path: root/tools/perf/builtin-bench.c
2015-05-08perf bench futex: Support parallel waker threadsDavidlohr Bueso
The futex-wake benchmark only measures wakeups done within a single process. While this has value in its own, it does not really generate any hb->lock contention. A new benchmark 'wake-parallel' is added, by extending the futex-wake code such that we can measure parallel waker threads. The program output shows the avg per-thread latency in order to complete its share of wakeups: Run summary [PID 13474]: blocking on 512 threads (at [private] futex 0xa88668), 8 threads waking up 64 at a time. [Run 1]: Avg per-thread latency (waking 64/512 threads) in 0.6230 ms (+-15.31%) [Run 2]: Avg per-thread latency (waking 64/512 threads) in 0.5175 ms (+-29.95%) [Run 3]: Avg per-thread latency (waking 64/512 threads) in 0.7578 ms (+-18.03%) [Run 4]: Avg per-thread latency (waking 64/512 threads) in 0.8944 ms (+-12.54%) [Run 5]: Avg per-thread latency (waking 64/512 threads) in 1.1204 ms (+-23.85%) Avg per-thread latency (waking 64/512 threads) in 0.7826 ms (+-9.91%) Naturally, different combinations of numbers of blocking and waker threads will exhibit different information. Signed-off-by: Davidlohr Bueso <dbueso@suse.de> Tested-by: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Davidlohr Bueso <dbueso@suse.de> Link: http://lkml.kernel.org/r/1431110280-20231-1-git-send-email-dave@stgolabs.net Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-06-19perf bench: Add --repeat optionDavidlohr Bueso
There are a number of benchmarks that do single runs and as a result does not really help users gain a general idea of how the workload performs. So the user must either manually do multiple runs or just use single bogus results. This option will enable users to specify the amount of runs (arbitrarily defaulted to 10, to use the existing benchmarks default) through the '--repeat' option. Add it to perf-bench instead of implementing it always in each specific benchmark. Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Jiri Olsa <jolsa@kernel.org> Link: http://lkml.kernel.org/r/1402942467-10671-2-git-send-email-davidlohr@hp.com [ Kept the existing default of 10, changing it to something else should be done on separate patch ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-31Merge branch 'perf-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull perf changes from Ingo Molnar: "Main changes: Kernel side changes: - Add SNB/IVB/HSW client uncore memory controller support (Stephane Eranian) - Fix various x86/P4 PMU driver bugs (Don Zickus) Tooling, user visible changes: - Add several futex 'perf bench' microbenchmarks (Davidlohr Bueso) - Speed up thread map generation (Don Zickus) - Introduce 'perf kvm --list-cmds' command line option for use by scripts (Ramkumar Ramachandra) - Print the evsel name in the annotate stdio output, prep to fix support outputting annotation for multiple events, not just for the first one (Arnaldo Carvalho de Melo) - Allow setting preferred callchain method in .perfconfig (Jiri Olsa) - Show in what binaries/modules 'perf probe's are set (Masami Hiramatsu) - Support distro-style debuginfo for uprobe in 'perf probe' (Masami Hiramatsu) Tooling, internal changes and fixes: - Use tid in mmap/mmap2 events to find maps (Don Zickus) - Record the reason for filtering an address_location (Namhyung Kim) - Apply all filters to an addr_location (Namhyung Kim) - Merge al->filtered with hist_entry->filtered in report/hists (Namhyung Kim) - Fix memory leak when synthesizing thread records (Namhyung Kim) - Use ui__has_annotation() in 'report' (Namhyung Kim) - hists browser refactorings to reuse code accross UIs (Namhyung Kim) - Add support for the new DWARF unwinder library in elfutils (Jiri Olsa) - Fix build race in the generation of bison files (Jiri Olsa) - Further streamline the feature detection display, trimming it a bit to show just the libraries detected, using VF=1 gets a more verbose output, showing the less interesting feature checks as well (Jiri Olsa). - Check compatible symtab type before loading dso (Namhyung Kim) - Check return value of filename__read_debuglink() (Stephane Eranian) - Move some hashing and fs related code from tools/perf/util/ to tools/lib/ so that it can be used by more tools/ living utilities (Borislav Petkov) - Prepare DWARF unwinding code for using an elfutils alternative unwinding library (Jiri Olsa) - Fix DWARF unwind max_stack processing (Jiri Olsa) - Add dwarf unwind 'perf test' entry (Jiri Olsa) - 'perf probe' improvements including memory leak fixes, sharing the intlist class with other tools, uprobes/kprobes code sharing and use of ref_reloc_sym (Masami Hiramatsu) - Shorten sample symbol resolving by adding cpumode to struct addr_location (Arnaldo Carvalho de Melo) - Fix synthesizing mmaps for threads (Don Zickus) - Fix invalid output on event group stdio report (Namhyung Kim) - Fixup header alignment in 'perf sched latency' output (Ramkumar Ramachandra) - Fix off-by-one error in 'perf timechart record' argv handling (Ramkumar Ramachandra) Tooling, cleanups: - Remove unused thread__find_map function (Jiri Olsa) - Remove unused simple_strtoul() function (Ramkumar Ramachandra) Tooling, documentation updates: - Update function names in debug messages (Ramkumar Ramachandra) - Update some code references in design.txt (Ramkumar Ramachandra) - Clarify load-latency information in the 'perf mem' docs (Andi Kleen) - Clarify x86 register naming in 'perf probe' docs (Andi Kleen)" * 'perf-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (96 commits) perf tools: Remove unused simple_strtoul() function perf tools: Update some code references in design.txt perf evsel: Update function names in debug messages perf tools: Remove thread__find_map function perf annotate: Print the evsel name in the stdio output perf report: Use ui__has_annotation() perf tools: Fix memory leak when synthesizing thread records perf tools: Use tid in mmap/mmap2 events to find maps perf report: Merge al->filtered with hist_entry->filtered perf symbols: Apply all filters to an addr_location perf symbols: Record the reason for filtering an address_location perf sched: Fixup header alignment in 'latency' output perf timechart: Fix off-by-one error in 'record' argv handling perf machine: Factor machine__find_thread to take tid argument perf tools: Speed up thread map generation perf kvm: introduce --list-cmds for use by scripts perf ui hists: Pass evsel to hpp->header/width functions explicitly perf symbols: Introduce thread__find_cpumode_addr_location perf session: Change header.misc dump from decimal to hex perf ui/tui: Reuse generic __hpp__fmt() code ...
2014-03-14perf bench: Fix NULL pointer dereference in "perf bench all"Patrick Palka
The for_each_bench() macro must check that the "benchmarks" field of a collection is not NULL before dereferencing it because the "all" collection in particular has a NULL "benchmarks" field (signifying that it has no benchmarks to iterate over). This fixes this NULL pointer dereference when running "perf bench all": [root@ssdandy ~]# perf bench all <SNIP> # Running mem/memset benchmark... # Copying 1MB Bytes ... 2.453675 GB/Sec 12.056327 GB/Sec (with prefault) Segmentation fault (core dumped) [root@ssdandy ~]# Signed-off-by: Patrick Palka <patrick@parcs.ath.cx> Cc: Ingo Molnar <mingo@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1394664051-6037-1-git-send-email-patrick@parcs.ath.cx Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Add futex-requeue microbenchmarkDavidlohr Bueso
Block a bunch of threads on a futex and requeue them on another, N at a time. This program is particularly useful to measure the latency of nthread requeues without waking up any tasks -- thus mimicking a regular futex_wait. An example run: $ perf bench futex requeue -r 100 -t 64 Run summary [PID 151011]: Requeuing 64 threads (from 0x7d15c4 to 0x7d15c8), 1 at a time. [Run 1]: Requeued 64 of 64 threads in 0.0400 ms [Run 2]: Requeued 64 of 64 threads in 0.0390 ms [Run 3]: Requeued 64 of 64 threads in 0.0400 ms ... [Run 100]: Requeued 64 of 64 threads in 0.0390 ms Requeued 64 of 64 threads in 0.0399 ms (+-0.37%) Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jason Low <jason.low2@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/r/1387081917-9102-4-git-send-email-davidlohr@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Add futex-wake microbenchmarkDavidlohr Bueso
Block a bunch of threads on a futex and wake them up, N at a time. This program is particularly useful to measure the latency of nthread wakeups in non-error situations: all waiters are queued and all wake calls wakeup one or more tasks. An example run: $ perf bench futex wake -t 512 -r 100 Run summary [PID 27823]: blocking on 512 threads (at futex 0x7e10d4), waking up 1 at a time. [Run 1]: Wokeup 512 of 512 threads in 6.0080 ms [Run 2]: Wokeup 512 of 512 threads in 5.2280 ms [Run 3]: Wokeup 512 of 512 threads in 4.8300 ms ... [Run 100]: Wokeup 512 of 512 threads in 5.0100 ms Wokeup 512 of 512 threads in 5.0109 ms (+-2.25%) Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jason Low <jason.low2@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/r/1387081917-9102-3-git-send-email-davidlohr@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-03-14perf bench: Add futex-hash microbenchmarkDavidlohr Bueso
Introduce futexes to perf-bench and add a program that stresses and measures the kernel's implementation of the hash table. This is a multi-threaded program that simply measures the amount of failed futex wait calls - we only want to deal with the hashing overhead, so a negative return of futex_wait_setup() is enough to do the trick. An example run: $ perf bench futex hash -t 32 Run summary [PID 10989]: 32 threads, each operating on 1024 [private] futexes for 10 secs. [thread 0] futexes: 0x19d9b10 ... 0x19dab0c [ 418713 ops/sec ] [thread 1] futexes: 0x19daca0 ... 0x19dbc9c [ 469913 ops/sec ] [thread 2] futexes: 0x19dbe30 ... 0x19dce2c [ 479744 ops/sec ] ... [thread 31] futexes: 0x19fbb80 ... 0x19fcb7c [ 464179 ops/sec ] Averaged 454310 operations/sec (+- 0.84%), total secs = 10 Signed-off-by: Davidlohr Bueso <davidlohr@hp.com> Acked-by: Darren Hart <dvhart@linux.intel.com> Cc: Aswin Chandramouleeswaran <aswin@hp.com> Cc: Darren Hart <dvhart@linux.intel.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Jason Low <jason.low2@hp.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Scott J Norton <scott.norton@hp.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Waiman Long <Waiman.Long@hp.com> Link: http://lkml.kernel.org/r/1387081917-9102-2-git-send-email-davidlohr@hp.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-23perf bench: Change the procps visible command-name of invididual benchmark ↵Ingo Molnar
tests plus cleanups Before this patch, looking at 'perf bench sched pipe' behavior over 'top' only told us that something related to perf is running: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 19934 mingo 20 0 54836 1296 952 R 18.6 0.0 0:00.56 perf 19935 mingo 20 0 54836 384 36 S 18.6 0.0 0:00.56 perf After the patch it's clearly visible what's going on: PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND 19744 mingo 20 0 125m 3536 2644 R 68.2 0.0 0:01.12 sched-pipe 19745 mingo 20 0 125m 1172 276 R 68.2 0.0 0:01.12 sched-pipe The benchmark-subsystem name is concatenated with the individual testcase name. Unfortunately 'perf top' does not show the reconfigured name, possibly because it caches ->comm[] values and does not recognize changes to them? Also clean up a few bits in builtin-bench.c while at it and reorganize the code and the output strings to be consistent. Use iterators to access the various arrays. Rename 'suites' concept to 'benchmark collection' and the 'bench_suite' to 'benchmark/bench'. The many repetitions of 'suite' made the code harder to read and understand. The new output is: comet:~/tip/tools/perf> ./perf bench Usage: perf bench [<common options>] <collection> <benchmark> [<options>] # List of all available benchmark collections: sched: Scheduler and IPC benchmarks mem: Memory access benchmarks numa: NUMA scheduling and MM benchmarks all: All benchmarks comet:~/tip/tools/perf> ./perf bench sched # List of available benchmarks for collection 'sched': messaging: Benchmark for scheduling and IPC pipe: Benchmark for pipe() between two processes all: Test all scheduler benchmarks comet:~/tip/tools/perf> ./perf bench mem # List of available benchmarks for collection 'mem': memcpy: Benchmark for memcpy() memset: Benchmark for memset() tests all: Test all memory benchmarks comet:~/tip/tools/perf> ./perf bench numa # List of available benchmarks for collection 'numa': mem: Benchmark for NUMA workloads all: Test all NUMA benchmarks Individual benchmark modules were not touched. Signed-off-by: Ingo Molnar <mingo@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Hitoshi Mitake <h.mitake@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/20131023123756.GA17871@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-10-09tools/perf: Standardize feature support define names to: HAVE_{FEATURE}_SUPPORTIngo Molnar
Standardize all the feature flags based on the HAVE_{FEATURE}_SUPPORT naming convention: HAVE_ARCH_X86_64_SUPPORT HAVE_BACKTRACE_SUPPORT HAVE_CPLUS_DEMANGLE_SUPPORT HAVE_DWARF_SUPPORT HAVE_ELF_GETPHDRNUM_SUPPORT HAVE_GTK2_SUPPORT HAVE_GTK_INFO_BAR_SUPPORT HAVE_LIBAUDIT_SUPPORT HAVE_LIBELF_MMAP_SUPPORT HAVE_LIBELF_SUPPORT HAVE_LIBNUMA_SUPPORT HAVE_LIBUNWIND_SUPPORT HAVE_ON_EXIT_SUPPORT HAVE_PERF_REGS_SUPPORT HAVE_SLANG_SUPPORT HAVE_STRLCPY_SUPPORT Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/n/tip-u3zvqejddfZhtrbYbfhi3spa@git.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-30perf tools: Make numa benchmark optionalPeter Hurley
Commit "perf: Add 'perf bench numa mem'..." added a NUMA performance benchmark to perf. Make this optional and test for required dependencies. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Acked-by: Ingo Molnar <mingo@kernel.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1359337882-21821-1-git-send-email-peter@hurleysoftware.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-30perf: Add 'perf bench numa mem' NUMA performance measurement suiteIngo Molnar
Add a suite of NUMA performance benchmarks. The goal was simulate the behavior and access patterns of real NUMA workloads, via a wide range of parameters, so this tool goes well beyond simple bzero() measurements that most NUMA micro-benchmarks use: - It processes the data and creates a chain of data dependencies, like a real workload would. Neither the compiler, nor the kernel (via KSM and other optimizations) nor the CPU can eliminate parts of the workload. - It randomizes the initial state and also randomizes the target addresses of the processing - it's not a simple forward scan of addresses. - It provides flexible options to set process, thread and memory relationship information: -G sets "global" memory shared between all test processes, -P sets "process" memory shared by all threads of a process and -T sets "thread" private memory. - There's a NUMA convergence monitoring and convergence latency measurement option via -c and -m. - Micro-sleeps and synchronization can be injected to provoke lock contention and scheduling, via the -u and -S options. This simulates IO and contention. - The -x option instructs the workload to 'perturb' itself artificially every N seconds, by moving to the first and last CPU of the system periodically. This way the stability of convergence equilibrium and the number of steps taken for the scheduler to reach equilibrium again can be measured. - The amount of work can be specified via the -l loop count, and/or via a -s seconds-timeout value. - CPU and node memory binding options, to test hard binding scenarios. THP can be turned on and off via madvise() calls. - Live reporting of convergence progress in an 'at glance' output format. Printing of convergence and deconvergence events. The 'perf bench numa mem -a' option will start an array of about 30 individual tests that will each output such measurements: # Running 5x5-bw-thread, "perf bench numa mem -p 5 -t 5 -P 512 -s 20 -zZ0q --thp 1" 5x5-bw-thread, 20.276, secs, runtime-max/thread 5x5-bw-thread, 20.004, secs, runtime-min/thread 5x5-bw-thread, 20.155, secs, runtime-avg/thread 5x5-bw-thread, 0.671, %, spread-runtime/thread 5x5-bw-thread, 21.153, GB, data/thread 5x5-bw-thread, 528.818, GB, data-total 5x5-bw-thread, 0.959, nsecs, runtime/byte/thread 5x5-bw-thread, 1.043, GB/sec, thread-speed 5x5-bw-thread, 26.081, GB/sec, total-speed See the help text and the code for more details. Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Andrea Arcangeli <aarcange@redhat.com> Cc: Rik van Riel <riel@redhat.com> Cc: Mel Gorman <mgorman@suse.de> Cc: Hugh Dickins <hughd@google.com> Signed-off-by: Ingo Molnar <mingo@kernel.org>
2013-01-24perf bench: Flush stdout before starting bench suiteNamhyung Kim
perf bench prints header message for bench suite before starting the benchmark. However if the stdout is redirected to a file and bench suite forks child processes this (and possibly other debugging messages too) will be repeated multiple times. $ perf bench sched messaging # Running sched/messaging benchmark... # 20 sender and receiver processes per group # 10 groups == 400 processes run Total time: 0.100 [sec] $ perf bench sched messaging > result.txt $ wc -l result.txt 391 In this file, there were so many "Running sched/messaging benchmark..." lines. This was because stdout is converted to fully-buffered due to the redirection and inherited child processes. Other lines are printed after reaping all those tasks. So fix it by flushing stdout before starting bench suites. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Hitoshi Mitake <h.mitake@gmail.com> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1357637966-8216-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-27perf bench: Documentation updateNamhyung Kim
The current perf-bench documentation has a couple of typos and even lacks entire description of mem subsystem. Fix it. Reported-by: Ingo Molnar <mingo@kernel.org> Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Ingo Molnar <mingo@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Link: http://lkml.kernel.org/r/1340172486-17805-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-01-24perf bench: Also allow measuring memset()Jan Beulich
This simply clones the respective memcpy() implementation. Cc: Ingo Molnar <mingo@elte.hu> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/r/4F16D743020000780006D735@nat28.tlf.novell.com Signed-off-by: Jan Beulich <jbeulich@suse.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-05-17perf options: Type check all the remaining OPT_ variantsArnaldo Carvalho de Melo
OPT_SET_INT was renamed to OPT_SET_UINT since the only use in these tools is to set something that has an enum type, that is builtin compatible with unsigned int. Several string constifications were done to make OPT_STRING require a const char * type. Cc: Frédéric Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> LKML-Reference: <new-submission> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2009-12-14perf bench: Add "all" pseudo subsystem and "all" pseudo suiteHitoshi Mitake
This patch adds a new "all" pseudo subsystem and an "all" pseudo suite. These are for testing all subsystem and its all suite, or all suite of one subsystem. (This patch also contains a few trivial comment fixes for bench/* and output style fixes. I judged that there are no necessity to make them into individual patch.) Example of use: | % ./perf bench sched all # Test all suites of sched subsystem | # Running sched/messaging benchmark... | # 20 sender and receiver processes per group | # 10 groups == 400 processes run | | Total time: 0.414 [sec] | | # Running sched/pipe benchmark... | # Extecuted 1000000 pipe operations between two tasks | | Total time: 10.999 [sec] | | 10.999317 usecs/op | 90914 ops/sec | | % ./perf bench all # Test all suites of all subsystems | # Running sched/messaging benchmark... | # 20 sender and receiver processes per group | # 10 groups == 400 processes run | | Total time: 0.420 [sec] | | # Running sched/pipe benchmark... | # Extecuted 1000000 pipe operations between two tasks | | Total time: 11.741 [sec] | | 11.741346 usecs/op | 85169 ops/sec | | # Running mem/memcpy benchmark... | # Copying 1MB Bytes from 0x7ff33e920010 to 0x7ff3401ae010 ... | | 808.407437 MB/Sec Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1260691319-4683-1-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-19perf bench: Add memcpy() benchmarkHitoshi Mitake
'perf bench mem memcpy' is a benchmark suite for measuring memcpy() performance. Example on a Intel(R) Core(TM)2 Duo CPU E6850 @ 3.00GHz: | % perf bench mem memcpy -l 1GB | # Running mem/memcpy benchmark... | # Copying 1MB Bytes from 0xb7d98008 to 0xb7e99008 ... | | 726.216412 MB/Sec Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> LKML-Reference: <1258471212-30281-1-git-send-email-mitake@dcl.info.waseda.ac.jp> [ v2: updated changelog, clarified history of builtin-bench.c ] Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10perf bench: Improve builtin-bench.c for more friendly outputHitoshi Mitake
This patch makes output of perf bench more friendly. Current style of putput, keeping user wait and printing everything suddenly when we finish, may confuse users. So I improved it: | % perf bench sched messaging | # Running sched/messaging benchmark... <- printed right after invocation | # 20 sender and receiver processes per group | # 10 groups == 400 processes run | | Total time: 1.476 [sec] Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1257865442-20252-2-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-10perf bench: Modify builtin-bench.c for processing common optionsHitoshi Mitake
This patch modifies builtin-bench.c for processing common options. The first option added is "--format". Users of perf bench will be able to specify output style by --format. Usage example: % ./perf bench sched messaging # with no style specify (20 sender and receiver processes per group) (10 groups == 400 processes run) Total time:1.431 sec % ./perf bench --format=simple sched messaging # specified simple 1.431 Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Paul Mackerras <paulus@samba.org> LKML-Reference: <1257808802-9420-3-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-11-08perf bench: Add builtin-bench.c: General framework for benchmark suitesHitoshi Mitake
This patch adds builtin-bench.c builtin-bench.c is a general framework for benchmark suites. Signed-off-by: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Mike Galbraith <efault@gmx.de> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Cc: fweisbec@gmail.com Cc: Jiri Kosina <jkosina@suse.cz> LKML-Reference: <1257381097-4743-5-git-send-email-mitake@dcl.info.waseda.ac.jp> Signed-off-by: Ingo Molnar <mingo@elte.hu>
