Users were not being able to have the explicitely specified vmlinux
pathname used, instead a search on the vmlinux path was always being
made.
Reported-by: Francis Moreau <francis.moro@gmail.com>
Acked-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: 2nddept-manager@sdl.hitachi.co.jp
Cc: Francis Moreau <francis.moro@gmail.com>
Cc: Franck Bui-Huu <vagabon.xyz@gmail.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
LPU-Reference: <m3hbelydz8.fsf_-_@gmail.com>
Signed-off-by: Franck Bui-Huu <fbuihuu@gmail.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Add basic module probe support on perf probe. This introduces "--module
<MODNAME>" option to perf probe for putting probes and showing lines and
variables in the given module.
Currently, this supports only probing on running modules. Supporting off-line
module probing is the next step.
e.g.)
[show lines]
# ./perf probe --module drm -L drm_vblank_info
<drm_vblank_info:0>
0 int drm_vblank_info(struct seq_file *m, void *data)
1 {
struct drm_info_node *node = (struct drm_info_node *) m->private
3 struct drm_device *dev = node->minor->dev;
[show vars]
# ./perf probe --module drm -V drm_vblank_info:3
Available variables at drm_vblank_info:3
@<drm_vblank_info+20>
(unknown_type) data
struct drm_info_node* node
struct seq_file* m
[put a probe]
# ./perf probe --module drm drm_vblank_info:3 node m
Add new event:
probe:drm_vblank_info (on drm_vblank_info:3 with node m)
You can now use it on all perf tools, such as:
perf record -e probe:drm_vblank_info -aR sleep 1
[list probes]
# ./perf probe -l
probe:drm_vblank_info (on drm_vblank_info:3@drivers/gpu/drm/drm_info.c with ...
LKML-Reference: <20101021101341.3542.71638.stgit@ltc236.sdl.hitachi.co.jp>
Signed-off-by: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Add --externs for allowing --vars to show accessible global (externally
defined) variables from a given probe point too.
This will give you a hint which globals can be accessible from the probe point.
LKML-Reference: <20101021101335.3542.31003.stgit@ltc236.sdl.hitachi.co.jp>
Just change the order of function arguments for ease of read; moving optional
bool flag to the last.
LKML-Reference: <20101021101329.3542.51200.stgit@ltc236.sdl.hitachi.co.jp>
Add -V (--vars) option for listing accessible local variables at given probe
point. This will help finding which local variables are available for event
arguments.
e.g.)
# perf probe -V call_timer_fn:23
Available variables at call_timer_fn:23
@<run_timer_softirq+345>
function_type* fn
int preempt_count
long unsigned int data
struct list_head work_list
struct list_head* head
struct timer_list* timer
struct tvec_base* base
LKML-Reference: <20101021101323.3542.40282.stgit@ltc236.sdl.hitachi.co.jp>
As a precursor for perf to support uprobes, rename fields/functions
that had kprobe in their name but can be shared across perf-kprobes
and perf-uprobes to probe.
Cc: Ananth N Mavinakayanahalli <ananth@in.ibm.com>
Cc: "Frank Ch. Eigler" <fche@redhat.com>
Cc: Jim Keniston <jkenisto@linux.vnet.ibm.com>
Cc: Mark Wielaard <mjw@redhat.com>
Cc: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
Cc: Naren A Devaiah <naren.devaiah@in.ibm.com>
Cc: "Paul E. McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
LKML-Reference: <20100729141351.GG21723@linux.vnet.ibm.com>
Signed-off-by: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
The probe plugin requires access to the source code for some operations. The
source code must be in the exact same location as specified by the DWARF tags,
but sometimes the location is an absolute path that cannot be replicated by a
normal user. This change adds the -s|--source option to allow the user to
specify the root of the kernel source tree.
Cc: Masami Hiramatsu <mhiramat@redhat.com>
LKML-Reference: <1276543590-10486-1-git-send-email-chase.douglas@canonical.com>
Signed-off-by: Chase Douglas <chase.douglas@canonical.com>
Functions that were calling xzalloc also returned -1 when, for other
reasons, it could fail, and the calleds are coping with failures, so
stop using die() and xzalloc().
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
Cc: Tom Zanussi <tzanussi@gmail.com>
LKML-Reference: <new-submission>
Add --max-probes option to change the maximum limit of
findable probe points per event, since inlined function can be
expanded into thousands of probe points. Default value is 128.
Signed-off-by: Masami Hiramatsu <mhiramat@redhat.com>
Suggested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
LKML-Reference: <20100421195640.24664.62984.stgit@localhost6.localdomain6>
Instead of using debugfs_path, use debugfs_find_mountpoint()
to find actual debugfs path.
LKML-Reference: <20100414223928.14630.38326.stgit@localhost6.localdomain6>
Reported-by: Ingo Molnar <mingo@elte.hu>
Remove die() and DIE_IF() code from util/probe-event.c since
these 'sudden death' in utility functions make reusing it from
other code (especially tui/gui) difficult.
LKML-Reference: <20100412171742.3790.33650.stgit@localhost6.localdomain6>
Set given names to event arguments. The syntax is same as kprobe-tracer,
you can add 'NAME=' right before each argument.
e.g.
./perf probe vfs_read foo=file
then, 'foo' is set to the argument name as below.
./perf probe -l
probe:vfs_read (on vfs_read@linux-2.6-tip/fs/read_write.c with foo)
LKML-Reference: <20100412171653.3790.74624.stgit@localhost6.localdomain6>
OPT_INCR()
Parsing an option from the command line with OPT_BOOLEAN on a
bool data type would not work on a big-endian machine due to the
manner in which the boolean was being cast into an int and
incremented. For example, running 'perf probe --list' on a
PowerPC machine would fail to properly set the list_events bool
and would therefore print out the usage information and
terminate.
This patch makes OPT_BOOLEAN work as expected with a bool
datatype. For cases where the original OPT_BOOLEAN was
intentionally being used to increment an int each time it was
passed in on the command line, this patch introduces OPT_INCR
with the old behaviour of OPT_BOOLEAN (the verbose variable is
currently the only such example of this).
I have reviewed every use of OPT_BOOLEAN to verify that a true
C99 bool was passed. Where integers were used, I verified that
they were only being used for boolean logic and changed them to
bools to ensure that they would not be mistakenly used as ints.
The major exception was the verbose variable which now uses
OPT_INCR instead of OPT_BOOLEAN.
Signed-off-by: Ian Munsie <imunsie@au.ibm.com>
Cc: <stable@kernel.org> # NOTE: wont apply to .3[34].x cleanly, please backport
Cc: Git development list <git@vger.kernel.org>
Cc: Ian Munsie <imunsie@au1.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: Valdis.Kletnieks@vt.edu
Cc: WANG Cong <amwang@redhat.com>
Cc: Thiago Farina <tfransosi@gmail.com>
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: John Kacur <jkacur@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com>
Just fix typos. --line option accepts ':START-END' syntax,
not ':START:END'.
Cc: systemtap <systemtap@sources.redhat.com>
Cc: DLE <dle-develop@lists.sourceforge.net>
LKML-Reference: <20100402165038.23551.62590.stgit@localhost6.localdomain6>
Cleanup debuginfo related code to eliminate fragile code which
pointed by Ingo (Thanks!).
1) Invert logic of NO_DWARF_SUPPORT to DWARF_SUPPORT.
2) For removing assymetric/local variable ifdefs, introduce
more helper functions.
3) Change options order to reduce the number of ifdefs.
LKML-Reference: <1269274229-20442-2-git-send-email-acme@infradead.org>
Introduce kprobe_trace_event and perf_probe_event and replace
old probe_point structure with it. probe_point structure is
not enough flexible nor extensible. New data structures
will help implementing further features.
LKML-Reference: <20100316220612.32050.33806.stgit@localhost6.localdomain6>
Add --dry-run option for debugging and testing.
LKML-Reference: <20100316220605.32050.6571.stgit@localhost6.localdomain6>
Since this name 'session' conflicts with 'perf_session', and
this structure just holds parameters anymore.
LKML-Reference: <20100316220544.32050.8788.stgit@localhost6.localdomain6>
Move add-probe routine to util/probe_event.c. This simplifies
main routine for reducing maintenance cost.
LKML-Reference: <20100316220537.32050.72214.stgit@localhost6.localdomain6>
Use wrapped functions as much as possible, to check out of
memory conditions in perf probe.
LKML-Reference: <20100316220530.32050.53951.stgit@localhost6.localdomain6>
Fix probe_point array-size overrun problem. In some cases (e.g.
inline function), one user-specified probe-point can be
translated to many probe address, and it overruns pre-defined
array-size. This also removes redundant MAX_PROBES macro
definition.
LKML-Reference: <20100312232217.2017.45017.stgit@localhost6.localdomain6>
[ Note that only root can create new probes. Eventually we should remove
the MAX_PROBES limit, but that is a larger patch not eligible to
perf/urgent treatment. ]
Move @SRC right after FUNC in syntax according to syntax change
on command line help.
Cc: K.Prasad <prasad@linux.vnet.ibm.com>
LKML-Reference: <20100304033843.3819.10087.stgit@localhost6.localdomain6>
Add lazy line matching support for specifying new probes.
This also changes the syntax of perf probe a bit. Now
perf probe accepts one of below probe event definitions.
1) Define event based on function name
[EVENT=]FUNC[@SRC][:RLN|+OFF|%return|;PTN] [ARG ...]
2) Define event based on source file with line number
[EVENT=]SRC:ALN [ARG ...]
3) Define event based on source file with lazy pattern
[EVENT=]SRC;PTN [ARG ...]
- New lazy matching pattern(PTN) follows ';' (semicolon). And it
must be put the end of the definition.
- So, @SRC is no longer the part which must be put at the end
of the definition.
Note that ';' (semicolon) can be interpreted as the end of
a command by the shell. This means that you need to quote it.
(anyway you will need to quote the lazy pattern itself too,
because it may contains other sensitive characters, like
'[',']' etc.).
Lazy matching
The lazy line matching is similar to glob matching except
ignoring spaces in both of pattern and target.
e.g.
'a=*' can matches 'a=b', 'a = b', 'a == b' and so on.
This provides some sort of flexibility and robustness to
probe point definitions against minor code changes.
(for example, actual 10th line of schedule() can be changed
easily by modifying schedule(), but the same line matching
'rq=cpu_rq*' may still exist.)
Changes in v3:
- Cast Dwarf_Addr to uintmax_t for printf-formats.
Changes in v2:
- Cast Dwarf_Addr to unsigned long long for printf-formats.
LKML-Reference: <20100225133611.6725.45078.stgit@localhost6.localdomain6>
Newer gcc introduces newer & richer debuginfo, and only libdw
in elfutils project can support it. So perf probe moves onto
elfutils-libdw from libdwarf.
Changes in v3:
- Cast Dwarf_Addr/Dwarf_Word to uintmax_t for printf-formats.
- Recover a sign-prefix which was removed in v2 by mistake.
Changes in v2:
- Fix a type-casting bug in Makefile.
- Cast Dwarf_Addr/Dwarf_Word to unsigned long long for printf-formats.
Cc: Ulrich Drepper <drepper@redhat.com>
Cc: Roland McGrath <roland@redhat.com>
LKML-Reference: <20100225133542.6725.34724.stgit@localhost6.localdomain6>
Rename *_probepoint to *_probe_point, for nothing
but a cosmetic reason.
LKML-Reference: <20100225133534.6725.52615.stgit@localhost6.localdomain6>
Do not show --line option in help message when perf
doesn't support dwarf.
LKML-Reference: <20100225133512.6725.88423.stgit@localhost6.localdomain6>
With the recent modifications done to untie the session and
symbol layers, 'perf probe' now can use just the symbols layer.
Acked-by: Masami Hiramatsu <mhiramat@redhat.com>
I noticed while writing the first test in 'perf regtest' that to
just test the symbol handling routines one needs to create a
perf session, that is a layer centered on a perf.data file,
events, etc, so I untied these layers.
This reduces the complexity for the users as the number of
parameters to most of the symbols and session APIs now was
reduced while not adding more state to all the map instances by
only having data that is needed to split the kernel (kallsyms
and ELF symtab sections) maps and do vmlinux relocation on the
main kernel map.
LKML-Reference: <1265223128-11786-1-git-send-email-acme@infradead.org>
I got this build error when building tip tree:
| cc1: warnings being treated as errors
| builtin-probe.c:123: error: 'opt_show_lines' defined but not used
This error is caused by:
| #ifndef NO_LIBDWARF
| OPT_CALLBACK('L', "line", NULL,
| "FUNC[:RLN[+NUM|:RLN2]]|SRC:ALN[+NUM|:ALN2]",
| "Show source code lines.", opt_show_lines),
| #endif
My environment defines NO_LIBDWARF, so gcc treated
opt_show_lines() as garbage. So I moved opt_show_lines() into
#ifndef NO_LIBDWARF ... #endif block.
Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
LKML-Reference: <1263645076-9993-1-git-send-email-mitake@dcl.info.waseda.ac.jp>
Add --line option to support showing probable source-code lines.
perf probe --line SRC:LN[-LN|+NUM]
or
perf probe --line FUNC[:LN[-LN|+NUM]]
This option shows source-code with line number if the line can
be probed. Lines without line number (and blue color) means that
the line can not be probed, because debuginfo doesn't have the
information of those lines.
The argument specifies the range of lines, "source.c:100-120"
shows lines between 100th to l20th in source.c file. And
"func:10+20" shows 20 lines from 10th line of func function.
e.g.
# ./perf probe --line kernel/sched.c:1080
<kernel/sched.c:1080>
* called with rq->lock held and irqs disabled
static void hrtick_start(struct rq *rq, u64 delay)
struct hrtimer *timer = &rq->hrtick_timer;
1086 ktime_t time = ktime_add_ns(timer->base->get_time(), delay);
hrtimer_set_expires(timer, time);
1090 if (rq == this_rq()) {
1091 hrtimer_restart(timer);
1092 } else if (!rq->hrtick_csd_pending) {
1093 __smp_call_function_single(cpu_of(rq), &rq->hrtick_csd,
1094 rq->hrtick_csd_pending = 1;
If you specifying function name, this shows function-relative
line number.
# ./perf probe --line schedule
<schedule:0>
asmlinkage void __sched schedule(void)
1 {
struct task_struct *prev, *next;
unsigned long *switch_count;
struct rq *rq;
int cpu;
need_resched:
preempt_disable();
9 cpu = smp_processor_id();
10 rq = cpu_rq(cpu);
11 rcu_sched_qs(cpu);
12 prev = rq->curr;
13 switch_count = &prev->nivcsw;
LKML-Reference: <20100106144534.27218.77939.stgit@dhcp-100-2-132.bos.redhat.com>
So that tools such as 'perf probe' don't have to lookup
'[kernel.kallsyms]' but instead access them directly after
perf_session__create_kernel_maps or
map_groups__create_kernel_maps.
LKML-Reference: <1262629169-22797-4-git-send-email-acme@infradead.org>
Check whether the debugfs path is correct before executing
a command, because perf-probe depends on debugfs.
Cc: Jim Keniston <jkenisto@us.ibm.com>
Cc: Jason Baron <jbaron@redhat.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
LKML-Reference: <20091216222400.14459.48162.stgit@dhcp-100-2-132.bos.redhat.com>
This simplifies a lot of functions, less stuff to be done by
tool writers.
LKML-Reference: <1260914682-29652-1-git-send-email-acme@infradead.org>
Fix perf probe to show which probe point is not found.
With out this patch, it shows just "No probe point found."
This doesn't help users if they specify several probes.
e.g.
# perf probe -f --add schedule --add test
Fatal: No probe point found.
This patch makes error message more helpful as below.
# perf probe --add schedule --add test
Fatal: Probe point 'test' not found. - probe not added.
Cc: Frank Ch. Eigler <fche@redhat.com>
LKML-Reference: <20091215153247.17436.49068.stgit@dhcp-100-2-132.bos.redhat.com>
Check symbols in symtab/kallsyms when no debuginfo
is available.
e.g.
# perf probe test
Fatal: Kernel symbol 'test' not found - probe not added.
LKML-Reference: <20091215153239.17436.55034.stgit@dhcp-100-2-132.bos.redhat.com>
Check build-id of vmlinux by using functions in symbol.c.
This also exposes map__load() for getting vmlinux path,
and removes vmlinux path list in builtin-probe.c,
because symbol.c already has that. Checking build-id
prevents users to open old or different debuginfo from
current running kernel.
LKML-Reference: <20091215153232.17436.45539.stgit@dhcp-100-2-132.bos.redhat.com>
Reject second attempt of adding same-name event. This patch
also provides --force option which allows user to add additional
probe events on the same-name event.
e.g.
(the first attempt : success)
./perf probe schedule
Added new event:
probe:schedule (on schedule+0)
(the second attempt : failure)
./perf probe schedule:11
Error: event "schedule" already exists. (Use -f to force duplicates.)
Fatal: Can't add new event.
(the second attempt with -f : successfully added)
./perf probe -f schedule:11
Added new event:
probe:schedule_1 (on schedule+45)
LKML-Reference: <20091215153225.17436.15166.stgit@dhcp-100-2-132.bos.redhat.com>
Support event name syntax for --add option. This allows
users to specify event name for each new event.
The --add syntax is:
perf probe --add '[EVENT=]SRC:LINE ARGS'
or
perf probe --add '[EVENT=]FUNC[+OFFS|%return|:RLN][@SRC] ARGS'
e.g.
./perf probe --add myprobe1=schedule
Note: currently group name is not supported yet, because it
can cause name-space confliction with other tracepoint/
hw-breakpoint events.
LKML-Reference: <20091215153218.17436.84675.stgit@dhcp-100-2-132.bos.redhat.com>
Show need-dwarf message only if the probe is really requires
debuginfo analysis. This also use pr_debug for debugging message
instead of pr_warning.
LKML-Reference: <20091215153135.17436.99052.stgit@dhcp-100-2-132.bos.redhat.com>
Check hyphen only command argument, because perf-probe doesn't
support event recording feature yet.
e.g.
# perf probe -
Error: '-' is not supported.
LKML-Reference: <20091215153128.17436.9266.stgit@dhcp-100-2-132.bos.redhat.com>
Clean up struct session in builtin-probe.c, including
change need_dwarf to bool and move listing flag into
struct session as list_events flag.
This also changes parse_perf_probe_event() interface
due to code readability.
LKML-Reference: <20091215153114.17436.77000.stgit@dhcp-100-2-132.bos.redhat.com>
Support perf probe --del <event> option. Currently,
perf probe can have only one event for each --del option.
If you'd like to delete several probe events, you need
to specify --del for each events.
LKML-Reference: <20091208220323.10142.62079.stgit@dhcp-100-2-132.bos.redhat.com>
Support vmlinux on current working direcotry by default and
also update file-open messages.
Now perf probe searches ./vmlinux too.
LKML-Reference: <20091208220309.10142.33040.stgit@dhcp-100-2-132.bos.redhat.com>
Fix add-probe command syntax without --add option.
perf-probe supports add-probe command without --add
option. But it treats each argument as an event definition.
e.g.
perf probe func arg1 arg2
is interpreted as
perf probe --add func --add arg1 --add arg2
But it may be useless in many cases.
This patch fixes this syntax to fold those arguments into
one event definition if there is no --add option. With this
change, above command is interpreted as below;
perf probe --add "func arg1 arg2"
LKML-Reference: <20091208220254.10142.73767.stgit@dhcp-100-2-132.bos.redhat.com>
Use pr_debug() for "missing vmlinux" debugging message.
LKML-Reference: <20091207170059.19230.51459.stgit@dhcp-100-2-132.bos.redhat.com>
Fix:
builtin-probe.c: In function 'cmd_probe':
builtin-probe.c:163: error: unused variable 'fd'
Signed-off-by: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
LKML-Reference: <4B162089.8000907@cn.fujitsu.com>
[ v2: use NO_LIBDWARF instead of __used ]
Add --list option for listing currently defined probe events
in the kernel. This shows events in below format;
[group:event] <perf-probe probe-definition>
for example:
[probe:schedule_0] schedule+30 cpu
Note that source file/line information is not supported yet.
So even if you added a probe by line, it will be shown in
<symbol+offset>.
LKML-Reference: <20091201002017.10235.76575.stgit@harusame>
Split probe event (kprobe-events and perf probe events) utility
functions from builtin-probe.c to probe-event.c.
LKML-Reference: <20091201001958.10235.90243.stgit@harusame>
Fix the index of formatted probe array for multiple probe
points, which should be probes[i] instead of probes[0].
LKML-Reference: <20091201001950.10235.54781.stgit@harusame>
Since the syntax has been changed, probe definition needs
parameters less than MAX_PROBE_ARGS + 1 (probe-point +
arguments).
LKML-Reference: <20091201001943.10235.80367.stgit@harusame>
