path: root/sound/soc/codecs/cs42l73.c
2015-08-30Merge remote-tracking branches 'asoc/topic/tas2552', 'asoc/topic/tas5086', ↵Mark Brown
'asoc/topic/tegra', 'asoc/topic/tlv' and 'asoc/topic/topology' into asoc-next
2015-08-30Merge remote-tracking branches 'asoc/topic/cs42l56', 'asoc/topic/cs42l73', ↵Mark Brown
'asoc/topic/cs4349' and 'asoc/topic/da732x' into asoc-next
2015-08-14ASoC: cs42l73: Use case range at appropriate placeAxel Lin
The readable registers are in continuous ranges: 0x01 ~ 0x03, 0x05 ~ 0x5f. Use case range syntax makes the code shorter with better readability when we have a large number of continuous switch cases. No functional change with this patch. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-08-05ASoC: cs42l73: Replace TLV_DB_RANGE_HEAD with DECLARE_TLV_DB_RANGELars-Peter Clausen
DECLARE_TLV_DB_RANGE() has the advantage over using TLV_DB_RANGE_HEAD() that it automatically calculates the number of items in the TLV and is hence less prone to manual error. Generate using the following coccinelle script // <smpl> @@ declarer name DECLARE_TLV_DB_RANGE; identifier tlv; constant x; @@ -unsigned int tlv[] = { - TLV_DB_RANGE_HEAD(x), +DECLARE_TLV_DB_RANGE(tlv, ... -}; +); // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-23ASoC: cs42l73: Fix mask for setting CS42L73_SP_3ST bitAxel Lin
CS42L73_SP_3ST is BIT(7), so the mask field is wrong. Fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-07-15ASoC: drivers: Drop owner assignment from i2c_driverKrzysztof Kozlowski
i2c_driver does not need to set an owner because i2c_register_driver() will set it. Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-06-01ASoC: cs42l73: Replace direct snd_soc_codec dapm field accessLars-Peter Clausen
The dapm field of the snd_soc_codec struct is eventually going to be removed, in preparation for this replace all manual access to codec->dapm.bias_level with snd_soc_codec_get_bias_level(). Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-04-27ASoC: Move bias level update to the coreLars-Peter Clausen
All drivers have the same line at the end of the set_bias_level callback to update the bias_level state. Move this update into snd_soc_dapm_force_bias_level() and remove them from the drivers. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-01-05ASoC: cs42l73: Constify struct regmap_config and snd_soc_codec_driverKrzysztof Kozlowski
The regmap_config struct may be const because it is not modified by the driver and regmap_init() accepts pointer to const. Make struct snd_soc_codec_driver const as well (snd_soc_register_codec() accepts pointer to const). Signed-off-by: Krzysztof Kozlowski <k.kozlowski@samsung.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-11-21ASoC: cs42l73: Replace w->codec snd_soc_dapm_to_codec(w->dapm)Lars-Peter Clausen
The codec field of the snd_soc_widget struct is eventually going to be removed, use snd_soc_dapm_to_codec(w->dapm) instead. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-09-09ASoC: cs42l73: Cleanup manual bias level transitionsLars-Peter Clausen
Set the CODEC driver's suspend_bias_off flag rather than manually going to SND_SOC_BIAS_OFF in suspend and SND_SOC_BIAS_STANDBY in resume. This makes the code a bit shorter and cleaner. Since the ASoC core now takes care of setting the bias level to SND_SOC_BIAS_OFF when removing the CODEC there is no need to do it manually anymore either. The manual transition to SND_SOC_BIAS_STANDBY at the end of CODEC probe() can also be removed as the core will automatically do this after the CODEC has been probed. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-08-04Merge remote-tracking branches 'asoc/topic/omap', 'asoc/topic/oom' and ↵Mark Brown
'asoc/topic/pxa' into asoc-next
2014-07-17ASoC: Fix SOC_DOUBLE_R_SX_TLV volume mixer argumentsBrian Austin
Remove unnecessary bit shifts. Correct min value to match datasheet. Num steps = number of steps between min and max. Reported-by: Ryan Harvey <ryan.harvey@cirrus.com> Signed-off-by: Ryan Harvey <ryan.harvey@cirrus.com> Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-06-27ASoC: cs42l73: Remove redundant OOM messageSachin Kamat
Let memory subsystem handle the error logging. Signed-off-by: Sachin Kamat <sachin.kamat@samsung.com> Acked-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-04-18ASoC: cs42l73: Convert to use devm_gpio_request_oneAxel Lin
Current code missed a gpio_free() call in cs42l73_i2c_remove(). Convert to use devm_gpio_request_one() to fix it. Signed-off-by: Axel Lin <axel.lin@ingics.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-03-23Merge tag 'asoc-v3.15-2' into asoc-nextMark Brown
ASoC: Updates for v3.15 This is mostly a few additional fixes from Lars-Peter, a new driver and cleaning up a git failure with merging the Intel branch (combined with an xargs failure to pay attention to error codes). The history lists a bunch of additional commits for the branch but the content of those commits is actually present already but not recorded in history due to git failing. Unfortunately xargs is used in the merge script and it doesn't do a good job of noticing errors from the commands it invokes. # gpg: Signature made Thu 13 Mar 2014 14:25:44 GMT using RSA key ID 7EA229BD # gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" # gpg: aka "Mark Brown <broonie@debian.org>" # gpg: aka "Mark Brown <broonie@kernel.org>" # gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" # gpg: aka "Mark Brown <broonie@linaro.org>" # gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
2014-03-23Merge tag 'asoc-v3.15' into asoc-nextMark Brown
ASoC: Updates for v3.15 Quite a busy release for ASoC this time, more on janitorial work than exciting new features but welcome nontheless: - Lots of cleanups from Takashi for enumerations; the original API for these was error prone so he's refactored lots of code to use more modern APIs which avoid issues. - Elimination of the ASoC level wrappers for I2C and SPI moving us closer to converting to regmap completely and avoiding some randconfig hassle. - Provide both manually and transparently locked DAPM APIs rather than a mix of the two fixing some concurrency issues. - Start converting CODEC drivers to use separate bus interface drivers rather than having them all in one file helping avoid dependency issues. - DPCM support for Intel Haswell and Bay Trail platforms. - Lots of work on improvements for simple-card, DaVinci and the Renesas rcar drivers. - New drivers for Analog Devices ADAU1977, TI PCM512x and parts of the CSR SiRF SoC. # gpg: Signature made Wed 12 Mar 2014 23:05:45 GMT using RSA key ID 7EA229BD # gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>" # gpg: aka "Mark Brown <broonie@debian.org>" # gpg: aka "Mark Brown <broonie@kernel.org>" # gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>" # gpg: aka "Mark Brown <broonie@linaro.org>" # gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
2014-03-18ASoC: cs42l73: Fix mask bits for SOC_VALUE_ENUM_SINGLEBrian Austin
The mask bits values were wrong for the SOC_VALUE_ENUM_SINGLE for the mono mix controls. Reported-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org> Cc: stable@vger.kernel.org
2014-03-13Merge remote-tracking branch 'asoc/topic/io' into asoc-nextMark Brown
2014-03-11ASoC: codec: Simplify ASoC probe code.Xiubo Li
For some CODEC drivers like who act as the MFDs children are ignored by this patch. Signed-off-by: Xiubo Li <Li.Xiubo@freescale.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-23ASoC: cs42l73: Use SOC_ENUM_SINGLE_DECL()Takashi Iwai
Just replace with the helper macro. No functional change at all. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Liam Girdwood <liam.r.girdwood@linux.intel.com> Acked-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-07ASoC: cs42l73: Constify rate constraintsLars-Peter Clausen
The rate constraints in this driver are shared between all device instances. It should not be (and is not) modified at runtime, so make them const. While we are at it also change the type for the rates array from u32 to unsigned int. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-05ASoC: cs42l73: Don't mix SNDRV_PCM_RATE_KNOT with specific ratesLars-Peter Clausen
SNDRV_PCM_RATE_KNOT means that the device can support rates that can not be expressed using the rate bits. The driver will provide a list of those rates specified through constraints. Any rate bits that are set in the rates mask will be ignored. So setting other rate bits besides SNDRV_PCM_RATE_KNOT wont have any effect, but might be confusing to the casual reader, so remove them. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-20ASoC: cs42l73: Add Device Tree support for CS42L73Brian Austin
This patch adds support for device tree for the CS42L73 CODEC Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-18ASoC: cs42l73: Namespace defines for cs42l73 codecBrian Austin
Cleanup to namespace the defines for the cs42l73 driver Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-10-18ASoC: cs42l73: Add platform data support for cs42l73 codecBrian Austin
Add support for RST GPIO and Charge Pump Freq in platform data Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-03-06ASoC: cs42l73: If Internal MCLK is >= 6.4MHz, then set SCLK to 64*Fs.Paul Handrigan
Signed-off-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-15Merge remote-tracking branch 'asoc/topic/cs42l73' into asoc-nextMark Brown
2012-12-10ASoC: cs42l73: Change VSPIN/VSPOUT to VSPINOUTPaul Handrigan
Since VSP only has one power bit, only provide one DAPM widget. Signed-off-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: cs42l73: Add DAPM events for power down.Paul Handrigan
Add power down delays between setting PDN and MCLKDIS for spk amp, spklo amp, and ear amp. Signed-off-by: Paul Handrigan <Paul.Handrigan@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-12-10ASoC: cs42l73: Add DMIC's as DAPM inputs.Paul Handrigan
2012-12-10ASoC: codecs: remove __dev* attributesBill Pemberton
CONFIG_HOTPLUG is going away as an option. As result the __dev* markings will be going away. Remove use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit. Signed-off-by: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-06-05ASoC: cs42l73: Convert to devm_regmap_init_i2c()Brian Austin
Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-21Merge branch 'topic/asoc' into for-linusTakashi Iwai
2012-05-13Merge tag 'v3.4-rc7' into for-3.5Mark Brown
Linux 3.4-rc7 Conflicts): drivers/base/regmap/regmap.c (overlap with bug fixes) sound/soc/blackfin/bf5xx-ssm2602.c (overlap with bug fixes)
2012-05-11ASoC: cs42l73: Sync digital mixer kcontrols to allow for 0dBBrian Austin
Some of the Digital mixer kcontrol max values were off by 1 not allowing a max of 0dB. Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: stable@vger.kernel.org
2012-05-09ASoC: cs42l73: Use DAPM routes to hook AIF widgets to DAI'sBrian Austin
2012-05-09ASoC: cs42l73: Remove Chip ID's from reg_defaultBrian Austin
We need to read the real register values Signed-off-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-05-09ASoC: cs42l73: Convert to module_i2c_driver()Brian Austin
2012-04-13ASoC: cs42l73: don't use negative array indexJesper Juhl
If cs42l73_get_mclkx_coeff() returns < 0 (which it can) in sound/soc/codecs/cs42l73.c::cs42l73_set_mclk(), then we'll be using the (negative) return value as array index on the very next line of code - that's bad. Catch the negative return value and propagate it to the caller (which checks for it) and things are a bit more sane :-) Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-04ASoC: codecs: Remove rtd->codec usage from CODEC driversMark Brown
In order to support CODEC<->CODEC links remove the assumption that there is only a single CODEC on a DAI link by removing the use of the CODEC pointer in the rtd from the CODEC drivers. They are already being passed their DAI whenever they are passed an rtd and can get the CODEC from there. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-04-03ASoC: core: Rework SOC_DOUBLE_R_SX_TLV add SOC_SINGLE_SX_TLVBrian Austin
Some codecs namely Cirrus Logic Codecs have a way of wrapping the dB scale around 0dB without 0dB being in the middle. Rework of SOC_DOUBLE_R_SX_TLV to be more consistent with other asoc tlv macros. Add single register macro : SOC_SINGLE_SX_TLV. Use snd_soc_info_volsw for .info Use snd_soc_get_volsw_sx, snd_soc_put_volsw_sx for single and double. kcontrols for CS42L51 and CS42L73 are adjusted to these new TLV Macros. The max value is determined by: (number of steps) +1 for 0dB +max from codec datasheet. Signed-off-by: Brian Austin <brian.austin@cirrus.com> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-02-01ASoC: cs42l73: Fix Output [X|A|V]SP_SCLK Sourcing Mode setting for master modeAxel Lin
For master mode, set Output [X|A|V]SP_SCLK Sourcing Mode to MCLK Mode. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-12-02ASoC: Drop unused state parameter from CODEC suspend callbackLars-Peter Clausen
The existence of this parameter is purely historical. None of the CODEC drivers uses it and we always pass in the same value anyway, so it should be safe to remove it. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Acked-by: Liam Girdwood <lrg@ti.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-29ASoC: cs42l73: Fix clear wrong bits in cs42l73_set_dai_fmtAxel Lin
What we want is to clear BIT[5:4](PCM_MODE_MASK) and BIT[3](PCM_BIT_ORDER) bits, but current code clears BIT[2:0]. Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-28ASoC: Convert CS42L73 to devm_kzalloc()Brian Austin
2011-11-23ASoC: Cleanup duplicated constLars-Peter Clausen
Commit 85e7652("ASoC: Constify snd_soc_dai_ops structs") accidentally introduced a few duplicated consts. This patch cleans it up. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: Constify snd_soc_dai_ops structsLars-Peter Clausen
Commit 1ee46ebd("ASoC: Make the DAI ops constant in the DAI structure") introduced the possibility to have constant DAI ops structures, yet this is barley used in both existing drivers and also new drivers being submitted, although none of them modifies its DAI ops structure. The later is not surprising since existing drivers are often used as templates for new drivers. So this patch just constifies all existing snd_soc_dai_ops structs to eliminate the issue altogether. The patch was generated with the following coccinelle semantic patch: // <smpl> @@ identifier ops; @@ -struct snd_soc_dai_ops ops = +const struct snd_soc_dai_ops ops = { ... }; // </smpl> Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-23ASoC: Staticise and constify cs42l73_reg_defaultsMark Brown
It's not exported and doesn't need to change. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2011-11-22ASoC: cs42l73: Make inv and format to be unsigned intAxel Lin
Fix below smatch warning: sound/soc/codecs/cs42l73.c +1030 cs42l73_set_dai_fmt(53) error: inv is never equal to 1024 (wrong type 0 - 255). sound/soc/codecs/cs42l73.c +1032 cs42l73_set_dai_fmt(55) error: inv is never equal to 768 (wrong type 0 - 255). sound/soc/codecs/cs42l73.c +1036 cs42l73_set_dai_fmt(59) error: inv is never equal to 1024 (wrong type 0 - 255). Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Axel Lin <axel.lin@gmail.com> Acked-by: Brian Austin <brian.austin@cirrus.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
