There is no code enabling DMIC clock in systems that don't provide platform
data for rt5640 after commit 71d97a794301 ("ASoC: rt5640: Use the platform
data for DMIC settings").
I think it's worth to keep this static DMIC clock and alternative data pin
setting during probe time. For making possible to use DMIC from ACPI probed
machine (prior ACPI 5.1 with _DSD) this patch moves DMIC configuration to
new exported rt5640_dmic_enable() that machine drivers can call.
Please note, this patch moves DMIC configuration from i2c probe to codec
probe in case platform data for rt5640 is set.
Signed-off-by: Jarkko Nikula <jarkko.nikula@linux.intel.com>
Cc: Oder Chiou <oder_chiou@realtek.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
support
The patch adds the function of the PLL clock calculation to RL6231 shared
support.
Signed-off-by: Oder Chiou <oder_chiou@realtek.com>
Signed-off-by: Mark Brown <broonie@linaro.org>
This patch correct rt5640's device ID
Signed-off-by: Bard Liao <bardliao@realtek.com>
We have been using rt5640.c codec driver with RT5642 codec chip before commit
022d21f004c1 ("ASoC: rt5640: add rt5639 support"). That commits starts using
device ID reading in reset register for adding device specific controls and
routes runtime.
Now since device ID appears to be different between RT5640 and RT5642 the
driver doesn't add those controls and routes that are valid also on RT5642.
Fix this by adding a device ID found by debugging and minimal code for
supporting RT5642.
This patch adds the rt5639 support
The patch removes the unused field in private data.
The patch removes the unused or incorrect setting of clock source.
This patch adds the ALC5640 codec driver.
