path: root/tools/lib/traceevent/event-parse.h
2016-02-29tools lib traceevent: Split pevent_print_event() into specific functionality ↵Steven Rostedt
functions Currently there's a single function that is used to display a record's data in human readable format. That's pevent_print_event(). Unfortunately, this gives little room for adding other output within the line without updating that function call. I've decided to split that function into 3 parts. pevent_print_event_task() which prints the task comm, pid and the CPU pevent_print_event_time() which outputs the record's timestamp pevent_print_event_data() which outputs the rest of the event data. pevent_print_event() now simply calls these three functions. To save time from doing the search for event from the record's type, I created a new helper function called pevent_find_event_by_record(), which returns the record's event, and this event has to be passed to the above functions. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20160229090128.43a56704@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-01-06tools lib traceevent: Factor out and export print_event_field[s]()Namhyung Kim
The print_event_field() and print_event_fields() functions print basic information of a given field or event without the print format. They'll be used by dynamic sort keys later. Committer note: Rename it to pevent_print_field[s]() to get proper namespacing, as discussed with Steven Rostedt. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andi Kleen <andi@firstfloor.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/r/1450876121-22494-1-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-09-02tools lib traceevent: Support function __get_dynamic_array_lenHe Kuang
Support helper function __get_dynamic_array_len() in libtraceevent, this function is used accompany with __print_array() or __print_hex(), but currently it is not an available function in the function list of process_function(). The total allocated length of the dynamic array is embedded in the top half of __data_loc_##item field. This patch adds new arg type PRINT_DYNAMIC_ARRAY_LEN to return the length to eval_num_arg(), Signed-off-by: He Kuang <hekuang@huawei.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Cc: Alexei Starovoitov <ast@plumgrid.com> Cc: Jiri Olsa <jolsa@kernel.org> Cc: Masami Hiramatsu <masami.hiramatsu.pt@hitachi.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Wang Nan <wangnan0@huawei.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1440822125-52691-32-git-send-email-wangnan0@huawei.com Signed-off-by: Wang Nan <wangnan0@huawei.com> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-07-23tools lib traceevent: Allow setting an alternative symbol resolverArnaldo Carvalho de Melo
The perf tools have a symbol resolver that includes solving kernel symbols using either kallsyms or ELF symtabs, and it also is using libtraceevent to format the trace events fields, including via subsystem specific plugins, like the "timer" one. To solve fields like "timer:hrtimer_start"'s "function", libtraceevent needs a way to map from its value to a function name and addr. This patch provides a way for tools that already have symbol resolving facilities to ask libtraceevent to use it when needing to resolve kernel symbols. Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: David Ahern <dsahern@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Stephane Eranian <eranian@google.com> Link: http://lkml.kernel.org/n/tip-fdx1fazols17w5py26ia3bwh@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-04-29tools lib traceevent: Add alias field to struct format_fieldJiri Olsa
Introduce an 'alias' field to 'struct format_field' to be able to use alternative name for the field. It is initialized with same string pointer as 'name' field. The free logic checks the 'alias' pointer being reset by user and frees it. This will be handy when converting data into CTF, where each field within event needs to have a unique name (while this is not required for tracepoint). Converter can easily assign unique name into the format_field struct. Suggested-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Jiri Olsa <jolsa@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: He Kuang <hekuang@huawei.com> Cc: Jeremie Galarneau <jgalar@efficios.com> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Cc: Tom Zanussi <tzanussi@gmail.com> Cc: Wang Nan <wangnan0@huawei.com> Link: http://lkml.kernel.org/n/tip-qwyq8blnfkg6s5vlbrvn1en3@git.kernel.org Link: http://lkml.kernel.org/r/1429372220-6406-6-git-send-email-jolsa@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Add support for __print_array()Javi Merino
Since 6ea22486ba46 ("tracing: Add array printing helper") trace can generate traces with variable element size arrays. Add support to parse them. Signed-off-by: Javi Merino <javi.merino@arm.com> Acked-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Jiri Olsa <jolsa@redhat.com> Link: http://lkml.kernel.org/r/1427195239-15730-1-git-send-email-javi.merino@arm.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Make plugin options either string or booleanSteven Rostedt
When a plugin option is defined, by default it is a boolean (true or false). If the option is something else, then it needs to set its "value" field to a default string other than NULL (can be just ""). If the value is not set then the option is considered boolean, and the updating of the option value will be handled accordingly. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135923.308372986@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Add pevent_data_pid_from_comm()Steven Rostedt (Red Hat)
There is a pevent_data_comm_from_pid() that returns the cmdline stored for a given pid in order for users to map pids to comms, but there's no method to convert a comm back to a pid. This is useful for filters that specify a comm instead of a PID (it's faster than searching each individual event). Add a way to retrieve a comm from a pid. Since there can be more than one pid associated to a comm, it returns a data structure that lets the user iterate over all the saved comms for a given pid. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135923.001103479@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-24tools lib traceevent: Copy trace_clock and free itSteven Rostedt (Red Hat)
The pevent->trace_clock should not be a direct pointer to what was given. It should be copied and freed. Note, valgrind pointed this out when a caller passed in a pointer that needed to be freed and it never was. Ideally, pevent should copy it (which this change does), and free the copy. It's up to the caller to free the clock string passed in. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20150324135922.695906738@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-03-21tools lib traceevent: Add destructor for format_fieldDavid Ahern
Move the calls that frees the resources allocated for a struct format_field to a separate routine. Signed-off-by: David Ahern <dsahern@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1426790181-19118-1-git-send-email-dsahern@gmail.com [ Split this part from a larger patch, added pevent_ prefix as requested by Steven ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2015-02-06tools lib traceevent: Introduce trace_seq_do_fprintf functionArnaldo Carvalho de Melo
So that we can specify a FILE object where to direct the formatted output. Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Borislav Petkov <bp@suse.de> Cc: David Ahern <dsahern@gmail.com> Cc: Don Zickus <dzickus@redhat.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-a49bhdrx8851f04hppn8bqxq@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-06-07tools lib traceevent: Added support for __get_bitmask() macroSteven Rostedt (Red Hat)
Coming in v3.16, trace events will be able to save bitmasks in raw format in the ring buffer and output it with the __get_bitmask() macro. In order for userspace tools to parse this, it must be able to handle the __get_bitmask() call and be able to convert the data that's in the ring buffer into a nice bitmask format. The output is similar to what the kernel uses to print bitmasks, with a comma separator every 4 bytes (8 characters). This allows for cpumasks to also be saved efficiently. The first user is the thermal:thermal_power_limit event which has the following output: thermal_power_limit: cpus=0000000f freq=1900000 cdev_state=0 power=5252 Link: http://lkml.kernel.org/r/20140506132238.22e136d1@gandalf.local.home Suggested-by: Javi Merino <javi.merino@arm.com> Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Tested-by: Javi Merino <javi.merino@arm.com> Link: http://lkml.kernel.org/r/20140603032224.229186537@goodmis.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-06-07tools lib traceevent: Add options to pluginsSteven Rostedt
The traceevent plugins allows developers to have their events print out information that is more advanced than what can be achieved by the trace event format files. As these plugins are used on the userspace side of the tracing tools, it is only logical that the tools should be able to produce different types of output for the events. The types of events still need to be defined by the plugins thus we need a way to pass information from the tool to the plugin to specify what type of information to be shown. Not only does the information need to be passed by the tool to plugin, but the plugin also requires a way to notify the tool of what options it can provide. This builds the plugin option infrastructure that is taken from trace-cmd that is used to allow plugins to produce different output based on the options specified by the tool. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20140603184154.0a4c031c@gandalf.local.home Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-06-07tools lib traceevent: Add flag to not load event pluginsSteven Rostedt (Red Hat)
Add a flag to pevent that will let the callers be able to set it and keep the system, and perhaps even normal plugins from being loaded. This is useful when plugins might hide certain information and seeing the raw events shows what may be going on. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Acked-by: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20140603032223.678098063@goodmis.org Signed-off-by: Jiri Olsa <jolsa@kernel.org>
2014-04-23tools lib traceevent: Fix backward compatibility macros for pevent filter enumsSteven Rostedt
The return value for pevent_filter_match() is suppose to return FILTER_NONE if the event doesn't have a filter, and FILTER_NOEXIST if there is no filter at all. But the change 41e12e580a7 "tools lib traceevent: Refactor pevent_filter_match() to get rid of die()" replaced the return value with PEVENT_ERRNO__* values and added "backward compatibility" macros that used the old names. Unfortunately, the NOEXIST and NONE macros were swapped, and this broke users that use the old return names. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/20140421222346.0351ced4@gandalf.local.home Signed-off-by: Jiri Olsa <jolsa@redhat.com>
2014-01-16tools lib traceevent: Add pevent_unregister_print_function()Namhyung Kim
When a plugin unloaded it needs to unregister its print handler from pevent. So add an unregister function to do it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1389839478-5887-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-16tools lib traceevent: Add pevent_unregister_event_handler()Namhyung Kim
When a plugin is unloaded it needs to unregister its handler from pevent. So add an unregister function to do it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1389839478-5887-2-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-15tools lib traceevent: Make plugin unload function receive peventNamhyung Kim
The PEVENT_PLUGIN_UNLOADER function might need some cleanup using pevent like unregister some handlers. So pass pevent as argument. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1389750340-15965-6-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2014-01-15tools lib traceevent: Add state member to struct trace_seqNamhyung Kim
The trace_seq->state is for tracking errors during the use of trace_seq APIs and getting rid of die() in it. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Jiri Olsa <jolsa@redhat.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/87fvopalbb.fsf@sejong.aot.lge.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-18tools lib traceevent: Introduce pevent_filter_strerror()Namhyung Kim
The pevent_filter_strerror() function is for receiving actual error message from pevent_errno value. To do that, add a static buffer to event_filter for saving internal error message If a failed function saved other information in the static buffer returns the information, otherwise returns generic error message. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-15-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Refactor pevent_filter_match() to get rid of die()Namhyung Kim
The test_filter() function is for testing given filter is matched to a given record. However it doesn't handle error cases properly so add a new argument err to save error info during the test and also pass it to internal test functions. The return value of pevent_filter_match() also converted to pevent_errno to indicate an exact error case. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-13-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Make pevent_filter_add_filter_str() return pevent_errnoNamhyung Kim
Refactor the pevent_filter_add_filter_str() to return a proper error code and get rid of the third error_str argument. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-12-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Refactor process_filter()Namhyung Kim
So that it can return a proper pevent_errno value. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-11-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Refactor create_arg_item()Namhyung Kim
So that it can return a proper pevent_errno value. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-10-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Get rid of die() in reparent_op_arg()Namhyung Kim
To do that, make the function returns the error code. Also pass error_str so that it can set proper error message when error occurred. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-9-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Get rid of die() in add_right()Namhyung Kim
Refactor it to return appropriate pevent_errno value. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-7-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-13tools lib traceevent: Get rid of malloc_or_die() in find_event()Namhyung Kim
Make it return pevent_errno to distinguish malloc allocation failure. Since it'll be returned to user later, add more error code. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386833777-3790-6-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-09tools lib traceevent: Get rid of die() in pevent_filter_clear_trivial()Namhyung Kim
Change the function signature to return error code and not call die() anymore. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Reviewed-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386567251-22751-13-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-04tools lib traceevent: Change pevent_parse_format to include pevent handleJiri Olsa
Changing the pevent_parse_format interface to include the pevent handle. The goal is to always use pevent object when dealing with traceevent library. The reason is that we might need additional processing (like plugins), which is not possible otherwise. Patches follow to make this happen completely. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386076182-14484-6-git-send-email-jolsa@redhat.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-04tools lib traceevent: Add traceevent_host_bigendian functionJiri Olsa
Adding traceevent_host_bigendian function to get host endianity. It's used in following patches. Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386076182-14484-5-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-12-04tools lib traceevent: Add plugin supportJiri Olsa
Backporting plugin support for traceevent lib. Backported from Steven Rostedt's trace-cmd repo (HEAD 0f2c2fb): git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/trace-cmd.git It's now possible to use following interface to load plugins (shared objects) to enhance pevent object functionality. The plugin interface/hooks are as follows: (taken from event-parse.h comments) - 'pevent_plugin_loader' (required) The function name to initialized the plugin. int pevent_plugin_loader(struct pevent *pevent) - 'pevent_plugin_unloader' (optional) The function called just before unloading int pevent_plugin_unloader(void) - 'pevent_plugin_options' (optional) Plugin options that can be set before loading struct plugin_option pevent_plugin_options[] = { { .name = "option-name", .plugin_alias = "overide-file-name", (optional) .description = "description of option to show users", }, { .name = NULL, }, }; Array must end with .name = NULL; The plugin_alias (below) can be used to give a shorter name to access the variable. Useful if a plugin handles more than one event. NOTE options support is not backported yet. - 'pevent_plugin_alias' (optional) The name to use for finding options (uses filename if not defined) New traceevent functions are added to search and load available plugins: struct plugin_list* traceevent_load_plugins(struct pevent *pevent) - loads plusing for 'struct pevent' object and returns loaded plugins list void traceevent_unload_plugins(struct plugin_list *plugin_list); - unload plugin list Signed-off-by: Jiri Olsa <jolsa@redhat.com> Cc: Corey Ashford <cjashfor@linux.vnet.ibm.com> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@kernel.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1386076182-14484-3-git-send-email-jolsa@redhat.com Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-04tools lib traceevent: Add pevent_print_func_field() helper functionSteven Rostedt
Add the pevent_print_func_field() that will look up a field that is expected to be a function pointer, and it will print the function name and offset of the address given by the field. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131101215501.869542711@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-04tools lib traceevent: Add flags NOHANDLE and PRINTRAW to individual eventsSteven Rostedt
Add the flags EVENT_FL_NOHANDLE and EVENT_FL_PRINTRAW to the event flags to have the event either ignore the register handler or to ignore the handler and also print the raw format respectively. This allows a tool to force a raw format or non handle for an event. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131101215501.655258742@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-04tools lib traceevent: Update printk formats when enteredSteven Rostedt (Red Hat)
Instead of cropping off the '"' and '\n"' from a printk format every time it is referenced, do it when it's added. This makes it easier to reference a printk_map and should speed things up a little. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20131101215500.495619312@goodmis.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-11-04tools lib traceevent: Add support for extracting trace_clock in reportYoshihiro YUNOMAE
If trace-cmd extracts trace_clock, trace-cmd reads trace_clock data from the trace.dat and switches outputting format of timestamp for each trace_clock. Signed-off-by: Yoshihiro YUNOMAE <yoshihiro.yunomae.ez@hitachi.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Namhyung Kim <namhyung@kernel.org> Link: http://lkml.kernel.org/r/20130424231305.14877.86147.stgit@yunodevel Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-07-12tools lib traceevent: Add page_size field to peventNamhyung Kim
The page size of traced system can be different than current system's because the recorded data file might be analyzed in a different machine. In this case we should use original page size of traced system when accessing the data file, so this information needs to be saved. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1370323231-14022-6-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-07-12tools lib traceevent: Add trace_seq_reset()Namhyung Kim
Sometimes it'd be useful if existing trace_seq can be reused. But currently it's impossible since there's no API to reset the trace_seq. Let's add trace_seq_reset() for this case. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1370323231-14022-5-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-07-12tools lib traceevent: Add const qualifier to string argumentsNamhyung Kim
If pevent_register_event_handler() received a string literal as @sys_name or @event_name parameter, it emitted a warning about const qualifier removal. Since they're not modified in the function we can make it have const qualifier. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1370323231-14022-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2013-01-24tools lib traceevent: Update FSF postal address to be URL's.Jon Stanley
The FSF now prefers to use URL's in copyright headers rather than their postal address. This change updates the address to be <http://www.gnu.org/licenses> per http://www.gnu.org/licenses/gpl-howto.html Signed-off-by: Jon Stanley <jonstanley@gmail.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347049967-3143-1-git-send-email-jonstanley@gmail.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-24tools lib traceevent: Carve out events format parsing routineArnaldo Carvalho de Melo
The pevent_parse_event() routine will parse a events/sys/tp/format file and add an event_format instance to the pevent struct. This patch introduces a pevent_parse_format() routine with just the bits needed to parse the event/sys/tp/format file and just return the event_format instance, useful for when all we want is to parse the format file, without requiring the pevent struct. Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: David Ahern <dsahern@gmail.com> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Mike Galbraith <efault@gmx.de> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephane Eranian <eranian@google.com> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/n/tip-lge0afl47arh86om0m6a5bqr@git.kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-11perf tools: Use __maybe_used for unused variablesIrina Tirdea
perf defines both __used and __unused variables to use for marking unused variables. The variable __used is defined to __attribute__((__unused__)), which contradicts the kernel definition to __attribute__((__used__)) for new gcc versions. On Android, __used is also defined in system headers and this leads to warnings like: warning: '__used__' attribute ignored __unused is not defined in the kernel and is not a standard definition. If __unused is included everywhere instead of __used, this leads to conflicts with glibc headers, since glibc has a variables with this name in its headers. The best approach is to use __maybe_unused, the definition used in the kernel for __attribute__((unused)). In this way there is only one definition in perf sources (instead of 2 definitions that point to the same thing: __used and __unused) and it works on both Linux and Android. This patch simply replaces all instances of __used and __unused with __maybe_unused. Signed-off-by: Irina Tirdea <irina.tirdea@intel.com> Acked-by: Pekka Enberg <penberg@kernel.org> Cc: David Ahern <dsahern@gmail.com> Cc: Ingo Molnar <mingo@redhat.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Cc: Paul Mackerras <paulus@samba.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1347315303-29906-7-git-send-email-irina.tirdea@intel.com [ committer note: fixed up conflict with a116e05 in builtin-sched.c ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-07tools lib traceevent: Get rid of die() from pevent_register_print_functionNamhyung Kim
If memory allocation for handler fails or argument type is not match, return gracefully instead of calling die(). Also add an new error code for the later case. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1346986187-5170-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-09-05tools lib traceevent: Modify header to work in C++ programsSteven Rostedt
Replace keyword "private" to "priv" in event-parse.h to allow it to be used in C++ programs. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Namhyung Kim <namhyung@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/1345735321.5069.62.camel@gandalf.local.home Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-22tools lib traceevent: Introduce pevent_strerrorNamhyung Kim
The pevent_strerror() sets @buf to a string that describes the (libtraceevent-specific) error condition that is passed via @errnum. This is similar to strerror_r() and does same thing if @errnum has a standard errno value. To sync error string with its code, define PEVENT_ERRORS with _PE() macro and use it as suggested by Steven. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1345618831-9148-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-08-22tools lib traceevent: Introduce pevent_errnoNamhyung Kim
Define and use error numbers for pevent_parse_event() and get rid of die() and do_warning() calls. If the function returns non-zero value, the caller can check the return code and do appropriate things. I chose the error numbers to be negative not to clash with standard errno, and as usual, 0 for success. Signed-off-by: Namhyung Kim <namhyung@kernel.org> Acked-by: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1345618831-9148-3-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-06-29tools lib traceevent: Add support for __print_hex()Namhyung Kim
Since the __print_hex() function is used in print fmt now, add corresponding parser routines. This makes the output of perf script on the kvm_emulate_insn event not to fail any more. before: kvm_emulate_insn: [FAILED TO PARSE] rip=3238197797 ... after: kvm_emulate_insn: 0:c102fa25:89 10 (prot32) Signed-off-by: Namhyung Kim <namhyung@kernel.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Ingo Molnar <mingo@kernel.org> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Steven Rostedt <rostedt@goodmis.org> Link: http://lkml.kernel.org/r/1340757701-10711-4-git-send-email-namhyung@kernel.org Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2012-04-25parse-events: Rename struct record to struct pevent_recordSteven Rostedt
As libtraceevent will be a library, having struct record is far too generic of a name to use. Renaming it to be consistent with the rest of the functions will be a better long term solution. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2012-04-25perf/events: Add flag to produce nsec outputSteven Rostedt
libtraceevent library prints out in usecs but perf wants to print out in nsecs. Add a flag that lets the user decide to print out in usec or nsec times. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2012-04-25events: Update tools/lib/traceevent to work with perfSteven Rostedt
Some of the util functions of libtraceevent.a conflict with perf, such as die(), warning() and others. Move them into event-util.h that is not included by the perf tools. Also, as perf compiles with 'bool' the filter_arg->bool needs to be renamed to filter_arg->boolean. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2012-04-25tools/events: Add files to create libtraceevent.aSteven Rostedt
Copy over the files from trace-cmd to the Linux tools directory such that applications like perf and latencytrace can use the more advanced parsing code. Because some of the file names of perf conflict with trace-cmd file names, the trace-cmd files have been renamed as follows: parse-events.c ==> event-parse.c parse-events.h ==> event-parse.h utils.h ==> event-utils.h The files have been updated to handle the changes to the header files but other than that, they are identical to what was in the trace-cmd repository. The history of these files, including authorship is available at the git repo: git://git.kernel.org/pub/scm/linux/kernel/git/rostedt/trace-cmd.git The Makefile was also copied over, but most of it was removed to focus on the parse-events code first. The parts of the Makefile for the plugins have also been removed, but will be added back when the plugin code is copied over as well. But that may be in its own separate directory. Signed-off-by: Steven Rostedt <rostedt@goodmis.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Arnaldo Carvalho de Melo <acme@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Jiri Olsa <jolsa@redhat.com> Cc: Arun Sharma <asharma@fb.com> Cc: Namhyung Kim <namhyung.kim@lge.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
