path: root/sound/soc/codecs/rt5631.c
2012-01-02ASoC: Convert rt5631 to devm_kzalloc()Axel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-02ASoC: Drop unused state parameter from CODEC suspend callbackLars-Peter Clausen
The existence of this parameter is purely historical. None of the CODEC drivers uses it and we always pass in the same value anyway, so it should be safe to remove it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-27ASoC: Remove unneeded platform_device.h inclusions from CODECsMark Brown
They've not been needed for a long time if they were ever required. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: Constify snd_soc_dai_ops structsLars-Peter Clausen
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure") introduced the possibility to have constant DAI ops structures, yet this is barley used in both existing drivers and also new drivers being submitted, although none of them modifies its DAI ops structure. The later is not surprising since existing drivers are often used as templates for new drivers. So this patch just constifies all existing snd_soc_dai_ops structs to eliminate the issue altogether. The patch was generated with the following coccinelle semantic patch: // <smpl> @@ identifier ops; @@ -struct snd_soc_dai_ops ops = +const struct snd_soc_dai_ops ops = { ... }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-20ASoC: rt5631: fix DB_RANGE sizeClemens Ladisch
Give the correct number of entries to TLV_DB_RANGE_HEAD to prevent the last entry from being omitted. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2011-10-20ASoC: rt5631: Remove unused codec field from struct rt5631_privAxel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-09-30ASoC: Remove unused function check_vdac_to_outmix from rt5631Mark Brown
2011-09-30ASoC: Staticise non-exported symbols in rt5631Mark Brown
2011-09-23ASoC: Staticize rt5631_daiAxel Lin
2011-09-21ASoC: Add driver for rt5631johnnyhsu@realtek.com
Signed-off-by: Johnny Hsu <johnnyhsu@realtek.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
