[ Upstream commit a0c426fe143328760c9fd565cd203a37a7b4fde8 ]
We will get DAI ID from "reg" property if it has on DT, otherwise get
it by counting port/endpoint.
But in below case, we need to get DAI ID = 0 via port reg = <0>, but
current implementation returns ID = 1, because it can't judge ID = 0 was
from "non reg" or "reg = <0>".
Thus, it will count port/endpoint number as "non reg" case.
of_graph_parse_endpoint() implementation itself is not a problem,
but because asoc_simple_card_get_dai_id() need to count port/endpoint
number when "non reg" case, it need to know ID = 0 was from
This patch fix this issue.
port {
reg = <0>;
xxxx: endpoint@0 {
=> xxxx: endpoint@1 {
Signed-off-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
commit b6f3fc005a2c8 ("ASoC: simple-card-utils: fixup
asoc_simple_card_get_dai_id() counting") fixuped getting DAI ID method.
It will get DAI ID from OF graph "port", but, we want to consider about
"endpoint", too.
And, we also want to keep compatibility.
This patch fixup it as
if (driver has specified DAI ID)
use it as DAI ID
else if (OF graph endpoint has reg)
use it as DAI ID
else if (OF graph port has reg)
use it as DAI ID
else
use endpoint count as DAI ID
Fixes: commit b6f3fc005a2c8 ("ASoC: simple-card-utils: fixup asoc_simple_card_get_dai_id() counting")
Reported-by: Tony Lindgren <tony@atomide.com>
Tested-by: Tony Lindgren <tony@atomide.com>
When CONFIG_OF is disabled, of_graph_parse_endpoint() does not
initialize 'info', and gcc can see that:
sound/soc/generic/simple-card-utils.c: In function 'asoc_simple_card_parse_graph_dai':
sound/soc/generic/simple-card-utils.c:284:13: error: 'info.port' may be used uninitialized in this function [-Werror=maybe-uninitialized]
It's probably best to check the return code anyway, and that also
takes care of the warning.
Fixes: b6f3fc005a2c ("ASoC: simple-card-utils: fixup asoc_simple_card_get_dai_id() counting")
Acked-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
asoc_simple_card_get_dai_id() returns DAI ID, but it is based on
DT node's "endpoint" position.
Almost all cases 1 port has 1 endpoint, thus, it was no problem.
But in reality, port : endpoint = 1 : N, thus, counting endpoint
is BUG, it should based on "port" ID.
This patch fixup it.
asoc_simple_card_of_parse_routing()
asoc_simple_card_of_parse_routing() had "option" parameter
to consider error handling, but it is very pointless parameter.
Let's remove it.
Current simple-card-utils has asoc_simple_card_parse_convert() to parse
convert channel/rate for be_hw_params_fixup.
But, it is parsing from top of node.
If sound card had multi subnode, we need to parse it from each sub node.
This patch tidyup asoc_simple_card_parse_convert() to allow parsing
settings from each node.
If simple-card-utils accept NULL pointer on asoc_simple_card_xxx(),
each driver code will be more simple.
Let's accept NULL pointer.
asoc_simple_card_clk_register() is used but only 1 user,
and very pointless code. Let's remove it.
To be more readable code, this patch adds
new for_each_card_prelinks() macro, and replace existing code to it.
Now no simple/audio cards are using legacy dai_link style for platform.
Let's remove compatible code.
Current ASoC is supporting snd_soc_dai_link_component for binding,
it is more useful than current legacy style.
Currently only codec is supporting it as multicodec (= codecs).
CPU will support multi style in the future.
We want to have it on Platform too in the future.
If all Codec/CPU/Platform are replaced into snd_soc_dai_link_component
style, we can remove legacy complex style.
This patch supports snd_soc_dai_link_component style
for simple-card-util for platform.
[current]
struct snd_soc_dai_link {
*cpu_name;
*cpu_of_node;
*cpu_dai_name;
*codec_name;
*codec_of_node;
*codec_dai_name;
*codecs;
num_codecs;
*platform_name;
*platform_of_node;
[in the future]
*cpus
num_cpus;
*codecs;
num_codecs;
*platform;
Now no simple/audio cards are using legacy dai_link style for codec.
for simple_card_utils for codec.
[current]
*cpu_name;
*cpu_of_node;
*cpu_dai_name;
*codec_name;
*codec_of_node;
*codec_dai_name;
*codecs;
num_codecs;
*platform_name;
*platform_of_node;
[in the future]
*cpus
num_cpus;
*codecs;
num_codecs;
*platform;
This patch moves headphone and microphone jack detection gpios from
simple-card driver. It is preparing for using this feature from other
drivers.
Signed-off-by: Katsuhiro Suzuki <suzuki.katsuhiro@socionext.com>
'asoc/topic/sta32x', 'asoc/topic/stm32' and 'asoc/topic/sunxi' into asoc-next
ASoC: Fixes for v4.13
A couple of fixes, one for a regression in simple-card introduced during
the merge window that was only reported this week and another for a
regression in registration of ACPI GPIOs.
# gpg: Signature made Thu 31 Aug 2017 12:50:29 BST
# gpg: using RSA key ADE668AA675718B59FE29FEA24D68B725D5487D0
# gpg: issuer "broonie@kernel.org"
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" [unknown]
# gpg: aka "Mark Brown <broonie@debian.org>" [unknown]
# gpg: aka "Mark Brown <broonie@kernel.org>" [unknown]
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" [unknown]
# gpg: aka "Mark Brown <broonie@linaro.org>" [unknown]
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>" [unknown]
# gpg: WARNING: This key is not certified with a trusted signature!
# gpg: There is no indication that the signature belongs to the owner.
# Primary key fingerprint: 3F25 68AA C269 98F9 E813 A1C5 C3F4 36CA 30F5 D8EB
# Subkey fingerprint: ADE6 68AA 6757 18B5 9FE2 9FEA 24D6 8B72 5D54 87D0
Some CPU drivers (e. g. davinci-mcasp) may require the system clock to
be configured as OUT, while there's no good way currently to set
SND_SOC_CLK_OUT in simple-soc driver if the clock is fixed-rate.
This patch makes asoc_simple_card_init_dai() initialize clock to
SND_SOCK_CLK_OUT if explicitly stated in the relevant dts file. This
change is transparent and doesn't change the default behavior.
Signed-off-by: Vitaly Wool <vitaly.wool@konsulko.com>
snd_soc_of_parse_card_name() doesn't return an error if the requested
property isn't present, but silently fails to fill the card name. This can
not be changed, as it is a backwards compatibility measure itself.
We can not rely on the return value of this function alone, but must check
if the card name has been filled sucessfully when deciding to skip the
fallback path, which is in place for existing users.
Fixes: dedfaa1eedc7 (ASoC: simple-card-utils: enable "label" on
asoc_simple_card_parse_card_name)
Signed-off-by: Lucas Stach <l.stach@pengutronix.de>
Fix inconsistent use of of_graph_get_port_parent() where
asoc_simple_card_parse_graph_dai() does of_node_get() before
calling it while other callers do not. We can fix this by
not trashing the node passed to of_graph_get_port_parent().
Let's also make sure the callers have correct refcounts and remove
related incorrect of_node_put() calls for of_for_each_phandle
as that's done by of_phandle_iterator_next() except when
we break out of the loop early.
Let's fix both issues with a single patch to avoid kobject
refcounts getting messed up more if two patches are merged
separately.
Otherwise strange issues can happen caused by memory corruption
caused by too many kobject_del() calls such as:
BUG: sleeping function called from invalid context at
kernel/locking/mutex.c:747
(___might_sleep)
(__mutex_lock)
(mutex_lock_nested)
(kernfs_remove)
(kobject_del)
(kobject_put)
(of_get_next_parent)
(of_graph_get_port_parent)
(asoc_simple_card_parse_graph_dai [snd_soc_simple_card_utils])
(asoc_graph_card_probe [snd_soc_audio_graph_card])
Fixes: 0ef472a973eb ("of_graph: add of_graph_get_port_parent()")
Fixes: 2692c1c63c29 ("ASoC: add audio-graph-card support")
Fixes: 1689333f8311 ("ASoC: simple-card-utils: add asoc_simple_card_parse_graph_dai()")
Reviewed-by: Rob Herring <robh@kernel.org>
Tested-by: Antonio Borneo <borneo.antonio@gmail.com>
Tested-by: Kuninori Morimoto <kuninori.morimoto.gx@renesas.com>
Current simple card drivers are parsing widgets on each own driver
(only simple-card at this point, but will be supported on all drivers)
Encapsulation is one of simple card util's purpose.
Let's add asoc_simple_card_of_parse_widgets for it.
Current simple card drivers are parsing routing on each own driver.
Let's add asoc_simple_card_of_parse_routing for it.
Current simple/audio scu card drivers are supporting same
convert-rate/convert-channels on DT, but doesn't use same function
for it.
Let's add asoc_simple_card_parse_convert/asoc_simple_card_convert_fixup
commit 891caea41746 ("ASoC: simple_card_utils:
add asoc_simple_card_clk_xxx()") added new asoc_simple_card_clk_xxx(),
but, it didn't have EXPORT_SYMBOL_GPL().
This patch adds it. Otherwise, we will get below error
ERROR: "asoc_simple_card_clk_enable" [sound/soc/generic/snd-soc-simple-scu-card.ko] undefined!
ERROR: "asoc_simple_card_clk_disable" [sound/soc/generic/snd-soc-simple-scu-card.ko] undefined!
ERROR: "asoc_simple_card_clk_enable" [sound/soc/generic/snd-soc-simple-card.ko] undefined!
ERROR: "asoc_simple_card_clk_disable" [sound/soc/generic/snd-soc-simple-card.ko] undefined!
ERROR: "asoc_simple_card_clk_enable" [sound/soc/generic/snd-soc-audio-graph-scu-card.ko] undefined!
ERROR: "asoc_simple_card_clk_disable" [sound/soc/generic/snd-soc-audio-graph-scu-card.ko] undefined!
ERROR: "asoc_simple_card_clk_enable" [sound/soc/generic/snd-soc-audio-graph-card.ko] undefined!
ERROR: "asoc_simple_card_clk_disable" [sound/soc/generic/snd-soc-audio-graph-card.ko] undefined!
Current simple-card-utils sets asoc_simple_dai::clk via
asoc_simple_card_parse_clk().
Current simple card drivers are using it directly for
clk_enable/disable.
Let's encapsulate it.
Let's share same debug message for sysclk
Let's share same debug message for DAI Name
Let's share same debug message for DAI format
Let's share same debug message for Card Name
Current asoc_simple_card_parse_daifmt is keeping backward compatibility
for bitmaster/framemaster which didn't use phandle.
The keep compatibility, it is checking prefix length, but it is
too strict. let's loosen it. Otherwise, OF-graph base sound card
which doesn't have prefix can't detect daifmt.
ALSA SoC needs to know connected DAI ID for detecting.
It is not a big problem if device/driver was only for sound,
but getting DAI ID will be difficult if device includes both
Video/Sound, like HDMI.
To solve this issue, this patch adds new snd_soc_get_dai_id() and
its related .of_xlate_dai_id callback on component driver.
In below case, we can handle Sound port (= port@2) as ID = 0
if .of_xlate_dai_id has its support.
hdmi {
port@0 { /* VIDEO */ };
port@1 { /* VIDEO */ };
port@2 { /* SOUND */ };
simple-card already has asoc_simple_card_parse_dai(),
but graph base parsing needs graph specific version of it.
Current asoc_simple_card_parse_card_name() detects [prefix]name,
but in generally, we uses "label" for user visible names.
This patch enables it.
The clock needs to be stored in the simple_dai structure, so it can
be enabled later on. This has been broken during the conversion to use
devm_* functions for the clk lookup.
Fixes: e984fd61e860 (ASoC: simple-card: use devm_get_clk_from_child())
Current simple-card-utils is getting clk by of_clk_get(), but didn't call
clk_free(). Now we can use devm_get_clk_from_child() for this purpose.
Let's use it.
simple_card_utils was created as simple_card_core in 1st prototype,
and current code still have it. Let's tidyup
Remove cpu/codec pointer check from asoc_simple_card_canonicalize_dailink()
This is verbose check, and will be issue if CPU name was created by
fmt_single_name() on simple-scu-card.c.
see also asoc_simple_card_canonicalize_cpu()
simple-card needs to decrease the reference count of the device nodes.
This patch makes this method simple style standard.
simple-card needs remove dai_link->cpu_dai_name if it CPU was
single DAI.
simple-card is assuming that sometimes platform and cpu are same.
simple-card is supporting clock/tdm slot initialization.
simple-card needs to get its dai name and endpoint node.
This patch makes it simple style standard
Current simple-card can get clock via DT clocks or
"system-clock-frequency" property.
simple-card-utils might be used as module, but MODULE_xxx()
information was missed. This patch adds it.
Otherwise, we will have below error, and can't use it.
Specil thanks to Kevin.
> insmod simple-card-utils.ko
simple_card_utils: module license 'unspecified' taints kernel.
Disabling lock debugging due to kernel taint
simple_card_utils: Unknown symbol snd_soc_of_parse_daifmt (err 0)
simple_card_utils: Unknown symbol snd_soc_of_parse_card_name (err 0)
insmod: can't insert 'simple-card-utils.ko': \
unknown symbol in module, or unknown parameter
Reported-by: Kevin Hilman <khilman@baylibre.com>
simple-card needs to get its card name.
Current simple-card is creating dai_link->name / dai_link->stream_name.
These are based on CPU + Codec name, or "fe.CPU" or "be.Codec" if it
was DPCM.
This patch adds asoc_simple_card_set_dailink_name() and set dailink
name as common method.
Current ALSA SoC has simple-card driver which is supporting both
platform and DT probe.
Now, some sound cards driver are created based on simple-card.
They have similar feature or function, but implemented separately
on each drivers. This is a waste of code.
OTOH, merging these driver into same driver is highly risk,
because it will be very difficult to keep compatibility.
More over, ALSA SoC want to have graph base of DT feature in the
future. Maybe it want to use simple-card like feature / function.
Because of these background, this patch creates simple-card
helper utils, and provides common function to each drivers.
1st is asoc_simple_card_parse_daifmt()
