path: root/sound/soc
2016-06-17ASoc: wm8731: add 32bit mode.Matt Flax
This patch adds 32 bit word capability to the wm8731 driver. The wm8731 codec is capable of handling 32 bit word sizes, however that has not previously been activated in the codec driver. Signed-off-by: Matt Flax <flatmax@flatmax.org> Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-28Merge tag 'sound-4.7-rc1-2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull more sound updates from Takashi Iwai: "This is the second update round for 4.7-rc1. Most of changes are about the pending ASoC updates and fixes, including a few new drivers. Below are some highlights: ASoC: - New drivers for MAX98371 and TAS5720 - SPI support for TLV320AIC32x4, along with the module split - TDM support for STI Uniperf IPs - Remaining topology API fixes / updates HDA: - A couple of Dell quirks and new Realtek codec support" * tag 'sound-4.7-rc1-2' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (63 commits) ALSA: hda - Fix headset mic detection problem for one Dell machine spi: spi-ep93xx: Fix the PTR_ERR() argument ALSA: hda/realtek - Add support for ALC295/ALC3254 ASoC: kirkwood: fix build failure ALSA: hda - Fix headphone noise on Dell XPS 13 9360 ASoC: ak4642: Enable cache usage to fix crashes on resume ASoC: twl6040: Disconnect AUX output pads on digital mute ASoC: tlv320aic32x4: Properly implement the positive and negative pins into the mixers rcar: src: skip disabled-SRC nodes ASoC: max98371 Remove duplicate entry in max98371_reg ASoC: twl6040: Select LPPLL during standby ASoC: rsnd: don't use prohibited number to PDMACHCRn.SRS ASoC: simple-card: Add pm callbacks to platform driver ASoC: pxa: Fix module autoload for platform drivers ASoC: topology: Fix memory leak in widget creation ASoC: Add max98371 codec driver ASoC: rsnd: count .probe/.remove for rsnd_mod_call() ASoC: topology: Check size mismatch of ABI objects before parsing ASoC: topology: Check failure to create a widget ASoC: add support for TAS5720 digital amplifier ...
2016-05-27remove lots of IS_ERR_VALUE abusesArnd Bergmann
Most users of IS_ERR_VALUE() in the kernel are wrong, as they pass an 'int' into a function that takes an 'unsigned long' argument. This happens to work because the type is sign-extended on 64-bit architectures before it gets converted into an unsigned type. However, anything that passes an 'unsigned short' or 'unsigned int' argument into IS_ERR_VALUE() is guaranteed to be broken, as are 8-bit integers and types that are wider than 'unsigned long'. Andrzej Hajda has already fixed a lot of the worst abusers that were causing actual bugs, but it would be nice to prevent any users that are not passing 'unsigned long' arguments. This patch changes all users of IS_ERR_VALUE() that I could find on 32-bit ARM randconfig builds and x86 allmodconfig. For the moment, this doesn't change the definition of IS_ERR_VALUE() because there are probably still architecture specific users elsewhere. Almost all the warnings I got are for files that are better off using 'if (err)' or 'if (err < 0)'. The only legitimate user I could find that we get a warning for is the (32-bit only) freescale fman driver, so I did not remove the IS_ERR_VALUE() there but changed the type to 'unsigned long'. For 9pfs, I just worked around one user whose calling conventions are so obscure that I did not dare change the behavior. I was using this definition for testing: #define IS_ERR_VALUE(x) ((unsigned long*)NULL == (typeof (x)*)NULL && \ unlikely((unsigned long long)(x) >= (unsigned long long)(typeof(x))-MAX_ERRNO)) which ends up making all 16-bit or wider types work correctly with the most plausible interpretation of what IS_ERR_VALUE() was supposed to return according to its users, but also causes a compile-time warning for any users that do not pass an 'unsigned long' argument. I suggested this approach earlier this year, but back then we ended up deciding to just fix the users that are obviously broken. After the initial warning that caused me to get involved in the discussion (fs/gfs2/dir.c) showed up again in the mainline kernel, Linus asked me to send the whole thing again. [ Updated the 9p parts as per Al Viro - Linus ] Signed-off-by: Arnd Bergmann <arnd@arndb.de> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Andrew Morton <akpm@linux-foundation.org> Link: https://lkml.org/lkml/2016/1/7/363 Link: https://lkml.org/lkml/2016/5/27/486 Acked-by: Srinivas Kandagatla <srinivas.kandagatla@linaro.org> # For nvmem part Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-05-27Merge remote-tracking branch 'asoc/topic/wm8962' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/rt5677' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/wm8960' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/qcom' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/sti' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/tlv320aic31xx' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/kconfig' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/rt298' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/mtk' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/omap' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/tas5270' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/topology' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/pxa' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/simple' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/twl6040' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/max98371' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/rcar' into asoc-nextMark Brown
2016-05-27Merge remote-tracking branch 'asoc/topic/tlv320aic32x4' into asoc-nextMark Brown
2016-05-25Merge remote-tracking branches 'asoc/fix/ak4642', 'asoc/fix/ep93xx', ↵Mark Brown
'asoc/fix/kirkwood' and 'asoc/fix/twl6040' into asoc-linus
2016-05-23ASoC: kirkwood: fix build failureSudip Mukherjee
While building m32r allmodconfig the build failed with: ERROR: "bad_dma_ops" [sound/soc/kirkwood/snd-soc-kirkwood.ko] undefined! To satisfy the dependency CONFIG_SND_KIRKWOOD_SOC should depend on HAS_DMA. Signed-off-by: Sudip Mukherjee <sudip.mukherjee@codethink.co.uk> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-19Merge tag 'sound-4.7-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound Pull sound updates from Takashi Iwai: "This time was again a relatively calm development cycle; most of updates are about drivers, and no radical changes are seen in any core code. Here are some highlights: ALSA core: - Continued hardening of ALSA hrtimer - A few leak fixes in timer interface - Fix poll error handling in PCM and compress - Add error propagation in compress API - Removal of dead rtctimer driver HD-audio: - Native ELD notify support for i915 HDMI - Realtek ALC234 & co support - Code refactoring to standardize chmap support - Continued development for SKL HDMI core support Firewire: - Apply delayed card registration to all drivers - Improved / stabilized the handling of PCM stream start / stop - Add tracepoints to dump a part of isochronous packet data - Fixed incoming/outgoing packet parameter usages - Add support for M-Audio profire series USB-audio: - Fixes for UAC2 clock source - SS+ support - Workaround for oft-seen repeated sample rate read errors ASoC: - Further slow progress on the topology code - Substantial updates and improvements for the da7219, es8328, fsl-ssi, Intel and rcar drivers. - Compress error handling in WM ADSP driver" * tag 'sound-4.7-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (177 commits) ALSA: firewire-lib: change a member of event structure to suppress sparse wanings to bool type sound: oss: Use setup_timer and mod_timer. ASoC: hdac_hdmi: Remove the unused 'timeout' variable ASoC: fsl_ssi: Fix channel slipping on capture (or playback) restart in full duplex. ASoC: fsl_ssi: Fix channel slipping in Playback at startup ASoC: fsl_ssi: Fix samples being dropped at Playback startup ASoC: fsl_ssi: Save a dev reference for dev_err() purpose. ASoC: fsl_ssi: The IPG/5 limitation concerns the bitclk, not the sysclk. ASoC: fsl_ssi: Real hardware channels max number is 32 ASoC: pcm5102a: Add support for PCM5102A codec ASoC: hdac_hdmi: add link management ASoC: Intel: Skylake: add link management ALSA: hdac: add link pm and ref counting ALSA: au88x0: Fix zero clear of stream->resources ASoC: rt298: Add DMI match for Broxton-P reference platform ASoC: rt298: fix null deref on acpi driver data ASoC: dapm: deprecate MICBIAS widget type ALSA: firewire-lib: drop skip argument from helper functions to queue a packet ALSA: firewire-lib: add context information to tracepoints ALSA: firewire-lib: permit to flush queued packets only in process context for better PCM period granularity ...
2016-05-19Merge tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dmaLinus Torvalds
Pull dmaengine updates from Vinod Koul: "This time round the update brings in following changes: - new tegra driver for ADMA device - support for Xilinx AXI Direct Memory Access Engine and Xilinx AXI Central Direct Memory Access Engine and few updates to this driver - new cyclic capability to sun6i and few updates - slave-sg support in bcm2835 - updates to many drivers like designware, hsu, mv_xor, pxa, edma, qcom_hidma & bam" * tag 'dmaengine-4.7-rc1' of git://git.infradead.org/users/vkoul/slave-dma: (84 commits) dmaengine: ioatdma: disable relaxed ordering for ioatdma dmaengine: of_dma: approximate an average distribution dmaengine: core: Use IS_ENABLED() instead of checking for built-in or module dmaengine: edma: Re-evaluate errors when ccerr is triggered w/o error event dmaengine: qcom_hidma: add support for object hierarchy dmaengine: qcom_hidma: add debugfs hooks dmaengine: qcom_hidma: implement lower level hardware interface dmaengine: vdma: Add clock support Documentation: DT: vdma: Add clock support for dmas dmaengine: vdma: Add config structure to differentiate dmas MAINTAINERS: Update Tegra DMA maintainers dmaengine: tegra-adma: Add support for Tegra210 ADMA Documentation: DT: Add binding documentation for NVIDIA ADMA dmaengine: vdma: Add Support for Xilinx AXI Central Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI CDMA dmaengine: vdma: Add Support for Xilinx AXI Direct Memory Access Engine Documentation: DT: vdma: update binding doc for AXI DMA dmaengine: vdma: Rename xilinx_vdma_ prefix to xilinx_dma dmaengine: slave means at least one of DMA_SLAVE, DMA_CYCLIC dmaengine: mv_xor: Allow selecting mv_xor for mvebu only compatible SoC ...
2016-05-18ASoC: ak4642: Enable cache usage to fix crashes on resumeMark Brown
The ak4642 driver is using a regmap cache sync to restore the configuration of the chip on resume but (as Peter observed) does not actually define a register cache which means that the resume is never going to work and we trigger asserts in regmap. Fix this by enabling caching. Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Reported-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Tested-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Mark Brown <broonie@kernel.org> Cc: stable@vger.kernel.org
2016-05-18ASoC: twl6040: Disconnect AUX output pads on digital mutePeter Ujfalusi
Disconnect also the path to AUXL from the HF path during digital_mute to avoid pop noise leakage to Line-out pads. Signed-off-by: Peter Ujfalusi <peter.ujfalusi@ti.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-17Merge tag 'gpio-v4.7-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for kernel cycle v4.7: Core infrastructural changes: - Support for natively single-ended GPIO driver stages. This means that if the hardware has registers to configure open drain or open source configuration, we use that rather than (as we did before) try to emulate it by switching the line to an input to get high impedance. This is also documented throughly in Documentation/gpio/driver.txt for those of you who did not understand one word of what I just wrote. - Start to do away with the unnecessarily complex and unitelligible ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB, another evolutional artifact from the time when the GPIO subsystem was unmaintained. Archs can now just select GPIOLIB and be done with it, cleanups to arches will trickle in for the next kernel. Some minor archs ACKed the changes immediately so these are included in this pull request. - Advancing the use of the data pointer inside the GPIO device for storing driver data by switching the PowerPC, Super-H Unicore and a few other subarches or subsystem drivers in ALSA SoC, Input, serial, SSB, staging etc to use it. - The initialization now reads the input/output state of the GPIO lines, so that each GPIO descriptor knows - if this callback is implemented - whether the line is input or output. This also reflects nicely in userspace "lsgpio". - It is now possible to name GPIO producer names, line names, from the device tree. (Platform data has been supported for a while). I bet we will get a similar mechanism for ACPI one of those days. This makes is possible to get sensible producer names for e.g. GPIO rails in "lsgpio" in userspace. New drivers: - New driver for the Loongson1. - The XLP driver now supports Broadcom Vulcan ARM64. - The IT87 driver now supports IT8620 and IT8628. - The PCA953X driver now supports Galileo Gen2. Driver improvements: - MCP23S08 was switched to use the gpiolib irqchip helpers and now also suppors level-triggered interrupts. - 74x164 and RCAR now supports the .set_multiple() callback - AMDPT was converted to use generic GPIO. - TC3589x, TPS65218, SX150X, F7188X, MENZ127, VX855, WM831X, WM8994 support the new single ended callback for open drain and in some cases open source. - Implement the .get_direction() callback for a few more drivers like PL061, Xgene. Cleanups: - Paul Gortmaker combed through the drivers and de-modularized those who are not really modules. - Move the GPIO poweroff DT bindings to the power subdir where they belong. - Rename gpio-generic.c to gpio-mmio.c, which is much more to the point. That's what it is handling, nothing more, nothing less" * tag 'gpio-v4.7-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (126 commits) MIPS: do away with ARCH_[WANT_OPTIONAL|REQUIRE]_GPIOLIB gpio: zevio: make it explicitly non-modular gpio: timberdale: make it explicitly non-modular gpio: stmpe: make it explicitly non-modular gpio: sodaville: make it explicitly non-modular pinctrl: sh-pfc: Let gpio_chip.to_irq() return zero on error gpio: dwapb: Add ACPI device ID for DWAPB GPIO controller on X-Gene platforms gpio: dt-bindings: add wd,mbl-gpio bindings gpio: of: make it possible to name GPIO lines gpio: make gpiod_to_irq() return negative for NO_IRQ gpio: xgene: implement .get_direction() gpio: xgene: Enable ACPI support for X-Gene GFC GPIO driver gpio: tegra: Implement gpio_get_direction callback gpio: set up initial state from .get_direction() gpio: rename gpio-generic.c into gpio-mmio.c gpio: generic: fix GPIO_GENERIC_PLATFORM is set to module case gpio: dwapb: add gpio-signaled acpi event support gpio: dwapb: convert device node to fwnode gpio: dwapb: remove name from dwapb_port_property gpio/qoriq: select IRQ_DOMAIN ...
2016-05-17ASoC: hdac_hdmi: Remove the unused 'timeout' variableFabio Estevam
Commit b2047e996cd88d3 ("ASoC: hdac_hdmi: add link management") introuduced the following build warning: sound/soc/codecs/hdac_hdmi.c:1721:16: warning: unused variable 'timeout' [-Wunused-variable] Remove the unused 'timeout' variable. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-16Merge branches 'acpi-pci', 'acpi-misc' and 'acpi-tools'Rafael J. Wysocki
* acpi-pci: ACPI,PCI,IRQ: remove SCI penalize function ACPI,PCI,IRQ: remove redundant code in acpi_irq_penalty_init() ACPI,PCI,IRQ: reduce static IRQ array size to 16 ACPI,PCI,IRQ: reduce resource requirements * acpi-misc: ACPI / sysfs: fix error code in get_status() ACPI / device_sysfs: Clean up checkpatch errors ACPI / device_sysfs: Change _SUN and _STA show functions error return to EIO ACPI / device_sysfs: Add sysfs support for _HRV hardware revision arm64: defconfig: Enable ACPI ACPI / ARM64: Remove EXPERT dependency for ACPI on ARM64 ACPI / ARM64: Don't enable ACPI by default on ARM64 acer-wmi: Use acpi_dev_found() eeepc-wmi: Use acpi_dev_found() ACPI / utils: Rename acpi_dev_present() * acpi-tools: tools/power/acpi: close file only if it is open
2016-05-13Merge remote-tracking branch 'asoc/topic/hdmi' into asoc-nextMark Brown
2016-05-13Merge remote-tracking branches 'asoc/topic/es8328', 'asoc/topic/find-dai', ↵Mark Brown
'asoc/topic/fsl', 'asoc/topic/fsl-sai' and 'asoc/topic/fsl-ssi' into asoc-next
2016-05-13Merge remote-tracking branches 'asoc/topic/davinci' and 'asoc/topic/dwc' ↵Mark Brown
into asoc-next
2016-05-13Merge remote-tracking branches 'asoc/topic/bcm2835', 'asoc/topic/cs42l56', ↵Mark Brown
'asoc/topic/da7213', 'asoc/topic/da7218' and 'asoc/topic/da7219' into asoc-next
2016-05-13Merge remote-tracking branches 'asoc/topic/adsp', 'asoc/topic/ak4624', ↵Mark Brown
'asoc/topic/atmel' and 'asoc/topic/au1x' into asoc-next
2016-05-13Merge remote-tracking branch 'asoc/topic/rt5645' into asoc-nextMark Brown
2016-05-13Merge remote-tracking branch 'asoc/topic/pcm5102' into asoc-nextMark Brown
2016-05-13Merge remote-tracking branch 'asoc/topic/intel' into asoc-nextMark Brown
2016-05-13Merge remote-tracking branch 'asoc/topic/imx' into asoc-nextMark Brown
2016-05-13Merge remote-tracking branch 'asoc/topic/dmaengine' into asoc-nextMark Brown
2016-05-13Merge remote-tracking branches 'asoc/fix/davinci', 'asoc/fix/fsl-ssi', ↵Mark Brown
'asoc/fix/rockchip' and 'asoc/fix/rt286' into asoc-linus
2016-05-13ASoC: fsl_ssi: Fix channel slipping on capture (or playback) restart in full ↵Arnaud Mouiche
duplex. Happened when the Playback (or Capture) is running continuously and Capture (or Playback) is restarted (xrun, manual stop/start...) Since the RX (or TX) FIFO are only reset when the whole SSI is disabled, pending samples from previous capture (or playback) session may still be present. They must be erased to not introduce channel slipping. FIFO Clear register fields are documented in IMX51, IMX35 reference manual. They are not documented in IMX50 or IMX6 RM, despite they are working as expected on IMX6SL and IMX6solo. Signed-off-by: Arnaud Mouiche <arnaud.mouiche@invoxia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Caleb Crome <caleb@crome.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: fsl_ssi: Fix channel slipping in Playback at startupArnaud Mouiche
Previously, SCR.SSIEN and SCR.TE were enabled at once if no capture stream was also running. This may not give a chance for the DMA to write the first sample in TX FIFO before the streaming starts on the PCM bus, inserting void samples first. Those void samples are then responsible for slipping the channels. Signed-off-by: Arnaud Mouiche <arnaud.mouiche@invoxia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Caleb Crome <caleb@crome.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: fsl_ssi: Fix samples being dropped at Playback startupArnaud Mouiche
If the capture is already running while playback is started, it is highly probable (>80% in a 8 channels scenario) that samples are lost between the DMA and TX fifo. The reason is that SIER.TDMAE is set before STCR.TFEN0, leaving a time window where the FIFO doesn't receive the samples written by the DMA. This particular case happened only if capture is already enabled as SCR.SSIEN is already set at the playback startup instant. Signed-off-by: Arnaud Mouiche <arnaud.mouiche@invoxia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Caleb Crome <caleb@crome.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: fsl_ssi: Save a dev reference for dev_err() purpose.Arnaud Mouiche
Most of functions only receive the ssi_private reference and don't have a knowledge of 'dev' pointer, even for debug purpose. Signed-off-by: Arnaud Mouiche <arnaud.mouiche@invoxia.com> Tested-by: Caleb Crome <caleb@crome.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: fsl_ssi: The IPG/5 limitation concerns the bitclk, not the sysclk.Arnaud Mouiche
im6sl reference manual 47.7.4: " Bit clock - Used to serially clock the data bits in and out of the SSI port. This clock is either generated internally (from SSI's sys clock) or taken from external clock source (through the Tx/Rx clock ports). [...] Care should be taken to ensure that the bit clock frequency (either internally generated by dividing the SSI's sys clock or sourced from external device through Tx/Rx clock ports) is never greater than 1/5 of the ipg_clk (from CCM) frequency. " Since, in master mode, the sysclk is a multiple of bitclk, we can easily reach a high sysclk value, whereas keeping a reasonable bitclk. ex: 8ch x 16bit x 48kHz = 6144000, requires a 24576000 sysclk (PM=1) yet ipg_clk/5 = 66Mhz/5 = 13.2 Signed-off-by: Arnaud Mouiche <arnaud.mouiche@invoxia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Caleb Crome <caleb@crome.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: fsl_ssi: Real hardware channels max number is 32Arnaud Mouiche
The max number of slots in TDM mode is 32: - Frame Rate Divider Control is a 5bit value - Time slot mask registers control 32 slots. Signed-off-by: Arnaud Mouiche <arnaud.mouiche@invoxia.com> Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Tested-by: Caleb Crome <caleb@crome.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: tlv320aic32x4: Properly implement the positive and negative pins into ↵Jeremy McDermond
the mixers The TLV320AIC32x4 has a very flexible mixer on the inputs to the ADCs. Each mixer has an available set of available pins that can be connected to the ADC positive and negative pins via three different resistor values. This allows for configuration of differential inputs as well as doing level manipulation between sources going into the mixers. The current code only provides positive pins and I implemented the resistors in an earlier patch. It turns out that it appears to more accurately model what's happening to implement each of the pins as a MUX rather than on/off switches and a mixer. This way each pin can be set to its desired resistor value. Since there are no switches, the mixer is no longer necessary in the DAPM path. I set the DAPM paths such that the "off" position of any of the MUXes turns the path off. This should allow for any input confiuration available on the codec. Signed-off-by: Jeremy McDermond <nh6z@nh6z.net> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: pcm5102a: Add support for PCM5102A codecFlorian Meier
Some definitions to support the PCM5102A codec by Texas Instruments. Signed-off-by: Florian Meier <florian.meier@koalo.de> Changes to original patch by Florian Meier: * rebased (Makefile and Kconfig * fixed checkpath errors (spaces, newlines) * added dt-binding documentation Signed-off-by: Martin Sperl <kernel@martin.sperl.org> Signed-off-by: Mark Brown <broonie@kernel.org>
2016-05-13ASoC: hdac_hdmi: add link managementVinod Koul
Manage the hda idisp link using shiny new link APIs. We need to keep link On while we probe and also hold the reference in runtime resume and drop in suspend Signed-off-by: Jeeja KP <jeeja.kp@intel.com> Signed-off-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Mark Brown <broonie@kernel.org>
