path: root/sound/usb/usbaudio.h
2011-08-26ALSA: usb-audio: add Starr Labs USB MIDI supportKristian Amlie
Add support for Starr Labs USB MIDI devices such as the Z7S, which are based on an FTDI serial UART chip. Based on a patch by Daniel Mack. Signed-off-by: Kristian Amlie <kristian@amlie.name> Acked-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: add new quirk type QUIRK_AUDIO_STANDARD_MIXERDaniel Mack
This quirk type will let the driver assume that there is a standard mixer on a given interface, or that a specific mixer quirks will handle the device. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: implement USB autosuspendOliver Neukum
Devices are autosuspended if no pcm nor midi channel is open Mixer devices may be opened. This way they are active when in use to play or record sound, but can be suspended while users have a mixer application running. [Small clean-ups using static inline by tiwai] Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-02-23ALSA: usb-audio: fix oops due to cleanup race when disconnectingTakashi Iwai
When a USB audio device is disconnected, snd_usb_audio_disconnect() kills all audio URBs. At the same time, the application, after being notified of the disconnection, might close the device, in which case ALSA calls the .hw_free callback, which should free the URBs too. Commit de1b8b93a0ba "[ALSA] Fix hang-up at disconnection of usb-audio" prevented snd_usb_hw_free() from freeing the URBs to avoid a hang that resulted from this race, but this introduced another race because the URB callbacks could now be executed after snd_usb_hw_free() has returned, and try to access already freed data. Fix the first race by introducing a mutex to serialize the disconnect callback and all PCM callbacks that manage URBs (hw_free and hw_params). Reported-and-tested-by: Pierre-Louis Bossart <pierre-louis.bossart@intel.com> Cc: <stable@kernel.org> [CL: also serialize hw_params callback] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-10-22ALSA: usb-audio: add Novation Launchpad supportClemens Ladisch
Add a quirk entry for the Novation Launchpad USB MIDI controller. QUIRK_MIDI_FASTLANE gets renamed to *_RAW_BYTES because this quirk type is now shared by different devices. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Tested-by: Jakob Flierl <jakob.flierl@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-31ALSA: usb-audio: parse clock topology of UAC2 devicesDaniel Mack
Audio devices which comply to the UAC2 standard can export complex clock topologies in its descriptors and set up links between them. The entities that are defined are - clock sources, which define the end-leafs. - clock selectors, which act as switch to select one out of many possible clocks sources. - clock multipliers, which have an input clock source, and act as clock source again. They can be used to derive one clock from another. All sample rate changes, clock validity queries and the like must go to clock source elements, while clock selectors and multipliers can be used as terminal clock source. The following patch adds a parser for these elements and functions to iterate over the tree and find the leaf nodes (clock sources). The samplerate set functions were moved to the new clock.c file. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-05-21ALSA: usb-audio: add support for Akai MPD16Krzysztof Foltman
The decoding/encoding is based on own reverse-engineering. Both control and data ports are handled. Writing to control port supports SysEx events only, as this is the only type of messages that MPD16 recognizes. Signed-off-by: Krzysztof Foltman <wdev@foltman.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: refactor codeDaniel Mack
Clean up the usb audio driver by factoring out a lot of functions to separate files. Code for procfs, quirks, urbs, format parsers etc all got a new home now. Moved almost all special quirk handling to quirks.c and introduced new generic functions to handle them, so the exceptions do not pollute the whole driver. Renamed usbaudio.c to card.c because this is what it actually does now. Renamed usbmidi.c to midi.c for namespace clarity. Removed more things from usbaudio.h. The non-standard drivers were adopted accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-05ALSA: usb-audio: header file cleanupsDaniel Mack
Rename snd-usb-lib to snd-usbmidi-lib as MIDI functions are the only thing it actually contains. Introduce a new header file to only declare these functions. Introduced usbmixer.h for all functions exported by usbmixer.c. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-03-02Merge remote branch 'alsa/devel' into topic/miscTakashi Iwai
Conflicts: sound/usb/usbaudio.c
2010-03-01ALSA: ua101: add Edirol UA-1000 supportClemens Ladisch
Add support for the Edirol UA-1000 to the UA-101 driver. Both devices behave the same, so we just have to shuffle around some interface numbers and name strings. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2010-02-23ALSA: usbaudio: consolidate header filesDaniel Mack
Use the definitions from linux/usb/audio.h all over the ALSA USB audio driver and add some missing definitions there as well. Use the endpoint attribute macros from linux/usb/ch9 and remove the own things from sound/usb/usbaudio.h. Now things are also nicely prefixed which makes understanding the code easier. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: implement basic set of class v2.0 parserDaniel Mack
This adds a number of parsers for audio class v2.0. In particular, the following internals are different and now handled by the code: * the number of streaming interfaces is now reported by an interface association descriptor. The old approach using a proprietary descriptor is deprecated. * The number of channels per interface is now stored in the AS_GENERAL descriptor (used to be part of the FORMAT_TYPE descriptor). * The list of supported sample rates is no longer stored in a variable length appendix of the format_type descriptor but is retrieved from the device using a class specific GET_RANGE command. * Supported sample formats are now reported as 32bit bitmap rather than a fixed value. For now, this is worked around by choosing just one of them. * A devices needs to have at least one CLOCK_SOURCE descriptor which denotes a clockID that is needed im the class request command. * Many descriptors (format_type, ...) have changed their layout. Handle this by casting the descriptors to the appropriate structs. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-02-23ALSA: usbaudio: introduce new types for audio class v2Daniel Mack
This patch adds some definitions for audio class v2. Unfortunately, the UNIT types PROCESSING_UNIT and EXTENSION_UNIT have different numerical representations in both standards, so there is need for a _V1 add-on now. usbmixer.c is changed accordingly. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio: use usbquirk.h for detection of HVR-950Q/850John S. Gruber
Detect the HVR-950Q HVR-850 urb data alignment quirk using usbquirk.h rather than using a case statement in snd_usb_audio_probe. Signed-off-by: John S. Gruber <JohnSGruber@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio: relax urb data align. restriction HVR-950Q and HVR-850 onlyJohn S. Gruber
Addressing audio quality problem. In sound/usb/usbaudio.c, for the Hauppage HVR-950Q and HVR-850 only, change retire_capture_urb to allow transfers on audio sub-slot boundaries rather than audio slots boundaries. With these devices the left and right channel samples can be split between two different urbs. Throwing away extra channel samples causes a sound quality problem for stereo streams as the left and right channels are swapped repeatedly, perhaps many times per second. Urbs unaligned on sub-slot boundaries are still truncated to the next lowest stride (audio slot) to retain synchronization on samples even though left/right channel synchronization may be lost in this case. Detect the quirk using a case statement in snd_usb_audio_probe. BugLink: https://bugs.launchpad.net/ubuntu/+bug/495745 Signed-off-by: John S. Gruber <JohnSGruber@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-28ALSA: usb-audio - Added functionality for E-mu 0404USB/0202USB/TrackerPreSergiy Kovalchuk
Added functionality: 1) Extension Units support (all XU settings now available at alsamixer, kmix, etc): - "AnalogueIn soft limiter" switch; - "Sample rate" selector (values 0,1,2,3,4,5 corresponds to 44.1 48 ... 192 kHz); - "DigitalIn CLK source" selector (internal/external) (**); - "DigitalOut format SPDIF/AC3" switch (**); (**)E-mu-0404usb only. 2) Automatic device sample rate adjustment depending on substream samplerate for both capture and playback substream. [minor coding-style fixes by tiwai] Signed-off-by: Sergiy Kovalchuk <cnb_zerg@yahoo.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-12-14sound: add Edirol UA-101 supportClemens Ladisch
Add experimental support for the Edirol UA-101 audio/MIDI interface. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-24sound: usb: make the USB MIDI module more independentClemens Ladisch
Remove the dependecy from the USB MIDI code on the snd_usb_audio structure. This allows using the USB MIDI module from another driver without having to pretend to be the generic USB audio driver. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-11-07ALSA: usb-audio: fix combine_word problemJulian Anastasov
Fix combine_word problem where first octet is not read properly. The only affected place seems to be the INPUT_TERMINAL type. Before now, sound controls can be created with the output terminal's name which is a fallback mechanism used only for unknown input terminal types. For example, Line can wrongly appear as Speaker. After the change it should appear as Line. The side effect of this change can be that users can expect the wrong control name in their scripts or programs while now we return the correct one. Probably, these defines should use get_unaligned_le16 and friends. Signed-off-by: Julian Anastasov <ja@ssi.bg> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2009-05-27sound: usb-audio: make the MotU Fastlane work againClemens Ladisch
Kernel 2.6.18 broke the MotU Fastlane, which uses duplicate endpoint numbers in a manner that is not only illegal but also confuses the kernel's endpoint descriptor caching mechanism. To work around this, we have to add a separate usb_set_interface() call to guide the USB core to the correct descriptors. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Reported-and-tested-by: David Fries <david@fries.net> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-10-10ALSA: snd-usb-audio: support for Edirol UA-4FX devicePedro Lopez-Cabanillas
Renamed the old quirk function for ua-700/ua-25 to become more generic, moving the MIDI interfaces to the quirk data header. Added a new quirk for the Edirol UA-4FX. Signed-off-by: Pedro Lopez-Cabanillas <pedro.lopez.cabanillas@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-15ALSA: usb-audio - Add ignore_ctl_error parameterTakashi Iwai
Added the ignore_ctl_error parameter to enable/disable the control-error handling for mixer interfaces. It was a hard-coded ifdef, and now you can change it more easily. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-08-01ALSA: Add USB US122L driverKarsten Wiese
Added a new US122L usb-audio driver. This driver works together with a dedicated alsa-lib plugin. Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2008-01-31[ALSA] usb audio suspend supportOliver Neukum
This patch implements suspend/resume support for USB audio devices. It works with the microphone in my camera. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
2007-02-09[ALSA] usbaudio - Add support for Edirol UA-101Bjoern Fay
Added support for the Edirol UA-101 (only in high-speed mode) by taking the quirks for the UA-1000 and change them accordingly. Changes were made in 'usbaudio.c', 'usbaudio.h', and 'usbquirks.h' MIDI and recording seem to work perfectly (with JACK), but playback gives some few glitches. I think that's the mentioned synchronizing-problem in the UA-1000 quirk ('FIXME: playback must be synchronized to capture'), so I didn't change that. ToDo: Adding Mixer-Support for the built-in control-panel/patch-bay/router. Signed-off-by: Bjoern Fay <mail@bfay.de> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@suse.cz>
2006-06-22[ALSA] USB midi: Remove duplicate CS_AUDIO_* #definesBen Williamson
Removed the CS_AUDIO_* #defines, which were duplicates of the class-specific USB_DT_CS_* #defines in <linux/usb_ch9.h>. Signed-off-by: Ben Williamson <ben.williamson@greyinnovation.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2006-03-22[ALSA] usb-audio: rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CMEClemens Ladisch
Modules: USB generic driver Rename QUIRK_MIDI_MIDITECH to QUIRK_MIDI_CME because Miditech keyboards are built by CME and use the same protocol, and don't force a Miditech product name for the USB ID used by both Miditech and CME UF-x keyboards. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2006-01-03[ALSA] Remove xxx_t typedefs: USB-AudioTakashi Iwai
Modules: USB generic driver Remove xxx_t typedefs from the USB-Audio driver. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2005-11-04[ALSA] usb-audio: remove old compatibility wrappers (2/2)Clemens Ladisch
Modules: USB generic driver Move the usb_complete_callback() compatibility wrapper out of the kernel tree. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-11-04[ALSA] usb-audio: remove old compatibility wrappers (1/2)Clemens Ladisch
Modules: USB generic driver Move the usb_pipe_needs_resubmit() compatibility wrapper out of the kernel tree. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-07-28[ALSA] usb-audio - change quirk type handlingClemens Ladisch
USB generic driver Make the quirk type an enum instead of a #defined integer, and use a table for the quirk constructor functions instead of a big switch statement. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-07-28[ALSA] usb-audio - add support for Miditech USB MIDI keyboardsClemens Ladisch
USB generic driver Add support for Miditech Midistart and MidiStudio keyboards (another case of devices using the standard protocol but having no descriptors). Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-07-28[ALSA] usb-audio - rename QUIRK_MIDI_MOTU to QUIRK_MIDI_RAWClemens Ladisch
USB generic driver Rename the protocol used by the MOTU FastLane to 'raw' because it might be useful with other devices, and there are other MOTU interfaces that do not use this protocol. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] usb-audio - cache vendor/product IDsClemens Ladisch
USB generic driver Cache the decoded values of idVendor/idProduct to get rid of most of those ugly le16_to_cpu() calls. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] usb-audio - move mixer data into separate structClemens Ladisch
USB generic driver Move all data related to audio control interfaces into a separate struct local to usbmixer.c. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2005-05-29[ALSA] usb-audio - remove superfluous parameterClemens Ladisch
USB generic driver,USB USX2Y This patch removes the superfluous driver parameter from the disconnect functions. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
