path: root/tools/lib/traceevent/trace-seq.c
2014-01-15tools lib traceevent: Get rid of malloc_or_die() in trace_seq_init()Namhyung Kim
Use plain malloc() and check its return value. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1389750340-15965-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-15tools lib traceevent: Check return value of realloc()Namhyung Kim
If realloc() fails, it'll leak the buffer. Also increate buffer size only if the allocation succeeded. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1389750340-15965-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-15tools lib traceevent: Add state member to struct trace_seqNamhyung Kim
The trace_seq->state is for tracking errors during the use of trace_seq APIs and getting rid of die() in it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/87fvopalbb.fsf@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-07-12tools lib traceevent: Add trace_seq_reset()Namhyung Kim
Sometimes it'd be useful if existing trace_seq can be reused. But currently it's impossible since there's no API to reset the trace_seq. Let's add trace_seq_reset() for this case. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1370323231-14022-5-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-24tools lib traceevent: Update FSF postal address to be URL's.Jon Stanley
The FSF now prefers to use URL's in copyright headers rather than their postal address. This change updates the address to be <http://www.gnu.org/licenses> per http://www.gnu.org/licenses/gpl-howto.html Signed-off-by: Jon Stanley <jonstanley@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347049967-3143-1-git-send-email-jonstanley@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-25events: Update tools/lib/traceevent to work with perfSteven Rostedt
Some of the util functions of libtraceevent.a conflict with perf, such as die(), warning() and others. Move them into event-util.h that is not included by the perf tools. Also, as perf compiles with 'bool' the filter_arg->bool needs to be renamed to filter_arg->boolean. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2012-04-25tools/events: Add files to create libtraceevent.aSteven Rostedt
Copy over the files from trace-cmd to the Linux tools directory such that applications like perf and latencytrace can use the more advanced parsing code. Because some of the file names of perf conflict with trace-cmd file names, the trace-cmd files have been renamed as follows: parse-events.c ==> event-parse.c parse-events.h ==> event-parse.h utils.h ==> event-utils.h The files have been updated to handle the changes to the header files but other than that, they are identical to what was in the trace-cmd repository. The history of these files, including authorship is available at the git repo: git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/trace-cmd.git The Makefile was also copied over, but most of it was removed to focus on the parse-events code first. The parts of the Makefile for the plugins have also been removed, but will be added back when the plugin code is copied over as well. But that may be in its own separate directory. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
