, etc, when it will be possible to see (cpu, timestamp) just after before every event. Also validate callchains in perf_session__process_event, i.e. as early as possible, and keep a counter of the number of events discarded due to invalid callchains, warning the user about it if it happens. There is an assumption that was kept that all events have the same sample_type, that will be dealt with in the future, when this preexisting limitation will be removed. Tested-by: Thomas Gleixner <tglx@linutronix.de> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Acked-by: Ian Munsie <imunsie@au1.ibm.com> Acked-by: Thomas Gleixner <tglx@linutronix.de> Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Ian Munsie <imunsie@au1.ibm.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Stephane Eranian <eranian@google.com> LKML-Reference: <1291318772-30880-4-git-send-email-acme@infradead.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-11-20perf stat: Change and clean up sys_perf_event_open error handlingCorey Ashford
This patch makes several changes to "perf stat": - "perf stat" will no longer go ahead and run the application when one or more of the specified events could not be opened. - Use error() and die() instead of pr_err() so that the output is more consistent with "perf top" and "perf record". - Handle permission errors in a more robust way, and in a similar way to "perf record" and "perf top". In addition, the sys_perf_event_open() error handling of "perf top" and "perf record" is made more consistent and adds the following phrase when an event doesn't open (with something ther than an access or permission error): "/bin/dmesg may provide additional information." This is added because kernel code doesn't have a good way of expressing detailed errors to user space, so its only avenue is to use printk's. However, many users may not think of looking at dmesg to find out why an event is being rejected. Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <fweisbec@gmail.com> Cc: Ian Munsie <ianmunsi@au1.ibm.com> Cc: Michael Ellerman <michaele@au1.ibm.com> LKML-Reference: <1290217044-26293-1-git-send-email-cjashfor@linux.vnet.ibm.com> Signed-off-by: Corey Ashford <cjashfor@linux.vnet.ibm.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
