The recent perf_evsel__fprintf_callchain() move to evsel.c added several
new symbol requirements to the python binding, for instance:
# perf test -v python
16: Try 'import perf' in python, checking link problems :
--- start ---
test child forked, pid 18030
Traceback (most recent call last):
File "<stdin>", line 1, in <module>
ImportError: /tmp/build/perf/python/perf.so: undefined symbol:
callchain_cursor
test child finished with -1
---- end ----
Try 'import perf' in python, checking link problems: FAILED!
This would require linking against callchain.c to access to the global
callchain_cursor variables.
Since lots of functions already receive as a parameter a
callchain_cursor struct pointer, make that be the case for some more
function so that we can start phasing out usage of yet another global
variable.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Cc: David Ahern <dsahern@gmail.com>
Cc: Jiri Olsa <jolsa@kernel.org>
Cc: Namhyung Kim <namhyung@kernel.org>
Cc: Wang Nan <wangnan0@huawei.com>
Link: http://lkml.kernel.org/n/tip-djko3097eyg2rn66v2qcqfvn@git.kernel.org
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
In tracepoints, it's possible to print gfp flags in a human-friendly
format through a macro show_gfp_flags(), which defines a translation
array and passes is to __print_flags(). Since the following patch will
introduce support for gfp flags printing in printk(), it would be nice
to reuse the array. This is not straightforward, since __print_flags()
can't simply reference an array defined in a .c file such as mm/debug.c
- it has to be a macro to allow the macro magic to communicate the
format to userspace tools such as trace-cmd.
The solution is to create a macro __def_gfpflag_names which is used both
in show_gfp_flags(), and to define the gfpflag_names[] array in
mm/debug.c.
On the other hand, mm/debug.c also defines translation tables for page
flags and vma flags, and desire was expressed (but not implemented in
this series) to use these also from tracepoints. Thus, this patch also
renames the events/gfpflags.h file to events/mmflags.h and moves the
table definitions there, using the same macro approach as for gfpflags.
This allows translating all three kinds of mm-specific flags both in
tracepoints and printk.
Signed-off-by: Vlastimil Babka <vbabka@suse.cz>
Reviewed-by: Michal Hocko <mhocko@suse.com>
Cc: Arnaldo Carvalho de Melo <acme@kernel.org>
Cc: Rasmus Villemoes <linux@rasmusvillemoes.dk>
Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com>
Cc: Minchan Kim <minchan@kernel.org>
Cc: Sasha Levin <sasha.levin@oracle.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
When updating tracing's show_gfp_flags() I have noticed that perf's
gfp_compact_table is also outdated. Fill in the missing flags and place
a note in gfp.h to increase chance that future updates are synced.
Convert the __GFP_X flags from "GFP_X" to "__GFP_X" strings in line with
the previous patch.
Acked-by: David Rientjes <rientjes@google.com>
Cc: Michal Hocko <mhocko@suse.com>
Before this patch each subcommand calls perf_config() by themself,
reading the default configuration together with subcommand specific
options. If a subcommand doesn't have it own options, it needs to call
'perf_config(perf_default_config, NULL)' to ensure .perfconfig is
loaded.
This patch brings perf_config(perf_default_config, NULL) to the very
start of main(), so subcommands don't need to do it.
After this patch, 'llvm.clang-path' works for 'perf trace'.
Signed-off-by: Wang Nan <wangnan0@huawei.com>
Suggested-and-Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Alexei Starovoitov <ast@kernel.org>
Cc: Li Zefan <lizefan@huawei.com>
Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com>
Cc: pi3orama@163.com
Link: http://lkml.kernel.org/r/1456479154-136027-4-git-send-email-wangnan0@huawei.com
Move the subcommand-related files from perf to a new library named
libsubcmd.a.
Since we're moving files anyway, go ahead and rename 'exec_cmd.*' to
'exec-cmd.*' to be consistent with the naming of all the other files.
Signed-off-by: Josh Poimboeuf <jpoimboe@redhat.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Link: http://lkml.kernel.org/r/c0a838d4c878ab17fee50998811612b2281355c1.1450193761.git.jpoimboe@redhat.com
And it is also a step in the direction of killing the separation of data
and text maps in map_groups.
Link: http://lkml.kernel.org/n/tip-rrds86kb3wx5wk8v38v56gw8@git.kernel.org
In places where we were using its open coded equivalent.
Link: http://lkml.kernel.org/n/tip-khkdugcdoqy3tkszm3jdxgbe@git.kernel.org
When an error occurs an error value is just returned without freeing the
session. So allocating and freeing session have to be matched as a pair
even if an error occurs.
Signed-off-by: Taeung Song <treeze.taeung@gmail.com>
Acked-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1435652124-22414-3-git-send-email-treeze.taeung@gmail.com
The last argument to strtok_r doesn't need to be initialized, its just a
placeholder to make this routine reentrant, but gcc doesn't know about
that and complains, breaking the build, fix it by setting it to NULL.
Link: http://lkml.kernel.org/n/tip-8e8rgbg3aom9uarsyqjrsctg@git.kernel.org
Fixes: 0e11115644b3 ("perf kmem: Print gfp flags in human readable string")
Cc: Borislav Petkov <bp@suse.de>
Cc: Don Zickus <dzickus@redhat.com>
Cc: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/n/tip-iyyvkbnkrd9g19f6ta9zfkem@git.kernel.org
tools/perf/builtin-kmem.c
In addition to using refcounts for the struct thread lifetime
management, we need to protect access to machine->threads from
concurrent access.
That happens in 'perf top', where a thread processes events, inserting
and deleting entries from that rb_tree while another thread decays
hist_entries, that end up dropping references and ultimately deleting
threads from the rb_tree and releasing its resources when no further
hist_entry (or other data structures, like in 'perf sched') references
it.
So the rule is the same for refcounts + protected trees in the kernel,
get the tree lock, find object, bump the refcount, drop the tree lock,
return, use object, drop the refcount if no more use of it is needed,
keep it if storing it in some other data structure, drop when releasing
that data structure.
I.e. pair "t = machine__find(new)_thread()" with a "thread__put(t)", and
"perf_event__preprocess_sample(&al)" with "addr_location__put(&al)".
The addr_location__put() one is because as we return references to
several data structures, we may end up adding more reference counting
for the other data structures and then we'll drop it at
addr_location__put() time.
Acked-by: David Ahern <dsahern@gmail.com>
Link: http://lkml.kernel.org/n/tip-bs9rt4n0jw3hi9f3zxyy3xln@git.kernel.org
Sometimes one can mistakenly run 'perf kmem stat' without running 'perf
kmem record' before or with a different configuration like recording
--slab and stat --page. Show a warning message like the one below to
inform the user:
# perf kmem stat --page --caller
No page allocation events found. Have you run 'perf kmem record --page'?
Signed-off-by: Namhyung Kim <namhyung@kernel.org>
Acked-by: Pekka Enberg <penberg@kernel.org>
Cc: Joonsoo Kim <js1304@gmail.com>
Cc: linux-mm@kvack.org
Link: http://lkml.kernel.org/r/1430837572-31395-1-git-send-email-namhyung@kernel.org
Currently perf kmem command will select --slab if neither --slab nor
--page is given for backward compatibility. Add kmem.default config
option to select the default value ('page' or 'slab').
# cat ~/.perfconfig
[kmem]
default = page
# perf kmem stat
SUMMARY (page allocator)
Total allocation requests : 1,518 [ 6,096 KB ]
Total free requests : 1,431 [ 5,748 KB ]
Total alloc+freed requests : 1,330 [ 5,344 KB ]
Total alloc-only requests : 188 [ 752 KB ]
Total free-only requests : 101 [ 404 KB ]
Total allocation failures : 0 [ 0 KB ]
Cc: Taeung Song <treeze.taeung@gmail.com>
Link: http://lkml.kernel.org/r/1429592107-1807-6-git-send-email-namhyung@kernel.org
Save libtraceevent output and print it in the header.
# GFP flags
# 00000010: NI: GFP_NOIO
# 000000d0: K: GFP_KERNEL
# 00000200: NWR: GFP_NOWARN
# 000084d0: K|R|Z: GFP_KERNEL|GFP_REPEAT|GFP_ZERO
# 000200d2: HU: GFP_HIGHUSER
# 000200da: HUM: GFP_HIGHUSER_MOVABLE
# 000280da: HUM|Z: GFP_HIGHUSER_MOVABLE|GFP_ZERO
# 002084d0: K|R|Z|NT: GFP_KERNEL|GFP_REPEAT|GFP_ZERO|GFP_NOTRACK
# 0102005a: NF|HW|M: GFP_NOFS|GFP_HARDWALL|GFP_MOVABLE
Total alloc (KB) | Hits | Order | Mig.type | GFP flags | Callsite
60 | 15 | 0 | UNMOVABL | K|R|Z|NT | pte_alloc_one
40 | 10 | 0 | MOVABLE | HUM|Z | handle_mm_fault
24 | 6 | 0 | MOVABLE | HUM | do_wp_page
24 | 6 | 0 | UNMOVABL | K | __pollwait
Requested-by: Joonsoo Kim <js1304@gmail.com>
Suggested-by: Minchan Kim <minchan@kernel.org>
Link: http://lkml.kernel.org/r/1429592107-1807-5-git-send-email-namhyung@kernel.org
Currently 'perf kmem stat --page' shows total (page) allocation stat by
default, but sometimes one might want to see live (total alloc-only)
requests/pages only. The new --live option does this by subtracting freed
allocation from the stat.
E.g.:
Total allocation requests : 988,858 [ 4,045,368 KB ]
Total free requests : 886,484 [ 3,624,996 KB ]
Total alloc+freed requests : 885,969 [ 3,622,628 KB ]
Total alloc-only requests : 102,889 [ 422,740 KB ]
Total free-only requests : 515 [ 2,368 KB ]
Order Unmovable Reclaimable Movable Reserved CMA/Isolated
0 172,173 3,083 806,686 . .
1 284 . . . .
2 6,124 58 . . .
3 114 335 . . .
4 . . . . .
5 . . . . .
6 . . . . .
7 . . . . .
8 . . . . .
9 . . 1 . .
10 . . . . .
# perf kmem stat --page --live
0 2,214 3,025 97,156 . .
1 59 . . . .
2 19 58 . . .
3 23 335 . . .
4 . . . . .
5 . . . . .
6 . . . . .
7 . . . . .
8 . . . . .
9 . . . . .
10 . . . . .
Link: http://lkml.kernel.org/r/1429592107-1807-4-git-send-email-namhyung@kernel.org
[ Added examples to the changeset log ]
Add new sort keys for page: page, order, migtype, gfp - existing
'bytes', 'hit' and 'callsite' sort keys also work for page. Note that
-s/--sort option should be preceded by either of --slab or --page option
to determine where the sort keys applies.
Now it properly groups and sorts allocation stats - so same
page/caller with different order/migtype/gfp will be printed on a
different line.
# perf kmem stat --page --caller -l 10 -s order,hit
64 | 4 | 2 | RECLAIM | 00285250 | new_slab
50,144 | 12,536 | 0 | MOVABLE | 0102005a | __page_cache_alloc
52 | 13 | 0 | UNMOVABL | 002084d0 | pte_alloc_one
40 | 10 | 0 | MOVABLE | 000280da | handle_mm_fault
28 | 7 | 0 | UNMOVABL | 000000d0 | __pollwait
20 | 5 | 0 | MOVABLE | 000200da | do_wp_page
20 | 5 | 0 | MOVABLE | 000200da | do_cow_fault
16 | 4 | 0 | UNMOVABL | 00000200 | __tlb_remove_page
16 | 4 | 0 | UNMOVABL | 000084d0 | __pmd_alloc
8 | 2 | 0 | UNMOVABL | 000084d0 | __pud_alloc
Link: http://lkml.kernel.org/r/1429592107-1807-3-git-send-email-namhyung@kernel.org
It is 'perf kmem' support caller statistics for page. Unlike slab case,
the tracepoints in page allocator don't provide callsite info. So it
records with callchain and extracts callsite info.
Note that the callchain contains several memory allocation functions
which has no meaning for users. So skip those functions to get proper
callsites. I used following regex pattern to skip the allocator
functions:
^_?_?(alloc|get_free|get_zeroed)_pages?
This gave me a following list of functions:
# perf kmem record --page sleep 3
# perf kmem stat --page -v
alloc func: __get_free_pages
alloc func: get_zeroed_page
alloc func: alloc_pages_exact
alloc func: __alloc_pages_direct_compact
alloc func: __alloc_pages_nodemask
alloc func: alloc_page_interleave
alloc func: alloc_pages_current
alloc func: alloc_pages_vma
alloc func: alloc_page_buffers
alloc func: alloc_pages_exact_nid
The output looks mostly same as --alloc (I also added callsite column
to that) but groups entries by callsite. Currently, the order,
migrate type and GFP flag info is for the last allocation and not
guaranteed to be same for all allocations from the callsite.
Total_alloc (KB) | Hits | Order | Mig.type | GFP flags | Callsite
1,064 | 266 | 0 | UNMOVABL | 000000d0 | __pollwait
44 | 11 | 0 | MOVABLE | 000280da | handle_mm_fault
12 | 3 | 0 | UNMOVABL | 000084d0 | __pud_alloc
8 | 2 | 0 | UNMOVABL | 00000010 | bio_copy_user_iov
4 | 1 | 0 | UNMOVABL | 000200d2 | pipe_write
4 | 1 | 0 | MOVABLE | 000280da | do_wp_page
4 | 1 | 0 | UNMOVABL | 002084d0 | pgd_alloc
Link: http://lkml.kernel.org/r/1429592107-1807-2-git-send-email-namhyung@kernel.org
0d68bc92c48 breaks compiles on RHEL6/OL6:
cc1: warnings being treated as errors
builtin-kmem.c: In function ‘search_page_alloc_stat’:
builtin-kmem.c:322: error: declaration of ‘stat’ shadows a global declaration
node = &parent->rb_left;
/usr/include/sys/stat.h:455: error: shadowed declaration is here
builtin-kmem.c: In function ‘perf_evsel__process_page_alloc_event’:
builtin-kmem.c:378: error: declaration of ‘stat’ shadows a global declaration
builtin-kmem.c: In function ‘perf_evsel__process_page_free_event’:
builtin-kmem.c:431: error: declaration of ‘stat’ shadows a global declaration
Rename local variable to pstat to avoid the name conflict.
Signed-off-by: David Ahern <david.ahern@oracle.com>
Link: http://lkml.kernel.org/r/1429033773-31383-1-git-send-email-david.ahern@oracle.com
Building the perf tool for 32-bit ARM results in the following build
error due to a combination of an incorrect conversion specifier and
compiling with -Werror:
builtin-kmem.c: In function ‘print_page_summary’:
builtin-kmem.c:644:9: error: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘u64’ [-Werror=format=]
nr_alloc_freed, (total_alloc_freed_bytes) / 1024);
builtin-kmem.c:647:9: error: format ‘%lu’ expects argument of type ‘long unsigned int’, but argument 3 has type ‘u64’ [-Werror=format=]
(total_page_alloc_bytes - total_alloc_freed_bytes) / 1024);
cc1: all warnings being treated as errors
This patch fixes the problem by consistently using PRIu64 for printing
out u64 values.
Link: http://lkml.kernel.org/r/1429796437-1790-1-git-send-email-will.deacon@arm.com
The perf kmem command records and analyze kernel memory allocation only
for SLAB objects. This patch implement a simple page allocator analyzer
using kmem:mm_page_alloc and kmem:mm_page_free events.
It adds two new options of --slab and --page. The --slab option is for
analyzing SLAB allocator and that's what perf kmem currently does.
The new --page option enables page allocator events and analyze kernel
memory usage in page unit. Currently, 'stat --alloc' subcommand is
implemented only.
If none of these --slab nor --page is specified, --slab is implied.
First run 'perf kmem record' to generate a suitable perf.data file:
# perf kmem record --page sleep 5
Then run 'perf kmem stat' to postprocess the perf.data file:
# perf kmem stat --page --alloc --line 10
PFN | Total alloc (KB) | Hits | Order | Mig.type | GFP flags
4045014 | 16 | 1 | 2 | RECLAIM | 00285250
4143980 | 16 | 1 | 2 | RECLAIM | 00285250
3938658 | 16 | 1 | 2 | RECLAIM | 00285250
4045400 | 16 | 1 | 2 | RECLAIM | 00285250
3568708 | 16 | 1 | 2 | RECLAIM | 00285250
3729824 | 16 | 1 | 2 | RECLAIM | 00285250
3657210 | 16 | 1 | 2 | RECLAIM | 00285250
4120750 | 16 | 1 | 2 | RECLAIM | 00285250
3678850 | 16 | 1 | 2 | RECLAIM | 00285250
3693874 | 16 | 1 | 2 | RECLAIM | 00285250
Total allocation requests : 44,260 [ 177,256 KB ]
Total free requests : 117 [ 468 KB ]
Total alloc+freed requests : 49 [ 196 KB ]
Total alloc-only requests : 44,211 [ 177,060 KB ]
Total free-only requests : 68 [ 272 KB ]
0 32 . 44,210 . .
1 . . . . .
2 . 18 . . .
3 . . . . .
4 . . . . .
5 . . . . .
6 . . . . .
7 . . . . .
8 . . . . .
9 . . . . .
10 . . . . .
Link: http://lkml.kernel.org/r/1428298576-9785-4-git-send-email-namhyung@kernel.org
Currently the perf kmem does not respect -i option.
Initializing the file.path properly after options get parsed.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Link: http://lkml.kernel.org/r/1428298576-9785-2-git-send-email-namhyung@kernel.org
Enable perf kmem to use perf.data when it is not owned by current user
or root.
Example:
# perf kmem record ls
# chown Yunlong.Song:Yunlong.Song perf.data
# ls -al perf.data
-rw------- 1 Yunlong.Song Yunlong.Song 5315665 Apr 2 10:54 perf.data
# id
uid=0(root) gid=0(root) groups=0(root),64(pkcs11)
Before this patch:
# perf kmem stat
File perf.data not owned by current user or root (use -f to override)
# perf kmem stat -f
Error: unknown switch `f'
usage: perf kmem [<options>] {record|stat}
-i, --input <file> input file name
-v, --verbose be more verbose (show symbol address, etc)
--caller show per-callsite statistics
--alloc show per-allocation statistics
-s, --sort <key[,key2...]>
sort by keys: ptr, call_site, bytes, hit,
pingpong, frag
-l, --line <num> show n lines
--raw-ip show raw ip instead of symbol
As shown above, the -f option does not work at all.
After this patch:
# perf kmem stat
# perf kmem stat -f
SUMMARY
Total bytes requested: 437599
Total bytes allocated: 615472
Total bytes wasted on internal fragmentation: 177873
Internal fragmentation: 28.900259%
Cross CPU allocations: 6/1192
As shown above, the -f option really works now.
Signed-off-by: Yunlong Song <yunlong.song@huawei.com>
Link: http://lkml.kernel.org/r/1427982439-27388-4-git-send-email-yunlong.song@huawei.com
Like perf stat, this makes easy to read the numbers on stat like below:
# perf kmem stat
SUMMARY
Total bytes requested: 9,770,900
Total bytes allocated: 9,782,712
Total bytes wasted on internal fragmentation: 11,812
Internal fragmentation: 0.120744%
Cross CPU allocations: 74/152,819
Suggested-by: Ingo Molnar <mingo@kernel.org>
Link: http://lkml.kernel.org/r/1427092244-22764-2-git-send-email-namhyung@kernel.org
Its table was a bit misaligned. Fix it.
Before:
# perf kmem stat --caller -l 10
Callsite | Total_alloc/Per | Total_req/Per | Hit | Ping-pong | Frag
radeon_cs_parser_init.part.1+11a | 2080/260 | 1504/188 | 8 | 0 | 27.692%
radeon_cs_parser_init.part.1+e1 | 384/96 | 288/72 | 4 | 0 | 25.000%
radeon_cs_parser_init.part.1+93 | 128/32 | 96/24 | 4 | 0 | 25.000%
load_elf_binary+a39 | 512/512 | 392/392 | 1 | 0 | 23.438%
__alloc_skb+89 | 6144/877 | 4800/685 | 7 | 6 | 21.875%
radeon_fence_emit+5c | 1152/192 | 912/152 | 6 | 0 | 20.833%
radeon_cs_parser_relocs+ad | 8192/2048 | 6624/1656 | 4 | 0 | 19.141%
radeon_sa_bo_new+78 | 1280/64 | 1120/56 | 20 | 0 | 12.500%
load_elf_binary+2c4 | 32/32 | 28/28 | 1 | 0 | 12.500%
anon_vma_prepare+101 | 576/72 | 512/64 | 8 | 0 | 11.111%
After:
Link: http://lkml.kernel.org/r/1426145571-3065-4-git-send-email-namhyung@kernel.org
Current perf kmem fails when -v option is used. As it's very useful for
debugging, let's allow it.
Link: http://lkml.kernel.org/r/1426145571-3065-3-git-send-email-namhyung@kernel.org
When it tries to free 'str', it was already updated by strsep() - so it
needs to save the original pointer.
# perf kmem stat -s xxx,hit
Error: Unknown --sort key: 'xxx'
*** Error in `perf': free(): invalid pointer: 0x0000000000e9e7b6 ***
======= Backtrace: =========
/usr/lib/libc.so.6(+0x7198e)[0x7fc7e6e0d98e]
/usr/lib/libc.so.6(+0x76dee)[0x7fc7e6e12dee]
/usr/lib/libc.so.6(+0x775cb)[0x7fc7e6e135cb]
./perf[0x44a1b5]
./perf[0x490b20]
./perf(parse_options_step+0x173)[0x491773]
./perf(parse_options_subcommand+0xa7)[0x491fb7]
./perf(cmd_kmem+0x2bc)[0x44ae4c]
./perf[0x47aa13]
./perf(main+0x60a)[0x427a9a]
/usr/lib/libc.so.6(__libc_start_main+0xf0)[0x7fc7e6dbc800]
./perf(_start+0x29)[0x427bb9]
Link: http://lkml.kernel.org/r/1426145571-3065-2-git-send-email-namhyung@kernel.org
By keeping pointers to machines, evlist and tool in ordered_events.
Link: http://lkml.kernel.org/n/tip-0c6huyaf59mqtm2ek9pmposl@git.kernel.org
Because perf_session__new() can fail for more reasons than just ENOMEM,
modify error code(ENOMEM or EINVAL) to -1.
Acked-by: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/1411522417-9917-1-git-send-email-treeze.taeung@gmail.com
Currently vmlinux_path__init() only tries to find vmlinux file from
current directory, /boot and some canonical directories with version
number of the running kernel. This can be a problem when reporting old
data recorded on a kernel version not running currently.
We can use --symfs option for this but it's annoying for user to do it
always. As we already have the info in the perf.data file, it can be
changed to use it for the search automatically.
Before:
$ perf report
# Samples: 4K of event 'cpu-clock'
# Event count (approx.): 1067250000
# Overhead Command Shared Object Symbol
71.87% swapper [kernel.kallsyms] [k] recover_probed_instruction
After:
71.87% swapper [kernel.kallsyms] [k] native_safe_halt
This requires to change signature of symbol__init() to receive struct
perf_session_env *.
Reported-by: Minchan Kim <minchan@kernel.org>
Cc: Namhyung Kim <namhyung.kim@lge.com>
Link: http://lkml.kernel.org/r/1407825645-24586-14-git-send-email-namhyung@kernel.org
This is a preparation of fixing dso__load_kernel_sym(). It needs a
session info before calling symbol__init().
Link: http://lkml.kernel.org/r/1407825645-24586-7-git-send-email-namhyung@kernel.org
The perf kmem command didn't process mmap events for some unknown reason
and it instead gets symbol info from a running kernel. This is
problematic if perf kmem record was run on a different kernel.
This patch adds the mmap event handlers and reverts the commit
e727ca73f85d ("perf kmem: Resolve kernel symbols again").
Link: http://lkml.kernel.org/r/1406872771-23933-1-git-send-email-namhyung@kernel.org
[ Fixed up merge conflict with Jiri's ordered_events rename patch set ]
The time ordering is generic for all kinds of events, so using generic
name 'ordered_events' for ordered_samples bool in perf_tool struct.
No functional change was intended.
Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com>
Cc: Jean Pihet <jean.pihet@linaro.org>
Link: http://lkml.kernel.org/n/tip-07mrqzcuhsks9wfmxrzsvemz@git.kernel.org
I believe that passing pid (instead of tid) as the 3rd arg of the
machine__find*_thread() was to find a main thread so that it can
search proper map group for symbols. However with the map sharing
patch applied, it now can do it in any thread.
It fixes a bug when each thread has different name, it only reports a
main thread for samples in other threads.
Acked-by: Stephane Eranian <eranian@google.com>
Link: http://lkml.kernel.org/r/1399856202-26221-1-git-send-email-namhyung@kernel.org
Use the previous patch implementation of cpunode_map for builtin-kmem.c
Should not be any functional difference.
Signed-off-by: Don Zickus <dzickus@redhat.com>
Reviewed-by: Namhyung Kim <namhyung@kernel.org>
Cc: Li Zefan <lizf@cn.fujitsu.com>
Link: http://lkml.kernel.org/r/1396896924-129847-4-git-send-email-dzickus@redhat.com
Signed-off-by: Jiri Olsa <jolsa@redhat.com>
Signed-off-by: Ramkumar Ramachandra <artagnon@gmail.com>
Link: http://lkml.kernel.org/r/1394853474-31019-2-git-send-email-artagnon@gmail.com
Not needed since this cset:
fcf65bf149af: perf evsel: Cache associated event_format
So lets trim this struct a bit.
Link: http://lkml.kernel.org/n/tip-j8setslokt0goiwxq9dogzqm@git.kernel.org
As the thread comm is going to be implemented by way of a more
complicated data structure than just a pointer to a string from the
thread struct, convert the readers of comm to use an accessor instead of
accessing it directly.
The accessor will be later overriden to support an enhanced comm
implementation.
Tested-by: Jiri Olsa <jolsa@redhat.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Link: http://lkml.kernel.org/n/tip-wr683zwy94hmj4ibogmnv9ce@git.kernel.org
[ Rename thread__comm_curr() to thread__comm_str() ]
[ Fixed up some minor const pointer issues ]
This patch is adding 'struct perf_data_file' object as a placeholder for
all attributes regarding perf.data file handling. Changing
perf_session__new to take it as an argument.
The rest of the functionality will be added later to keep this change
simple enough, because all the places using perf_session are changed
now.
Link: http://lkml.kernel.org/r/1381847254-28809-2-git-send-email-jolsa@redhat.com
The commit '2814eb0 perf kmem: Remove die() calls' disabled 'perf kmem'
command for machines without numa support. It made the command fail if
'/sys/devices/system/node' dir wasn't found.
Skipping the numa based initialization in case the directory is not
found and continue execution.
Link: http://lkml.kernel.org/r/1379003976-5839-5-git-send-email-jolsa@redhat.com
The ip_event struct assumes fixed positions for ip, pid and tid. That
is no longer true with the addition of PERF_SAMPLE_IDENTIFIER. The
information is anyway in struct sample, so use that instead.
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Cc: Namhyung Kim <namhyung@gmail.com>
Link: http://lkml.kernel.org/r/1377591794-30553-5-git-send-email-adrian.hunter@intel.com
Add a new parameter for 'pid' to machine__findnew_thread().
Change callers to pass 'pid' when it is known.
Note that callers sometimes want to find the main thread
which has the memory maps. The main thread has tid == pid
so the usage in that case is:
machine__findnew_thread(machine, pid, pid)
whereas the usage to find the specific thread is:
machine__findnew_thread(machine, pid, tid)
Link: http://lkml.kernel.org/r/1377591794-30553-2-git-send-email-adrian.hunter@intel.com
As evident from 'machine__process_fork_event()' and
'machine__process_exit_event()' the 'pid' member of struct thread is
actually the tid.
Rename 'pid' to 'tid' in struct thread accordingly.
Link: http://lkml.kernel.org/r/1372944040-32690-13-git-send-email-adrian.hunter@intel.com
It no longer have any affect on the processing and is marked as obsolete
anyway.
Link: http://lkml.kernel.org/n/tip-tvwyspiqr4getzfib2lw06ty@git.kernel.org
Link: http://lkml.kernel.org/r/1372307120-737-1-git-send-email-namhyung@kernel.org
[ combined patch removing the -f usage in various sub-commands, such as 'perf sched', etc, by Namhyung Kim ]
Instead of hand coded equivalent.
Link: http://lkml.kernel.org/n/tip-42ldngi973f4ssvzlklo8t2k@git.kernel.org
Link: http://lkml.kernel.org/r/1356030701-16284-8-git-send-email-sasha.levin@oracle.com
It is always there, no sense in calling a function named
"perf_session__find_host_machine".
Also no sense in checking if that function return is NULL, so ditch
needless error handling.
Link: http://lkml.kernel.org/n/tip-a6a3zx3afbrxo8p2zqm5mxo8@git.kernel.org
Currently many perf commands annotate/evlist/report/script/lock etc all
support "-i" option to chose a specific perf data, and all of them
create a local "input_name" to save the file name for that perf data.
Since most of these commands need it, we can add a global variable for
it, also it can some other benefits:
1. When calling script browser inside hists/annotation browser, it needs
to know the perf data file name to run that script.
2. For further feature like runtime switching to another perf data file,
this variable can also help.
Signed-off-by: Feng Tang <feng.tang@intel.com>
Link: http://lkml.kernel.org/r/1351569369-26732-2-git-send-email-feng.tang@intel.com
Some variables were global but used in just one function, so move it to
where it belongs.
Link: http://lkml.kernel.org/n/tip-wu8lz0g2qg26aqgi51xgzkpp@git.kernel.org
