path: root/sound/soc/codecs/lm4857.c
2012-02-04ASoC: core: Add support for DAI and machine kcontrols.Liam Girdwood
Currently ASoC can only add kcontrols using codec and platform component device handles. It's also desirable to add kcontrols for DAIs (i.e. McBSP) and for SoC card machine drivers too. This allows the kcontrol to have a direct handle to the parent ASoC component DAI/SoC Card/Platform/Codec device and hence easily get it's private data. This change makes snd_soc_add_controls() static and wraps it in the folowing calls (card and dai are new) :- snd_soc_add_card_controls() snd_soc_add_codec_controls() snd_soc_add_dai_controls() snd_soc_add_platform_controls() This patch also does a lot of small mechanical changes in individual codec drivers to replace snd_soc_add_controls() with snd_soc_add_codec_controls(). It also updates the McBSP DAI driver to use snd_soc_add_dai_controls(). Finally, it updates the existing machine drivers that register controls to either :- 1) Use snd_soc_add_card_controls() where no direct codec control is required. 2) Use snd_soc_add_codec_controls() where there is direct codec control. In the case of 1) above we also update the machine drivers to get the correct component data pointers from the kcontrol (rather than getting the machine pointer via the codec pointer). Signed-off-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-27ASoC: Convert lm4857 to devm_kzalloc()Axel Lin
Signed-off-by: Axel Lin <axel.lin@gmail.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-10-06ASoC: Remove references to linux@wolfsonmicro.comMark Brown
2011-03-07ASoC: neo1973_wm8753: Move lm4857 specefic code to its own moduleLars-Peter Clausen
This patch moves the code for the lm4857 AMP from the neo1973_wm8753 sound board driver to its own module. The lm4857 is a generic AMP IC and not specific to the neo1973. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
