path: root/sound/usb/mixer.c
2014-03-05ALSA: usb-audio: Add quirk for Logitech Webcam C500Takashi Iwai
Logitech C500 (046d:0807) needs the same workaround like other Logitech Webcams. Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-09-26ALSA: Fix assignment of 0/1 to bool variablesPeter Senna Tschudin
Convert 0 to false and 1 to true when assigning values to bool variables. Inspired by commit 3db1cd5c05f35fb43eb134df6f321de4e63141f2. The simplified semantic patch that find this problem is as follows (http://coccinelle.lip6.fr/): @@ bool b; @@ ( -b = 0 +b = false | -b = 1 +b = true ) Signed-off-by: Peter Senna Tschudin <peter.senna@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-08-12ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam C525Maksim A. Boyko
Add the volume control quirk for avoiding the kernel warning for the Logitech HD Webcam C525 as in the similar commit 36691e1be6ec551eef4a5225f126a281f8c051c2 for the Logitech HD Webcam C310. Reported-by: Maksim Boyko <maksim.a.boyko@gmail.com> Tested-by: Maksim Boyko <maksim.a.boyko@gmail.com> Cc: <stable@vger.kernel.org> # 3.10.5+ Signed-off-by: Maksim Boyko <maksim.a.boyko@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-17ALSA: usb-audio: Fix invalid volume resolution for Logitech HD Webcam c310Takashi Iwai
Just like the previous fix for LogitechHD Webcam c270 in commit 11e7064f35bb87da8f427d1aa4bbd8b7473a3993, c310 model also requires the same workaround for avoiding the kernel warning. Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=59741 Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-06-05ALSA: usb-audio - Fix invalid volume resolution on Logitech HD webcam c270Takashi Iwai
USB audio driver spews an error message when probing Logitech HD webcam c270: ALSA mixer.c:1300 usb_audio: Warning! Unlikely big volume range (=6144), cval->res is probably wrong. ALSA mixer.c:1304 usb_audio: [5] FU [Mic Capture Volume] ch = 1, val = 1536/7680/1 Obviously the device needs a fixed volume resolution (cval->res = 384) like other Logitech devices. Bugzilla: https://bugzilla.novell.com/show_bug.cgi?id=821735 Reported-and-tested-by: Cristian Rodríguez <crrodriguez@opensuse.org> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-20ALSA: snd-usb: mixer: ignore -EINVAL in snd_usb_mixer_controls()Daniel Mack
Creation of individual mixer controls may fail, but that shouldn't cause the entire mixer creation to fail. Even worse, if the mixer creation fails, that will error out the entire device probing. All the functions called by parse_audio_unit() should return -EINVAL if they find descriptors that are unsupported or believed to be malformed, so we can safely handle this error code as a non-fatal condition in snd_usb_mixer_controls(). That fixes a long standing bug which is commonly worked around by adding quirks which make the driver ignore entire interfaces. Some of them might now be unnecessary. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-and-tested-by: Rodolfo Thomazelli <pe.soberbo@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-20ALSA: snd-usb: mixer: propagate errors up the call chainDaniel Mack
In check_input_term() and parse_audio_feature_unit(), propagate the error value that has been returned by a failing function instead of -EINVAL. That helps cleaning up the error pathes in the mixer. Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-03-20ALSA: usb: Parse UAC2 extension unit like for UAC1Torstein Hegge
UAC2_EXTENSION_UNIT_V2 differs from UAC1_EXTENSION_UNIT, but can be handled in the same way when parsing the unit. Otherwise parse_audio_unit() fails when it sees an extension unit on a UAC2 device. UAC2_EXTENSION_UNIT_V2 is outside the range allocated by UAC1. Signed-off-by: Torstein Hegge <hegge@resisty.net> Acked-by: Daniel Mack <zonque@gmail.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-02-11ALSA: usb-audio: add support for M-Audio FT C600Matt Gruskin
Adds quirks and mixer support for the M-Audio Fast Track C600 USB audio interface. This device is very similar to the C400 - the C600 simply has some more inputs and outputs, so the existing C400 support is extended to support this device as well. Signed-off-by: Matt Gruskin <matthew.gruskin@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-01-27ALSA: usb-audio: fix invalid length check for RME and other UAC 2 devicesClemens Ladisch
Commit 23caaf19b11e (ALSA: usb-mixer: Add support for Audio Class v2.0) forgot to adjust the length check for UAC 2.0 feature unit descriptors. This would make the code abort on encountering a feature unit without per-channel controls, and thus prevented the driver to work with any device having such a unit, such as the RME Babyface or Fireface UCX. Reported-by: Florian Hanisch <fhanisch@uni-potsdam.de> Tested-by: Matthew Robbetts <wingfeathera@gmail.com> Tested-by: Michael Beer <beerml@sigma6audio.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: 2.6.35+ <stable@vger.kernel.org> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-29ALSA: usb - Don't create "Speaker" mixer controls on headphones and headsetsDavid Henningsson
A lot of headsets/headphones have a "Speaker" mixer control. This confuses PulseAudio to think it is a speaker instead of a headphone/headset. Therfore, we rename it to "Headphone". We determine if something is a headphone similar to how udev determines form factor (see 78-sound-card.rules). BugLink: https://bugs.launchpad.net/bugs/1082357 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-29ALSA: usb-audio: Fast Track C400 mixer rangesEldad Zack
Add ranges for various Fast Track C400 controls, as observed while using the vendor's mixer control software (res values are an estimation). Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-29ALSA: usb-audio: skip UAC2 EFFECT_UNITEldad Zack
Current code mishandles the case where the device is a UAC2 and the bDescriptorSubtype is a UAC2 Effect Unit (0x07). It tries to parse it as a Processing Unit (which is similar to two other UAC1 units with overlapping subtypes), but since the structure is different (See: 4.7.2.10, 4.7.2.11 in UAC2 standard), the parsing is done incorrectly and prevents the device from initializing. For now, just ignore the unit. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-11-29ALSA: usb-audio: add control index offsetEldad Zack
Currently, channel IDs exceeding 31 (0x1f) cannot be used. The channel ID is derived from the cmask. Extending cmask to a 64-bit type would only allow it to go up to 63 (0x3f). Some devices have channel IDs exceeding that as well. To address that, add an offset to the mixer element which is then accounted for in the UAC set/get functions. Signed-off-by: Eldad Zack <eldad@fogrefinery.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-30ALSA: usb-audio: Use rwsem for disconnect protectionTakashi Iwai
Replace mutex with rwsem for codec->shutdown protection so that concurrent accesses are allowed. Also add the protection to snd_usb_autosuspend() and snd_usb_autoresume(), too. Reported-by: Matthieu CASTET <matthieu.castet@parrot.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-10-30ALSA: usb-audio: Fix races at disconnectionTakashi Iwai
Close some races at disconnection of a USB audio device by adding the chip->shutdown_mutex and chip->shutdown check at appropriate places. The spots to put bandaids are: - PCM prepare, hw_params and hw_free - where the usb device is accessed for communication or get speed, in mixer.c and others; the device speed is now cached in subs->speed instead of accessing to chip->dev The accesses in PCM open and close don't need the mutex protection because these are already handled in the core PCM disconnection code. The autosuspend/autoresume codes are still uncovered by this patch because of possible mutex deadlocks. They'll be covered by the upcoming change to rwsem. Also the mixer codes are untouched, too. These will be fixed in another patch, too. Reported-by: Matthieu CASTET <matthieu.castet@parrot.com> Cc: <stable@vger.kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-09-20ALSA: usb - disable broken hw volume for Tenx TP6911David Henningsson
While going through Ubuntu bugs, I discovered this patch being posted and a confirmation that the patch works as expected. Finding out how the hw volume really works would be preferrable to just disabling the broken one, but this would be better than nothing. Credit: sndfnsdfin (qawsnews) BugLink: https://bugs.launchpad.net/bugs/559939 Signed-off-by: David Henningsson <david.henningsson@canonical.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-05-15ALSA: usb-audio - Call get_min_max_*() after determining the name stringTakashi Iwai
get_min_max_with_quirks() must be called after the control id name string is determined, but the current code changes the id name string after calling the function. Reported-by: Christian Melki <christian.melki@ericsson.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: M-Audio Fast Track Ultra: Add effect controlsFelix Homann
This adds controls for the effects section on the FTU devices. Some of these controls need volume quirks. They are added to mixer.c. [fixed missing break by tiwai] Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-24ALSA: usb-audio: Rename and export mixer_vol_tlvFelix Homann
Rename mixer_vol_tlv to snd_usb_mixer_vol_tlv and export it to make it reuseable in mixer_quirks.c. Signed-off-by: Felix Homann <linuxaudio@showlabor.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2012-04-15ALSA: snd-usb-audio: Skip un-parseable mixer units instead of erroringMark Hills
Some interfaces reference endpoints which do not exists. To accomodate these, do not fail completely, but skip over them. This allows the Electrix Ebox-44 with earlier firmware to be detected and used for audio. Signed-off-by: Mark Hills <mark@pogo.org.uk> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-09ALSA: snd_usb_audio: add Logitech HD Webcam c510 to quirk-384Alexey Fisher
Logitech HD Webcam c510 provide wrong mixer resolution. Add it to "res = 384" quirk. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-11-08ALSA: usb-audio - Fix the missing volume quirks at delayed initTakashi Iwai
In the recent usb-audio driver, the initialization of volume ranges may be delayed when the device doesn't respond well at the probing time. But the volume quirks for certain devices are applied only in mixer_ctl_feature_info() thus only at the very first probe and will be missing when the volume range is initialized later. This patch moves the volume quirk code to be always called from the volume-range extraction (get_min_max()), so that the quirks are properly applied in the later init time. Reported-and-tested-by: Alexey Fisher <bug-track@fisher-privat.net> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-10-13ALSA: usb-audio - Fix possible access over audio_feature_info[] arrayTakashi Iwai
The audio_feature_info[] array should contain all entries for UAC2_FU_*, but currently a few last entries are missing. Even though, the driver tries to probe these entries in parse_audio_feature_unit() and may access the range over the array. This patch fixes the bug by limiting the loop size properly using ARRAY_SIZE() instead of a hard-coded magic number. Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-09-27ALSA: usb-audio: increase control transfer timeoutClemens Ladisch
There are certain devices that are reportedly so slow that they need more than 100 ms to handle control transfers. Therefore, increase the timeout in mixer(_quirks).c to 1000 ms. The timeout parameter of snd_usb_ctl_msg() is now constant, so we can drop it. Reported-by: Felipe Balbi <balbi@ti.com> Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-19ALSA: usb-audio - Check the dB-range validity in the later read, tooTakashi Iwai
When the initial check of dB-range failed due to the read error, try to check again at the later read, too. When an invalid dB range is found, remove TLV flags and notify the mixer info change. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-19ALSA: usb-audio - Fix missing mixer dB informationTakashi Iwai
The recent fix for testing dB range at the mixer creation time seems to cause regressions in some devices. In such devices, reading the dB info at probing time gives an error, thus both dBmin and dBmax are still zero, and TLV flag isn't set although the later read of dB info succeeds. This patch adds a workaround for such a case by assuming that the later read will succeed. In future, a similar test should be performed in a case where a wrong dB range is seen even in the later read. Signed-off-by: Takashi Iwai <tiwai@suse.de> Cc: <stable@kernel.org>
2011-08-04ALSA: snd-usb: operate on given mixer interface onlyDaniel Mack
When creating the mixers for an USB audio device, the current code looks at the host interface stored in mixer->chip->ctrl_if. Change this and rather keep a local pointer to the interface that was given when snd_usb_create_mixer() was called. Signed-off-by: Daniel Mack <zonque@gmail.com> Reported-by: Nicolai Krakowiak <nicolai.krakowiak@gmail.com> Reported-by: Lean-Yves LENHOF <jean-yves@lenhof.eu.org> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-08-04ALSA: snd-usb: avoid dividing by zero on invalid inputNicolai Krakowiak
Signed-off-by: Nicolai Krakowiak <nicolai.krakowiak@gmail.com> Acked-by: Daniel Mack <zonque@gmail.com> Acked-by: Clemens Ladisch <clemens@ladisch.de> Cc: stable@kernel.org Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: export snd_usb_feature_unit_ctlDaniel Mack
In order to allow quirks functions to hook up to the standard feature unit op tables, this patch exports a pointer to the struct that is used internally. That way, all the code handling the control can be kept private, and external code can reference the symbol to re-use it. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-25ALSA: usb-audio: rework add_control_to_empty()Daniel Mack
This patch renames add_control_to_empty() to snd_usb_mixer_add_control() and exports it, so the quirks functions can make use of it. Also, as "struct mixer_build" is private to mixer.c, rewrite the function to take an argument of type "struct usb_mixer_interface" instead. Signed-off-by: Daniel Mack <zonque@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-05-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-04-28ALSA: usb-audio - Don't expose broken dB rangesTakashi Iwai
Some crappy USB-audio devices give broken dB ranges, e.g. both min and max are 0dB. This confuses the volume control that prefers dB expression such as alsactl or PulseAudio. In such a case, it's much better not to expose the broken dB information. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: implement USB autosuspendOliver Neukum
Devices are autosuspended if no pcm nor midi channel is open Mixer devices may be opened. This way they are active when in use to play or record sound, but can be suspended while users have a mixer application running. [Small clean-ups using static inline by tiwai] Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11ALSA: usbaudio: fix suspend/resumeOliver Neukum
- ESHUTDOWN must be correctly handled - the optional interrupt endpoint's URB must be stopped and restarted Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-11Merge branch 'fix/misc' into topic/miscTakashi Iwai
2011-03-10ALSA: usb-audio - Add "cval->res = 384" quirk for Logitech Webcam C600Alexey Fisher
One more affected devices: Logitech Webcam C600 (046d:0808) Volume range before quirk is 6400, after (also real) is 16. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-03-10ALSA: usb-audio - Add volume range check and warn if it too bigAlexey Fisher
2011-02-08ALSA: usbaudio - Enable the E-MU 0204 USBJoseph Teichman
Signed-off-by: Joseph Teichman <josteich@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-01-10ALSA: usb-audio: use enum control info helperClemens Ladisch
Simplify info callbacks by using the snd_ctl_enum_info() helper function. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-16ALSA: usb/mixer: remove bogus castDan Carpenter
"uinfo->value.enumerated.item" is an unsigned int. If it's negative when we do the comparison: if ((int)uinfo->value.enumerated.item >= cval->max) then we would read past the end of the array on the next line. I also changed the strcpy() to strlcpy() out of paranoia. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-16ALSA: usb-audio - Fix an unused-variable compile warningTakashi Iwai
Used only when CONFIG_SND_DEBUG=y sound/usb/mixer.c: In function 'get_min_max': sound/usb/mixer.c:762: warning: unused variable 'chip' Reported-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-09-03ALSA: usb-audio: fix detection of vendor-specific device protocol settingsClemens Ladisch
The Audio Class v2 support code in 2.6.35 added checks for the bInterfaceProtocol field. However, there are devices (usually those detected by vendor-specific quirks) that do not have one of the predefined values in this field, which made the driver reject them. To fix this regression, restore the old behaviour, i.e., assume that a device with an unknown bInterfaceProtocol field (other than UAC_VERSION_2) has more or less UAC-v1-compatible descriptors. [compile warning fixes by tiwai] Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: Daniel Mack <daniel@caiaq.de> Cc: <stable@kernel.org> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-24ALSA: usb - Fix compile error with CONFIG_SND_DEBUG_VERBOSE=yTakashi Iwai
Replaced the forgotten cval->mixer->ctrlif. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: simplify control interface accessDaniel Mack
As the control interface is now carried in struct snd_usb_audio, we can simplify the API a little and also drop the private ctrlif field from struct usb_mixer_interface. Also remove a left-over function prototype in pcm.h. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: move and add some commentsDaniel Mack
Also add a list of open topics. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio: unify UAC macros and struct namesDaniel Mack
Get rid of the last occurances of _v1 suffixes, and move the version number right after the "uac" string. Now things are consitent again. Sorry for the forth and back, but it just looks much nicer this way. Signed-off-by: Daniel Mack <daniel@caiaq.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-23ALSA: usb-audio - Add volume resolution quirk for some Logitech webcamsAlexey Fisher
Some programs like Skype trying to set capture volume automatically. Normally it will tray, carefully step by step lover or higher, set the volume. In real word it work not really well, because devises and vendors lie about real audio settings. For example most Logitech webcams have 6400 or 3500 steps for capture volume. They do not tell that actual resolution is 384. So we have only 7 or 18 real steps. In this patch I set real resolution only for tested devices. Signed-off-by: Alexey Fisher <bug-track@fisher-privat.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2010-06-11ALSA: usb-audio: fix UAC2 control value queriesDaniel Mack
For RANGE requests, we should only query as much bytes as we're in fact interested in. For CUR requests, we shouldn't confuse the firmware with an overlong request but just ask for 2 bytes. This might need fixing in the future as it's not entirely clear when to dispatch 1-byte, 2-byte and 4-byte request blocks. For now, we assume everything is coded in 16bit - this works for all firmware implementations I've seen. Signed-off-by: Daniel Mack <daniel@caiaq.de> Reported-by: Alex Lee <alexlee188@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
