path: root/sound/pci
2011-07-30Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (430 commits) [media] ir-mce_kbd-decoder: include module.h for its facilities [media] ov5642: include module.h for its facilities [media] em28xx: Fix DVB-C maxsize for em2884 [media] tda18271c2dd: Fix saw filter configuration for DVB-C @6MHz [media] v4l: mt9v032: Fix Bayer pattern [media] V4L: mt9m111: rewrite set_pixfmt [media] V4L: mt9m111: fix missing return value check mt9m111_reg_clear [media] V4L: initial driver for ov5642 CMOS sensor [media] V4L: sh_mobile_ceu_camera: fix Oops when USERPTR mapping fails [media] V4L: soc-camera: remove soc-camera bus and devices on it [media] V4L: soc-camera: un-export the soc-camera bus [media] V4L: sh_mobile_csi2: switch away from using the soc-camera bus notifier [media] V4L: add media bus configuration subdev operations [media] V4L: soc-camera: group struct field initialisations together [media] V4L: soc-camera: remove now unused soc-camera specific PM hooks [media] V4L: pxa-camera: switch to using standard PM hooks [media] NetUP Dual DVB-T/C CI RF: force card hardware revision by module param [media] Don't OOPS if videobuf_dvb_get_frontend return NULL [media] NetUP Dual DVB-T/C CI RF: load firmware according card revision [media] omap3isp: Support configurable HS/VS polarities ... Fix up conflicts: - arch/arm/mach-omap2/board-rx51-peripherals.c: cleanup regulator supply definitions in mach-omap2 vs OMAP3: RX-51: define vdds_csib regulator supply - drivers/staging/tm6000/tm6000-alsa.c (trivial)
2011-07-28Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: sound: oss: rename local change_bits to avoid powerpc bitsops.h definition ALSA: hda - Fix duplicated DAC assignments for Realtek ALSA: asihpi - off by one in asihpi_hpi_ioctl() ALSA: hda - Fix Oops with Realtek quirks with NULL adc_nids ALSA: asihpi - bug fix pa use before init. ALSA: hda - Add support for vref-out based mute LED control on IDT codecs
2011-07-27[media] radio-sf16fmr2: convert to generic TEA575x interfaceOndrej Zary
Convert radio-sf16fmr2 to use generic TEA575x implementation. Most of the driver code goes away as SF16-FMR2 is basically just a TEA5757 tuner connected to ISA bus. The card can optionally be equipped with PT2254A volume control (equivalent of TC9154AP) - the volume setting is completely reworked (with balance control added) and tested. Signed-off-by: Ondrej Zary <linux@rainbow-software.org> Acked-by: Takashi Iwai <tiwai@suse.de> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-07-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tiwai/sound-2.6: (22 commits) ALSA: hda - Cirrus Logic CS421x support ALSA: Make pcm.h self-contained ALSA: hda - Allow codec-specific set_power_state ops ALSA: hda - Add post_suspend patch ops ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PM ALSA: hda - Make sure mute led reflects master mute state ALSA: hda - Fix invalid mute led state on resume of IDT codecs ASoC: Revert "ASoC: SAMSUNG: Add I2S0 internal dma driver" ALSA: hda - Add support of the 4 internal speakers on certain HP laptops ALSA: Make snd_pcm_debug_name usable outside pcm_lib ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parser ASoC: dapm - Add methods to retrieve snd_card and soc_card from dapm context. ASoC: SAMSUNG: Add I2S0 internal dma driver ASoC: SAMSUNG: Modify I2S driver to support idma ASoC: davinci: add missing break statement ASoC: davinci: fix codec start and stop functions ASoC: dapm - add DAPM macro for external enum widgets ASoC: Acknowledge WM8962 interrupts before acting on them ASoC: sgtl5000: guide user when regulator support is needed ASoC: sgtl5000: refactor registering internal ldo ...
2011-07-27ALSA: hda - Fix duplicated DAC assignments for RealtekTakashi Iwai
Copying hp_pins and speaker_pins from line_out_pins may confuse the parser, and it can lead to duplicated initializations for the same pin with a wrong DAC assignment. The problem appears in 3.0 kernel code. Cc: <stable@kernel.org> (for 3.0) Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27ALSA: asihpi - off by one in asihpi_hpi_ioctl()Dan Carpenter
"adapter" is used as an array index in the adapters[] array so the off by one would make us read past the end. 1c073b67979 "ALSA: asihpi - Remove spurious adapter index check" reverted Dan Rosenberg's check that would have prevented the overflow here. Signed-off-by: Dan Carpenter <error27@gmail.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27ALSA: hda - Fix Oops with Realtek quirks with NULL adc_nidsTakashi Iwai
Somce quirk models don't set adc_nids but let the parser filling it. But the recent code has unnecessary NULL-checks of spec->input_mux, and it resulted in NULL dereferences. This patch fixes that regression. Reported-and-tested-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27ALSA: asihpi - bug fix pa use before init.Eliot Blennerhassett
Fixes bug introduced by 1c073b67. Also declare pa local to block in which it is used. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-27ALSA: hda - Add support for vref-out based mute LED control on IDT codecsVitaliy Kulikov
This patch also registers all necessary callbacks to support mute LED only when such control is enabled. And it keeps codec AFG in D0 or D1 state all the time when aggressive power managemnt is enabled for vref-out control (and mute LED) work correctly. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26atomic: use <linux/atomic.h>Arun Sharma
This allows us to move duplicated code in <asm/atomic.h> (atomic_inc_not_zero() for now) to <linux/atomic.h> Signed-off-by: Arun Sharma <asharma@fb.com> Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: David Miller <davem@davemloft.net> Cc: Eric Dumazet <eric.dumazet@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-26ALSA: hda - Cirrus Logic CS421x supportTim Howe
This update includes the changes necessary for supporting the CS421x family of codecs. Previously this file only supported the CS420x family of codecs. This file also contains init verbs to correct several issues in the CS421x hardware. Behavior between the CS421x and CS420x codec families is similar, so several functions have been reused with "if" statements to determine which codec family (CS421x or CS420x) is present. Also, this file will be updated sometime in the near future in order to add support for a system using CS421x that requires mono mix on the speaker output only. [Fix const usages and adaption for new APIs by tiwai] Signed-off-by: Tim Howe <tim.howe@cirrus.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26ALSA: hda - Allow codec-specific set_power_state opsTakashi Iwai
The procedure for codec D-state change may have exceptional cases depending on the codec chip, such as a longer delay or suppressing D3. This patch adds a new codec ops, set_power_state() to override the system default function. For ease of porting, snd_hda_codec_set_power_to_all() helper function is extracted from the default set_power_state() function. As an example, the Conexant codec-specific delay is removed from the default routine but moved to patch_conexant.c. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26ALSA: hda - Add post_suspend patch opsTakashi Iwai
Add a new ops, post_suspend(), which is called after suspend() ops is performed. This is called only in the case of the real PM suspend, and the codec driver can use this for further changing of D-state or clearing the LED, etc. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26ALSA: hda - Make CONFIG_SND_HDA_POWER_SAVE depending on CONFIG_PMTakashi Iwai
It makes little sense to enable power-saving without PM. This removes SND_HDA_NEEDS_RESUME define so that we can use CONFIG_PM in all places. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26ALSA: hda - Make sure mute led reflects master mute stateVitaliy Kulikov
This patch adds checking of mute state on all outputs besides just speakers to calculate the master mute state for mute led support. It also renames and splits the function that does it for better code clarity. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-26ALSA: hda - Fix invalid mute led state on resume of IDT codecsVitaliy Kulikov
Codec state is not restored immediately on resume but on the first access when power-save is enabled. That leads to an invalid mute led state after resume until either sound is played or some control is changed. This patch adds a possibility for a vendor specific patch to restore codec state immediately after resume if required. And it adds code to restore IDT codecs state immediately on resume on HP systems with mute led support. Signed-off-by: Vitaliy Kulikov <Vitaliy.Kulikov@idt.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (43 commits) fs: Merge split strings treewide: fix potentially dangerous trailing ';' in #defined values/expressions uwb: Fix misspelling of neighbourhood in comment net, netfilter: Remove redundant goto in ebt_ulog_packet trivial: don't touch files that are removed in the staging tree lib/vsprintf: replace link to Draft by final RFC number doc: Kconfig: `to be' -> `be' doc: Kconfig: Typo: square -> squared doc: Konfig: Documentation/power/{pm => apm-acpi}.txt drivers/net: static should be at beginning of declaration drivers/media: static should be at beginning of declaration drivers/i2c: static should be at beginning of declaration XTENSA: static should be at beginning of declaration SH: static should be at beginning of declaration MIPS: static should be at beginning of declaration ARM: static should be at beginning of declaration rcu: treewide: Do not use rcu_read_lock_held when calling rcu_dereference_check Update my e-mail address PCIe ASPM: forcedly -> forcibly gma500: push through device driver tree ... Fix up trivial conflicts: - arch/arm/mach-ep93xx/dma-m2p.c (deleted) - drivers/gpio/gpio-ep93xx.c (renamed and context nearby) - drivers/net/r8169.c (just context changes)
2011-07-24ALSA: hda - Add support of the 4 internal speakers on certain HP laptopsVitaliy Kulikov
2011-07-24ALSA: Make snd_pcm_debug_name usable outside pcm_libEliot Blennerhassett
Formatting a PCM name is useful for module debug too. Add snd_prefix when making function public. [minor coding-style fixes by tiwai] Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-23ALSA: hda - Fix DAC filling for multi-connection pins in Realtek parserTakashi Iwai
Fix a regression in the DAC filling code in patch_realtek.c. The already filled DACs in multiout.dac_nids[] were ignored because of num_dacs=0, thus always pointed to the first DAC. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22Merge branch 'topic/hda' into for-linusTakashi Iwai
2011-07-22Merge branch 'topic/misc' into for-linusTakashi Iwai
2011-07-22ALSA: asihpi - Replace with snd_ctl_boolean_mono_info()Takashi Iwai
2011-07-22ALSA: asihpi - HPI version 4.08Eliot Blennerhassett
HPI Version is used to check for firmware compatibility. This version will accept 4.08.xx released firmware, and will also accept 4.09.xx beta firmware Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Add volume mute controlsEliot Blennerhassett
Mute functionality was recently added to the DSP firmware Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Control name updatesEliot Blennerhassett
Add names corresponding to new HPI node types. Shorten some names so that constructed names don't overflow the maximum name length. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Use size_t for sizeof resultEliot Blennerhassett
2011-07-22ALSA: asihpi - Explicitly include mutex.hEliot Blennerhassett
Because mutex is used in adapter struct defined here. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Add new node and message definesEliot Blennerhassett
2011-07-22ALSA: asihpi - Make local function staticEliot Blennerhassett
Fixes a sparse warning. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Fix minor typos and spellingEliot Blennerhassett
2011-07-22ALSA: asihpi - Remove unused structures, macros and functionsEliot Blennerhassett
2011-07-22ALSA: asihpi - Remove spurious adapter index checkEliot Blennerhassett
Subsystem requests don't have or need a valid adapter index. The adapter index is already checked further on, before it is used to index the adapters array. (Reverts 4a122c10f) Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Revise snd_pcm_debug_name, get rid of DEBUG_NAME macroEliot Blennerhassett
Work towards moving the function into alsa common header. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - DSP code loader API now independent of OSEliot Blennerhassett
The loader API has been revised so that OS specific data is kept local to hpidspcd.c, and the public API is unchanged across OSes. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Remove controlex structs and associated special data transfer ↵Eliot Blennerhassett
code Some cobranet control data would not fit in an original HPI message. Now that HPI is able to transfer larger messages, this special handling is no longer required. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Increase request and response buffer sizesEliot Blennerhassett
Allow for up to 256 bytes of extra data on top of standard hpi request and response sizes. Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-22ALSA: asihpi - Give more meaningful name to hpi request message typeEliot Blennerhassett
Having a 'request message' makes more sense than a 'message message' Signed-off-by: Eliot Blennerhassett <eblennerhassett@audioscience.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-21ALSA: hda - Remove a superfluous argument of via_auto_init_output()Takashi Iwai
"force" argument is always true, so let's strip it off. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-21ALSA: hda - Fix indep-HP path (de-)activation for VT1708* codecsTakashi Iwai
This patch fixes non-working indep-HP control on VT1708* codecs. The problems are that via_independent_hp_put() wasn't fixed to follow the recent change of three HP paths, and hp_indep_path didn't contain the amp nids of mixer elements. Together with the fixes, a few code clean-ups are done. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-18ALSA: hda - Switch HP DAC dynamically with indep-HP switch for VIATakashi Iwai
This patch changes the behavior of independent-HP enum switch. Now instead of returning a busy error, the driver switches dynamically the stream of the HP (and shared) DACs according to the current mode. The logic is similar like the dual-mic ADC switch, but a bit more complicated because of the presence of shared DAC. Together with the change, a mutex is introduced to protect against the possible races for the indep-HP mode setting. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-18ALSA: hda - Implement dynamic loopback control for VIA codecsTakashi Iwai
This patch adds the dynamic control of analog-loopback for VIA codecs. When the loopback is enabled, the inputs from line-ins and mics are mixed with the front DAC, and sent to the front outputs. The very same input is routed to the headhpones and speakers in loopback mode. However, since the loopback mix can't take other than the front DAC, there is no longer individual volume controls for headphones and speakers. Once when the loopback control is off, these volumes take effect. Since the individual volumes are more desired in general use caess, the loopback mode is set to off as default for now. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-18ALSA: virtuoso: fix silent analog output on Xonar Essence ST DeluxeClemens Ladisch
Commit dd203fa97bd5 (ALSA: virtuoso: remove non-working controls on Essence ST Deluxe) made it impossible to adjust the volume after the driver initialized it to muted. Ensure that those DACs that can be accessed with I2C are initialized to the same volume that is the reset default of the DAC without I2C. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Cc: 2.6.38+ <stable@kernel.org>
2011-07-15ALSA: intel8x0: Apply headphones+mute LED quirk for Dell Inspiron 9300Daniel T Chen
BugLink: https://bugs.launchpad.net/bugs/774895 The original reporter states that his volume keys do not change the desired Master and PCM mixer elements together, so apply the hp+mute led quirk for his PCI SSID. Reported-by: Jeffrey Finkelstein Signed-off-by: Daniel T Chen <crimsun@ubuntu.com> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-14ALSA: hda - Fix krealloc() replacement in hda_codec.cTakashi Iwai
It was obviously wrong, grr.... Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-14ALSA: hda - Re-add need_dac_fix check for multi-io jacks of Realtek codecsTakashi Iwai
During the rewrite, the check of spec->need_dac_fix and the corresponding num_dacs change was dropped from the channel-mode control. This patch re-adds it, and also enables need_dac_fix for ALC880 as default, as this feature was originally introduced to fix h/w bugs of this chip. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-12ALSA: hda - fix up typos in Kconfig help for default buffer size introduced ↵Paul Menzel
in acfa634f This commit is a fix up for commit acfa634f. commit acfa634f7e199193ec28282e82a5a6dd8edebcb7 Author: Takashi Iwai <tiwai@suse.de> Date: Tue Jul 12 17:27:46 2011 +0200 ALSA: hda - Add Kconfig for the default buffer size Signed-off-by: Paul Menzel <paulepanter@users.sourceforge.net> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-12ALSA: hda - Add Kconfig for the default buffer sizeTakashi Iwai
Add a Kconfig entry to specify the default buffer size. Distros using PulseAudio can choose a larger value here. Signed-off-by: Takashi Iwai <tiwai@suse.de>
2011-07-12ALSA: Use krealloc() in possible placesTakashi Iwai
2011-07-12ALSA: hda - Expose secret DAC-AA connection of some VIA codecsTakashi Iwai
VT1718S and co have a secret connection from DAC to AA-mix, which doesn't appear in the connection list obtained from the h/w. Currently the driver fixes the connection index locally at init, but now we can expose it statically via snd_hda_override_connections() so that this conection can be checked better by the parser in future. Signed-off-by: Takashi Iwai <tiwai@suse.de>
