path: root/sound/usb/usbmidi.c
2008-01-31[ALSA] Remove sound/driver.hTakashi Iwai
This header file exists only for some hacks to adapt alsa-driver tree. It's useless for building in the kernel. Let's move a few lines in it to sound/core.h and remove it. With this patch, sound/driver.h isn't removed but has just a single compile warning to include it. This should be really killed in future. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-10-16[ALSA] usb-audio: add workaround for ESI MIDI Mate/RomIO IIClemens Ladisch
Force low speed USB MIDI devices like the ESI MIDI Mate and RomIO II to use interrupt transfers because the USB core would not be happy about low speed bulk transfers. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] usb-audio: allow output interrupt transfers for MIDIClemens Ladisch
Allow output interrupt transfers for some MIDI devices that require them. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-10-16[ALSA] usb-audio: fix parsing of SysEx messages from CME keyboardsClemens Ladisch
When CME keyboards send a SysEx message (e.g. master volume), the USB packet uses a format different from the standard format. Parsing this packet according to the specification corrupts the SysEx message itself and can cause the following MIDI messages to be misinterpreted, too. This patch adds a workaround for this case. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] usb-audio: work around wrong wMaxPacketSize on ESI M4UClemens Ladisch
Add a workaround for the ESI M4U that claims to support 32-byte packets but ignores the remaining bytes of packets bigger than four bytes. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2007-05-11[ALSA] usb-audio: work around broken M-Audio MidiSport Uno firmwareClemens Ladisch
The firmware of the M-Audio USB Uno MIDI Interface has, at least in hardware revision 1.25, a bug that garbles its USB output. When it receives a Note On MIDI message that uses running status, the resulting USB MIDI packet has a wrong CIN (4 instead of 9) and a wrong length (2 bytes, the status byte is still missing). This patch adds a workaround to track the CINs and the MIDI messages of received USB MIDI packets to detect whether a packet with CIN 4 is a correct SysEx packet or a buggy running status packet. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-12-01usb: usbmidi kill urb cleanupMariusz Kozlowski
- usb_kill_urb() cleanup Signed-off-by: Mariusz Kozlowski <m.kozlowski@tuxland.pl> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
Maintain a per-CPU global "struct pt_regs *" variable which can be used instead of passing regs around manually through all ~1800 interrupt handlers in the Linux kernel. The regs pointer is used in few places, but it potentially costs both stack space and code to pass it around. On the FRV arch, removing the regs parameter from all the genirq function results in a 20% speed up of the IRQ exit path (ie: from leaving timer_interrupt() to leaving do_IRQ()). Where appropriate, an arch may override the generic storage facility and do something different with the variable. On FRV, for instance, the address is maintained in GR28 at all times inside the kernel as part of general exception handling. Having looked over the code, it appears that the parameter may be handed down through up to twenty or so layers of functions. Consider a USB character device attached to a USB hub, attached to a USB controller that posts its interrupts through a cascaded auxiliary interrupt controller. A character device driver may want to pass regs to the sysrq handler through the input layer which adds another few layers of parameter passing. I've build this code with allyesconfig for x86_64 and i386. I've runtested the main part of the code on FRV and i386, though I can't test most of the drivers. I've also done partial conversion for powerpc and MIPS - these at least compile with minimal configurations. This will affect all archs. Mostly the changes should be relatively easy. Take do_IRQ(), store the regs pointer at the beginning, saving the old one: struct pt_regs *old_regs = set_irq_regs(regs); And put the old one back at the end: set_irq_regs(old_regs); Don't pass regs through to generic_handle_irq() or __do_IRQ(). In timer_interrupt(), this sort of change will be necessary: - update_process_times(user_mode(regs)); - profile_tick(CPU_PROFILING, regs); + update_process_times(user_mode(get_irq_regs())); + profile_tick(CPU_PROFILING); I'd like to move update_process_times()'s use of get_irq_regs() into itself, except that i386, alone of the archs, uses something other than user_mode(). Some notes on the interrupt handling in the drivers: (*) input_dev() is now gone entirely. The regs pointer is no longer stored in the input_dev struct. (*) finish_unlinks() in drivers/usb/host/ohci-q.c needs checking. It does something different depending on whether it's been supplied with a regs pointer or not. (*) Various IRQ handler function pointers have been moved to type irq_handler_t. Signed-Off-By: David Howells <dhowells@redhat.com> (cherry picked from 1b16e7ac850969f38b375e511e3fa2f474a33867 commit)
2006-10-01[PATCH] kmemdup: some usersAlexey Dobriyan
Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-22[ALSA] USB midi: Remove duplicate CS_AUDIO_* #definesBen Williamson
Removed the CS_AUDIO_* #defines, which were duplicates of the class-specific USB_DT_CS_* #defines in <linux/usb_ch9.h>. Signed-off-by: Ben Williamson <ben.williamson@greyinnovation.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-06-22[ALSA] rawmidi: add get_port_info callback for sequencer information flagsClemens Ladisch
Add a get_port_info callback to the snd_rawmidi_global_ops structure to allow the USB MIDI driver to supply information flags for the sequencer ports created by seq_midi. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: optimize snd_usbmidi_count_bits()Clemens Ladisch
Modules: USB generic driver Reduce the code size of the snd_usbmidi_count_bits() function by using simpler operations. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CMEClemens Ladisch
Modules: USB generic driver Rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CME because Miditech keyboards are built by CME and use the same protocol, and don't force a Miditech product name for the USB ID used by both Miditech and CME UF-x keyboards. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] usb-audio: cosmetic changesClemens Ladisch
Modules: USB generic driver Move some entries around to keep them sorted by ID. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-03-22[ALSA] Add support for EDIROL UM-3exBrent Cook
Modules: USB generic driver This is my naive attempt at adding ALSA device support. The attached patch provides support for the EDIROL UM-3ex. This is a 3-port USB midi interface with a built-in USB hub and the ability to chain 2 other UM-3x's in a master-slave configuration. I only have one, so I do not know how this works in practice. Though this is a 3-port device, I had to throw in that 4th 'Control' interface to the definition in order to make the 3rd port work. If I set in/out_cables to 0x000b, a 3rd interface appears on the driver, but it does nothing. Changing it to 0x000f allows the 3rd interface to work, but of course interface 4 does not work because it does not exist. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-01-03[ALSA] Remove xxx_t typedefs: USB-AudioTakashi Iwai
Modules: USB generic driver Remove xxx_t typedefs from the USB-Audio driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] usb-audio: remove superfluous includeClemens Ladisch
Modules: USB generic driver Remove a superfluous include of the sound/minors.h header. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] usb-audio: remove old compatibility wrappers (2/2)Clemens Ladisch
Modules: USB generic driver Move the usb_complete_callback() compatibility wrapper out of the kernel tree. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] usb-audio: remove old compatibility wrappers (1/2)Clemens Ladisch
Modules: USB generic driver Move the usb_pipe_needs_resubmit() compatibility wrapper out of the kernel tree. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] usb-audio: simplify MIDI quirk handlingClemens Ladisch
Modules: USB generic driver Simplify the handling of MIDI quirks by treating an interface without quirks as a QUIRK_MIDI_STANDARD_INTERFACE. This also fixes the bug where a MIDI_STANDARD quirk would not be recognized. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-10-28[PATCH] gfp_t: drivers/usbAl Viro
2005-09-12[ALSA] Replace with kzalloc() - othersTakashi Iwai
Documentation,SA11xx UDA1341 driver,Generic drivers,MPU401 UART,OPL3 OPL4,Digigram VX core,I2C cs8427,I2C lib core,I2C tea6330t,L3 drivers AK4114 receiver,AK4117 receiver,PDAudioCF driver,PPC PMAC driver SPARC AMD7930 driver,SPARC cs4231 driver,Synth,Common EMU synth USB generic driver,USB USX2Y Replace kcalloc(1,..) with kzalloc(). Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-08-30[ALSA] usb-audio: throttle MIDI URB resubmits on USB errorsClemens Ladisch
USB generic driver When a USB error occurs that might indicate that the device has been unplugged, don't resubmit the URB immediately to prevent flooding the log with error messages before khubd has us disconnect()ed. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-08-30[ALSA] usb-audio: fix Emagic MIDI protocol handlingClemens Ladisch
USB generic driver Emagic devices pad their packets not with 0xff bytes but with a 0xff byte followed by garbage, so we have to stop at the first such byte. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-08-30[ALSA] usb-audio: use usb_buffer_alloc/freeClemens Ladisch
USB generic driver Use the USB buffer allocation functions to avoid repeated DMA mappings of our buffers, which are re-used quite a lot. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-07-28[ALSA] usb-audio - add support for Miditech USB MIDI keyboardsClemens Ladisch
USB generic driver Add support for Miditech Midistart and MidiStudio keyboards (another case of devices using the standard protocol but having no descriptors). Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-07-28[ALSA] usb-audio - rename QUIRK_MIDI_MOTU to QUIRK_MIDI_RAWClemens Ladisch
USB generic driver Rename the protocol used by the MOTU FastLane to 'raw' because it might be useful with other devices, and there are other MOTU interfaces that do not use this protocol. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] usb-audio - cache vendor/product IDsClemens Ladisch
USB generic driver Cache the decoded values of idVendor/idProduct to get rid of most of those ugly le16_to_cpu() calls. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] usb-audio - remove superfluous parameterClemens Ladisch
USB generic driver,USB USX2Y This patch removes the superfluous driver parameter from the disconnect functions. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] usb-audio - allow USB MIDI quirks to specify endpoints explicitlyClemens Ladisch
USB generic driver This patch reintroduces the check for endpoint numbers that are specified explicitly in the quirk structure. This check was accidentally dropped in the last rewrite of snd_usbmidi_detect_endpoints(). Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
