[ Upstream commit f32c2877bcb068a718bb70094cd59ccc29d4d082 ]
There was a missing comparison with 0 when checking if type is "s64" or
"u64". Therefore, the body of the if-statement was entered if "type" was
"u64" or not "s64", which made the first strcmp() redundant since if
type is "u64", it's not "s64".
If type is "s64", the body of the if-statement is not entered but since
the remainder of the function consists of if-statements which will not
be entered if type is "s64", we will just return "val", which is
correct, albeit at the cost of a few more calls to strcmp(), i.e., it
will behave just as if the if-statement was entered.
If type is neither "s64" or "u64", the body of the if-statement will be
entered incorrectly and "val" returned. This means that any type that is
checked after "s64" and "u64" is handled the same way as "s64" and
"u64", i.e., the limiting of "val" to fit in for example "s8" is never
reached.
This was introduced in the kernel tree when the sources were copied from
trace-cmd in commit f7d82350e597 ("tools/events: Add files to create
libtraceevent.a"), and in the trace-cmd repo in 1cdbae6035cei
("Implement typecasting in parser") when the function was introduced,
i.e., it has always behaved the wrong way.
Detected by cppcheck.
Signed-off-by: Rikard Falkeborn <rikard.falkeborn@gmail.com>
Reviewed-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Cc: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Fixes: f7d82350e597 ("tools/events: Add files to create libtraceevent.a")
Link: http://lkml.kernel.org/r/20190409091529.2686-1-rikard.falkeborn@gmail.com
Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
[ Upstream commit 7c5b019e3a638a5a290b0ec020f6ca83d2ec2aaa ]
Fix buffer overflow observed when running perf test.
The overflow is when trying to evaluate "1ULL << (64 - 1)" which is
resulting in -9223372036854775808 which overflows the 20 character
buffer.
If is possible this bug has been reported before but I still don't see
any fix checked in:
See: https://www.spinics.net/lists/linux-perf-users/msg07714.html
Reported-by: Michael Sartain <mikesart@fastmail.com>
Reported-by: Mathias Krause <minipli@googlemail.com>
Signed-off-by: Tony Jones <tonyj@suse.de>
Acked-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20190228015532.8941-1-tonyj@suse.de
In order to make libtraceevent into a proper library, its API
should be straightforward.
After discussion with Steven Rostedt, we decided to remove the
tep_data_event_from_type() API and to replace it with tep_find_event(),
as it does the same.
Signed-off-by: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Cc: Jiri Olsa <jolsa@redhat.com>
Cc: Namhyung Kim <namhyung@kernel.org>
Link: http://lkml.kernel.org/r/20181201040852.913841066@goodmis.org
Signed-off-by: Steven Rostedt (VMware) <rostedt@goodmis.org>
After a discussion with Steven Rostedt, we decided to rename a few APIs,
to have more intuitive names.
This patch renames tep_is_file_bigendian() to tep_file_bigendian().
Link: http://lkml.kernel.org/r/20181201040852.767549746@goodmis.org
The tep_register_event_handler() functions returns -1 in case it
successfully registers the new event handler. Such return code is used
by the other library APIs in case of an error.
To unify the return logic of tep_register_event_handler() with the other
APIs, this patch introduces enum tep_reg_handler, which is used by this
function as return value, to handle all possible successful return
cases.
Link: http://lkml.kernel.org/r/20181201040852.628034497@goodmis.org
trace_seq_vprintf() APIs
In order to make libtraceevent into a proper library, its API should be
straightforward.
The trace_seq_printf() and trace_seq_vprintf() APIs have inconsistent
returned values with the other trace_seq_* APIs.
This path changes the return logic of trace_seq_printf() and
trace_seq_vprintf() to return the number of printed characters, as the
other trace_seq_* related APIs.
Link: http://lkml.kernel.org/r/20181201040852.485792891@goodmis.org
In order to make libtraceevent a proper library, variables, data
structures and functions should have a unique prefix to prevent name
space conflicts. That prefix will be "tep_".
This patch renames 'struct cmdline' to 'struct tep_cmdline'.
Link: http://lkml.kernel.org/r/20181201040852.358871851@goodmis.org
This patch initializes the host_bigendian member of the tep_handle
structure with the byte order of the current host, when this handler is
created - in tep_alloc() API. We need this in order to remove the
tep_set_host_bigendian() API.
Link: http://lkml.kernel.org/r/20181201040852.216292134@goodmis.org
This patch adds a new API of tracevent library: tep_override_comm() It
registers a pid / command mapping. If a mapping with the same pid
already exists, the entry is updated with the new command.
Link: http://lkml.kernel.org/r/20181130154648.038915912@goodmis.org
So that the user can specify outside LDFLAGS values.
Keeping the CFLAGS in there as well, so we don't break existing scripts.
Signed-off-by: Jiri Olsa <jolsa@kernel.org>
Cc: Herton Krzesinski <herton@redhat.com>
Cc: Tzvetomir Stoyanov (VMware) <tz.stoyanov@gmail.com>
Link: http://lkml.kernel.org/r/20181212091214.GC17489@krava
In the case that a bprintk event has a dereferenced pointer that is
stored as a string, and there's more values to process (more args), the
arg was not updated to point to the next arg after processing the
dereferenced pointer, and it screwed up what was to be displayed.
Cc: linux-trace-devel@vger.kernel.org
Cc: stable@vger.kernel.org
Fixes: 37db96bb49629 ("tools lib traceevent: Handle new pointer processing of bprint strings")
Link: http://lkml.kernel.org/r/20181210134522.3f71e2ca@gandalf.local.home
Go over the tools/ files that are maintained in Arnaldo's tree and
fix common typos: half of them were in comments, the other half
in JSON files.
No change in functionality intended.
Committer notes:
This was split from a larger patch as there are code that is,
additionally, maintained outside the kernel tree, so to ease cherry
picking and/or backporting, split this into multiple patches.
Cc: Steven Rostedt (VMware) <rostedt@goodmis.org>
Link: http://lkml.kernel.org/r/20181203102200.GA104797@gmail.com
straightforward. This patch hides few API functions, intended for
internal usage only:
tep_free_event(), tep_free_format_field(), __tep_data2host2(),
__tep_data2host4() and __tep_data2host8().
The patch also alignes the libtraceevent summary man page with
these API changes.
Link: http://lkml.kernel.org/r/20181130154647.891651290@goodmis.org
In order to make libtraceevent into a proper library, variables, data
structures and functions require a unique prefix to prevent name space
conflicts. This renames tep_free_format() to tep_free_event(), which
describes more closely the purpose of the function.
Link: http://lkml.kernel.org/r/20181130154647.591673556@goodmis.org
'struct tep_event'
conflicts.
This renames 'struct tep_event_format' to 'struct tep_event', which
describes more closely the purpose of the struct.
Cc: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/20181130154647.436403995@goodmis.org
[ Fixup conflict with 6e33c250a88f ("tools lib traceevent: Fix compile warnings in tools/lib/traceevent/event-parse.c") ]
This patch installs trace-seq.h header file on "make install".
Link: http://lkml.kernel.org/r/20181130154647.176265533@goodmis.org
This patch implements integration with pkg-config framework. pkg-config
can be used by the library users to determine required CFLAGS and
LDFLAGS in order to use the library
Link: http://lkml.kernel.org/r/20181130154647.022471992@goodmis.org
This patch implements a new API of the tracevent library:
int tep_get_ref(struct tep_handle *tep);
The API returns the reference counter "ref_count" of the tep handler.
As "struct tep_handle" is internal only, its members cannot be accessed
by the library users, the API is used to get the reference counter.
Link: http://lkml.kernel.org/r/20181130154646.890615385@goodmis.org
This patch adds a sanity check to is_timestamp_in_us() input parameter
trace_clock. It avoids a potential segfault in this function for the
case trace_clock is NULL.
Reported-by: Slavomir Kaslev <kaslevs@vmware.com>
Link: http://lkml.kernel.org/r/20181128145552.68c4f87b@gandalf.local.home
Fix following warnings:
event-parse.c: In function ‘tep_find_event_by_name’:
event-parse.c:3521:21: warning: ‘event’ may be used uninitialized in this function [-Wmaybe-uninitialized]
pevent->last_event = event;
CC ui/gtk/hists.o
LINK plugin_mac80211.so
CC nlattr.o
event-parse.c: In function ‘tep_data_lat_fmt’:
event-parse.c:5200:4: warning: ‘migrate_disable’ may be used uninitialized in this function [-Wmaybe-uninitialized]
trace_seq_printf(s, "%d", migrate_disable);
event-parse.c:5207:4: warning: ‘lock_depth’ may be used uninitialized in this function [-Wmaybe-uninitialized]
trace_seq_printf(s, "%d", lock_depth);
LINK plugin_sched_switch.so
LINK plugin_function.so
LINK plugin_xen.so
event-parse.c: In function ‘tep_event_info’:
event-parse.c:5047:7: warning: ‘len_arg’ may be used uninitialized in this function [-Wmaybe-uninitialized]
trace_seq_printf(s, format, len_arg, (char)val);
event-parse.c:4884:6: note: ‘len_arg’ was declared here
int len_arg;
event-parse.c:4338:11: warning: ‘vsize’ may be used uninitialized in this function [-Wmaybe-uninitialized]
val = tep_read_number(pevent, bptr, vsize);
event-parse.c:4224:6: note: ‘vsize’ was declared here
int vsize;
$ gcc --version
gcc (Clear Linux OS for Intel Architecture) 8.2.1 20180502
Signed-off-by: Adrian Hunter <adrian.hunter@intel.com>
Link: http://lkml.kernel.org/r/20181122112937.10582-1-adrian.hunter@intel.com
local header file
As traceevent is going to be transferred into a proper library,
its local data should be protected from the library users.
This patch encapsulates struct tep_handler into a local header,
not visible outside of the library. It implements also a bunch
of new APIs, which library users can use to access tep_handler members.
Cc: linux trace devel <linux-trace-devel@vger.kernel.org>
Cc: tzvetomir stoyanov <tstoyanov@vmware.com>
Link: http://lkml.kernel.org/r/20181005122225.522155df@gandalf.local.home
While working on having PowerTop use libtracevent as a shared object
library, Tzvetomir hit "str_error_r not defined". This was added by commit
c3cec9e68f12d ("tools lib traceevent: Use str_error_r()") because
strerror_r() has two definitions, where one is GNU specific, and the other
is XSI complient. The strerror_r() is in a wrapper str_error_r() to keep the
code from having to worry about which compiler is being used.
The problem is that str_error_r() is external to libtraceevent, and not part
of the library. If it is used as a shared object then the tools using it
will need to define that function. I do not want that function defined in
libtraceevent itself, as it is out of scope for that library.
As there's only a single instance of this call, and its in the traceevent
library's own tep_strerror() function, we can copy what was done in perf,
and create yet another external file that undefs _GNU_SOURCE to use the more
portable version of the function. We don't need to worry about the errors
that strerror_r() returns. If the buffer isn't big enough, we simply
truncate it.
Reported-by: Tzvetomir Stoyanov <tstoyanov@vmware.com>
Link: http://lkml.kernel.org/r/20181005121816.484e654f@gandalf.local.home
conflicts. That prefix will be "tep_". This adds prefix tep_ to
enum filter_trivial_type and all its members.
Signed-off-by: Tzvetomir Stoyanov (VMware) <tz.stoyanov@gmail.com>
Link: http://lkml.kernel.org/r/20180919185725.076387655@goodmis.org
conflicts. That prefix will be "tep_". This renames data2host*() APIs
Link: http://lkml.kernel.org/r/20180919185724.751088939@goodmis.org
conflicts. That prefix will be "tep_". This renames struct plugin_list
to struct tep_plugin_list
Link: http://lkml.kernel.org/r/20180919185724.586889128@goodmis.org
structs filter_type and event_filter
Link: http://lkml.kernel.org/r/20180919185724.309837130@goodmis.org
to various structs filter_arg_*..
Link: http://lkml.kernel.org/r/20180919185724.152948543@goodmis.org
struct filter_arg, enum filter_value_type and all enum's members.
Link: http://lkml.kernel.org/r/20180919185723.972818215@goodmis.org
conflicts. That prefix will be "tep_". This adds prefix tep_ to enums
filter_exp_type, filter_arg_type and all enum's members
Link: http://lkml.kernel.org/r/20180919185723.824559046@goodmis.org
filter_boolean_type, filter_op_type, filter_cmp_type and all enum's members
Link: http://lkml.kernel.org/r/20180919185723.680572508@goodmis.org
tep_print_arg_type
conflicts. That prefix will be "tep_". This renames enum print_arg_type to
enum tep_print_arg_type and add prefix TEP_ to all its members.
Link: http://lkml.kernel.org/r/20180919185723.533960748@goodmis.org
conflicts. That prefix will be "tep_". This adds prefix tep_ to all
print_* structures
Link: http://lkml.kernel.org/r/20180919185723.381753268@goodmis.org
conflicts. That prefix will be "tep_". This adds prefix TEP_
to all members of nameless enum EVENT_FL_*
Link: http://lkml.kernel.org/r/20180919185723.116643250@goodmis.org
tep_event_{sort_}type
conflicts. That prefix will be "tep_". This renames enum event_type to
enum tep_event_type, enum event_sort_type to enum tep_event_sort_type
and add prefix TEP_ to all enum's members
Link: http://lkml.kernel.org/r/20180919185722.961022207@goodmis.org
tep_format_flags
conflicts. That prefix will be "tep_". This renames enum format_flags
to enum tep_format_flags and adds prefix TEP_ to all of its members.
Link: http://lkml.kernel.org/r/20180919185722.803127871@goodmis.org
tep_format{_field}
conflicts. That prefix will be "tep_". This renames struct format to
struct tep_format and struct format_field to struct tep_format_field
Link: http://lkml.kernel.org/r/20180919185722.661319373@goodmis.org
tep_event_format
conflicts. That prefix will be "tep_". This renames struct event_format
to struct tep_event_format
Link: http://lkml.kernel.org/r/20180919185722.495820809@goodmis.org
header file
In order to make libtraceevent into a proper library, all its APIs
should be defined in corresponding header files. This patch splits
trace-seq related APIs in a separate header file: trace-seq.h
Link: http://lkml.kernel.org/r/20180828185038.2dcb2743@gandalf.local.home
Replace the GPL text with SPDX tags in the tools/lib/traceevent files.
Cc: Yordan Karadzhov (VMware) <y.karadz@gmail.com>
Link: http://lkml.kernel.org/r/20180816111015.125e0f25@gandalf.local.home
conflicts. That prefix will be "tep_" and not "pevent_". This changes
static variables and functions in event-parse.c: pevent_func_params,
__pevent_parse_format, __pevent_parse_event, pevent_error_str, pevent_search_event
Link: http://lkml.kernel.org/r/20180808180703.575392642@goodmis.org
APIs: pevent_reset_function_resolver, pevent_strerror, pevent_list_events,
pevent_event_common_fields, pevent_event_fields, pevent_ref, pevent_unref
Link: http://lkml.kernel.org/r/20180808180703.426198047@goodmis.org
APIs: pevent_buffer_init, pevent_read_token, pevent_free_token,
pevent_peek_char, pevent_get_input_buf, pevent_get_input_buf_ptr
Link: http://lkml.kernel.org/r/20180808180703.275281085@goodmis.org
APIs: pevent_pid_is_registered, pevent_get_cpus, pevent_set_cpus,
pevent_is_file_bigendian, pevent_is_host_bigendian, pevent_is_latency_format,
pevent_set_latency_format
Link: http://lkml.kernel.org/r/20180808180703.114110715@goodmis.org
APIs: pevent_find_function, pevent_find_function_address,
pevent_find_event_by_name, pevent_find_event_by_record
Link: http://lkml.kernel.org/r/20180808180702.966965051@goodmis.org
APIs: pevent_free_format, pevent_free_format_field, pevent_get_field_raw,
pevent_get_field_val, pevent_get_common_field_val, pevent_get_any_field_val
Link: http://lkml.kernel.org/r/20180808180702.821244942@goodmis.org
APIs: pevent_data_lat_fmt, pevent_data_type, pevent_data_event_from_type,
pevent_data_pid, pevent_data_preempt_count, pevent_data_flags,
pevent_data_comm_from_pid, pevent_data_pid_from_comm, pevent_cmdline_pid
Link: http://lkml.kernel.org/r/20180808180702.678020020@goodmis.org
APIs: pevent_register_print_function, pevent_unregister_print_function,
pevent_register_event_handler, pevent_unregister_event_handler,
pevent_register_function, pevent_register_trace_clock
Link: http://lkml.kernel.org/r/20180808180702.524813185@goodmis.org
APIs: PEVENT_FILTER_ERROR_BUFSZ, pevent_filter_alloc,
pevent_filter_add_filter_str, pevent_filter_match, pevent_filter_strerror,
pevent_event_filtered, pevent_filter_reset, pevent_filter_clear_trivial,
pevent_filter_free, pevent_filter_make_string, pevent_filter_remove_event,
pevent_filter_event_has_trivial, pevent_filter_copy, pevent_update_trivial,
pevent_filter_compare
Link: http://lkml.kernel.org/r/20180808180702.370659353@goodmis.org
conflicts. That prefix will be "tep_" and not "traceevent_". This changes
APIs: traceevent_plugin_list_options, traceevent_plugin_free_options_list,
traceevent_plugin_add_options, traceevent_plugin_remove_options,
traceevent_print_plugins
Link: http://lkml.kernel.org/r/20180808180702.089951638@goodmis.org
APIs: pevent_function_handler, pevent_func_handler,
pevent_func_arg_type, PEVENT_FUNC_ARG_VOID, PEVENT_FUNC_ARG_INT,
PEVENT_FUNC_ARG_LONG, PEVENT_FUNC_ARG_STRING, PEVENT_FUNC_ARG_PTRS,
PEVENT_FUNC_ARG_MAX_TYPES
Link: http://lkml.kernel.org/r/20180808180701.935881193@goodmis.org
