'asoc/topic/atmel' and 'asoc/topic/au1x' into asoc-next
The bits in the ARIZONA_CLOCK_CONTROL register only respond to writes of
a '1', a write of '0' is ignored. So there's no need to use update_bits.
We can do a simple write to set bits.
Signed-off-by: Richard Fitzgerald <rf@opensource.wolfsonmicro.com>
Signed-off-by: Mark Brown <broonie@kernel.org>
When setting up an FLL in pseudo-fractional mode it is preferred
to use a lower FRATIO if possible to give a higher reference clock
frequency. This patch swaps the two loops in arizona_calc_fratio()
so that lower FRATIOs are tried first. The decrementing loop is also
changed to start from init_ratio because the original settings might
already give a fractional value for N.K
The thermal warning IRQs for the speaker are requested in CODEC probe
but never freed. This patch frees them in CODEC remove.
Signed-off-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
The CS47L24 and WM1831 codecs only use the OUT4L widget so we can
skip creation of the OUT4R widget.
'asoc/topic/ads117x', 'asoc/topic/adsp' and 'asoc/topic/arizona' into asoc-next
The debug logging of FLL calculations was confusing. Values were
printed in hex without indicating this by a leading 0x, and
despite these normally being required in decimal. Also where the
register value isn't the actual value (it s a power-of-two or
0 means 1, 1 means 2, ...) it was unclear whether the actual or
register value was shown.
This patch changes the log print so that all mathematical values
are shown in decimal, all register values are shown in hex with a
0x prefix, and where the register value isn't the actual integer
value the decimal integer value is shown in () after the hex
register value.
When the FLL is in pseudo-fractional mode there is an additional
limit on fref based on the fratio, to prevent aliasing around the
Nyquist frequency. If fref exceeds this limit the refclk divider
must be increased and the calculation tried again until a suitable
combination of fref and fratio is found or we have to fall back to
integer mode.
This patch also adds some debug log prints around this code.
The Arizona CODECs support several rates that do not have simple defines
in ALSA. This patch adds support for SNDRV_PCM_RATE_KNOT so that users
can open stream at these rates. As part of this we should always set
constraints in arizona_startup, currently we only set the constraints if
we already have a clock to limit rates to that family of sample rates.
This patch updates this to set a constraint of all rates supported by
the chip if we do not already know which family of rates to limit to.
Finally we also reduce the list of rates supported in the constraints to
only include those that are supported on current parts.
ASoC: Updates for v4.5
This is quite a busy release on the driver front with a lot of new
drivers being added but comparatively quiet on the core side with only
one big change going in and that a fairly straightforward refactoring.
- Conversion of the array of DAI links to a list by Mengdong Lin,
supporting dynamically adding and removing DAI links.
- Some more fixes for the topology code, though it is still not final
and ready for enabling in production. We really need to get to the
point where that can be done.
- A pile of changes for Intel SkyLake drivers which hopefully deliver
some useful initial functionality for systems with this chipset,
though there is more work still to come.
- New drivers for a number of Imagination Technologies IPs.
- Lots of new features and cleanups for the Renesas drivers.
- ANC support for WM5110.
- New driver for Atmel class D speaker drivers.
- New drivers for Cirrus CS47L24 and WM1831.
- New driver for Dialog DA7128.
- New drivers for Realtek RT5659 and RT56156.
- New driver for Rockchip RK3036.
- New driver for TI PC3168A
# gpg: Signature made Wed 23 Dec 2015 00:42:40 GMT using RSA key ID 5D5487D0
# gpg: Good signature from "Mark Brown <broonie@sirena.org.uk>"
# gpg: aka "Mark Brown <broonie@debian.org>"
# gpg: aka "Mark Brown <broonie@kernel.org>"
# gpg: aka "Mark Brown <broonie@tardis.ed.ac.uk>"
# gpg: aka "Mark Brown <broonie@linaro.org>"
# gpg: aka "Mark Brown <Mark.Brown@linaro.org>"
# gpg: WARNING: This key is not certified with a trusted signature!
# gpg: There is no indication that the signature belongs to the owner.
# Primary key fingerprint: 3F25 68AA C269 98F9 E813 A1C5 C3F4 36CA 30F5 D8EB
# Subkey fingerprint: ADE6 68AA 6757 18B5 9FE2 9FEA 24D6 8B72 5D54 87D0
commit 9b8ef9f6b3fc ("ASoC: dapm: Add startup & shutdown for dai_links")
Added support for calling startup on CODEC to CODEC links, however this
is called with a NULL runtime pointer. There isn't really a sensible way
to pass a valid runtime pointer to a CODEC to CODEC link at the moment,
so we need to make the startup function safe for NULL runtimes.
This patch returns from the Arizona startup function early if there is no
runtime, this is perfectly safe as all the startup function does is set
the PCM constraints for user-space which arn't relevant to a CODEC to
CODEC link anyway.
For a sample rate of 12kHz the bclk was taken from the 44.1kHz table as
we test for a multiple of 8kHz. This patch fixes this issue by testing
for multiples of 4kHz instead.
Signed-off-by: Nikesh Oswal <Nikesh.Oswal@cirrus.com>
Cc: stable@vger.kernel.org
This patch rearranges the switch statement in arizona_calc_fratio so
that older codecs are the special cases, with the default case
applying to newer codecs (WM8998 and later). This is preferable
because it avoids having to patch new cases in every time a new
codec is added.
Both the sysclk and asyncclk members of arizona_priv are signed by we
refer to them through an unsigned pointer. This patch fixes this small
harmless error.
The core expects "const char * const" and "unsigned int" for enum
controls, various places in Arizona use "const char *" and "int".
This patch corrects the type of these arrays.
When switching between two clock sources using the FLL freerun to smooth
the transition we should wait 32uS after putting the FLL into freerun
before we proceed. In practice we appear to be getting enough delay from
the surrounding code, but better to make it explicit.
The wm5110 device contains a hardware ANC block, this patch connects up
controls and routing for this.
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-arizona
The code was able to generate illegal OPCLK_REF values because the
reference frequency tables listed all values of SYSCLK instead of
valid values for OPCLK_REF clock. The maximum OPCLK_REF clock is
49.152MHz or 45.1584MHz.
We will occasionally require to take different action based on if an
input is analog or digital so add a helper function to return if an
input is analog.
Since the addition of the WILL_PMU / WILL_PMD several of the switches in
arizona.c no longer cover all cases or have a default case. Whilst this
isn't causing any problems in the interests of robustness add default
cases.
'asoc/topic/rl6231', 'asoc/topic/rockchip' and 'asoc/topic/rt286' into asoc-next
'asoc/topic/ak4542', 'asoc/topic/arizona' and 'asoc/topic/atmel' into asoc-next
The extcon driver takes the DAPM mutex from within the interrupt thread
in several places, which makes it possible to get into a situation where
the interrupt thread is blocked waiting on the DAPM mutex whilst a DAPM
sequence is running which is attempting to configure the FLL. In this
case the FLL completion can't be completed as as the IRQ handler is
ONE_SHOT, which cause the FLL lock to use the full time out (250mS) and
report that the process timed out.
It is not really practical to make the extcon driver not take the DAPM
mutex from within the interrupt thread, at least not without extensive
modification. So this patch fixes the issue by switching the wait for
the FLL lock to polling. A few fast polls are done first as the FLL
should lock quickly for a good quality reference clock, (indeed it hits
on the first poll on my system) and it will poll every 20mS after that
until it times out.
The wrong register was used to set the gain of ref loop, when changing
the FLL output on an active FLL. This patch corrects the offset of the
gain register.
Signed-off-by: Nikesh Oswal <Nikesh.Oswal@wolfsonmicro.com>
Separate the functionality using sequences of register writes from the
functions that take register defaults. This change renames the arguments
in order to support the extension of reg_sequence to take an optional
delay to be applied after any given register in a sequence is written.
This avoids adding an int to all register defaults, which could
substantially increase memory usage for regmaps with large default tables.
This also updates all the clients of multi_reg_write/register_patch.
Signed-off-by: Nariman Poushin <nariman@opensource.wolfsonmicro.com>
Specifying unstable coefficients for the low/high pass filters can have
a severe impact on the audio. This patchs adds a stability check on the
coefficients written to the low/high pass filter block to prevent this.
Specifying unstable coefficients for the EQ can have a severe impact on
the audio. This patchs adds a stability check on the coefficients
written to the EQ, for this it is necessary to merge the mode control
and the coefficients as some coefficients may only be unstable with a
certain mode setting so it is ideal if these are always updated in sync.
The rate controls are codec-specific, it's not possible to
generically say what the range or the meaning of each control
is (or even if they exist at all) - that depends on the
particular codec.
This is currently being handled for Arizona codecs by putting
an Arizona-specific table of controls inside the wm_adsp driver.
This creates a dependency between wm_adsp and arizona.c, and is an
awkward solution if the ADSP is used in another family of codecs
Fix this by moving the Arizona-specific rate controls into the
Arizona codec drivers.
The WM8997 and WM5102 codecs need to boost DVFS for higher sample rates.
The WM5102 and WM8997 codecs have an internal dynamic clock booster.
When this booster is active, the DCVDD voltage must be increased.
If all the currently active audio paths can run with the root SYSCLK
we can disable the booster, allowing us to turn down DCVDD voltage
to save power.
Previously this was being done by having the booster enable bit set
as a side-effect of the LDO1 regulator driver, which is unexpected
behaviour of a regulator and not compatible with using an external
regulator. [Originally this was documented as a feature of the internal
LDO -- broonie]
This patch exports functions to handle the booster enable and
DCVDD voltage, with each relevant subsystem flagging whether it can
currently run without the booster. Note that these subsystems are
stateless and none of them are nestable, so there's no need for
reference counting, we only need a simple boolean for each subsystem
of whether their current condition could require the booster or will
allow us to turn the codec down to lower operating power.
The dapm field of the snd_soc_codec struct is eventually going to be
removed, in preparation for this replace all manual access to codec->dapm
with snd_soc_codec_get_dapm().
Acked-by: Charles Keepax <ckeepax@opensource.wolfsonmicro.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc
Pull char/misc driver updates from Greg KH:
"Here's the big char/misc driver patchset for 4.1-rc1.
Lots of different driver subsystem updates here, nothing major, full
details are in the shortlog.
All of this has been in linux-next for a while"
* tag 'char-misc-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/char-misc: (133 commits)
mei: trace: remove unused TRACE_SYSTEM_STRING
DTS: ARM: OMAP3-N900: Add lis3lv02d support
Documentation: DT: lis302: update wakeup binding
lis3lv02d: DT: add wakeup unit 2 and wakeup threshold
lis3lv02d: DT: use s32 to support negative values
Drivers: hv: hv_balloon: correctly handle num_pages>INT_MAX case
Drivers: hv: hv_balloon: correctly handle val.freeram<num_pages case
mei: replace check for connection instead of transitioning
mei: use mei_cl_is_connected consistently
mei: fix mei_poll operation
hv_vmbus: Add gradually increased delay for retries in vmbus_post_msg()
Drivers: hv: hv_balloon: survive ballooning request with num_pages=0
Drivers: hv: hv_balloon: eliminate jumps in piecewiese linear floor function
Drivers: hv: hv_balloon: do not online pages in offline blocks
hv: remove the per-channel workqueue
hv: don't schedule new works in vmbus_onoffer()/vmbus_onoffer_rescind()
hv: run non-blocking message handlers in the dispatch tasklet
coresight: moving to new "hwtracing" directory
coresight-tmc: Adding a status interface to sysfs
coresight: remove the unnecessary configuration coresight-default-sink
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound
Pull sound updates from Takashi Iwai:
"There have been major modernization with the standard bus: in ALSA
sequencer core and HD-audio. Also, HD-audio receives the regmap
support replacing the in-house cache register cache code. These
changes shouldn't impact the existing behavior, but rather
refactoring.
In addition, HD-audio got the code split to a core library part and
the "legacy" driver parts. This is a preliminary work for adapting
the upcoming ASoC HD-audio driver, and the whole transition is still
work in progress, likely finished in 4.1.
Along with them, there are many updates in ASoC area as usual, too:
lots of cleanups, Intel code shuffling, etc.
Here are some highlights:
ALSA core:
- PCM: the audio timestamp / wallclock enhancement
- PCM: fixes in DPCM management
- Fixes / cleanups of user-space control element management
- Sequencer: modernization using the standard bus
HD-audio:
- Modernization using the standard bus
- Regmap support
- Use standard runtime PM for codec power saving
- Widget-path based power-saving for IDT, VIA and Realtek codecs
- Reorganized sysfs entries for each codec object
- More Dell headset support
ASoC:
- Move of jack registration to the card level
- Lots of ASoC cleanups, mainly moving things from the CODEC level to
the card level
- Support for DAPM routes specified by both the machine driver and DT
- Continuing improvements to rcar
- pcm512x enhacements
- Intel platforms updates
- rt5670 updates / fixes
- New platforms / devices: some non-DSP Qualcomm platforms, Google's
Storm platform, Maxmim MAX98925 CODECs and the Ingenic JZ4780 SoC
Misc:
- ice1724: Improved ESI W192M support
- emu10k1: Emu 1010 fixes/enhancement"
* tag 'sound-4.1-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound: (411 commits)
ALSA: hda - set GET bit when adding a vendor verb to the codec regmap
ALSA: hda/realtek - Enable the ALC292 dock fixup on the Thinkpad T450
ALSA: hda - Fix another race in runtime PM refcounting
ALSA: hda - Expose codec type sysfs
ALSA: ctl: fix to handle several elements added by one operation for userspace element
ASoC: Intel: fix array_size.cocci warnings
ASoC: n810: Automatically disconnect non-connected pins
ASoC: n810: Consistently pass the card DAPM context to n810_ext_control()
ASoC: davinci-evm: Use card DAPM context to access widgets
ASoC: mop500_ab8500: Use card DAPM context to access widgets
ASoC: wm1133-ev1: Use card DAPM context to access widgets
ASoC: atmel: Improve machine driver compile test coverage
ASoC: atmel: Add dependency to SND_SOC_I2C_AND_SPI where necessary
ALSA: control: Fix a typo of SNDRV_CTL_ELEM_ACCESS_TLV_* with SNDRV_CTL_TLV_OP_*
ALSA: usb-audio: Don't attempt to get Microsoft Lifecam Cinema sample rate
ASoC: rnsd: fix build regression without CONFIG_OF
ALSA: emu10k1: add toggles for E-mu 1010 optical ports
ALSA: ctl: fill identical information to return value when adding userspace elements
ALSA: ctl: fix a bug to return no identical information in info operation for userspace controls
ALSA: ctl: confirm to return all identical information in 'activate' event
return type of wait_for_completion_timeout is unsigned long not int. An
appropriately named unsigned long is added and the assignment fixed up.
Signed-off-by: Nicholas Mc Guire <hofrat@osadl.org>
arizona_extcon_do_magic does not lend a lot of clarity to the purpose
of the function, and as all the registers used are described in the
datasheet there is no need to obfuscate the code. This patch renames the
function to arizona_extcon_hp_clamp, as it controls clamping on the
headphone output.
Acked-by: Lee Jones <lee.jones@linaro.org>
Signed-off-by: Chanwoo Choi <cw00.choi@samsung.com>
Move parts of linux/mfd/arizona/pdata.h and gpio.h into a new file in
the dt-binding directory for use by device tree bindings. This also
makes gpio.h redundant so remove it in the process.
Acked-by: Mark Brown <broonie@kernel.org>
Acked-by: Rob Herring <robh@kernel.org>
Signed-off-by: Lee Jones <lee.jones@linaro.org>
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/sound into asoc-w-codec
Save a bit of scheduling by coalescing all the output power up delays
into a single delay.
Give the output disable sequence a chance to fully complete, otherwise
there is a danger we may remove the clock before it is finished
resulting in a pop noise. The delay for each output must be cumulative
and these are coalesced into a single delay.
The codec field of the snd_soc_widget struct is eventually going to be
removed, use snd_soc_dapm_to_codec(w->dapm) instead.
'asoc/topic/compress' and 'asoc/topic/cq93vc' into asoc-next
