The DAPM widgets are now insntantiated by the core when creating the card
so there is no need for the individual CODEC drivers to do so.
snd_soc_init_card() is always called as the last part of the CODEC probe
function so we can factor it out into the core card setup rather than
have each CODEC replicate the code to do the initialiastation. This will
be required to support multiple CODECs per card.
The PM core will grow pm_link infrastructure in 2.6.33 which can be
used to implement the intended functionality of the ASoC-specific
device suspend and resume callbacks so drop them.
Fix a couple of typos and a missing header file inclusion to build wm8711.c
properly with CONFIG_SPI_MASTER.
Coding style changes only.
The WM8711 or WM8711L (WM8711/L) is a low power stereo DAC with an
integrated headphone driver. The WM8711/L is designed specifically for
portable MP3 audio and speech players. The WM8711/L is also ideal for
MD, CD machines and DAT players.
Signed-off-by: Mike Arthur <Mike.Arthur@wolfsonmicro.com>
