path: root/tools/perf/arch/x86
2012-11-19perf: Make perf build for x86 with UAPI disintegration appliedDavid Howells
Make perf build for x86 once the UAPI disintegration patches for that arch have been applied by adding the appropriate -I flags - in the right order - and then converting some #includes that use ../.. notation to find main kernel headerfiles to use <asm/foo.h> and <linux/foo.h> instead. Note that -Iarch/foo/include/uapi is present _before_ -Iarch/foo/include. This makes sure we get the userspace version of the pt_regs struct. Ideally, we wouldn't have the latter -I flag at all, but unfortunately we want asm/svm.h and asm/vmx.h in builtin-kvm.c and these aren't part of the UAPI - at least not for x86. I wonder if the bits outside of the __KERNEL__ guards *should* be transferred there. I note also that perf seems to do its dependency handling manually by listing all the header files it might want to use in LIB_H in the Makefile. Can this be changed to use -MD? Note that to do make this work, we need to export and UAPI disintegrate linux/hw_breakpoint.h, which I think should've been exported previously so that perf can access the bits. We have to do this in the same patch to maintain bisectability. Signed-off-by: David Howells <dhowells@redhat.com>
2012-08-11perf tools: Support for DWARF CFI unwinding on post processingJiri Olsa
This brings the support for DWARF cfi unwinding on perf post processing. Call frame informations are retrieved and then passed to libunwind that requests memory and register content from the applications. Adding unwind object to handle the user stack backtrace based on the user register values and user stack dump. The unwind object access the libunwind via remote interface and provides to it all the necessary data to unwind the stack. The unwind interface provides following function: unwind__get_entries And callback (specified in above function) to retrieve the backtrace entries: typedef int (*unwind_entry_cb_t)(struct unwind_entry *entry, void *arg); Signed-off-by: Jiri Olsa <jolsa@redhat.com> Original-patch-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-12-git-send-email-jolsa@redhat.com [ Replaced use of perf_session by usage of perf_evsel ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-10perf tools: Add interface to arch registers setsJiri Olsa
Adding header files to access unified API for arch registers. util/perf_regs.h - global perf_reg declarations arch/x86/include/perf_regs.h - x86 arch specific Adding perf_reg_name function to obtain register name based on the reg ID value, and PERF_REGS_MASK macro with mask definition of all current arch registers (will be used in unwind patches). Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: "Frank Ch. Eigler" <fche@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Benjamin Redelings <benjamin.redelings@nescent.org> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: Cyrill Gorcunov <gorcunov@openvz.org> Cc: Frank Ch. Eigler <fche@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Robert Richter <robert.richter@amd.com> Cc: Stephane Eranian <eranian@google.com> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Ulrich Drepper <drepper@gmail.com> Link: http://lkml.kernel.org/r/1344345647-11536-9-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-03-14perf tools: Use scnprintf where applicableArnaldo Carvalho de Melo
Several places were expecting that the value returned was the number of characters printed, not what would be printed if there was space. Fix it by using the scnprintf and vscnprintf variants we inherited from the kernel sources. Some corner cases where the number of printed characters were not accounted were fixed too. Reported-by: Anton Blanchard <anton@samba.org> Cc: Anton Blanchard <anton@samba.org> Cc: Eric B Munson <emunson@mgebm.net> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Yanmin Zhang <yanmin_zhang@linux.intel.com> Cc: stable@kernel.org Link: http://lkml.kernel.org/n/tip-kwxo2eh29cxmd8ilixi2005x@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2011-10-07perf tools: Make perf.data more self-descriptive (v8)Stephane Eranian
The goal of this patch is to include more information about the host environment into the perf.data so it is more self-descriptive. Overtime, profiles are captured on various machines and it becomes hard to track what was recorded, on what machine and when. This patch provides a way to solve this by extending the perf.data file with basic information about the host machine. To add those extensions, we leverage the feature bits capabilities of the perf.data format. The change is backward compatible with existing perf.data files. We define the following useful new extensions: - HEADER_HOSTNAME: the hostname - HEADER_OSRELEASE: the kernel release number - HEADER_ARCH: the hw architecture - HEADER_CPUDESC: generic CPU description - HEADER_NRCPUS: number of online/avail cpus - HEADER_CMDLINE: perf command line - HEADER_VERSION: perf version - HEADER_TOPOLOGY: cpu topology - HEADER_EVENT_DESC: full event description (attrs) - HEADER_CPUID: easy-to-parse low level CPU identication The small granularity for the entries is to make it easier to extend without breaking backward compatiblity. Many entries are provided as ASCII strings. Perf report/script have been modified to print the basic information as easy-to-parse ASCII strings. Extended information about CPU and NUMA topology may be requested with the -I option. Thanks to David Ahern for reviewing and testing the many versions of this patch. $ perf report --stdio # ======== # captured on : Mon Sep 26 15:22:14 2011 # hostname : quad # os release : 3.1.0-rc4-tip # perf version : 3.1.0-rc4 # arch : x86_64 # nrcpus online : 4 # nrcpus avail : 4 # cpudesc : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz # cpuid : GenuineIntel,6,15,11 # total memory : 8105360 kB # cmdline : /home/eranian/perfmon/official/tip/build/tools/perf/perf record date # event : name = cycles, type = 0, config = 0x0, config1 = 0x0, config2 = 0x0, excl_usr = 0, excl_kern = 0, id = { 29, 30, 31, # HEADER_CPU_TOPOLOGY info available, use -I to display # HEADER_NUMA_TOPOLOGY info available, use -I to display # ======== # ... $ perf report --stdio -I # ======== # captured on : Mon Sep 26 15:22:14 2011 # hostname : quad # os release : 3.1.0-rc4-tip # perf version : 3.1.0-rc4 # arch : x86_64 # nrcpus online : 4 # nrcpus avail : 4 # cpudesc : Intel(R) Core(TM)2 Quad CPU Q6600 @ 2.40GHz # cpuid : GenuineIntel,6,15,11 # total memory : 8105360 kB # cmdline : /home/eranian/perfmon/official/tip/build/tools/perf/perf record date # event : name = cycles, type = 0, config = 0x0, config1 = 0x0, config2 = 0x0, excl_usr = 0, excl_kern = 0, id = { 29, 30, 31, # sibling cores : 0-3 # sibling threads : 0 # sibling threads : 1 # sibling threads : 2 # sibling threads : 3 # node0 meminfo : total = 8320608 kB, free = 7571024 kB # node0 cpu list : 0-3 # ======== # ... Reviewed-by: David Ahern <dsahern@gmail.com> Tested-by: David Ahern <dsahern@gmail.com> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Robert Richter <robert.richter@amd.com> Cc: Andi Kleen <ak@linux.intel.com> Link: http://lkml.kernel.org/r/20110930134040.GA5575@quad Signed-off-by: Stephane Eranian <eranian@google.com> [ committer notes: Use --show-info in the tools as was in the docs, rename perf_header_fprintf_info to perf_file_section__fprintf_info, fixup conflict with f69b64f7 "perf: Support setting the disassembler style" ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2010-04-22perf: Move arch specific code into separate arch directoryIan Munsie
The perf userspace tool included some architecture specific code to map registers from the DWARF register number into the names used by the regs and stack access API. This moves the architecture specific code out into a separate arch/x86 directory along with the infrastructure required to use it. Signed-off-by: Ian Munsie <imunsie@au.ibm.com> Acked-by: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Paul Mackerras <paulus@samba.org>
