path: root/sound
2013-05-06ALSA: mips/sgio2audio: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Vivien Chappelier <vivien.chappelier@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-06ALSA: mips/hal2: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Cc: Thomas Bogendoerfer <tsbogend@alpha.fanken.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-04ALSA: hda - Fix 3.9 regression of EAPD init on Conexant codecsTakashi Iwai
The older Conexant codecs have up to two EAPDs and these are supposed to be rather statically turned on. The new generic parser code assumes the dynamic on/off per path usage, thus it resulted in the silent output on some machines. This patch fixes the problem by simply assuming the static EAPD on for such old Conexant codecs as we did until 3.8 kernel. Reported-and-tested-by: Christopher K. <c.krooss@gmail.com> Cc: <stable@vger.kernel.org> [v3.9] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-03sound: Fix make allmodconfig on MIPSTakashi Iwai
The compile of soundcard.c is broken on MIPS when allmodconfig is used because of the missing MAX_DMA_CHANNELS definition. As a simple workaround, just add a Kconfig dependency. Reported-by: Andrew Morton <akpm@linux-foundation.org> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-03ALSA: hda - Fix system panic when DMA > 40 bits for Nvidia audio controllersMike Travis
The audio driver mistakenly allows 64 bit addresses to be created for the audio driver on Nvidia GPUs. Unfortunately, the hardware normally only supports up to 40 bits of DMA. This can cause system panics as well as misdirected data when the address is > 40 bits as the upper part the address is truncated. Signed-off-by: Mike Travis <travis@sgi.com> Reviewed-by: Mike Habeck <habeck@sgi.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-03ALSA: atmel: Remove redundant platform_set_drvdata()Sachin Kamat
Commit 0998d06310 (device-core: Ensure drvdata = NULL when no driver is bound) removes the need to set driver data field to NULL. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Acked-by: Hans-Christian Egtvedt <egtvedt@samfundet.no> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-05-03Merge tag 'asoc-v3.10-4' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: Updates for v3.10 A few more bug fixes, the DAPM clock fix is actually a driver specific one since currently there's only one user of the clock support due to the problems relying on the clock API.
2013-05-03Merge remote-tracking branch 'asoc/fix/wm8994' into asoc-linusMark Brown
2013-05-03Merge remote-tracking branch 'asoc/fix/davinci' into asoc-linusMark Brown
2013-05-03ASoC: McASP: Fix receive clock polarity in DAIFMT_NB_NF mode.Marek Belisko
According documentation bit ACLKRPOL is set to 0 (receiver samples data on falling edge) and when set to 1 (receiver samples data on rising edge). I2S data are always sampled on falling edge and valid during rising edge of bit clock. So in case of capture data transmitter sample data on falling edge and macsp must read then on rising edge. Signed-off-by: Marek Belisko <marek.belisko@streamunlimited.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-30ASoC: wm8994: missing break in wm8994_aif3_hw_params()Dan Carpenter
The missing break here means that we always return early and the function is a no-op. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2013-04-30ASoC: McASP: Add pins output direction for rx clocks when configured in ↵Marek Belisko
CBS_CFS format When McASP is bit clock and frame clock master enable pin output for rx clocks. Signed-off-by: Marek Belisko <marek.belisko@streamunlimited.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-30ASoC: dapm: use clk_prepare_enable and clk_disable_unprepareFabio Baltieri
Update dapm_clock_event to use clk_prepare_enable and clk_disable_unprepare. Signed-off-by: Fabio Baltieri <fabio.baltieri@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-30ALSA: usb-audio: caiaq: fix endianness bug in snd_usb_caiaq_maschine_dispatchEldad Zack
Current code does this: be16_to_cpu(buf[i * 2] << 8 | buf[(i * 2) + 1]) Which is effectively (neglecting the index): be16_to_cpu(be16_to_cpu(*((u16 *) buf))) This means the int16 in the buffer is not converted at all. Daniel Mack confirmed that the driver works on little endian CPUs, leading to the conclusion that the device-side structure is actually little endian. This changes the code to use le16_to_cpu(). Caught by sparse. Acked-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: asihpi: add format support check in snd_card_asihpi_capture_formatsEldad Zack
Some Asihpi formats are not supported or invalid, and their mapping to ALSA format is set to -1. Before performing the format conversion into ALSA bitwise formats, add a consistency check for the requested format, as done in snd_card_asihpi_playback_formats(). Compile tested only. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: pcm_format_to_bits strong-typed conversionEldad Zack
Add a function to handle conversion from snd_pcm_format_t to bitwise with proper typing. Change such conversions to use this function and silence sparse warnings. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: compress: fix the states to check for allowing readVinod Koul
for reading compressed data, we need to allow when we are paused, draining or stopped. Signed-off-by: Vinod Koul <vinod.koul@intel.com> Cc: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Cc: Richard Fitzgerald <rf@opensource.wolfsonmicro.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: hda - Move Thinkpad X220 to use auto parserDavid Henningsson
This enables better volume controls than the current model parser. Also, because the original quirk for X220 was added to fix docking station support, add the TP410 fixup instead. Reported-by: Willian Jon McCann <william.jon.mccann@gmail.com> Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-29ALSA: USB: adjust for changed 3.8 USB APIClemens Ladisch
The recent changes in the USB API ("implement new semantics for URB_ISO_ASAP") made the former meaning of the URB_ISO_ASAP flag the default, and changed this flag to mean that URBs can be delayed. This is not the behaviour wanted by any of the audio drivers because it leads to discontinuous playback with very small period sizes. Therefore, our URBs need to be submitted without this flag. Reported-by: Joe Rayhawk <jrayhawk@fairlystable.org> Cc: <stable@vger.kernel.org> # 3.8 only Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-26ALSA: usb - Avoid unnecessary sample rate changes on USB 2.0 clock sourcesDavid Henningsson
The Scarlett 2i2 seems to take almost 500 ms to set the sample rate, even if the clock is currently set to that value. This patch speeds up prepare of the device, by avoiding setting the clock to something it already is. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-26sound: oss/dmabuf: use dma_map_singleArnd Bergmann
The virt_to_bus/bus_to_virt functions have been deprecated for as long as I can remember, and they are used in very few remaining instances, usually in obscure ISA device drivers. The OSS sound drivers are the only ones that are still used on the ARM architecture, and only on some of the earliest StrongARM machines. The problem for converting the OSS subsystem to use dma_map_single instead is that the caller of virt_to_bus does not have a device pointer, since the subsystem has never been ported to use the common device infrastructure. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-26ALSA: ali5451: use mdelay instead of large udelay constantsArnd Bergmann
ARM cannot handle udelay for more than 2 miliseconds, so we should use mdelay instead for those. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-25Merge tag 'asoc-v3.10-3' of ↵Takashi Iwai
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into for-next ASoC: More updates for v3.10 A few more fixes, nothing too major though the DMA changes fix modular builds.
2013-04-25ALSA: hda - Add the support for ALC286 codecKailang Yang
It's yet another ALC269-variant. Signed-off-by: Kailang Yang <kailang@realtek.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-25ALSA: usb-audio: USB quirk for Yamaha THR10CTrulan Martin
This patch adds a USB quirk for the Yamaha THR10C amp. Signed-off-by: Trulan Martin <trulanm@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-25ALSA: usb-audio: USB quirk for Yamaha THR5ATrulan Martin
This patch adds a USB quirk for the Yamaha THR5A amp. Signed-off-by: Trulan Martin <trulanm@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-25ALSA: usb-audio: USB quirk for Yamaha THR10Trulan Martin
This patch adds a USB quirk for the Yamaha THR10 amp. Signed-off-by: Trulan Martin <trulanm@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-25ALSA: usb-audio: Fix autopm error during probingTakashi Iwai
We've got strange errors in get_ctl_value() in mixer.c during probing, e.g. on Hercules RMX2 DJ Controller: ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x201, wIndex = 0xa00, type = 4 ALSA mixer.c:352 cannot get ctl value: req = 0x83, wValue = 0x200, wIndex = 0xa00, type = 4 .... It turned out that the culprit is autopm: snd_usb_autoresume() returns -ENODEV when called during card->probing = 1. Since the call itself during card->probing = 1 is valid, let's fix the return value of snd_usb_autoresume() as success. Reported-and-tested-by: Daniel Schürmann <daschuer@mixxx.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-25ALSA: snd-usb: try harder to find USB_DT_CS_ENDPOINTDaniel Mack
The USB_DT_CS_ENDPOINT class-specific endpoint descriptor is usually stuffed directly after the standard USB endpoint descriptor, and this is where the driver currently expects it to be. There are, however, devices in the wild that have it the other way around in their descriptor sets, so the USB_DT_CS_ENDPOINT comes *before* the standard enpoint. Devices known to implement it that way are "Sennheiser BTD-500" and Plantronics USB headsets. When the driver can't find the USB_DT_CS_ENDPOINT, it won't be able to change sample rates, as the bitmask for the validity of this command is storen in bmAttributes of that descriptor. Fix this by searching the entire interface instead of just the extra bytes of the first endpoint, in case the latter fails. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Torstein Hegge <hegge@resisty.net> Reported-and-tested-by: Yves G <alsa-user@vivigatt.com> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-24ALSA: sound kconfig typoPavel Machek
Fix english in sound/drivers/Kconfig. Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-24ALSA: emu10k1: Fix dock firmware loadingTakashi Iwai
The commit [b209c4df: ALSA: emu10k1: cache emu1010 firmware] broke the firmware loading of the dock, just (mistakenly) ignoring a different firmware for docks on some models. This patch revives them again. Bugzilla: https://bugs.archlinux.org/task/34865 Reported-and-tested-by: Tobias Powalowski <tobias.powalowski@googlemail.com> Cc: <stable@vger.kernel.org> [v3.8+] Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-23Merge remote-tracking branch 'asoc/topic/ux500' into asoc-nextMark Brown
2013-04-23Merge remote-tracking branch 'asoc/topic/max98088' into asoc-nextMark Brown
2013-04-23Merge remote-tracking branch 'asoc/topic/fsl' into asoc-nextMark Brown
2013-04-23Merge remote-tracking branch 'asoc/topic/dma' into asoc-nextMark Brown
2013-04-23Merge remote-tracking branch 'asoc/topic/davinci' into asoc-nextMark Brown
2013-04-23Merge remote-tracking branch 'asoc/topic/cs4271' into asoc-nextMark Brown
2013-04-23Merge remote-tracking branch 'asoc/topic/core' into asoc-nextMark Brown
2013-04-23ASoC: ux500: forward declare msp_i2s_platform_dataArnd Bergmann
We get a lot of build warnings from the msp driver like: In file included from sound/soc/ux500/ux500_msp_dai.h:21:0, from sound/soc/ux500/mop500.c:25: sound/soc/ux500/ux500_msp_i2s.h:546:11: warning: 'struct msp_i2s_platform_data' declared inside parameter list [enabled by default] struct msp_i2s_platform_data *platform_data); ^ sound/soc/ux500/ux500_msp_i2s.h:546:11: warning: its scope is only this definition or declaration, which is probably not what you want [enabled by default] The easiest solution is to add a declaration of the struct name. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-23ASoC: davinci-mcasp: Add Support BCLK-to-LRCLK ratio for TDM modesMichal Bachraty
For TDM mode, BCLK-to-LCLK ratio is computed as (tdm_slots) x (word_length). I2S mode is only subset of TDM mode with specific tdm_slots = 2 channels. Also bclk_lrclk_ratio can be greater than 255, therefore u16 need to be used. Signed-off-by: Michal Bachraty <michal.bachraty@streamunlimited.com> Acked-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-23ASoC: davinci-pcm, davinci-mcasp: Clean up active_serializersMichal Bachraty
As pointed of by Vaibhav, commit message: "ASoC: davinci-mcasp: Add support for multichannel playback" number of active serializers can be hidden into fifo_level variable, which is set in davimci-mcasp. Signed-off-by: Michal Bachraty <michal.bachraty@streamunlimited.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-23ASoC: generic-dmaengine-pcm: call dma_request_slave_channel()Shawn Guo
dma_request_slave_channel() is a more appropriate API for dmaengine clients that adopt generic DMA bindings to call. Let's use it instead of of_dma_request_slave_channel() to save <linux/of_dma.h> include. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-23ASoC: generic-dmaengine-pcm: use a more common dma nameShawn Guo
The examples in Documentation/devicetree/bindings/dma/dma.txt recommends the name for dma channel doing both RX and TX to be "rx-tx". This becomes a common pattern that has been adopted by platforms that converts to generic DMA bindings. Let's follow this common pattern in generic-dmaengine-pcm. Signed-off-by: Shawn Guo <shawn.guo@linaro.org> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ALSA: hda - Limit internal mic boost for a few Asus machinesDavid Henningsson
These are being reported as being so noisy at high mic boost levels, so they are unusable in practice. Therefore artificially limit the boosts. BugLink: https://bugs.launchpad.net/bugs/1089795 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-22ASoC: mxs: Use generic dmaengine PCMLars-Peter Clausen
Use the generic dmaengine PCM driver instead of a custom implementation. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ASoC: mxs: Setup dma data in DAI probeLars-Peter Clausen
This allows us to access the DAI DMA data when we create the PCM. We'll use this when converting mxs to generic DMA engine PCM driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ASoC: mxs-pcm: Set SNDRV_PCM_INFO_HALF_DUPLEXLars-Peter Clausen
The MXS SAIF is only half-duplex so set the SNDRV_PCM_INFO_HALF_DUPLEX flag for the PCM in order to prevent playback and capture from running at the same time. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ASoC: generic-dmaengine-pcm: Add support for half-duplexLars-Peter Clausen
Some platforms which are half-duplex share the same DMA channel between the playback and capture stream. Add support for this to the generic dmaengine PCM driver. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Tested-by: Shawn Guo <shawn.guo@linaro.org> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2013-04-22ALSA: snd-usb-audio: set the timeout for usb control set messages to 5000 msDaniel Schürmann
Set the timeout for USB control set messages according to the USB 2 spec, using the macros from include/linux/usb.h. The get timout becomes 5000 ms even though it is 500 ms in the spec. This patch is required to run the Hercules RMX2 which needs a timeout of 1240 ms. More notes from author: I still distinguish between set and get but as long both are 5000 ms GCC will remove it anyway. IMHO this is more easy read and there is no need to explain why we use a get timeout for set messages. Signed-off-by: Daniel Schürmann <daschuer@mixxx.org> Acked-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-04-22ALSA: compress: Use kzalloc() for ioctls writing back dataTakashi Iwai
Like the previous patch by Dan, we should clear the data to be returned from certain compress ioctls, namely, snd_compr_get_codec_caps() and snd_compr_get_params(). This time, we can simply replace kmalloc() with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
