OPT_INCR()
Parsing an option from the command line with OPT_BOOLEAN on a
bool data type would not work on a big-endian machine due to the
manner in which the boolean was being cast into an int and
incremented. For example, running 'perf probe --list' on a
PowerPC machine would fail to properly set the list_events bool
and would therefore print out the usage information and
terminate.
This patch makes OPT_BOOLEAN work as expected with a bool
datatype. For cases where the original OPT_BOOLEAN was
intentionally being used to increment an int each time it was
passed in on the command line, this patch introduces OPT_INCR
with the old behaviour of OPT_BOOLEAN (the verbose variable is
currently the only such example of this).
I have reviewed every use of OPT_BOOLEAN to verify that a true
C99 bool was passed. Where integers were used, I verified that
they were only being used for boolean logic and changed them to
bools to ensure that they would not be mistakenly used as ints.
The major exception was the verbose variable which now uses
OPT_INCR instead of OPT_BOOLEAN.
Signed-off-by: Ian Munsie <imunsie@au.ibm.com>
Cc: <stable@kernel.org> # NOTE: wont apply to .3[34].x cleanly, please backport
Cc: Git development list <git@vger.kernel.org>
Cc: Ian Munsie <imunsie@au1.ibm.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
Cc: Hitoshi Mitake <mitake@dcl.info.waseda.ac.jp>
Cc: Eric B Munson <ebmunson@us.ibm.com>
Cc: Valdis.Kletnieks@vt.edu
Cc: WANG Cong <amwang@redhat.com>
Cc: Thiago Farina <tfransosi@gmail.com>
Cc: Masami Hiramatsu <mhiramat@redhat.com>
Cc: Xiao Guangrong <xiaoguangrong@cn.fujitsu.com>
Cc: Jaswinder Singh Rajput <jaswinderrajput@gmail.com>
Cc: Arjan van de Ven <arjan@linux.intel.com>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Tom Zanussi <tzanussi@gmail.com>
Cc: John Kacur <jkacur@redhat.com>
Cc: Li Zefan <lizf@cn.fujitsu.com>
LKML-Reference: <1271147857-11604-1-git-send-email-imunsie@au.ibm.com>
So that we avoid conflict with libc's string.h header.
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Suggested-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Cc: Frédéric Weisbecker <fweisbec@gmail.com>
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
That will be in both struct hist_entry and struct
callchain_list, so that the TUI can store a pointer to the pair
(map, symbol) in the trees where hist_entries and
callchain_lists are present, to allow precise annotation instead
of looking for the first symbol with the selected name.
LKML-Reference: <1269459619-982-4-git-send-email-acme@infradead.org>
Using the same parameter as in 'perf report', allowing to
specify just one and disambiguate between DSOs that have the
symbol of interest.
LKML-Reference: <1269459619-982-3-git-send-email-acme@infradead.org>
Before this patch we would not find a vmlinux, then try to pass
objdump "[kernel.kallsyms]" as the filename, it would get
confused and produce no output:
[root@doppio ~]# perf annotate n_tty_write
Percent | Source code & Disassembly of [kernel.kallsyms]
Now we check that and emit meaningful warning:
Can't annotate n_tty_write: No vmlinux file was found in the
path: [0] vmlinux
[1] /boot/vmlinux
[2] /boot/vmlinux-2.6.34-rc1-tip+
[3] /lib/modules/2.6.34-rc1-tip+/build/vmlinux
[4] /usr/lib/debug/lib/modules/2.6.34-rc1-tip+/vmlinux
[root@doppio ~]#
This bug was introduced when we added automatic search for
vmlinux, before that time the user had to specify a vmlinux
file.
v2: Print the warning just for the first symbol found when no
symbol name is specified, otherwise it will spam the screen
repeating the warning for each symbol.
Reported-by: Ingo Molnar <mingo@elte.hu>
LKML-Reference: <1268669073-6856-1-git-send-email-acme@infradead.org>
histogram tree
Now that report can store historgrams for multiple events we
need to be able to do the post processing work for each
histogram. This patch changes the post processing functions so
that they can be called individually for each event's histogram.
Signed-off-by: Eric B Munson <ebmunson@us.ibm.com>
[ Guarantee bisectabilty by fixing up builtin-report.c ]
LKML-Reference: <1267804269-22660-5-git-send-email-acme@infradead.org>
In order to minimize the impact of storing multiple events in a
report this function will now take the root of the histogram
tree so that the logic for selecting the proper tree can be
inserted before the call.
LKML-Reference: <1267804269-22660-3-git-send-email-acme@infradead.org>
Without this patch we get this for need_resched:
[root@mica ~]# perf annotate need_resched
Percent | Source code & Disassembly of vmlinux
: Disassembly of section .text:
: ffffffff810095ed <need_resched>:
: return (state & TASK_INTERRUPTIBLE) || __fatal_signal_pending(p);
: static inline int need_resched(void)
0.00 : ffffffff810095ed: 55 push %rbp
: return unlikely(test_thread_flag(TIF_NEED_RESCHED));
0.00 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi
: static inline struct thread_info *current_thread_info(void)
: struct thread_info *ti;
: ti = (void *)(percpu_read_stable(kernel_stack) +
0.00 : ffffffff810095f3: 65 48 8b 3c 25 48 b5 mov %gs:0xb548,%rdi
0.00 : ffffffff810095fa: 00 00
0.00 : ffffffff810095fc: 48 89 e5 mov %rsp,%rbp
0.00 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi
0.00 : ffffffff81009606: e8 9d ff ff ff callq ffffffff810095a8 <test_ti_thread_flag>
0.00 : ffffffff8100960b: c9 leaveq
0.00 : ffffffff8100960c: 85 c0 test %eax,%eax
0.00 : ffffffff8100960e: 0f 95 c0 setne %al
0.00 : ffffffff81009611: 0f b6 c0 movzbl %al,%eax
: Disassembly of section .vsyscall_0:
: Disassembly of section .vsyscall_fn:
: Disassembly of section .vsyscall_1:
: Disassembly of section .vsyscall_2:
: Disassembly of section .init.text:
: Disassembly of section .altinstr_replacement:
: Disassembly of section .exit.text:
[root@mica ~]#
But from the 'perf report' result we know that there are hits
for need_resched on a 4 way machine mostly doing nothing, so
after adding code to show what is in each hist offset and
collapsing IP hits for what happens between objdump lines we
get, for the same perf.data file:
[root@mica ~]# perf annotate -v need_resched
52.78 : ffffffff810095ee: be 03 00 00 00 mov $0x3,%esi
9.72 : ffffffff810095ff: 48 81 ef d8 1f 00 00 sub $0x1fd8,%rdi
37.50 : ffffffff8100960e: 0f 95 c0 setne %al
[root@mica ~]#
And now 'perf annotate -v', verbose mode, will show the hits per
precise IP, so that one can make sense of the attribution to
each objdumop line:
Looking at the vmlinux_path (5 entries long)
Using /lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux
for symbols annotate_sym: filename=/lib/modules/2.6.33-rc8-tip-00784-g3471df5-dirty/build/vmlinux, sym=need_resched, start=0xffffffff810095ed, end=0xffffffff81009614
ffffffff810095f1: 152
ffffffff81009603: 28
ffffffff8100960f: 55
ffffffff81009610: 53
h->sum: 288
<SNIP same annotation>
LKML-Reference: <1267194194-15670-1-git-send-email-acme@infradead.org>
Because symbol->end is not fixed up at symbol_filter time, only
after all symbols for a DSO are loaded, and that, for asm
symbols, may be bogus, causing segfaults when hits happen in
these symbols.
Reported-by: David Miller <davem@davemloft.net>
Reported-by: Anton Blanchard <anton@samba.org>
Acked-by: David Miller <davem@davemloft.net>
Cc: <stable@kernel.org> # for .33.x. Does not apply cleanly, needs backport.
LKML-Reference: <20100225155740.GB8553@ghostprotocols.net>
The problem was we were incorrectly calculating objdump
addresses for sym->start and sym->end, look:
For simple ET_DYN type DSO (*.so) with one function, objdump -dS
output is something like this:
000004ac <my_strlen>:
int my_strlen(const char *s)
4ac: 55 push %ebp
4ad: 89 e5 mov %esp,%ebp
4af: 83 ec 10 sub $0x10,%esp
i.e. we have relative-to-dso-mapping IPs (=RIP) there.
For ET_EXEC type and probably for prelinked libs as well (sorry
can't test - I don't use prelink) objdump outputs absolute IPs,
e.g.
08048604 <zz_strlen>:
extern "C"
int zz_strlen(const char *s)
8048604: 55 push %ebp
8048605: 89 e5 mov %esp,%ebp
8048607: 83 ec 10 sub $0x10,%esp
So, if sym->start is always relative to dso mapping(*), we'll
have to unmap it for ET_EXEC like cases, and leave as is for
ET_DYN cases.
(*) and it is - we've explicitely made it relative. Look for
adjust_symbols handling in dso__load_sym()
Previously we were always unmapping sym->start and for ET_DYN
dsos resulting addresses were wrong, and so objdump output was
empty.
The end result was that perf annotate output for symbols from
non-prelinked *.so had always 0.00% percents only, which is
wrong.
To fix it, let's introduce a helper for converting rip to
objdump address, and also let's document what map_ip() and
unmap_ip() do -- I had to study sources for several hours to
understand it.
Signed-off-by: Kirill Smelkov <kirr@landau.phys.spbu.ru>
LKML-Reference: <1265223128-11786-8-git-send-email-acme@infradead.org>
Not to pollute too much 'perf annotate' debugging sessions.
LKML-Reference: <1265223128-11786-7-git-send-email-acme@infradead.org>
Since they can come from another architecture with bigger
pointers, i.e. processing a 64-bit perf.data on a 32-bit arch.
LKML-Reference: <1263478990-8200-1-git-send-email-acme@infradead.org>
Since now all that we have are perf event handlers, leave just
the name of the event.
LKML-Reference: <1261957026-15580-9-git-send-email-acme@infradead.org>
So that --dsos, --comm, --symbols can bem used in more tools,
like in perf diff:
$ perf record -f find / > /dev/null
$ perf diff --dsos /lib64/libc-2.10.1.so | head -5
1 +22392124 /lib64/libc-2.10.1.so _IO_vfprintf_internal
2 +6410655 /lib64/libc-2.10.1.so __GI_memmove
3 +1 +9192692 /lib64/libc-2.10.1.so _int_malloc
4 -1 -15158605 /lib64/libc-2.10.1.so _int_free
5 +45669 /lib64/libc-2.10.1.so _IO_new_file_xsputn
LKML-Reference: <1260914682-29652-3-git-send-email-acme@infradead.org>
Will be used in perf diff too.
LKML-Reference: <1260914682-29652-2-git-send-email-acme@infradead.org>
This simplifies a lot of functions, less stuff to be done by
tool writers.
LKML-Reference: <1260914682-29652-1-git-send-email-acme@infradead.org>
And it is also needed by 'perf diff'.
LKML-Reference: <1260828571-3613-1-git-send-email-acme@infradead.org>
LKML-Reference: <1260810361-22828-1-git-send-email-acme@infradead.org>
As we'll need to sort multiple times for multiple perf sessions,
so that we can then do a diff.
LKML-Reference: <1260803439-16783-1-git-send-email-acme@infradead.org>
All hist entries are in only one of them, so use just one and a
temporary rb_root while sorting/collapsing.
LKML-Reference: <1260797831-11220-1-git-send-email-acme@infradead.org>
There is still some more work to do to disentangle map creation
from DSO loading, but this happens only for the kernel, and for
the early adopters of perf diff, where this disentanglement
matters most, we'll be testing different kernels, so no problem
here.
Further clarification: right now we create the kernel maps for
the various modules and discontiguous kernel text maps when
loading the DSO, we should do it as a two step process, first
creating the maps, for multiple mappings with the same DSO
store, then doing the dso load just once, for the first hit on
one of the maps sharing this DSO backing store.
LKML-Reference: <1260741029-4430-6-git-send-email-acme@infradead.org>
So that we can process two perf.data files.
We still need to add a O_MMAP mode for perf_session so that we
can do all the mmap stuff in it.
LKML-Reference: <1260741029-4430-5-git-send-email-acme@infradead.org>
By having the cwd/cwdlen in the perf_session struct and
full_paths in perf_event_ops.
Now its just a matter of passing the ops.
LKML-Reference: <1260741029-4430-4-git-send-email-acme@infradead.org>
No need for all tools to register it and then immediately call
perf_session__process_events.
LKML-Reference: <1260741029-4430-3-git-send-email-acme@infradead.org>
Pass the event_ops to perf_session__process_events instead.
Also move the event_ops definition to session.h, starting to
move things around to their right place, trimming the many
unneeded headers we have.
LKML-Reference: <1260741029-4430-2-git-send-email-acme@infradead.org>
They will need it to get the right threads list, etc.
LKML-Reference: <1260741029-4430-1-git-send-email-acme@infradead.org>
That does all the initialization boilerplate, opening the file,
reading the header, checking if it is valid, etc.
And that will as well have the threads list, kmap (now) global
variable, etc, so that we can handle two (or more) perf.data files
describing sessions to compare.
LKML-Reference: <1260573842-19720-1-git-send-email-acme@infradead.org>
perf-annotate doesn't parse perf.data correctly in that it
doesn't read perf header. Fix this by using
mmap_dispatch_perf_file().
Before:
TOTAL events: 17565
MMAP events: 3221
LOST events: 10
COMM events: 235
EXIT events: 2
THROTTLE events: 1
UNTHROTTLE events: 2
FORK events: 10
READ events: 1
SAMPLE events: 14083
After:
TOTAL events: 17290
MMAP events: 3203
LOST events: 0
COMM events: 234
EXIT events: 1
THROTTLE events: 0
UNTHROTTLE events: 0
FORK events: 0
READ events: 0
SAMPLE events: 13852
Signed-off-by: Li Zefan <lizf@cn.fujitsu.com>
Cc: Arnaldo Carvalho de Melo <acme@infradead.org>
Cc: Arjan van de Ven <arjan@infradead.org>
LKML-Reference: <4B14B201.9030708@cn.fujitsu.com>
Now we have a very high level routine for simple tools to
process IP sample events:
int event__preprocess_sample(const event_t *self,
struct addr_location *al,
symbol_filter_t filter)
It receives the event itself and will insert new threads in the
global threads list and resolve the map and symbol, filling all
this info into the new addr_location struct, so that tools like
annotate and report can further process the event by creating
hist_entries in their specific way (with or without callgraphs,
etc).
It in turn uses the new next layer function:
void thread__find_addr_location(struct thread *self, u8 cpumode,
enum map_type type, u64 addr,
This one will, given a thread (userspace or the kernel kthread
one), will find the given type (MAP__FUNCTION now, MAP__VARIABLE
too in the near future) at the given cpumode, taking vdsos into
account (userspace hit, but kernel symbol) and will fill all
these details in the addr_location given.
Tools that need a more compact API for plain function
resolution, like 'kmem', can use this other one:
struct symbol *thread__find_function(struct thread *self, u64 addr,
So, to resolve a kernel symbol, that is all the 'kmem' tool
needs, its just a matter of calling:
sym = thread__find_function(kthread, addr, NULL);
The 'filter' parameter is needed because we do lazy
parsing/loading of ELF symtabs or /proc/kallsyms.
With this we remove more code duplication all around, which is
always good, huh? :-)
LKML-Reference: <1259346563-12568-12-git-send-email-acme@infradead.org>
While implementing event__preprocess_sample, that will do all of
the symbol lookup in one convenient function, I noticed that
util/process_event.[ch] were not being used at all, then started
looking if there were other functions that could be shared
and...
All those functions really don't need to receive offset + head,
the only thing they did was common to all of them, so do it at
one place instead.
Stats about number of each type of event processed now is done
in a central place.
LKML-Reference: <1259346563-12568-11-git-send-email-acme@infradead.org>
Making the routines that were so far specific to the kernel maps
useful for all threads.
This is done by making the kernel maps be contained in a kernel
"thread".
This gets the kernel specific routines closer to the userspace
counterparts, which will help in reducing the boilerplate for
resolving a symbol, as will be demonstrated in the next patches.
LKML-Reference: <1259346563-12568-9-git-send-email-acme@infradead.org>
By using an array of rb_roots in struct dso we can, from a
struct map instance to get the right symbol rb_tree more easily.
This way we can have just one symbol lookup method for struct
map instances, map__find_symbol, instead of one per symtab type
(functions, variables).
LKML-Reference: <1259346563-12568-6-git-send-email-acme@infradead.org>
perf annotate was the only user, and it doesn't really need it.
LKML-Reference: <1259346563-12568-4-git-send-email-acme@infradead.org>
As we'll have kernel_map[s]__variables too.
LKML-Reference: <1259346563-12568-2-git-send-email-acme@infradead.org>
Paving the way for supporting variable in adition to function
symbols.
LKML-Reference: <1259074912-5924-1-git-send-email-acme@infradead.org>
And also express its configuration toggles via a struct.
Now all one has to do is to call symbol__init(NULL) if the
defaults are OK, or pass a struct symbol_conf pointer with the
desired configuration.
If a tool uses kernel_maps__find_symbol() to look at the kernel
and modules mappings for a symbol but didn't call symbol__init()
first, that will generate a one time warning too, alerting the
subcommand developer that symbol__init() must be called.
LKML-Reference: <1259071517-3242-2-git-send-email-acme@infradead.org>
Prevent bit-rot in perf-annotate by using common functions where
possible. Here we create process_events.[ch] to hold the common
functions.
Signed-off-by: John Kacur <jkacur@redhat.com>
Cc: acme@redhat.com
LKML-Reference: <1259073301-11506-3-git-send-email-jkacur@redhat.com>
Now that we can check the buildid to see if it really matches,
this can be done safely:
vmlinux
/boot/vmlinux
/boot/vmlinux-<uts.release>
/lib/modules/<uts.release>/build/vmlinux
/usr/lib/debug/lib/modules/%s/vmlinux
More can be added - if you know about distros that put the
vmlinux somewhere else please let us know.
LKML-Reference: <1259001550-8194-1-git-send-email-acme@infradead.org>
Just like we do with the other DSOs. This also simplifies the
kernel_maps setup process, now all that the tools need to do is
to call kernel_maps__init and the maps for the modules and
kernel will be created, then, later, when
kernel_maps__find_symbol() is used, it will also call
maps__find_symbol that already checks if the symtab was loaded,
loading it if needed.
Now if one does 'perf top --hide_kernel_symbols' we won't pay
the price of loading the (many) symbols in /proc/kallsyms or
vmlinux.
LKML-Reference: <1258757489-5978-4-git-send-email-acme@infradead.org>
It should just load kernel symbols, not load the list of
modules. There are more stuff to move to other routines, but
lets do it in several steps.
End goal is to be able to defer symbol table loading till we
find a hit for that map address range. So that the kernel &
modules are handled just like all the other DSOs in the system.
LKML-Reference: <1258757489-5978-1-git-send-email-acme@infradead.org>
Before we were storing this in the DSO, but in fact this is a
property of the 'symbol' class, not something that will vary
among DSOs, so move it to a global variable and initialize it
using the existing symbol__init routine.
LKML-Reference: <1256927305-4628-2-git-send-email-acme@infradead.org>
So that we can have a quicker start on perf top and even
speedups in the other tools, as we can have maps with no hits,
so no need to load its symtabs.
LKML-Reference: <1256773881-4191-1-git-send-email-acme@infradead.org>
We were using eprintf in some places, that looks at a global
'verbose' level, and at other places passing a 'v' parameter to
specify the verbosity level, unify it by introducing
pr_{err,warning,debug,etc}, just like in the kernel.
LKML-Reference: <1256153646-10097-1-git-send-email-acme@redhat.com>
If the user doesn't pass a symbol name to annotate, it will
annotate all the symbols that have hits, in order, just like
'perf report -s comm,dso,symbol'.
This is a natural followup patch to the one that uses
output_hists to find the symbols with hits.
The common case is to annotate the first few entries at the top
of a perf report, so lets type less characters.
LKML-Reference: <1256058509-19678-1-git-send-email-acme@redhat.com>
We have this sym_priv_size mechanism for attaching private areas
to struct symbol entries but annotate wasn't using it, adding
private areas to struct symbol in addition to a ->priv pointer.
Scrap all that and use the sym_priv_size mechanism.
LKML-Reference: <1256055940-19511-1-git-send-email-acme@redhat.com>
We need this because we get section relative addresses when
reading the symtabs, but when a tool like 'perf annotate' needs
to match these address to what 'objdump -dS' produces we need
the address + section back again.
So in annotate now we look at the 'struct hist_entry' instances
(that weren't really being used) so that we iterate only over
the symbols that had some hit and get the map where that
particular hit happened so that we can get the right address to
match with annotate.
Verified that at least:
perf annotate mmap_read_counter # Uses the ~/bin/perf binary
perf annotate --vmlinux /home/acme/git/build/perf/vmlinux intel_pmu_enable_all
on a 'perf record perf top' session seems to work.
LKML-Reference: <1255979877-12533-1-git-send-email-acme@redhat.com>
In each case, if the NULL test on thread is needed, then the
dereference should be after the NULL test.
A simplified version of the semantic match that detects this
problem is as follows (http://coccinelle.lip6.fr/):
// <smpl>
@match exists@
expression x, E;
identifier fld;
* x->fld
... when != \(x = E\|&x\)
* x == NULL
// </smpl>
LKML-Reference: <Pine.LNX.4.64.0910170842500.9213@ask.diku.dk>
This was just being copy'n'pasted all over.
LKML-Reference: <20091013141629.GD21809@ghostprotocols.net>
Like printing every symbol created.
LKML-Reference: <1254923340-4870-1-git-send-email-acme@redhat.com>
As it was not being exposed via any command line and with --dsos/--comms
we can do this and even more, like asking for just kernel + some module:
[root@doppio linux-2.6-tip]# perf report --dsos \[kernel\],\[drm\]
--vmlinux /home/acme/git/build/tip-recvmmsg/vmlinux --modules | head -15
# Samples: 619669
# Overhead Command Shared Object Symbol
7.12% swapper [kernel] [k] read_hpet
6.86% init [kernel] [k] read_hpet
6.22% init [kernel] [k] mwait_idle_with_hints
5.34% swapper [kernel] [k] mwait_idle_with_hints
3.01% firefox [kernel] [.] vread_hpet
2.14% Xorg [drm] [k] drm_clflush_pages
2.09% pidgin [kernel] [.] vread_hpet
1.58% npviewer.bin [kernel] [.] vread_hpet
1.37% swapper [kernel] [k] hpet_next_event
1.23% Xorg [kernel] [k] read_hpet
LKML-Reference: <20091003233048.GA30535@ghostprotocols.net>
