path: root/tools/arch/arc
2016-09-19tools include: Add mman macros needed by perf for all archWang Nan
Some macros required by tools/perf/trace/beauty/mmap.c is not support for all architectures. For example, MAP_32BIT is defined on x86 only, alpha doesn't define MADV_HWPOISON and MADV_SOFT_OFFLINE. This patch regenerates mman.h for each arch, defines these missing macros for perf. For missing MADV_*, fall back to asm-generic/mman-common because they are in a 'case ...' statement. For flags, define it to 0. Following is the script to generate this patch: macros=`cat $0 | awk 'V==1 {print}; /^# start macro list/ {V=1}'` rm `find ./tools/arch/ -name mman.h` for arch in `ls tools/arch` do [ -d tools/arch/$arch/include/uapi/asm ] || mkdir -p tools/arch/$arch/include/uapi/asm src=arch/$arch/include/uapi/asm/mman.h target=tools/arch/$arch/include/uapi/asm/mman.h.tmp real_target=tools/arch/$arch/include/uapi/asm/mman.h guard="TOOLS_ARCH_"`echo $arch | awk '{print toupper($0)}'`_UAPI_ASM_MMAN_FIX_H rm -f $target [ -f $src ] && for m in $macros do if grep '#define[ \t]*'$m $src > /dev/null 2>&1 then grep -h '#define[ \t]*'$m $src | sed 's/[ \t]*\/\*.*$//g' >> $target fi done if [ -f $src ] then grep '#include <asm-generic' $src >> $target else echo "#include <asm-generic/mman.h>" >> $target fi touch $real_target for m in $macros do if cat << EOF | gcc -Itools/arch/$arch/include -Itools/arch/$arch/include/uapi -Iinclude/ -Iinclude/uapi -E - | grep $m > /dev/null 2>&1 #include <uapi/asm/mman.h.tmp> #include <uapi/linux/mman.h> $m EOF then echo "Fixing $m for $arch" echo "/* $m is undefined on $arch, fix it for perf */" >> $target if echo $m | grep '^MADV_' > /dev/null 2>&1 then grep -h '#define[ \t]*'$m include/uapi/asm-generic/mman-common.h | sed 's/[ \t]*\/\*.*$//g' >> $target else echo "#define $m 0" >> $target fi fi done real_target=tools/arch/$arch/include/uapi/asm/mman.h echo '#ifndef '$guard > $real_target echo '#define '$guard >> $real_target cat $target | sed 's|asm-generic|uapi/asm-generic|g' >> $real_target echo '#endif' >> $real_target rm $target echo "$real_target" done exit 0 # Following macros are extracted from: # tools/perf/trace/beauty/mmap.c # # start macro list MADV_DODUMP MADV_DOFORK MADV_DONTDUMP MADV_DONTFORK MADV_DONTNEED MADV_FREE MADV_HUGEPAGE MADV_HWPOISON MADV_MERGEABLE MADV_NOHUGEPAGE MADV_NORMAL MADV_RANDOM MADV_REMOVE MADV_SEQUENTIAL MADV_SOFT_OFFLINE MADV_UNMERGEABLE MADV_WILLNEED MAP_32BIT MAP_ANONYMOUS MAP_DENYWRITE MAP_EXECUTABLE MAP_FILE MAP_FIXED MAP_GROWSDOWN MAP_HUGETLB MAP_LOCKED MAP_NONBLOCK MAP_NORESERVE MAP_POPULATE MAP_PRIVATE MAP_SHARED MAP_STACK MAP_UNINITIALIZED MREMAP_FIXED MREMAP_MAYMOVE PROT_EXEC PROT_GROWSDOWN PROT_GROWSUP PROT_NONE PROT_READ PROT_SEM PROT_WRITE Signed-off-by: Wang Nan <wangnan0@huawei.com> Tested-by: Kim Phillips <kim.phillips@arm.com> Tested-by: Naveen N. Rao <naveen.n.rao@linux.vnet.ibm.com> Cc: Ravi Bangoria <ravi.bangoria@linux.vnet.ibm.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Fixes: 277cf08f3feb ("perf trace beauty mmap: Fix defines for non !x86_64") Link: http://lkml.kernel.org/r/1473850649-83389-3-git-send-email-wangnan0@huawei.com Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
2016-09-13tools include: Add uapi mman.h for each architectureWang Nan
Some mmap related macros have different values for different architectures. This patch introduces uapi mman.h for each architectures. Three headers are cloned from kernel include to tools/include: tools/include/uapi/asm-generic/mman-common.h tools/include/uapi/asm-generic/mman.h tools/include/uapi/linux/mman.h The main part of this patch is generated by following script: macros=`cat $0 | awk 'V==1 {print}; /^# start macro list/ {V=1}'` for arch in `ls tools/arch` do [ -d tools/arch/$arch/include/uapi/asm ] || mkdir -p tools/arch/$arch/include/uapi/asm src=arch/$arch/include/uapi/asm/mman.h target=tools/arch/$arch/include/uapi/asm/mman.h guard="TOOLS_ARCH_"`echo $arch | awk '{print toupper($0)}'`_UAPI_ASM_MMAN_FIX_H echo '#ifndef '$guard > $target echo '#define '$guard >> $target [ -f $src ] && for m in $macros do if grep '#define[ \t]*'$m $src > /dev/null 2>&1 then grep -h '#define[ \t]*'$m $src | sed 's/[ \t]*\/\*.*$//g' >> $target fi done if [ -f $src ] then grep '#include <asm-generic' $src >> $target else echo "#include <asm-generic/mman.h>" >> $target fi echo '#endif' >> $target echo "$target" done exit 0 # Following macros are extracted from: # tools/perf/trace/beauty/mmap.c # # start macro list MADV_DODUMP MADV_DOFORK MADV_DONTDUMP MADV_DONTFORK MADV_DONTNEED MADV_HUGEPAGE MADV_HWPOISON MADV_MERGEABLE MADV_NOHUGEPAGE MADV_NORMAL MADV_RANDOM MADV_REMOVE MADV_SEQUENTIAL MADV_SOFT_OFFLINE MADV_UNMERGEABLE MADV_WILLNEED MAP_32BIT MAP_ANONYMOUS MAP_DENYWRITE MAP_EXECUTABLE MAP_FILE MAP_FIXED MAP_GROWSDOWN MAP_HUGETLB MAP_LOCKED MAP_NONBLOCK MAP_NORESERVE MAP_POPULATE MAP_PRIVATE MAP_SHARED MAP_STACK MAP_UNINITIALIZED MREMAP_FIXED MREMAP_MAYMOVE PROT_EXEC PROT_GROWSDOWN PROT_GROWSUP PROT_NONE PROT_READ PROT_SEM PROT_WRITE Signed-off-by: Wang Nan <wangnan0@huawei.com> Cc: Zefan Li <lizefan@huawei.com> Cc: pi3orama@163.com Link: http://lkml.kernel.org/r/1473684871-209320-2-git-send-email-wangnan0@huawei.com [ Added new files to tools/perf/MANIFEST to fix the detached tarball build, add mman.h for ARC ] Signed-off-by: Arnaldo Carvalho de Melo <acme@redhat.com>
