path: root/sound/soc/codecs/wm8900.h
2008-12-10ASoC: Convert WM8900 to do more work at I2C probe timeMark Brown
Redo the instantiation of the WM8900 to do most of the initialisation work when the I2C driver probes rather than when the ASoC device is instantiated, registering the codec with the ASoC core when done. Also move all dynamic allocations into a single kmalloc() to simplify error handling and rename the I2C driver to make output more sensible. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2008-10-16ALSA: ASoC: Convert wm8900 to a new-style i2c driverJean Delvare
Convert the wm8900 codec driver to the new (standard) device driver binding model. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2008-08-06ALSA: ASoC: Add WM8900 CODEC driverMark Brown
The WM8900 is designed for portable multimedia applications requiring low power consumption, high performance audio and a compact form factor providing: - 24 bit stereo ADC and DAC - Microphone and line inputs - Line outputs - Class G headphone amplifier Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Jaroslav Kysela <perex@perex.cz>
