Pull perf updates from Ingo Molnar:
"Bigger kernel side changes:
- Add backwards writing capability to the perf ring-buffer code,
which is preparation for future advanced features like robust
'overwrite support' and snapshot mode. (Wang Nan)
- Add pause and resume ioctls for the perf ringbuffer (Wang Nan)
- x86 Intel cstate code cleanups and reorgnization (Thomas Gleixner)
- x86 Intel uncore and CPU PMU driver updates (Kan Liang, Peter
Zijlstra)
- x86 AUX (Intel PT) related enhancements and updates (Alexander
Shishkin)
- x86 MSR PMU driver enhancements and updates (Huang Rui)
- ... and lots of other changes spread out over 40+ commits.
Biggest tooling side changes:
- 'perf trace' features and enhancements. (Arnaldo Carvalho de Melo)
- BPF tooling updates (Wang Nan)
- 'perf sched' updates (Jiri Olsa)
- 'perf probe' updates (Masami Hiramatsu)
- ... plus 200+ other enhancements, fixes and cleanups to tools/
The merge commits, the shortlog and the changelogs contain a lot more
details"
* 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (249 commits)
perf/core: Disable the event on a truncated AUX record
perf/x86/intel/pt: Generate PMI in the STOP region as well
perf buildid-cache: Use lsdir() for looking up buildid caches
perf symbols: Use lsdir() for the search in kcore cache directory
perf tools: Use SBUILD_ID_SIZE where applicable
perf tools: Fix lsdir to set errno correctly
perf trace: Move seccomp args beautifiers to tools/perf/trace/beauty/
perf trace: Move flock op beautifier to tools/perf/trace/beauty/
perf build: Add build-test for debug-frame on arm/arm64
perf build: Add build-test for libunwind cross-platforms support
perf script: Fix export of callchains with recursion in db-export
perf script: Fix callchain addresses in db-export
perf script: Fix symbol insertion behavior in db-export
perf symbols: Add dso__insert_symbol function
perf scripting python: Use Py_FatalError instead of die()
perf tools: Remove xrealloc and ALLOC_GROW
perf help: Do not use ALLOC_GROW in add_cmd_list
perf pmu: Make pmu_formats_string to check return value of strbuf
perf header: Make topology checkers to check return value of strbuf
perf tools: Make alias handler to check return value of strbuf
After 0161028b7c8a ("perf/core: Change the default paranoia level to 2")
'perf stat' fails for users without CAP_SYS_ADMIN, so just use
'perf_evsel__fallback()' to have the same behaviour as 'perf record',
i.e. set perf_event_attr.exclude_kernel to 1.
Now:
[acme@jouet linux]$ perf stat usleep 1
Performance counter stats for 'usleep 1':
0.352536 task-clock:u (msec) # 0.423 CPUs utilized
0 context-switches:u # 0.000 K/sec
0 cpu-migrations:u # 0.000 K/sec
49 page-faults:u # 0.139 M/sec
309,407 cycles:u # 0.878 GHz
243,791 instructions:u # 0.79 insn per cycle
49,622 branches:u # 140.757 M/sec
3,884 branch-misses:u # 7.83% of all branches
0.000834174 seconds time elapsed
[acme@jouet linux]$
Reported-by: Ingo Molnar <mingo@kernel.org>
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Masami Hiramatsu <mhiramat@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-b20jmx4dxt5hpaa9t2rroi0o@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Add debug output of raw counter values per CPU when perf stat -v is
specified, together with their cpu numbers. This is very useful to
debug problems with per core counters, where we can normally only see
aggregated values.
v2: Make it depend on -vv, not -v
Link: http://lkml.kernel.org/r/1461787251-6702-12-git-send-email-andi@firstfloor.org
Add metric only support for -A too. This requires a new print function
that prints the metrics in the right order.
v2: Fix manpage
v3: Simplify nrcpus computation
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1457049458-28956-7-git-send-email-andi@firstfloor.org
Add a new mode to only print metrics. Sometimes we don't care about the
raw values, just want the computed metrics. This allows more compact
printing, so with -I each sample is only a single line. This also
allows easier plotting and processing with other tools.
The main target is with using --topdown, but it also works with -T and
standard perf stat. A few metrics are not supported.
To avoiding having to hardcode all the metrics in the code it uses a two
pass approach: first compute dummy metrics and only print the headers in
the print_metric callback. Then use the callback to print the actual
values.
There are some additional changes in the stat printout code to handle
all metrics being on a single line.
One issue is that the column code doesn't know in advance what events
are not supported by the CPU, and it would be hard to find out as this
could change based on dynamic conditions. That causes empty columns in
some cases.
The output can be fairly wide, often you may need more than 80 columns.
Example:
% perf stat -a -I 1000 --metric-only
1.001452803 frontend cycles idle insn per cycle stalled cycles per insn branch-misses of all branches
1.001452803 158.91% 0.66 2.39 2.92%
2.002192321 180.63% 0.76 2.08 2.96%
3.003088282 150.59% 0.62 2.57 2.84%
4.004369835 196.20% 0.98 1.62 3.79%
5.005227314 231.98% 0.84 1.90 4.71%
v2: Lots of updates.
v3: Use slightly narrower columns
v4: Add comment
Link: http://lkml.kernel.org/r/1457049458-28956-6-git-send-email-andi@firstfloor.org
Add an extra check for frontend stalled in the metrics. This avoids an
extra column for the --metric-only case when the CPU does not support
frontend stalled.
v2: Add separate init function
Link: http://lkml.kernel.org/r/1456858672-21594-8-git-send-email-andi@firstfloor.org
Enable metrics printing in --per-core / --per-socket mode. We need to
save the shadow metrics in a unique place. Always use the first CPU in
the aggregation. Then use the same CPU to retrieve the shadow value
later.
Example output:
% perf stat --per-core -a ./BC1s
Performance counter stats for 'system wide':
S0-C0 2 2966.020381 task-clock (msec) # 2.004 CPUs utilized (100.00%)
S0-C0 2 49 context-switches # 0.017 K/sec (100.00%)
S0-C0 2 4 cpu-migrations # 0.001 K/sec (100.00%)
S0-C0 2 467 page-faults # 0.157 K/sec
S0-C0 2 4,599,061,773 cycles # 1.551 GHz (100.00%)
S0-C0 2 9,755,886,883 instructions # 2.12 insn per cycle (100.00%)
S0-C0 2 1,906,272,125 branches # 642.704 M/sec (100.00%)
S0-C0 2 81,180,867 branch-misses # 4.26% of all branches
S0-C1 2 2965.995373 task-clock (msec) # 2.003 CPUs utilized (100.00%)
S0-C1 2 62 context-switches # 0.021 K/sec (100.00%)
S0-C1 2 8 cpu-migrations # 0.003 K/sec (100.00%)
S0-C1 2 281 page-faults # 0.095 K/sec
S0-C1 2 6,347,290 cycles # 0.002 GHz (100.00%)
S0-C1 2 4,654,156 instructions # 0.73 insn per cycle (100.00%)
S0-C1 2 947,121 branches # 0.319 M/sec (100.00%)
S0-C1 2 37,322 branch-misses # 3.94% of all branches
1.480409747 seconds time elapsed
v2: Rebase to older patches
v3: Document shadow cpus. Fix aggr_get_id argument. Fix -A shadows (Jiri)
Link: http://lkml.kernel.org/r/1456785386-19481-4-git-send-email-andi@firstfloor.org
Now support CSV output for metrics. With the new output callbacks this
is relatively straight forward by creating new callbacks.
This allows to easily plot metrics from CSV files.
The new line callback needs to know the number of fields to skip them
correctly
Example output before:
% perf stat -x, true
0.200687,,task-clock,200687,100.00
0,,context-switches,200687,100.00
0,,cpu-migrations,200687,100.00
40,,page-faults,200687,100.00
730871,,cycles,203601,100.00
551056,,stalled-cycles-frontend,203601,100.00
<not supported>,,stalled-cycles-backend,0,100.00
385523,,instructions,203601,100.00
78028,,branches,203601,100.00
3946,,branch-misses,203601,100.00
After:
.502457,,task-clock,502457,100.00,0.485,CPUs utilized
0,,context-switches,502457,100.00,0.000,K/sec
0,,cpu-migrations,502457,100.00,0.000,K/sec
45,,page-faults,502457,100.00,0.090,M/sec
644692,,cycles,509102,100.00,1.283,GHz
423470,,stalled-cycles-frontend,509102,100.00,65.69,frontend cycles idle
<not supported>,,stalled-cycles-backend,0,100.00,,,,
492701,,instructions,509102,100.00,0.76,insn per cycle
,,,,,0.86,stalled cycles per insn
97767,,branches,509102,100.00,194.578,M/sec
4788,,branch-misses,509102,100.00,4.90,of all branches
or easier readable
$ perf stat -x, -o x.csv true
$ column -s, -t x.csv
0.490635 task-clock 490635 100.00 0.489 CPUs utilized
0 context-switches 490635 100.00 0.000 K/sec
0 cpu-migrations 490635 100.00 0.000 K/sec
45 page-faults 490635 100.00 0.092 M/sec
629080 cycles 497698 100.00 1.282 GHz
409498 stalled-cycles-frontend 497698 100.00 65.09 frontend cycles idle
<not supported> stalled-cycles-backend 0 100.00
491424 instructions 497698 100.00 0.78 insn per cycle
0.83 stalled cycles per insn
97278 branches 497698 100.00 198.270 M/sec
4569 branch-misses 497698 100.00 4.70 of all branches
Two new fields are added: metric value and metric name.
v2: Split out function argument changes
v3: Reenable metrics for real.
v4: Fix wrong hunk from refactoring.
v5: Remove extra "noise" printing (Jiri), but add it to the not counted case.
Print empty metrics for not counted.
v6: Avoid outputting metric on empty format.
v7: Print metric at the end
v8: Remove extra run, ena fields
v9: Avoid extra new line for unsupported counters
Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/r/1456785386-19481-3-git-send-email-andi@firstfloor.org
Only put the frontend/backend stalled cycles into the default perf stat
events when the CPU actually supports them.
This avoids empty columns with --metric-only on newer Intel CPUs.
Committer note:
Before:
$ perf stat ls
Performance counter stats for 'ls':
1.080893 task-clock (msec) # 0.619 CPUs utilized
0 context-switches # 0.000 K/sec
0 cpu-migrations # 0.000 K/sec
97 page-faults # 0.090 M/sec
3,327,741 cycles # 3.079 GHz
<not supported> stalled-cycles-frontend
1,609,544 instructions # 0.48 insn per cycle
319,117 branches # 295.235 M/sec
12,246 branch-misses # 3.84% of all branches
0.001746508 seconds time elapsed
After:
$ perf stat ls
0.693948 task-clock (msec) # 0.662 CPUs utilized
95 page-faults # 0.137 M/sec
1,792,509 cycles # 2.583 GHz
1,599,047 instructions # 0.89 insn per cycle
316,328 branches # 455.838 M/sec
12,453 branch-misses # 3.94% of all branches
0.001048987 seconds time elapsed
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1456532881-26621-2-git-send-email-andi@firstfloor.org
'perf stat' accepts some config terms but doesn't apply them. For
example:
# perf stat -e 'instructions/no-inherit/' -e 'instructions/inherit/' bash
# ls
# exit
Performance counter stats for 'bash':
266258061 instructions/no-inherit/
266258061 instructions/inherit/
1.402183915 seconds time elapsed
The result is confusing, because user may expect the first
'instructions' event exclude the 'ls' command.
This patch forbid most of these config terms for 'perf stat'.
Result:
# ./perf stat -e 'instructions/no-inherit/' -e 'instructions/inherit/' bash
event syntax error: 'instructions/no-inherit/'
\___ 'no-inherit' is not usable in 'perf stat'
We can add blocked config terms back when 'perf stat' really supports them.
This patch also removes unavailable config term from error message:
# ./perf stat -e 'instructions/badterm/' ls
event syntax error: 'instructions/badterm/'
\___ unknown term
valid terms: config,config1,config2,name
# ./perf stat -e 'cpu/badterm/' ls
event syntax error: 'cpu/badterm/'
\___ unknown term
valid terms: pc,any,inv,edge,cmask,event,in_tx,ldlat,umask,in_tx_cp,offcore_rsp,config,config1,config2,name
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Brendan Gregg <brendan.d.gregg@gmail.com>
Cc: Cody P Schafer <dev@codyps.com>
Cc: He Kuang <hekuang@huawei.com>
Cc: Jeremie Galarneau <jeremie.galarneau@efficios.com>
Cc: Kirill Smelkov <kirr@nexedi.com>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: Zefan Li <lizefan@huawei.com>
Cc: pi3orama@163.com
Link: http://lkml.kernel.org/r/1455882283-79592-11-git-send-email-wangnan0@huawei.com
Arnaldo pointed out that the earlier cb110f471025 ("perf stat: Move
noise/running printing into printout") change changed behavior for not
counted counters. This patch fixes it again.
Fixes: cb110f471025 ("perf stat: Move noise/running printing into printout")
Link: http://lkml.kernel.org/r/1455749045-18098-2-git-send-email-andi@firstfloor.org
Move the running/noise printing into printout to avoid duplicated code
in the callers.
v2: Merged with other patches. Remove unnecessary hunk.
Readd hunk that ended in earlier patch.
v3: Fix noise/running output in CSV mode
v4: Merge with later patch that also moves not supported printing.
Link: http://lkml.kernel.org/r/1454173616-17710-4-git-send-email-andi@firstfloor.org
Now that we can modify the metrics printout functions easily, it's
straight forward to support metric printing for interval mode. All that
is needed is to print the time stamp on every new line. Pass the prefix
into the context and print it out.
v2: Move wrong hunk to here.
Committer note:
Before:
[root@jouet ~]# perf stat -I 1000 -e instructions,cycles sleep 1
# time counts unit events
1.000168216 538,913 instructions
1.000168216 748,765 cycles
1.000660048 153,741 instructions
1.000660048 214,066 cycles
After:
1.000215928 519,620 instructions # 0.69 insn per cycle
1.000215928 752,003 cycles
1.000946033 148,502 instructions # 0.33 insn per cycle
1.000946033 160,104 cycles
Acked-by: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/1454173616-17710-3-git-send-email-andi@firstfloor.org
Abstract the printing of shadow metrics. Instead of every metric calling
fprintf directly and taking care of indentation, use two call backs: one
to print metrics and another to start a new line.
This will allow adding metrics to CSV mode and also using them for other
purposes.
The computation of padding is now done in the central callback, instead
of every metric doing it manually. This makes it easier to add new
metrics.
v2: Refactor functions, printout now does more. Move
shadow printing. Improve fallback callbacks. Don't
use void * callback data.
v3: Remove unnecessary hunk. Add typedef for new_line
v4: Remove unnecessary hunk. Don't print metrics for CSV/interval
mode yet. Move printout change to separate patch.
v5: Fix bisect bugs. Avoid bogus frontend cycles printing.
Fix indentation in different aggregation modes.
v6: Delay newline handling
Link: http://lkml.kernel.org/r/1454173616-17710-2-git-send-email-andi@firstfloor.org
Markus reported gcc 6 complains when compiling perf stat command:
builtin-stat.c:1591:27: error: ‘recort_usage’ defined but not used
[-Werror=unused-const-variable]
static const char * const recort_usage[] = {
I fixed the typo and realized we already export record_usage, so I also
prefixed it with stat (and included report_usage).
Reported-by: Markus Trippelsdorf <markus@trippelsdorf.de>
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1452591329-27620-1-git-send-email-jolsa@kernel.org
For pipe sessions we need to keep sample_type zero, because script's
perf_evsel__check_attr is triggered by sample_type != 0, and the check
would fail on stat session.
I was tempted to keep it zero unconditionally, but the pipe session is
sufficient. In perf.data session we are guarded by HEADER_STAT feature.
Cc: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1452028152-26762-2-git-send-email-jolsa@kernel.org
Allowing to override record aggr_mode. It's possible to use perf stat
like:
$ perf stat report -A
$ perf stat report --per-core
$ perf stat report --per-socket
To customize the recorded aggregate mode regardless what was used during
the stat record command.
Reported-by: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1446734469-11352-19-git-send-email-jolsa@kernel.org
[ Renamed 'stat' parameter to 'st' to fix 'already defined' build error with older distros (e.g. RHEL6.7) ]
Adding processing of event update events, so perf stat report can store
additional info for events - unit,scale,name.
Committer note:
Before:
# perf stat record -e power/energy-cores/ -a
^C
77.41 Joules power/energy-cores/
1.597176695 seconds time elapsed
# perf stat report
Performance counter stats for '/home/acme/bin/perf stat record -e power/energy-cores/ -a':
332,488,114,176 power/energy-cores/
After, using the same perf.data file generated in the "Before" case
above:
# perf stat report
Link: http://lkml.kernel.org/r/1446734469-11352-17-git-send-email-jolsa@kernel.org
Adding processing of stat and stat round events.
The stat data com in stat events, using generic function
process_stat_round_event to store data under perf_evsel object.
The stat-round events comes each interval or as last event in non
interval mode. The function process_stat_round_event process stored data
for each perf_evsel object and print it out.
Committer note:
After this patch:
$ perf stat record usleep 1
0.498381 task-clock (msec) # 0.571 CPUs utilized
2 context-switches # 0.004 M/sec
149 page-faults # 0.299 M/sec
1,271,635 cycles # 2.552 GHz
928,712 stalled-cycles-frontend # 73.03% frontend cycles idle
663,286 stalled-cycles-backend # 52.16% backend cycles idle
792,614 instructions # 0.62 insns per cycle
# 1.17 stalled cycles per insn
136,850 branches # 274.589 M/sec
<not counted> branch-misses (0.00%)
0.000873419 seconds time elapsed
$ perf stat report
Performance counter stats for '/home/acme/bin/perf stat record usleep 1':
Link: http://lkml.kernel.org/r/1446734469-11352-16-git-send-email-jolsa@kernel.org
So we have csv_sep properly initialized before report command leg.
Link: http://lkml.kernel.org/r/1446734469-11352-18-git-send-email-jolsa@kernel.org
Using perf.data's perf_env data to initialize aggregate config.
Link: http://lkml.kernel.org/r/1446734469-11352-15-git-send-email-jolsa@kernel.org
[ s/stat/st/g, s/socket/socket_id/g to fix 'already defined' build error with older distros (e.g. RHEL6.7) ]
Adding processing of stat config event and initialize stat_config
object.
Link: http://lkml.kernel.org/r/1446734469-11352-14-git-send-email-jolsa@kernel.org
Adding processing of cpu/threads maps. Configuring session's evlist with
these maps.
Link: http://lkml.kernel.org/r/1446734469-11352-13-git-send-email-jolsa@kernel.org
[ s/stat/st/g, s/time/tm/g parameters to fix 'already defined' build error with older distros (e.g. RHEL6.7) ]
Adding 'perf stat report' command support. ATM it only processes attr
events and display nothing.
Link: http://lkml.kernel.org/r/1446734469-11352-12-git-send-email-jolsa@kernel.org
Synthesize other events stuff not carried within attr event - unit,
scale, name.
Link: http://lkml.kernel.org/r/1446734469-11352-11-git-send-email-jolsa@kernel.org
We currently don't support storing multiple session in perf.data,
so we can't allow -r option in stat record.
$ perf stat -e cycles -r 2 record ls
Cannot use -r option with perf stat record.
Committer note:
Before this patch we would a perf.data file such as:
<SNIP>
Performance counter stats for 'ls' (2 runs):
3,935,236 cycles
0.002353261 seconds time elapsed ( +- 4.76% )
$ perf report -D | grep PERF_RECORD | grep ROUND
0xf0 [0]: failed to process type: 16
Error:
failed to process sample
Link: http://lkml.kernel.org/r/1446734469-11352-10-git-send-email-jolsa@kernel.org
Writing stat round events on 'perf stat record' for each interval round.
In non interval mode we store round event after the last stat event.
Committer note:
After the patch:
0x852 [0x18]: PERF_RECORD_STAT_ROUND
Link: http://lkml.kernel.org/r/1446734469-11352-9-git-send-email-jolsa@kernel.org
Writing stat events on 'perf stat record' at the time we read counter
values from kernel.
Committer note:
After the patch:
0.598006 task-clock (msec) # 0.484 CPUs utilized
1 context-switches # 0.002 M/sec
52 page-faults # 0.087 M/sec
882,744 cycles # 1.476 GHz
581,416 stalled-cycles-frontend # 65.86% frontend cycles idle
636,479 instructions # 0.72 insns per cycle
# 0.91 stalled cycles per insn
129,334 branches # 216.275 M/sec
7,512 branch-misses # 5.81% of all branches
0.001235157 seconds time elapsed
$ oldperf evlist
task-clock
context-switches
cpu-migrations
page-faults
cycles
instructions
branches
branch-misses
$ oldperf report --stdio
Error:
The perf.data file has no samples!
# To display the perf.data header info, please use --header/--header-only options.
0x5b0 [0x28]: PERF_RECORD_THREAD_MAP nr: 1 thread: 5504
0x5d8 [0x12]: PERF_RECORD_CPU_MAP nr: 1 cpu: 65535
0x5ea [0x40]: PERF_RECORD_STAT_CONFIG
0x62a [0x30]: PERF_RECORD_STAT
0x65a [0x30]: PERF_RECORD_STAT
0x68a [0x30]: PERF_RECORD_STAT
0x6ba [0x30]: PERF_RECORD_STAT
0x6ea [0x30]: PERF_RECORD_STAT
0x71a [0x30]: PERF_RECORD_STAT
0x74a [0x30]: PERF_RECORD_STAT
0x77a [0x30]: PERF_RECORD_STAT
0x7aa [0x30]: PERF_RECORD_STAT
-1 -1 0x7da [0x40]: PERF_RECORD_MMAP -1/0: [0xffffffff81000000(0x1f000000) @ 0xffffffff81000000]: x [kernel.kallsyms]_text
Tested-by: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1446734469-11352-8-git-send-email-jolsa@kernel.org
Allowing storing stat record data into pipe, so report tools
(report/script) could read data directly from record.
Committer note:
Before this patch:
$ perf stat record -o - usleep 1 | perf report -i -
incompatible file format (rerun with -v to learn more)
$ perf stat record -o - usleep 1 | perf script -i -
$ ls -la perf.data
ls: cannot access perf.data: No such file or directory
After:
# --header/--header-only options.
Error:
The - file has no samples!
Display of symbols requested but neither sample IP nor sample address
is selected. Hence, no addresses to convert to symbols.
0 [0x80]: failed to process type: 64
$ ls -la perf.data
Link: http://lkml.kernel.org/r/1446734469-11352-7-git-send-email-jolsa@kernel.org
Store event IDs in evlist object so it get stored into perf.data file.
Link: http://lkml.kernel.org/r/1446734469-11352-6-git-send-email-jolsa@kernel.org
Synthesizing needed stat record data for report/script:
- cpu/thread maps
- stat config
Committer note:
New records generated on a perf.data file with this patch:
$ perf report -D | grep PERF_RECORD_
0x568 [0x28]: PERF_RECORD_THREAD_MAP nr: 1 thread: 29097
0x590 [0x12]: PERF_RECORD_CPU_MAP nr: 1 cpu: 65535
0x5a2 [0x40]: PERF_RECORD_STAT_CONFIG
Link: http://lkml.kernel.org/r/1446734469-11352-5-git-send-email-jolsa@kernel.org
[ Adjusted wrt kernel PERF_RECORD_MMAP added when introducing 'perf stat record' ]
Disabling all non stat related features.
Also as we now enable STAT feature in the data file, adding code to
instruct session open to skip sample type checking for stat data files.
Link: http://lkml.kernel.org/r/1446734469-11352-4-git-send-email-jolsa@kernel.org
Add 'perf stat record' command support. It creates simple (header only)
perf.data file ATM.
The record command could be specified anywhere among stat options. All
stat command options are valid for stat record command with '-o' option
exception. If specified for record command it denotes the perf data file
name.
Committer note:
Set sample_type to PERF_SAMPLE_IDENTIFIER, which should be harmless
while avoiding that older tools show confusing messages, for instance,
with sample_type = 0, we get:
0.630237 task-clock (msec) # 0.528 CPUs utilized
52 page-faults # 0.083 M/sec
978,312 cycles # 1.552 GHz
671,931 stalled-cycles-frontend # 68.68% frontend cycles idle
646,379 instructions # 0.66 insns per cycle
# 1.04 stalled cycles per insn
131,046 branches # 207.931 M/sec
7,073 branch-misses # 5.40% of all branches
0.001193240 seconds time elapsed
$ oldperf evlist
WARNING: The perf.data file's data size field is 0 which is unexpected.
Was the 'perf record' command properly terminated?
non matching sample_type
While with sample_type set to PERF_SAMPLE_IDENTIFIER, after we re-run 'perf
stat record usleep' we get:
$ oldperf evlist
task-clock
context-switches
cpu-migrations
page-faults
cycles
instructions
branches
branch-misses
Which at least shows the names of the events in the perf.data file.
Additionally, such files, when passed to 'perf report' will produce:
Warning:
Kernel address maps (/proc/{kallsyms,modules}) were restricted.
Check /proc/sys/kernel/kptr_restrict before running 'perf record'.
As no suitable kallsyms nor vmlinux was found, kernel samples
can't be resolved.
Samples in kernel modules can't be resolved as well.
Error:
Which is confusing and can be solved by just adding the kernel mmap record,
which will also remove that warning about the data size field being equal to
zero, after generating the mmap record:
0.600796 task-clock (msec) # 0.478 CPUs utilized
54 page-faults # 0.090 M/sec
886,844 cycles # 1.476 GHz
582,169 stalled-cycles-frontend # 65.65% frontend cycles idle
638,344 instructions # 0.72 insns per cycle
130,204 branches # 216.719 M/sec
7,500 branch-misses # 5.76% of all branches
0.001255897 seconds time elapsed
$ oldperf evlist
task-clock
context-switches
cpu-migrations
page-faults
cycles
instructions
branches
branch-misses
Error:
[acme@zoo linux]$
No warnings, sensible output about what are the events in the perf.data file and also
a "file has no samples" message, which indeed it doesn't.
Link: htp://lkml.kernel.org/r/1446734469-11352-3-git-send-email-jolsa@kernel.org
Move the subcommand-related files from perf to a new library named
libsubcmd.a.
Since we're moving files anyway, go ahead and rename 'exec_cmd.*' to
'exec-cmd.*' to be consistent with the naming of all the other files.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/c0a838d4c878ab17fee50998811612b2281355c1.1450193761.git.jpoimboe@redhat.com
Fix cmd_stat() to release cpu_map objects (aggr_map and
cpus_aggr_map) afterwards.
refcnt debugger shows that the cmd_stat initializes cpu_map
but not puts it.
# ./perf stat -v ls
REFCNT: BUG: Unreclaimed objects found.
==== [0] ====
Unreclaimed cpu_map@0x29339c0
Refcount +1 => 1 at
./perf(cpu_map__empty_new+0x6d) [0x4e64bd]
./perf(cmd_stat+0x5fe) [0x43594e]
./perf() [0x47b785]
./perf(main+0x617) [0x422587]
/lib64/libc.so.6(__libc_start_main+0xf5) [0x7f2dff420af5]
./perf() [0x4226fd]
REFCNT: Total 1 objects are not reclaimed.
"cpu_map" leaks 1 objects
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Link: http://lkml.kernel.org/r/20151209021127.10245.93697.stgit@localhost.localdomain
[ Remove NULL checks before calling the put operation, it checks it already ]
It's more readable this way and we can save one
perf_evsel__is_group_leader condition in current code.
Link: http://lkml.kernel.org/r/1449133606-14429-7-git-send-email-jolsa@kernel.org
Currently we have 2 kinds of stat counters based on when the event is
enabled:
1) tracee command events, which are enable once the
tracee executes exec syscall (enable_on_exec bit)
2) all other events which get alive within the
perf_event_open syscall
And 2) case could raise a problem in case we want additional filter to
be attached for event. In this case we want the event to be enabled
after it's configured with filter.
Changing the behaviour of 2) events, so they all are created as disabled
(disabled bit). Adding extra enable call to make them alive once they
finish setup.
Link: http://lkml.kernel.org/r/1449133606-14429-6-git-send-email-jolsa@kernel.org
No need to mimic the behaviour of perf_evlist__enable, we can use it
directly.
Link: http://lkml.kernel.org/r/1449133606-14429-5-git-send-email-jolsa@kernel.org
All events now share proper cpu and thread maps. There's no need to pass
those maps from evlist, it's safe to use evsel maps for enabling event.
Link: http://lkml.kernel.org/r/1449133606-14429-2-git-send-email-jolsa@kernel.org
Clear sample_(type|period) for counting, as it only confuses debug
output with unwanted sampling details:
Before:
$ sudo perf stat -e 'raw_syscalls:sys_enter' -vv ls
perf_event_attr:
type 2
size 112
config 0x11
{ sample_period, sample_freq } 1
sample_type TIME|CPU|PERIOD|RAW
read_format TOTAL_TIME_ENABLED|TOTAL_TIME_RUNNING
disabled 1
inherit 1
enable_on_exec 1
exclude_guest 1
After:
perf_event_attr:
type 2
size 112
config 0x11
disabled 1
inherit 1
enable_on_exec 1
exclude_guest 1
Link: http://lkml.kernel.org/r/1448465815-27404-1-git-send-email-jolsa@kernel.org
So they can be used in perf stat record command in following patch.
Link: http://lkml.kernel.org/r/1446734469-11352-2-git-send-email-jolsa@kernel.org
Instead of every caller deciding whether to call abs or nsec printout
do it all in a single central function. No functional changes.
Link: http://lkml.kernel.org/r/1446515428-7450-3-git-send-email-andi@firstfloor.org
The sw clock metrics printing was missed in the earlier move to
stat-shadow of all the other metric printouts. Move it too.
v2: Fix metrics printing in this version to make bisect safe.
Link: http://lkml.kernel.org/r/1446515428-7450-2-git-send-email-andi@firstfloor.org
Currently any time we need to access socket or core id for given cpu, we
access the sysfs topology file.
Adding a cpus_aggr_map cpu_map to cache those entries.
Link: http://lkml.kernel.org/r/1445784728-21732-3-git-send-email-jolsa@kernel.org
Adding data arg to cpu_map__build_map callback, so we could pass data
along to the callback. It'll be needed in following patches to retrieve
topology info from perf.data.
Link: http://lkml.kernel.org/r/1444992092-17897-41-git-send-email-jolsa@kernel.org
Adding AGGR_UNSET mode, so we could distinguish unset aggr_mode in
following patches.
Link: http://lkml.kernel.org/r/1444992092-17897-30-git-send-email-jolsa@kernel.org
It's used as the perf_evsel::priv data, so the name suits better. Also
we'll need the perf_stat name free for more generic struct.
Link: http://lkml.kernel.org/r/1444992092-17897-29-git-send-email-jolsa@kernel.org
The --interval-print parameter was limited to 100ms. However, for
example, 10ms is required to do sophisticated bandwidth analysis using
uncore events.
The test shows that the overhead of the system-wide uncore monitoring
with 10ms interval is only ~2%. So this patch reduces the minimal
interval-print allowd to 10ms.
But 10ms may not work well for all cases. For example, when the
cpus/threads number is very large, for system-wide core event monitoring
the overhead could be high.
To handle this issue, a warning will be displayed when the
interval-print is set between 10ms to 100ms. So users can make a
decision according to their specific cases.
# perf stat -e uncore_imc_1/cas_count_read/ -a --interval-print 10 -- sleep 1
print interval < 100ms. The overhead percentage could be high in some
cases. Please proceed with caution.
0.010200451 0.10 MiB uncore_imc_1/cas_count_read/
0.020475117 0.02 MiB uncore_imc_1/cas_count_read/
0.030692800 0.01 MiB uncore_imc_1/cas_count_read/
0.040948161 0.02 MiB uncore_imc_1/cas_count_read/
0.051159564 0.00 MiB uncore_imc_1/cas_count_read/
Signed-off-by: Kan Liang <kan.liang@intel.com>
Link: http://lkml.kernel.org/r/1443776674-42511-1-git-send-email-kan.liang@intel.com
[ Added warning about overhead when using sub 100ms intervals to the man page ]
Since 3b3eb0445 running perf stat on a system without
backend-stalled-cycles spits out ugly warnings by default.
Since that is quite common, make the message a debug message only.
We know anyways that the counter wasn't read by the normal <unsupported>
output.
Link: http://lkml.kernel.org/r/1441147966-14917-1-git-send-email-andi@firstfloor.org
